Unknown filesystem type ‘ntfs3’
Since latest stable update VeraCrypt complains:
unknown filesystem type ‘ntfs3’
Non‑VeraCrypt disks are not affected. VeraCrypt volumes with other filesystems work fine as well.
I am still running ntfs-3g. After the automatic switch to ntfs3 in 2023, I had some issues on two disks, so I blacklisted ntfs3.
ntfs-3g has worked flawlessly for many years on a daily basis. I am aware of the “dirty flag” thing with ntfs-3g.
Because VeraCrypt and ntfs‑3g are not updated, what is causing the “unknown filesystem type ‘ntfs3’” error ?
$ mount.ntfs --version
ntfs-3g 2022.10.3 external FUSE 29
$ ls /sbin/mount.ntfs* -l
/sbin/mount.ntfs -> /usr/bin/ntfs-3g
/sbin/mount.ntfs-3g -> /usr/bin/ntfs-3g
In one case I managed to mount VeraCrypt with ntfs-3g.
$ veracrypt --filesystem=none ...
$ sudo mount -t ntfs-3g /dev/loop0 ...
$ udisksctl mount -b /dev/sda
When mounting an NTFS volume it shows up as type fuseblk.
$ udisksctl mount -t ntfs-3g -b /dev/sda
Throws :
Error mounting /dev/sda: GDBus.Error:org.freedesktop.UDisks2.Error.OptionNotPermitted: Requested filesystem type ntfs-3g is neither well-known nor
in /proc/filesystems nor in /etc/filesystems
$ cat /proc/filesystems
Does not show any ntfs*.
ntfs‑3g does work, but in some cases it is no longer detected since the latest update.
I am using kernel 6.12.
I am aware that using ntfs is something one should avoid, but in my case it’s something i really depend on for compatibility reasons.
Thank you for any hints
Try referencing the filesystem type (ntfs) rather than the driver name; example:
sudo mount -t ntfs /dev/sdXY
And remember, we typically mount a partition (/dev/sdXY) with a filesystem, rather than the disk (/dev/sdX) itself.
ah. ok. its “ntfs” not “ntfs-3g”
udisksctl mount -t ntfs -b /dev/sda1
veracrypt --filesystem=ntfs /dev/sda1 /media/veracrypt1
thank you very much !!!
any idea what is causing the unknown filesystem type 'ntfs3'
without --filesystem=ntfs ?
ntfs3 is not a filesystem type, so naturally it will be “unknown” – I imagine you still have it incorrectly use elsewhere; check your /etc/fstab, for example; you might also try again after a reboot.
I have also moved your posts to a dedicated topic as your issue seemingly has nothing to do with the Update.
No, sorry – that was a misunderstanding.
ntfs3 has been black‑listed for years, so my system uses only ntfs-3g.
ntfs filesystems were automatically detected when mounting via udisksctl and VeraCrypt.
After the latest stable update, VeraCrypt no longer recognizes ntfs-3g !
It complains about an unknown filesystem type 'ntfs3'.
I have to point it manually.
So something changed in the last update.
There is nothing about ntfs, ntfs3, ntfs-3g in my fstab.
