Unexpected Inconsistency Run fsck manually
Hi all.
My laptop (Asus Tuf A15) has had problems lately, where it would randomly freeze. I would shut down (hold power) and restart and usually it’d be fine.
Now, it’s happened again but won’t boot up. It loads to a screen, and says:
UNEXPECTED INCONSISTENCY: RUN fsck MANUALLY (i.e., without -a, or -p options)
ERROR: Bailing out. Run ‘fsck UUID= ##’ manually
FILESYSTEM CHECK FAILED
Please run fsck manually. After leaving this maintenance shell, the system will reboot automatically.
sh: can’t access tty: job control turned off
And under that there’s a line I can run commands, all I can get it to do is “exit” and reboot but it lands on the same screen.
Any advice what to try?
Boot live iso and run fsck from there.
I made a bootable USB with Manjaro, and booted the laptop up.
After it loaded, I went into command prompt and ran “fsck” and it just says
fsck from util-linux 2.39.3
Boot live iso → GParted → Start the “Check” option on the selected partition of the installed system
Yeah, it’s not a magic command. Search how to check disk with fsck.
These links should be useful:
Note that fsck should run on an unmounted partition with a Linux filesystem, and will usually require elevated privileges (sudo).
Additionally, it is often preferable to perform such operations from a bootable Manjaro installer, or similar.
Note also that when using the chroot environment from the Manjaro installer, you are already the root user, so sudo is not needed.
I hope this helps. Cheers.
First look in your Drivelist with:
lsblk
After identication your drive/partition use use this command:
sudo fsck -f -y /dev/sdXX
(-f Forcescan -y always yes to all questions) (sdXX Replace XX with your unmounted drive that needs to be scanned)
Edit:
I would also find out why your Laptop is freezing and if its a heat problem, when your laptop has not enough ram you can also stop the freeze with REISUB, i recommend to activate it.
It saved my OS in the past as i had problems, from hard Shutdown because of this feature. When my memory was full and my mouse cursor froze.
