" Edit the file /etc/default/grub as root and append amdgpu.ppfeaturemask=0xffffffff to GRUB_CMDLINE_LINUX_DEFAULT"
I edited the file and added the parameters but when regenerating grub, things don’t seem to compute
sudo grub-mkconfig -o /boot/grub/grub.cfg
or
sudo update-grub
Doesn’t seem to work
sudo update-grub
/etc/default/grub: line 1: #: command not found
Can anyone see what I’m doing wrong?
/etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
Does this mean you manually downloaded the source?
Is there a reason to do this rather than just installing the package from the repos?
On to the meat of the issue…
Both grub-mkconfig and update-grub have regular shell shebangs ( #! /bin/sh ) meaning it will use whatever is the system default shell… do you happen to have a weird one at play?
And, assuming its still installed, what happens if you run it explicitly with bash with something like:
I doubt. Repo package don’t configure grub config.
I wouldn’t recommend that flag if you don’t know what to do. It enables control over voltage - if you make mistake you can easily break your GPU. But if you want it anyway use this command to discover correct value (via Arch Wiki)
Hi, sorry I wasn’t clear about what I was doing. Yes I did install from repos. But to unlock overclocking I need to add the boot parameter “amdgpu.ppfeaturemask=0xffffffff” to my bootloader configuration (grub).
I managed to add the parameter and save but unable to update it to the grub.cfg
sudo bash update-grub
Instructions I’m trying to follow:
Full AMD GPU controls
Currently, to have full control of your AMD GPU while using the amdgpu driver, you need to append the boot parameter amdgpu.ppfeaturemask=0xffffffff to your bootloader configuration and reboot.
NOTE: The following instructions are for guidance only. Check your distribution documentation on how to add boot parameters.
GRUB bootloader
Edit the file /etc/default/grub as root and append amdgpu.ppfeaturemask=0xffffffff to GRUB_CMDLINE_LINUX_DEFAULT:
GRUB_CMDLINE_LINUX_DEFAULT="... amdgpu.ppfeaturemask=0xffffffff"
NOTE: In the above example, ... represent other existing parameters. Do not add ... to your GRUB_CMDLINE_LINUX_DEFAULT. You should only add amdgpu.ppfeaturemask=0xffffffff.
Then regenerate the bootloader configuration file with the command:
Reboot your system.
You should have more controls when you select Advanced as Performance mode.
Ok, but this is the first time ever seeing an error like this.
Cannot even find an example in the search engines.
I still wonder … what shell is being used?
Something like;
echo $0
echo $SHELL
/usr/bin/ps -p $$
That first line could be removed… its supposed to be a comment anyways.
But if all # are somehow being interpreted as an unknown command … who knows what else is wrong.
I wonder If I managed to corrupt the file opening it in office my first attempt. I am very new to all this. could I replace the file somehow and start again?
Any plain text editor should do. You have not set your desktop environment in your profile, so I cannot be more specific, but in Plasma, kwrite or kate would be suitable editors, and in GNOME, gnome-text-editor — I don’t know what the other environments come installed with.
Alternatively, you could also use nano, which is a terminal-based editor. It should normally come installed by default in all three of the official Manjaro editions.
Important note: Do also bear in mind that you should never use a Windows application for editing a UNIX text file, because Windows uses both a carriage return and a newline character as the end-of-line denominator, while UNIX only uses a newline character.
The presence of the carriage return character in a UNIX configuration file or script will lead to malfunctions.
