Hello and thanks in advance!
My original issue is that my sound has a loud ‘pop’ or ‘click’ when trying to play audio after having been idle for a few minutes. Likely a power saving issue.
I’ve tried looking at various posts to solve the issue, but it seems I am even a step further behind than I realized - my primary audio device is not detecting properly. My line-out mini-jack audio is simply listed as “built-in analog stereo” in the sound settings, and in the Manjaro settings hardware its listed as “unknown device name (intel)”
It feels like the issue is somewhere in my “hybrid” config - but I have already gotten myself into trouble messing with these drivers so figured I’d turn to the forum for help
(I have an nvidia rtx 3060 graphics card which I also use the HDMI out for video+audio to go my connected TV)
So when I try to unload the module per this answer it doesn’t recognize it. And there is this very short Arch page, but without my device identified and the… vagueness of gives me pause.
My inxi
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=32193760-3d01-42b7-bae3-e2efd77f0538 rw quiet splash
resume=UUID=41831ccf-ea2b-4978-b1eb-d518eb84e7be udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Dell product: XPS 8940 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0K3CM7 v: A00 serial: <superuser required> part-nu: 09C5
uuid: <superuser required> UEFI: Dell v: 2.0.13 date: 04/01/2021
Info: model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x62
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 79888
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Dell
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 02:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting failed: nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 80 s-size: 609x343mm (23.98x13.50")
s-diag: 699mm (27.52") monitors: <missing: xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: xcb,xlib
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 02:00.1 chip-ID: 10de:228e
class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek Killer E2600 GbE vendor: Rivet Networks driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.43 TiB used: 14.32 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC711 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 41002131 temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75WN4A1
tech: HDD rpm: 7200 serial: <filter> fw-rev: 7113 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer size: 58.45 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 46.8 GiB size: 45.76 GiB (97.79%) used: 13.7 GiB (29.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 410.32 GiB size: 402.81 GiB (98.17%)
used: 629.3 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 46.0 C pch: 47.0 C mobo: 44.0 C gpu: nvidia
temp: 57 C
Fan Speeds (rpm): cpu: 997 fan-1: 809 gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.29 GiB used: 4.06 GiB (26.5%)
Processes: 361 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1177 pm: pacman pkgs: 1163 libs: 318 tools: pamac pm: flatpak
pkgs: 14 Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
cat /proc/asound/modules
0 snd_hda_intel
1 snd_hda_intel
Moderator edit: Removed screenshot of Manjaro Hardware Settings > Hardware Configuration. Please post the output of mhwd -l && mhwd -li instead. See Manjaro Hardware Detection Overview - Manjaro
