orbag
5 October 2020 20:38
1
Hi everyone,
After updating my system to Manjaro Mikah, I experience the following problem:
When using any terminal (have tried with gnome-terminal and urxvt) and SIGINT is sent (Ctrl + C) I get the following error message in my terminal (this one for gnome-terminal):
output: unknown terminal “xterm-256color”
and the “xterm-256color” holds whatever is written to $TERM, for urxvt it is “rxvt-unicode-256color” .
When searching this error message online I only find threads concerning terminal issues when ssh’ing, and they advise to change $TERM, but in my case I’m on my local system, and changing $TERM to another value, eg “export TERM=linux” will just change the error to 'output: unknown terminal “linux” ’
Does anyone know what’s going on here?
On a potential sidenote: after rebooting from update I also experienced the problem that my GUI failed to start up due to some nvidea drivers issues which I could solve , so perhaps this could be linked (however I don’t see the connection between my terminal and the nvidia drivers)
Fabby
7 October 2020 10:28
2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Do you also get the output: unknown terminal “xterm-256color”
error when you create a new user and log in there?
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
orbag
8 October 2020 20:02
3
Here is my output to inxi:
~ inxi --admin --verbosity=7 --filter --no-host --width
tput: unknown terminal "xterm-256color"
Argument "" isn't numeric in numeric eq (==) at /usr/bin/inxi line 387.
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=7b9a0c0f-3b65-4a3b-ac35-c89c93c4caa5 rw quiet apparmor=1
security=apparmor resume=UUID=44c3553f-5fb8-4c9c-9cea-080d71984e7d
udev.log_priority=3
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X712FBC_S712FB
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X712FBC v: 1.0 serial: <filter>
UEFI: American Megatrends v: X712FBC.302 date: 10/18/2019
ID-1: BAT0 charge: 40.3 Wh condition: 42.3/47.0 Wh (90%) volts: 11.8/11.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 80
RAM: total: 15.49 GiB used: 1.35 GiB (8.7%)
Topology: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
L2 cache: 8192 KiB bogomips: 36812
Speed: 900 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: NVIDIA GM108M [GeForce MX110] vendor: ASUSTeK driver: nouveau
v: kernel alternate: nvidia_drm,nvidia bus ID: 02:00.0 chip ID: 10de:174e
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 13d3:56dd serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: compton driver: modesetting
unloaded: intel,nouveau alternate: fbdev,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 3000
bus ID: 03:00.0 chip ID: 10ec:c822
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 1.38 TiB used: 65.15 GiB (4.6%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 002C scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-80Z10T2
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A04 scheme: GPT
ID-1: / raw size: 500.00 GiB size: 491.15 GiB (98.23%)
used: 65.15 GiB (13.3%) fs: ext4 dev: /dev/sda3 label: N/A
uuid: 7b9a0c0f-3b65-4a3b-ac35-c89c93c4caa5
ID-2: /boot/efi raw size: 513.0 MiB size: 512.0 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: F38D-4A2F
ID-1: swap-1 type: partition size: 24.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 label: N/A uuid: 44c3553f-5fb8-4c9c-9cea-080d71984e7d
ID-1: /dev/nvme0n1p1 size: 260.0 MiB fs: vfat label: SYSTEM uuid: 64DC-4CBB
ID-2: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 size: 476.03 GiB fs: ntfs label: OS
uuid: A676DE2176DDF253
ID-4: /dev/nvme0n1p4 size: 650.0 MiB fs: ntfs label: RECOVERY
uuid: 3C7207B672077444
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-6:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56dd
serial: <filter>
Device-2: 1-10:3 info: Lite-On Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s chip ID: 04ca:4005 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 286 Uptime: 4h 13m Init: systemd v: 246 Compilers: gcc: 10.2.0
alt: 8/9 Packages: 1294 pacman: 1291 lib: 311 snap: 3 Shell: fish v: 3.1.2
running in: gnome-terminal inxi: 3.1.05
I tried creating a new user and logging in to there, and here I don’t get this problem, so the problem must be somewhere in my configurations, but where…
EDIT: I also found out that when I type reset, I get this output:
~ reset
reset: can't initialize terminal type xterm-256color (error -1)
Terminal type?
orbag
8 October 2020 20:12
5
I found the issue: the difference between my new user and me was that the new user uses bash, while I commonly use fish.
I then found out I dont have to problem with bash, only with fish.
After shotgun debugging my config.fish file I found that this line caused the failure:
set -gx PATH /opt/anaconda/bin $PATH
So something in my /opt/anaconda/bin file must be causing this strange behaviour.
I don’t know why, I removed this line out of my config and I’m happy that I got rid of the error
Fabby
8 October 2020 20:14
6
That is good under DOS and Windows but wrong under Linux…
It should read:
set -gx PATH /opt/anaconda/bin:$PATH
(a colon, not a space)
orbag
8 October 2020 20:19
7
I think it’s just specific fish syntax because according to their documentation you have to do it like that. For some reason I can’t share links otherwise I would share the link to the documentation page of fish where they explain it.
Thanks for helping me!
system
Closed
23 October 2020 20:19
8
