[Unstable Update] 2022-06-29 - Kernels, Plasma 5.25.2, Firefox, Nvidia 515.57, Python, Haskell
Hello community,
Another unstable branch update with some usual updates for you.
Check out the new Ryzen Laptop by Starlabs: Starbook
  • Some of our Kernels got updated
  • Plasma 5.25.2 got released
  • Firefox is at 102.0
  • Nvidia drivers got updated to 515.57
  • Regular Haskell and Python updates
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
:information_source: You may need to rebuild any AUR packages that install files to site-packages …
Get our latest daily developer images now from Github: Plasma, GNOME, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
  • linux419 4.19.249
  • linux54 5.4.201
  • linux510 5.10.126
  • linux515 5.15.50
  • linux517 5.17.15 (EOL)
  • linux518 5.18.7
  • linux519 5.19-rc4
  • linux515-rt 5.15.49_rt47
  • linux518-rt 5.18.0_rt11
Package Changes (Wed Jun 29 02:35:52 CEST 2022)
A detailed list of all changes can be found here.
0 voters
Known issues
After the update, I found ark cannot open .zip with .z01 file:
Failed to open archive: Multi-disk zip
In Ark settings, disable libzip plugin. (399949 – [libzip] Can't extract from files with extension ".zip.NNN")
Thanks, solved. By the way, the latest version of libzip is 1.9.2, but unstable still uses 1.8.0
It’s what’s on arch. Anyway, 1.9.2 doesn’t fix it.
