Hi,
from a couple of week, I’m having issues with the palemoon
browser: when I play videos on Youtube, the CPU usage increase and the browser became extremely slow, crashing in the end.
I tried to reset the settings to default in safe mode, but the problem persists.
I tried with brave
browser, and it works perfectly
My hardware:
[salome@salome ~]$ inxi -Fxzmi
Kernel: 4.4.268-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: G41M-VS3. serial: <filter>
BIOS: American Megatrends v: P1.60 date: 09/09/2011
RAM: total: 3.86 GiB used: 1.25 GiB (32.4%)
RAM Report:
Info: Quad Core model: Intel Core2 Quad Q9650 bits: 64 type: MCP
arch: Penryn rev: A cache: L2: 6 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 23946
Speed: 2992 MHz min/max: N/A Core speeds (MHz): 1: 2992 2: 2992 3: 2992
4: 2992
Device-1: NVIDIA GT218 [GeForce 210] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 04:00.0
Display: x11 server: X.org 1.20.11 driver: loaded: nouveau
OpenGL: renderer: NVA8 v: 3.3 Mesa 21.0.3 direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Sound Server-1: ALSA v: k4.4.268-1-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Device-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: ASRock
driver: atl1c v: 1.0.1.1-NAPI port: dc00 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 6.37 TiB used: 82.84 GiB (1.3%)
ID-1: /dev/sda vendor: Western Digital model: WD60EFRX-68L0BN1
ID-2: /dev/sdb vendor: Western Digital model: WD10EZRX-00A8LB0
ID-1: / size: 98.88 GiB used: 82.8 GiB (83.7%) fs: ext4 dev: /dev/sdb3
ID-2: /boot size: 495.8 MiB used: 46.7 MiB (9.4%) fs: ext4 dev: /dev/sdb1
ID-1: swap-1 type: partition size: 5.03 GiB used: 0 KiB (0.0%)
dev: /dev/sdb2
System Temperatures: cpu: 32.5 C mobo: 29.0 C gpu: nouveau temp: 37.0 C
Fan Speeds (RPM): cpu: 1985 fan-1: 763 fan-3: 0 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.30
Processes: 194 Uptime: 5h 53m Init: systemd Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1223 Shell: Bash v: 5.1.4 inxi: 3.3.04
