Unknown display wayland gnome 40
no,what is tty .pls explain
I recommend reading this:
And this will explain a bit the usage of TTY
This is the long version of The TTY demystified
It will be helpful on the long run.
how can i solve this error.what is the command of it
$ sudo pacman -Syu xorg-xdpyinfo
It’s missing command. Just install xorg-xdpyinfo package.
what is the command of it.pls help.because i’m new.
Here is the explain: XDPYINFO
you can also install it in pamac just click the search button and search for xorg-xdpyinfo then install it.
thanks
thank you very much
helpful
