Thank you for your quick reply.
So here is what the command inxi -Frazy shows me :
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=41e744a3-86f6-4388-9ead-649a3cc97b17 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: B150M-A D3 v: Rev X.0x
UEFI: American Megatrends v: 2201 date: 03/13/2017
Info: model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 31211
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 54 s-size: 903x508mm (35.55x20.00")
s-diag: 1036mm (40.79")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
memory: 2.93 GiB
API: Vulkan v: 1.3.276 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 550.54.14 device-ID: 10de:1c02
surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Local Storage: total: 698.65 GiB used: 98.77 GiB (14.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD501LJ size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: 0-10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Maxtor model: STM3250310AS
size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: A scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 98.77 GiB (43.3%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 26 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 49%
Packages: 1498 pm: pacman pkgs: 1484 libs: 475 tools: pamac pm: flatpak
pkgs: 14
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://manjaro.ynh.ovh/stable/$repo/$arch
3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.funami.tech/manjaro/stable/$repo/$arch
8: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
Memory: total: 8 GiB available: 7.68 GiB used: 4.3 GiB (56.0%)
Processes: 220 Power: uptime: 1d 5h 56m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
moderator note: fixed formatting
And command mhwd -li -l :
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
0000:01:00.0 (0300:10de:1c02) Display controller nVidia Corporation:
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
And finally this command pacman -Qs unity :
local/lib32-libappindicator-gtk2 12.10.0.r298-1 Allow applications to extend a menu via Ayatana indicators in Unity, KDE or Systray (32-bit) (GTK+ 2 library)
Thanks
