Recently I’ve been getting a problem where the fans spin up to full speed and then the laptop just switches off. Looking in the journal I see crashes related to kernel split-locks. I have no idea what this means but assume it could be related to a kernel update. Has anyone else seen this problem?
inxi:
Kernel: 6.12.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=64dbb951-063f-43f5-bb22-3358237997b5 rw quiet splash apparmor=1
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: PC Specialist product: NH5x_NH7x_HHx_HJx_HKx v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: CLEVO model: NHxxHJHK serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: INSYDE v: 1.07.03TPCS1
date: 05/13/2021
ID-1: BAT0 charge: 42.9 Wh (100%) condition: 42.9/47.2 Wh (90.9%)
volts: 16.7 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
charging: status: full cycles: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x56
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB
desc: 8x1.2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 73744
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: CLEVO/KAPOK
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: speed: Unknown lanes: 63
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:25a2
class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 5986:9102
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x065b built: 2019 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.3.2-arch1.1
note: incomplete (EGL sourced) renderer: Mesa Intel UHD Graphics (TGL GT1),
llvmpipe (LLVM 21.1.6 256 bits)
API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT1) driver: mesa intel v: 25.3.2-arch1.1
device-ID: 8086:9a60 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.12.63-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-4: PulseAudio v: 17.0-98-gb096 status: active with:
tools: pacat,pactl
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Info: services: NetworkManager, smbd, sshd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 2.75 TiB used: 400.14 GiB (14.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 102.12 GiB (53.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 298.02 GiB (62.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 39.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 34.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.13 GiB used: 4.12 GiB (13.2%)
Processes: 409 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Packages: 2315 pm: pacman pkgs: 2229 libs: 582 tools: gnome-software,pamac
pm: flatpak pkgs: 49 pm: snap pkgs: 37 Compilers: clang: 21.1.6 gcc: 15.2.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.40
last reboot:
reboot system boot 6.12.63-1-MANJA* Mon Jan 5 12:35 still running
reboot system boot 6.12.63-1-MANJA* Mon Jan 5 11:12 - 11:14 (00:01)
reboot system boot 6.12.63-1-MANJA* Mon Jan 5 10:45 - 11:12 (00:26)
reboot system boot 6.12.63-1-MANJA* Mon Jan 5 09:19 - 09:21 (00:01)
reboot system boot 6.12.63-1-MANJA* Sun Jan 4 11:14 - crash (22:05)
reboot system boot 6.12.63-1-MANJA* Sun Jan 4 11:10 - crash (00:03)
reboot system boot 6.12.63-1-MANJA* Sun Jan 4 11:05 - crash (00:04)
reboot system boot 6.12.63-1-MANJA* Sat Jan 3 20:09 - crash (14:56)
reboot system boot 6.12.62-1-MANJA* Sat Jan 3 19:46 - 20:08 (00:22)
reboot system boot 6.12.62-1-MANJA* Sat Jan 3 19:34 - crash (00:12)
reboot system boot 6.12.62-1-MANJA* Sun Dec 21 15:20 - crash (13+04:13)
reboot system boot 6.12.62-1-MANJA* Sun Dec 21 15:17 - crash (00:03)
reboot system boot 6.12.62-1-MANJA* Sat Dec 20 10:58 - crash (1+04:18)
reboot system boot 6.12.62-1-MANJA* Fri Dec 19 17:33 - crash (17:24)
reboot system boot 6.12.62-1-MANJA* Fri Dec 19 17:31 - crash (00:02)
reboot system boot 6.12.62-1-MANJA* Fri Dec 19 17:29 - 17:30 (00:00)
reboot system boot 6.12.62-1-MANJA* Fri Dec 19 17:26 - crash (00:02)
reboot system boot 6.12.62-1-MANJA* Thu Dec 18 15:41 - crash (1+01:45)
reboot system boot 6.12.48-1-MANJA* Thu Dec 18 15:17 - crash (00:23)
reboot system boot 6.12.48-1-MANJA* Tue Dec 16 11:45 - crash (2+03:31)
reboot system boot 6.12.48-1-MANJA* Sun Nov 16 07:45 - 11:45 (30+03:59)
reboot system boot 6.12.48-1-MANJA* Sun Nov 16 06:53 - 07:45 (00:51)
reboot system boot 6.12.48-1-MANJA* Sat Nov 1 14:34 - 06:53 (14+16:18)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 11:00 - 11:24 (00:23)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:57 - crash (00:03)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:46 - crash (00:10)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:37 - 10:45 (00:08)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:29 - crash (00:07)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:22 - 10:29 (00:06)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 10:04 - crash (00:18)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 09:50 - 10:03 (00:13)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 07:52 - 07:59 (00:06)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 06:48 - 07:22 (00:34)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 06:47 - crash (00:01)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 06:00 - crash (00:46)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 05:55 - crash (00:05)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 05:54 - crash (00:01)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 05:40 - crash (00:13)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 05:39 - crash (00:01)
reboot system boot 6.6.107-1-MANJA* Sat Nov 1 05:36 - crash (00:03)
reboot system boot 6.6.107-1-MANJA* Tue Oct 14 09:43 - 05:35 (17+20:52)
reboot system boot 6.6.103-3-MANJA* Thu Sep 18 14:16 - 09:43 (25+19:26)
reboot system boot 6.6.103-3-MANJA* Thu Sep 18 10:02 - 12:48 (02:46)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 10:42 - 09:32 (2+22:50)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 10:40 - 10:41 (00:00)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 10:22 - 10:39 (00:17)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 10:20 - 10:21 (00:01)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 10:17 - 10:19 (00:02)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 09:32 - 10:15 (00:43)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 09:25 - 09:32 (00:06)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 09:20 - crash (00:04)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 09:15 - 09:20 (00:05)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:55 - crash (01:20)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:44 - crash (00:10)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:43 - crash (00:00)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:38 - crash (00:05)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:33 - 07:36 (00:03)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:30 - crash (00:02)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 07:15 - crash (00:15)
reboot system boot 6.6.103-3-MANJA* Mon Sep 15 05:53 - 07:11 (01:17)
reboot system boot 6.6.103-3-MANJA* Sun Sep 14 15:45 - 05:53 (14:07)
reboot system boot 6.6.103-3-MANJA* Sun Sep 14 15:12 - 15:45 (00:32)
reboot system boot 6.6.103-3-MANJA* Sun Sep 14 15:10 - crash (00:01)
reboot system boot 6.6.103-3-MANJA* Sun Sep 14 12:15 - crash (02:55)
reboot system boot 6.6.103-3-MANJA* Sat Sep 13 10:00 - 12:03 (02:02)
reboot system boot 6.6.103-3-MANJA* Thu Sep 11 09:40 - 09:33 (1+23:53)
Journal:
Jan 05 11:12:41 isildur kernel: Linux version 6.12.63-1-MANJARO (linux612@manjaro) (gcc (GCC) 15.2.1 20251112, GNU ld (GNU Binutils) 2.45.1) #1 SMP PREEMPT_DYNAMIC Thu, 18 Dec 2025 13:46:28 +0000
Jan 05 11:12:41 isildur kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=64dbb951-063f-43f5-bb22-3358237997b5 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Jan 05 11:12:41 isildur kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Jan 05 11:12:41 isildur kernel: BIOS-provided physical RAM map:
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000069f98fff] usable
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000069f99000-0x000000006a898fff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x000000006a899000-0x00000000734aefff] usable
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000734af000-0x00000000752fefff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000752ff000-0x0000000075b2efff] ACPI NVS
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000075b2f000-0x0000000075bfefff] ACPI data
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000075bff000-0x0000000075bfffff] usable
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000075c00000-0x0000000079ffffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x000000007a600000-0x000000007a7fffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x000000007b000000-0x00000000807fffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x00000000ff500000-0x00000000ffffffff] reserved
Jan 05 11:12:41 isildur kernel: BIOS-e820: [mem 0x0000000100000000-0x000000087f7fffff] usable
Jan 05 11:12:41 isildur kernel: NX (Execute Disable) protection: active
Jan 05 11:12:41 isildur kernel: APIC: Static calls initialized
Jan 05 11:12:41 isildur kernel: e820: update [mem 0x686e1018-0x686f0e57] usable ==> usable
Jan 05 11:12:41 isildur kernel: e820: update [mem 0x686d2018-0x686e0057] usable ==> usable
Jan 05 11:12:41 isildur kernel: extended physical RAM map:
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000000100000-0x00000000686d2017] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000686d2018-0x00000000686e0057] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000686e0058-0x00000000686e1017] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000686e1018-0x00000000686f0e57] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000686f0e58-0x0000000069f98fff] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000069f99000-0x000000006a898fff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x000000006a899000-0x00000000734aefff] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000734af000-0x00000000752fefff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000752ff000-0x0000000075b2efff] ACPI NVS
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000075b2f000-0x0000000075bfefff] ACPI data
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000075bff000-0x0000000075bfffff] usable
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000075c00000-0x0000000079ffffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x000000007a600000-0x000000007a7fffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x000000007b000000-0x00000000807fffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x00000000ff500000-0x00000000ffffffff] reserved
Jan 05 11:12:41 isildur kernel: reserve setup_data: [mem 0x0000000100000000-0x000000087f7fffff] usable
Jan 05 11:12:41 isildur kernel: efi: EFI v2.7 by INSYDE Corp.
Jan 05 11:12:41 isildur kernel: efi: ACPI=0x75bfe000 ACPI 2.0=0x75bfe014 TPMFinalLog=0x75a85000 SMBIOS=0x739e3000 SMBIOS 3.0=0x739e1000 MEMATTR=0x6f21a018 ESRT=0x6f21b098 INITRD=0x6a8a8a98 RNG=0x75b86018 TPMEventLog=0x75b83018
Jan 05 11:12:41 isildur kernel: random: crng init done
Jan 05 11:12:41 isildur kernel: efi: Remove mem82: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
Jan 05 11:12:41 isildur kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
Jan 05 11:12:41 isildur kernel: efi: Not removing mem83: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
Jan 05 11:12:41 isildur kernel: efi: Remove mem85: MMIO range=[0xff500000-0xffffffff] (11MB) from e820 map
Jan 05 11:12:41 isildur kernel: e820: remove [mem 0xff500000-0xffffffff] reserved
Jan 05 11:12:41 isildur kernel: SMBIOS 3.3.0 present.
Jan 05 11:12:41 isildur kernel: DMI: PC Specialist LTD NH5x_NH7x_HHx_HJx_HKx/NHxxHJHK, BIOS 1.07.03TPCS1 05/13/2021
Jan 05 11:12:41 isildur kernel: DMI: Memory slots populated: 2/2
Jan 05 11:12:41 isildur kernel: tsc: Detected 2300.000 MHz processor
Jan 05 11:12:41 isildur kernel: tsc: Detected 2304.000 MHz TSC
Jan 05 11:12:41 isildur kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jan 05 11:12:41 isildur kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jan 05 11:12:41 isildur kernel: last_pfn = 0x87f800 max_arch_pfn = 0x400000000
Jan 05 11:12:41 isildur kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
Jan 05 11:12:41 isildur kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Jan 05 11:12:41 isildur kernel: last_pfn = 0x75c00 max_arch_pfn = 0x400000000
Jan 05 11:12:41 isildur kernel: esrt: Reserving ESRT space from 0x000000006f21b098 to 0x000000006f21b0d0.
Jan 05 11:12:41 isildur kernel: e820: update [mem 0x6f21b000-0x6f21bfff] usable ==> reserved
