Unstable might not be syncing to Arch correctly
Plasma 6.3.4 landed in Arch stable 16 hours ago. It is still not in Manjaro unstable.
It seems that either
  • Unstable is not syncing to Arch
  • The Arch mirror used by Manjaro is not syncing to Arch’s Tier 1 mirror.
Either way, there is an error in the system somewhere, and I hope it gets addressed.
I remember unstable branched synced quite often - but lately I have heard several times Philip saying
Stop chasing Arch
That likely means the sync is manually initiated when … ?
That is all I know :grimacing:
It is now. :wink:
FYI, syncing with Arch is done manually. There is no problem.
So how is the edge / unstable separation coming along?
@romangg talked about it last year but either I’ve missed news on that front or it’s indeed been quiet.
OK, I just got Plasma 6.3.4 installed. I wanted this update because it fixes the bug that caused notification text to be covered by the icon.
I was under the assumption that Manjaro unstable synced with Arch stable automatically.
I have been there too - but educating myself on build order taught me - it is not that simple.
→ DeveloperWiki:Toolchain maintenance - ArchWiki
At times it has to be manual - especially if important libraries has been updated - then packages need to be rebuilt in a strict order
→ Automate kernel rebuild on toolchain update (#4) · Issues · Release plan / Releases · GitLab
I still don’t understand the process fully - but I believe @Yochanan has a very clear understanding.
→ Improve Release Process and Branches (#3) · Issues · Release plan / Releases · GitLab
