DomyIT
10 October 2023 16:51
1
Hi everyone, I installed Eclipse by downloading it from the official website.
Command:
tar -xzf eclipse-inst-jre-linux64.tar.gz
And then I started the “eclipse-inst” executable file.
Now I would like to uninstall it, I am left with the icon in the applications menu, and the “eclipse” folder in “/home/user/”.
How can I solve it?
Zesko
10 October 2023 17:46
2
Did you run it without root permission?
I guess eclipse-inst
is the shell script.
You can track where Eclipse files are stored if you can read and understand what is written in this shell script.
Eclipse desktop file may be located in $HOME/.local/share/applications/
Search where is eclipse in your home folder
$ find $HOME/ -name "*eclipse*"
DomyIT
10 October 2023 18:11
3
I removed the “/home/user/eclipse” and “home/user/.config/eclipse” folders.
Thanks!
Solved!
system
Closed
14 October 2023 10:20
5
