Hello, hope that everyone is doing fine.
Lately, roughly after kernel 5.7, I have been investigating a patter that arises on proprietary drivers for Nvidia cards on Plasma, probably after the Plasma update itself, but don’t quote me on that.
Basically, after the system wakes up back from sleep :
if the system was locked , then it ends up resulting in a black screen with an active cursor;
if the system was unlocked (i.e. preventing to lock after resuming from sleep), then the system is relatively fine, but it ends up with minor graphical issues like broken transparency or other compositor issues. Upon locking the screen (super+L) a similar error occurs: all the interface is frozen but the mouse. However no black screen is present, almost like as the screen was locked, but the lockscreen did not display.
I am currently running Linux 5.8 with video-nvidia-450xx drivers. Switching to 440xx did not fix the issue, nor switching to Linux 5.7, or 5.6.
Note I can still access other sessions via ctrl+alt+f2, so the system isn’t frozen.
Did anyone end up noticing the same issue? Thanks anyone in advance for helping out.
Kernel: 5.8.3-2-MANJARO
DE: Plasma 5.19.4
CPU: Intel i5-9600K (6) @ 4.800GHz
GPU: NVIDIA GeForce GTX 1060 6GB
Fabby
8 September 2020 16:17
2
Welcome to Manjaro!
Nope, haven’t noticed anything.
However, does this also happen if you create a new user and log in there???
For the future, please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on.
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Fabby
20 September 2020 10:47
4
> System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=3e2010a7-c97f-4294-b887-2952e34fc467 rw quiet
> pci=nomsi,noaer loglevel=3 rd.systemd.show_status=auto rd.udev.log_priority=3 touch ~/.hushlogin
> Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
> Machine: Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId serial: <filter> Chassis: type: 10
> serial: <filter>
> Mobo: HP model: 81F5 v: 66.25 serial: <filter> UEFI [Legacy]: Insyde v: F.09 date: 05/19/2016
> Battery: ID-1: BAT1 charge: 33.9 Wh condition: 33.9/33.9 Wh (100%) volts: 16.9/14.8 model: 111-83-72 HS04041 type: Unknown
> serial: <filter> status: Full
> Memory: RAM: total: 3.31 GiB used: 1.19 GiB (35.8%)
> RAM Report: permissions: Unable to run dmidecode. Root privileges required.
> CPU: Topology: Quad Core model: AMD A6-7310 APU with AMD Radeon R4 Graphics bits: 64 type: MCP arch: Puma
> family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030105 L2 cache: 2048 KiB bogomips: 15974
> Speed: 2395 MHz min/max: 1000/2000 MHz boost: enabled Core speeds (MHz): 1: 2311 2: 2215 3: 2322 4: 2335
> Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext clflush cmov cmp_legacy constant_tsc cpb
> cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht hw_pstate ibs
> lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw
> overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
> ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale
> vme vmmcall wdt xsave xsaveopt
> Vulnerabilities: Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
> Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
> Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard driver: radeon
> v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:9851
> Device-2: Microdia HP Webcam type: USB driver: uvcvideo bus ID: 3-1.1:3 chip ID: 0c45:651b serial: <filter>
> Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: radeon FAILED: ati unloaded: modesetting
> alternate: fbdev,vesa display ID: :0 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
> Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
> OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.6-1-MANJARO LLVM 10.0.1) v: 4.5 Mesa 20.1.7 direct render: Yes
> Audio: Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel
> v: kernel bus ID: 00:01.1 chip ID: 1002:9840
> Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
> bus ID: 00:14.2 chip ID: 1022:780d
> Sound Server: ALSA v: k5.8.6-1-MANJARO
> Network: Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8723be v: kernel
> port: 3000 bus ID: 02:00.0 chip ID: 10ec:b723
> IF: wlo1 state: down mac: <filter>
> Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000
> bus ID: 03:00.0 chip ID: 10ec:8136
> IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
> IP v6: <filter> type: dynamic noprefixroute scope: global
> IP v6: <filter> type: noprefixroute scope: link
> WAN IP: <filter>
> Drives: Local Storage: total: 818.89 GiB used: 142.98 GiB (17.5%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/sda vendor: Samsung model: MZNTY256HDHP-000H1 size: 238.47 GiB block size: physical: 4096 B
> logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1H3Q scheme: MBR
> ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 114.66 GiB block size: physical: 512 B
> logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
> SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
> ID-3: /dev/sdc type: USB vendor: Toshiba model: MK5059GSXP size: 465.76 GiB block size: physical: 512 B
> logical: 512 B rotation: 5400 rpm serial: <filter> rev: GN00 scheme: MBR
> Optical-1: /dev/sr0 vendor: hp model: DVDRW GUD1N rev: MD00 dev-links: cdrom
> Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
> RAID: Message: No RAID data was found.
> Partition: ID-1: / raw size: 170.63 GiB size: 166.95 GiB (97.84%) used: 142.98 GiB (85.6%) fs: ext4 dev: /dev/sda2 label: N/A
> uuid: 3e2010a7-c97f-4294-b887-2952e34fc467
> Swap: Alert: No Swap data was found.
> Unmounted: ID-1: /dev/sda1 size: 3.45 GiB fs: swap label: N/A uuid: 06bfac29-2676-4e90-8ddf-68b1094e41d5
> ID-2: /dev/sda3 size: 100.0 MiB fs: ntfs label: System Reserved uuid: 7CF41693F416502E
> ID-3: /dev/sda4 size: 64.30 GiB fs: ntfs label: N/A uuid: 36C45642C4560511
> ID-4: /dev/sdb1 size: 114.66 GiB fs: vfat label: N/A uuid: 9C30-BDCA
> ID-5: /dev/sdc1 size: 465.76 GiB fs: ntfs label: LG External HDD uuid: E03CE9DB3CE9ACAA
> USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
> Hub: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0438:7900
> Device-1: 1-1.1:3 info: N/A type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
> chip ID: 3938:1031
> Device-2: 1-1.4:4 info: Realtek type: Bluetooth driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s
> chip ID: 0bda:b008 serial: <filter>
> Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
> Device-1: 2-1:2 info: SanDisk Cruzer Blade type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
> speed: 480 Mb/s chip ID: 0781:5567 serial: <filter>
> Device-2: 2-2:3 info: LG USA External HDD type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
> speed: 480 Mb/s chip ID: 043e:70f5 serial: <filter>
> Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
> Hub: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0438:7900
> Device-1: 3-1.1:3 info: Microdia HP Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
> Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
> Sensors: System Temperatures: cpu: 57.4 C mobo: 20.0 C gpu: radeon temp: 59 C
> Fan Speeds (RPM): N/A
> Info: Processes: 213 Uptime: 1m Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1544 pacman: 1538
> lib: 459 flatpak: 6 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Fabby
20 September 2020 21:20
6
You’re running on AMD and I’m an nVidia guy so I know that the AMD modules are built into the kernel, so try out (in that order)
linux54 (LTS = Long Time Support Kernel)
linux59
linux419
I!f you don’t know how to do that:
System Settings
Type kernel
Click Kernel
Add all of the above
reboot
try them one by one.
Hello everyone.
So yes, apparently there’s other posts that have similar issues.
This is one of them
https://forum.manjaro.org/t/gnome-chromium-chrome-windows-become-blank-after-suspend-when-using-nvidia-graphics/24641/5
I have experienced similar graphical bugs whenever I disable the lockscreen. Ultimately, it seems to end up in being a crash of the Compositor. Further research brought to possibly some loss of VRAM.
This is very similar to a post on the Arch forum:
https://bbs.archlinux.org/viewtopic.php?id=254218
Ultimately, with the Nouveau drivers, everything works fine… Unfortunately I’m in need of those Nvidia deivers.
Hi all, same situation here…
but I am not on nvidia nor amd.
Anyway, I’ve tried other kernels as well, but when it happens only sometimes I’ve decided to use only kernel54 LTS…
So now it just happened again, so I found CTRL+ALT+F7 to quit lock-screen (without possibility to enter my password) and enter to command line,
then by “startx” I started desktop environment (KDE) again, but surely I’ve started another instance of KDE where nothing what I previously left open was open. But I could see my browsers running in “task manager” and in htop command.
So I have no idea, how to return into this previous instance of KDE nor how to bring opened browsers into my actual instance. So I’ve just rebooted.
Somebody have some idea, pls, how to go back into my 1st instance of DE in such situation ?
Or better, what to do to prevent loosing LOGIN SCREEN after PC go to lock after period of time ?
It seems, that is not only graphic card related issue.
Thx a lot !
Here is my inxi:
System: Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=d37b62f9-df05-4ceb-a809-6c5041ae61c7 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Latitude E7440 v: 00 serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 07F3F4 v: A00 serial: <filter> UEFI: Dell v: A28 date: 06/13/2019
Battery: ID-1: BAT0 charge: 30.3 Wh condition: 30.3/47.1 Wh (64%) volts: 8.5/7.6 model: LGC-LGC6.2 DELL 0D47W44
type: Li-poly serial: <filter> status: Full
Memory: RAM: total: 7.68 GiB used: 2.71 GiB (35.2%)
CPU: Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 L2 cache: 4096 KiB bogomips: 21559
Speed: 2694 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2694 2: 2694 3: 2694 4: 2694
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Device-2: Sunplus Innovation Laptop Integrated Webcam HD type: USB driver: uvcvideo bus ID: 2-4:2
chip ID: 1bcf:2985
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1182x380mm (46.5x15.0") s-diag: 1242mm (48.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: DP1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.2.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.4.77-1-MANJARO
Network: Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: 3.2.6-k port: f080 bus ID: 00:19.0
chip ID: 8086:155a
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: f040 bus ID: 02:00.0 chip ID: 8086:08b1
Drives: Local Storage: total: 719.07 GiB used: 327.89 GiB (45.6%)
ID-1: /dev/mmcblk0 model: SU16G size: 14.84 GiB block size: physical: 512 B logical: 512 B serial: <filter>
scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdb vendor: Samsung model: SSD PM851 mSATA 256GB size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8D0Q scheme: GPT
Partition: ID-1: / raw size: 187.50 GiB size: 184.06 GiB (98.16%) used: 41.42 GiB (22.5%) fs: ext4 dev: /dev/sdb6 label: N/A
uuid: d37b62f9-df05-4ceb-a809-6c5041ae61c7
ID-2: /boot/efi raw size: 100.0 MiB size: 96.0 MiB (96.00%) used: 25.1 MiB (26.1%) fs: vfat dev: /dev/sdb2
label: N/A uuid: 568A-6088
ID-3: /run/timeshift/backup raw size: 411.59 GiB size: 404.13 GiB (98.19%) used: 286.45 GiB (70.9%) fs: ext4
dev: /dev/sda5 label: N/A uuid: 045da513-1be4-46c5-992a-d9070cc24798
Swap: Kernel: swappiness: 40 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 10.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: ID-1: /dev/mmcblk0p1 size: 14.83 GiB fs: vfat label: N/A uuid: 8765-4321
ID-2: /dev/sda1 size: 529.0 MiB fs: ntfs label: Recovery uuid: 5A8AB41B8AB3F19D
ID-3: /dev/sda2 size: 99.0 MiB fs: vfat label: N/A uuid: 6EB4-C3F1
ID-4: /dev/sda3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-5: /dev/sda4 size: 48.20 GiB fs: ntfs label: N/A uuid: EA7CCCC27CCC8B31
ID-6: /dev/sdb1 size: 529.0 MiB fs: ntfs label: Recovery uuid: 907C8A117C89F270
ID-7: /dev/sdb3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-8: /dev/sdb4 size: 50.34 GiB fs: ntfs label: N/A uuid: 32588B1F588AE149
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8000
Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:07dc
Device-2: 1-1.5:4 info: Broadcom BCM5880 Secure Applications Processor type: Smart Card driver: N/A interfaces: 2
rev: 1.1 speed: 12 Mb/s chip ID: 0a5c:5800 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 2-4:2 info: Sunplus Innovation Laptop Integrated Webcam HD type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 1bcf:2985
Device-2: 2-6:3 info: Logitech Cordless Mouse Receiver type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 1.5 Mb/s chip ID: 046d:c50e
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 78.0 C mobo: 52.0 C sodimm: 36.0 C
Fan Speeds (RPM): cpu: 5609
Info: Processes: 219 Uptime: 15m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1474 lib: 394 flatpak: 0
Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
Im having the same issues on the 5.9 kernel. I have yet to find a solution for “unable to resume from sleep.”
Kernel: 5.9.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=46f1bf50-2e62-41b0-8223-3f129d65eb12 rw quiet apparmor=1
Type: Laptop System: System76 product: Kudu Professional v: kudp1b
serial:
Mobo: System76 model: Kudu Professional v: kudp1b serial:
BIOS: American Megatrends v: 1.03.06RS762 date: 07/28/2014
ID-1: BAT0 charge: 52.7 Wh condition: 52.7/62.2 Wh (85%)
volts: 12.7/11.1 model: Notebook BAT type: Li-ion serial:
status: Full
RAM: total: 7.70 GiB used: 1.11 GiB (14.4%)
RAM Report:
Info: Quad Core model: Intel Core i7-4710MQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB bogomips: 39926
Speed: 1597 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1597
2: 1596 3: 1597 4: 1597 5: 1600 6: 1596 7: 1598 8: 1598
bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida invpcid
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt
xtopology xtpr
SMT vulnerable
Device-1: Intel 4th Gen Core Processor Integrated Graphics
vendor: CLEVO/KAPOK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0416
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo
bus ID: 2-8:4 chip ID: 5986:055c serial:
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 128
size: 380x210mm (15.0x8.3") diag: 434mm (17.1")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20
Sound Server: ALSA v: k5.9.10-1-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: f040
bus ID: 04:00.0 chip ID: 8086:08b3
IF: wlp4s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic mngtmpaddr scope: global
IP v6: scope: link
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: e000 bus ID: 05:00.2
chip ID: 10ec:8168
IF: enp5s0f2 state: down mac:
IP v4: type: noprefixroute scope: global broadcast:
IP v6: virtual: stable-privacy scope: link
WAN IP:
Local Storage: total: 465.76 GiB used: 138.09 GiB (29.6%)
ID-1: /dev/sda vendor: Crucial model: CT500BX100SSD1 size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: rev: MU01 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208FB rev: TC00
dev-links: cdrom
ID-1: / raw size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 138.09 GiB (30.2%) fs: ext4 dev: /dev/sda1 label: N/A
uuid: 46f1bf50-2e62-41b0-8223-3f129d65eb12
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 2-6:2 info: Elan Micro 2.4G Cordless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 04f3:02f4
Device-2: 2-7:3 info: Intel Bluetooth wireless interface
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:07dc
Device-3: 2-8:4 info: Acer BisonCam NB Pro type: Video
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 214 Uptime: 7m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1354 lib: 349 flatpak: 0 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.08
I am having the same issue, latest kernel, Intel graphics. In my case CTR+ALT+BCKSPCE only takes me to a completely black screen with only cursor, as opposed to just KDE lock screen. No further input does anything, other than brightness/sound able to be adjusted.
I read some really old threads, and found a small fix to get rid of just the black screen by changing the KDE Lock Screen theme in System Settings > Workspace Behavior > Screen Locking > Appearance > Wallpaper Type.
Update: After some further testing the specific problem appears to be that everything freezes after any kind of keyboard input after coming out of hibernation. The problem seems very similar to a closed bug report from about 5 years ago, that I cant link to because apparently “links are not allowed in posts” even if I use the hyperlink function.
Second Update: I found a thread in a separate forum which may have possible solutions and/or a possible explanation for why this is happening, but I sadly cant link it because FOR SOME REASON “links are not allowed in your post”. The title of the thread is “Manjaro: Can’t log in. Screen freezes after I enter my password”
Output Of inxi:
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=872371cd-8c9b-4d66-a62b-4051b0117390 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Apple product: MacBookPro14,1 v: 1.0 serial: <filter> Chassis: type: 9 v: Mac-B4831CEBD52A0C4C
serial: <filter>
Mobo: Apple model: Mac-B4831CEBD52A0C4C v: MacBookPro14,1 serial: <filter> UEFI: Apple v: 428.0.0.0.0
date: 06/16/2020
Battery: ID-1: BAT0 charge: 39.8 Wh condition: 45.1/54.6 Wh (83%) volts: 12.1/11.4 model: SMP bq20z451 type: Li-ion
serial: N/A status: Discharging cycles: 622
Memory: RAM: total: 7.64 GiB used: 1.33 GiB (17.4%)
CPU: Info: Dual Core model: Intel Core i5-7360U bits: 64 type: MT MCP arch: Amber Lake family: 6 model-id: 8E (142)
stepping: 9 microcode: DE L2 cache: 4096 KiB bogomips: 18406
Speed: 600 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 600 2: 600 3: 600 4: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel Iris Plus Graphics 640 vendor: Apple driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5926
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7") s-diag: 798mm (31.4")
Monitor-1: eDP1 res: 2560x1600 hz: 60 dpi: 224 size: 290x180mm (11.4x7.1") diag: 341mm (13.4")
OpenGL: renderer: Mesa Intel Iris Plus Graphics 640 (Kaby Lake GT3e) (KBL GT3) v: 4.6 Mesa 20.2.3
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Device-2: Broadcom and subsidiaries 720p FaceTime HD Camera driver: bdc-pci alternate: bdc_pci bus ID: 03:00.0
chip ID: 14e4:1570
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Broadcom and subsidiaries BCM4350 802.11ac Wireless Network Adapter vendor: Apple driver: brcmfmac
v: kernel port: 3040 bus ID: 02:00.0 chip ID: 14e4:43a3
Drives: Local Storage: total: 113.00 GiB used: 14.05 GiB (12.4%)
ID-1: /dev/nvme0n1 vendor: Apple model: SSD AP0128J size: 113.00 GiB block size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 16.14.01 scheme: GPT
ID-2: /dev/nvme0n2 vendor: Apple model: SSD AP0128J size: 8 KiB block size: physical: 4096 B logical: 4096 B
Partition: ID-1: / raw size: 71.71 GiB size: 70.09 GiB (97.73%) used: 13.96 GiB (19.9%) fs: ext4 dev: /dev/nvme0n1p3
label: N/A uuid: 872371cd-8c9b-4d66-a62b-4051b0117390
ID-2: /boot/efi raw size: 300.0 MiB size: 299.3 MiB (99.76%) used: 87.5 MiB (29.2%) fs: vfat dev: /dev/nvme0n1p1
label: EFI uuid: 5F66-17ED
Unmounted: ID-1: /dev/nvme0n1p2 size: 40.99 GiB fs: ntfs label: BOOTCAMP uuid: 34F5EE1202469FF7
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A
Info: Processes: 169 Uptime: 10m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1245 lib: 362 flatpak: 0
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
