Hey guys,
I’ve been trying to uninstall mysql but I keep getting this error.
“error:target not found :mysl”
Any help please
It is spelled wrong
Please give the exact command you tried and the output you got.
Thank you but it was my fault. I wrote it wrong by mistake here.
I tried: pacman - Rns mysql
And I keep getting this:
Error: target not found:mysql
So it is already uninstalled
This is (still) wrong syntax.
Also, check if you mean mysql++
Would require
sudo pacman -Rsn mysql++
Hmm, if you got
You must have tried
$ pacman -Rns mysql
That packge doesn’t seem to be installed on your system.
Well no it’s not
Same error again
What makes you think, you have the mysql
package installed?
The error message you got tells you it’s not …
Most likely you mean mariadb and not mysql.
Please post output of:
pacman -Qo mysqld
If for some reason @moson’s post doesn’t point you in the right direction (sounds like it should)…
How did you install it? If it wasn’t with Pamac (Add/Remove Software) or Pacman, then they don’t know about it.
I get this:
/usr/bin/mysqld is owned by mariadb 10.5.9-1
Because when I type mysql - - version
I get:
Mysql Ver 15.1 Distrib 10.5.9-MariaDB, for linux (x86_64) using readline 5.1
Well, now you know what package to uninstall then.
So there you have the mariadb
package.
$ pacman -Qo $(which mysql)
/usr/bin/mysql is owned by mariadb-clients 10.5.10-1
And the mysql
on your system probably is provided by mariadb-clients
package as well.
