Unified Remote is in the Startup Application with a green switch in Cinnamon DE, yet it won’t auto start upon login. I have to manually start it every session.
If you click the run now in auto start does it run?
Yes it does.
Check in .conf/autostart that it is there and check it says what you want. Be aware you can not put a script in here. scripts have to be seperate perhaps in $HOME and called from there. I am pretty sure
you can’t use sudo and this too has to be put in a script but needs to be in the system perhaps /usr/bin .
