i can’t find steam in my manjaro or cannot uninstall it as well
i have just 128GB SSD and .steam/share is using 30GB almost i cant even update my other apps
i search in my laptop there are two games CS (counter strike) and TM launcher for mincraft
i don’t play those game because i can’t due to graphic card or i am not interested such game
i have xbox for that i use my laptop just for smooth working
[zeeshan@pits ~]$ pacman -Ss steam
community/game-devices-udev 0.18-1
Udev rules for controllers
community/gamescope 3.11.47-1
SteamOS session compositing window manager
community/sl 5.05-3
Steam Locomotive runs across your terminal when you type "sl" as you meant to type "ls"
community/steamos-compositor-plus 1.9.0-1
Compositor used by SteamOS 2.x with some added tweaks and fixes
multilib/linux-steam-integration 0.7.3-10
Helper for enabling better Steam integration on Linux
multilib/steam 1.0.0.75-2
Valve's digital software delivery system
multilib/steam-native-runtime 1.0.0.70-4
Native replacement for the Steam runtime using system libraries
i think package is broken maybe
please guide me i will be thankful to you
As far as I know, the game data in your /home folder will not be removed when you uninstall steam, so you need to delete it yourself. It should mostly be found in your users ./local folder.
check if you have steam installed: pacman -Qs steam
if you want to make some space, remove cache: sudo pacman -Scc
clear your journal: sudo journalctl --rotate sudo journalctl -m --vacuum-time=1s
The first answer there, marked with a green check mark, is the info that I mean.
two (or three?) versions of “core”
two times cornyjokes
two times discord
two times disk-space-saver
two times skype
four versions of gnome
two times whatsapp
perhaps some maintenance can reduce the space that is occupied?
I have never used snaps until now - and don’t intend to do so if I can avoid it.
