Hi,
Using Add/Remove Software.
Is it normal for unifi from AUR to take such long time to build?
Currently about 45 minutes “Building mongodb…”.
Thanks.
pinxi -Fxz
Machine: Type: Laptop System: MEDION product: P6645 MD61379 v: 5.13_VEB_1AUOK026 serial: <filter>
Mobo: MEDION model: M15WKN v: 0.2 serial: <filter> UEFI: American Megatrends v: 206 date: 10/30/2018
Battery: ID-1: BAT0 charge: 40.7 Wh condition: 40.7/41.6 Wh (98%) model: M153137 status: Full
CPU: Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake rev: B L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 1800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1800 2: 1800 3: 1800 4: 1800 5: 1800 6: 1800 7: 1800
8: 1800
Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX150] driver: N/A bus ID: 02:00.0
Display: server: X.Org 1.20.9 driver: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Pegatron driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Sound Server: ALSA v: k5.8.11-1-MANJARO
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
Drives: Local Storage: total: 357.72 GiB used: 154.16 GiB (43.1%)
ID-1: /dev/nvme0n1 model: E12-256G-PHISON-SSD-B3-BB1 size: 238.47 GiB
ID-2: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 119.24 GiB
Partition: ID-1: / size: 229.50 GiB used: 85.15 GiB (37.1%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: file size: 8.00 GiB used: 1.10 GiB (13.8%) file: /swapfile
Sensors: System Temperatures: cpu: 62.0 C mobo: N/A
Info: Processes: 268 Uptime: 5h 24m Memory: 7.67 GiB used: 4.00 GiB (52.1%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1399 Shell: Bash v: 5.0.18 pinxi: 3.1.04-1```
