So when I was updating system with yay -Syu I got many errors like that
error: archlinux-keyring: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/archlinux-keyring-20231222-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
Whether I refuse or agree I get this error:
error: failed to commit transaction (invalid or corrupted package (PGP signature))
-> error installing repo packages
So I searched it in google and found point about that in pacman troubleshouting
I was doing everything like in instruction, but on this part:
Install the downloaded packages Assuming the files is the current folder and using wildcard so you don't have to deal with dates and versions - remove the packages after successful installation
user $ sudo pacman -U manjaro-keyring*.pkg.tar.xz archlinux-keyring*.pkg.tar.zst
I got following errors:
error: could not open file manjaro-keyring-20240103any.pkg.tar.xz: Unrecognized archive format
error: 'manjaro-keyring-20240103any.pkg.tar.xz': cannot open package file
error: could not open file archlinux-keyring-20240103any.pkg.tar.zst: Unrecognized archive format
error: 'archlinux-keyring-20240103any.pkg.tar.zst': cannot open package fil
If you need any more information ask, I’m quite newbie to Linux and I don’t know if I put sufficient info here.
I guess I just couldnt imagine those formats not being recognized.
For example … the hundreds of packages installed here all end in .pkg.tar.zst, and of course pacman does not complain about them.
local/lib32-xz 5.4.5-1
Library and command line tools for XZ and LZMA compressed files (32-bit)
local/lib32-zstd 1.5.5-1
Zstandard - Fast real-time compression algorithm (32-bit)
local/python-zstandard 0.22.0-1
Python bindings to the Zstandard (zstd) compression library
local/xz 5.4.5-1
local/zstd 1.5.5-1
The latest manjaro and archlinux keyrings are 20230719-2 and 20231222-1, respectively. It is not clear to me exactly what keyring files you managed to download.
Okey, thanks. Looks like I didn’t understand Replace YYYYMMDD-R as available from the mirror. part of pacman troubleshouting. I thought that it refers to date of last modification of directory. Anyway now, when I downloaded right files, it worked.
Kubaryt tried to download a nonexistent file. The content of the resulting “keyring” file was likely just a “404 Not Found” error message. pacman cannot interpret that as a valid package regardless of whether the filename contains a proper dash or not.
