Unexpected computer reboot
Hello.
I have some strange computer reboot about 1 time in 1-2 days mostly while working with Mozilla Firefox or LibreOffice.
Symptoms:
Mouse freezes, then few small rectangular spots appear on the monitor, then the screen turns black, and in the end login window with Manjaro original wallpaper appears. Total time is few seconds - everything happens very quickly.
CPU Ryzen 7 7700 and gpu intgrated in CPU, gpu diver is amdgpu.
The motherboard is ASUS B650-E WIFI,
memory Adata Lancer Blade 232GB,
system disk apacer NAS sata III SSD - 1 TB with two partitions - “/boot/efi” and “/”,
swap - separate apacer panther sata III SSD 512 GB,
/home partition is on the NVME M.2 Spatium M480 Pro 2 TB,
power unit - Core Reactor II 850 Gold,
keyboard, mouse and Deskjet 2320 printer connected via usb 2.0 hub to one of usb 2.0 ports on back panel of MB (printer, of course has separate power supply),
monitor - IIyama Prolite xub2797qsu-b1 27’’ 2560
1440, 60Hz.
If anyone can help, please respond.
Hi and welcome,
Instead please provide the output of inxi -Farz
Dear cscs, thank you very much for your answer and suggestion. And I am sorry dor delay - just I could not be that time here.
And one more sorry, could I paste here all the output of inxi -Farz? And if yes is it possible to put it here as is or it needs special format like some code?
You can post that here.
It does need formatting.
  • highlight everything
  • copy/paste the output into the editor window here
  • highlight everything again here in the edit window
then look at the top row of the edit window - use this symbol: </>
to format it as “preformatted text” - so that it’ll look like the terminal output that you saw
it will then look like this (click to expand):
inxi -zv8
  Kernel: 6.8.0-52-generic x86_64 bits: 64 compiler: N/A
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.8.0-52-generic
    root=UUID=e3d59116-1204-4700-b8c4-4f496790d85c ro quiet splash
    mitigations=off nowatchdog audit=0
    resume=UUID=e3d59116-1204-4700-b8c4-4f496790d85c resume_offset=4171776
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.1 Vera
    base: Ubuntu 22.04 jammy
  Type: Laptop System: Sony product: SVE14A2M6EB v: C60BCWQA
  Mobo: Sony model: VAIO serial: <superuser required>
    UEFI: American Megatrends v: R0202V5 date: 03/14/2013
  ID-1: BAT0 charge: 31.1 Wh (100.0%) condition: 31.1/62.6 Wh (49.6%)
    volts: 12.3 min: 10.8 model: Sony Corp. type: Li-ion serial: N/A
    status: Full
  RAM: total: 7.63 GiB used: 3.53 GiB (46.2%)
  RAM Report:
  Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1197 min/max: 1200/2400 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1197 2: 1197 3: 1197 4: 1197 bogomips: 19155
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pts rdtscp
    rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
    xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: Vulnerable
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
  Type: mds status: Vulnerable; SMT vulnerable
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Sony driver: i915
    v: kernel ports: active: VGA-1 off: LVDS-1 empty: DP-1,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Foxconn / Hon Hai USB2.0 Camera type: USB driver: uvcvideo
    bus-ID: 2-1.3:3 chip-ID: 0489:d600 class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.4 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting unloaded: fbdev,vesa gpu: i915 display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
    s-diag: 449mm (17.7")
  Monitor-1: VGA-1 model: Hannspree HW191D serial: <filter> built: 2008
    res: 1440x900 hz: 60 dpi: 90 gamma: 1.2 size: 408x255mm (16.1x10.0")
    diag: 481mm (18.9") ratio: 16:10 modes: max: 1440x900 min: 720x400
  OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
    v: 4.2 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Sound Server-1: ALSA v: k6.8.0-52-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
  Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:0887
    class-ID: 0280
  IP v6: <filter> type: noprefixroute scope: global
  IP v6: <filter> type: temporary dynamic scope: global
  IP v6: <filter> type: mngtmpaddr noprefixroute scope: global
    vendor: Sony driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full
    mac: <filter>
  IP v6: <filter> scope: link
  Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
    driver: btusb v: 0.8 bus-ID: 2-1.6:4 chip-ID: 8087:07da class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 3 state: up address: <filter>
    bt-v: 2.1 lmp-v: 4.0 sub-v: fc00 hci-v: 4.0 rev: 1ebd
  Info: acl-mtu: 310:10 sco-mtu: 64:8 link-policy: rswitch hold sniff park
    link-mode: peripheral accept
    service-classes: rendering, capturing, object transfer, audio, telephony
  Local Storage: total: 596.17 GiB used: 337.3 GiB (56.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD6400BEVT-22A0RT0 size: 596.17 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 1A01 scheme: GPT
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-U633J rev: SN01
    dev-links: cdrom
  ID-1: / raw-size: 595.67 GiB size: 585.25 GiB (98.25%)
    used: 337.3 GiB (57.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: e3d59116-1204-4700-b8c4-4f496790d85c
    used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 4D5A-3FC2
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.3:3 info: Foxconn / Hon Hai USB2.0 Camera type: Video
  Device-2: 2-1.6:4 info: Intel Centrino Bluetooth Wireless Transceiver
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Logitech Wireless Receiver type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 50mA chip-ID: 046d:c542 class-ID: 0301
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 42.0 C mobo: N/A
  Packages: note: see --pkg apt: 3130 lib: 1579
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/nordvpn.list
    1: deb https://repo.nordvpn.com//deb/nordvpn/debian stable main
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb http://linux-mint.froonix.org vera main upstream import backport
    2: deb http://ftp-stud.hs-esslingen.de/ubuntu jammy main restricted universe multiverse
    3: deb http://ftp-stud.hs-esslingen.de/ubuntu jammy-updates main restricted universe multiverse
    4: deb http://ftp-stud.hs-esslingen.de/ubuntu jammy-backports main restricted universe multiverse
    5: deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Processes:
  CPU top: 5 of 237
  1: cpu: 21.8% command: firefox pid: 2094 mem: 530.0 MiB (6.7%)
  2: cpu: 15.0% command: qemu-system-x86_64 pid: 31933
    mem: 906.5 MiB (11.5%)
  3: cpu: 9.9% command: firefox-bin pid: 2233 mem: 113.1 MiB (1.4%)
  4: cpu: 5.5% command: firefox-bin pid: 5949 mem: 536.8 MiB (6.8%)
  5: cpu: 4.2% command: xorg pid: 884 mem: 97.8 MiB (1.2%)
  Memory top: 5 of 237
  1: mem: 906.5 MiB (11.5%) command: qemu-system-x86_64 pid: 31933
    cpu: 15.0%
  2: mem: 536.8 MiB (6.8%) command: firefox-bin pid: 5949 cpu: 5.5%
  3: mem: 530.0 MiB (6.7%) command: firefox pid: 2094 cpu: 21.8%
  4: mem: 231.3 MiB (2.9%) command: firefox-bin pid: 2298 cpu: 0.4%
  5: mem: 223.4 MiB (2.8%) command: firefox-bin pid: 29823 cpu: 1.3%
  Processes: 237 Uptime: 3h 39m wakeups: 1 Init: systemd v: 249 runlevel: 5
  tool: systemctl Compilers: gcc: 11.4.0 alt: 11/12 Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.13
or look here:
[HowTo] Use public command-line pastebin services without installing anything!
<command> | curl -F 'file=@-' https://0x0.st
would translate to:
inxi -zv8 | curl -F 'file=@-' https://0x0.st
post the link that you get back - again formatted as a quote or preformatted text
since you probably can’t post “live” links without formatting them
(which is a good thing in any case - that is why even I always do these steps, even though I would not need to … it just looks better :wink: )
Hello, dear Nachlese.
Thank you very much for your kindly help. It’s very important and useful for me.
When a link is given to you, the expectation is that you should follow it, and read the content. As it happens, your question would have been unneeded if you had done so.
The following topic was linked from the previous topic, and describes all you need to know about formatting requirements:
Hello, dear Forum members.
Here is inxi -Farz output:
inxi -Farz
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e2301536-a040-4dd1-8ba0-d3498a4d0ae8 rw quiet splash apparmor=1
    security=apparmor resume=UUID=8d8e03c1-9ae5-40b8-a354-b9253be093d9
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Mobo: ASUSTeK model: TUF GAMING B650-E WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 3024 date: 08/02/2024
  Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 545 min/max: 545/5389 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 545 2: 545 3: 545
    4: 545 5: 545 6: 545 7: 545 8: 545 9: 545 10: 545 11: 545 12: 545 13: 545
    14: 545 15: 545 16: 545 bogomips: 121413
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: HDMI-A-1,Writeback-1 bus-ID: 0b:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 33.0 C
  Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: DP-1 model: Idek Iiyama PL2797Q serial: <filter> built: 2024
    res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    raphael_mendocino LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO)
    device-ID: 1002:164e memory: 500 MiB unified: no
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp8s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0489:e0e2
  Local Storage: total: 3.22 TiB used: 60.29 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M480 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM80.1 temp: 28.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: 1TB SATA SSD
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 5PE0 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Apacer model: AS350 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  ID-1: / raw-size: 952.87 GiB size: 936.84 GiB (98.32%)
    used: 11.11 GiB (1.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 288 KiB (0.0%) fs: vfat dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 49.18 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 476.94 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb1 maj-min: 8:17
  System Temperatures: cpu: 38.0 C mobo: 30.5 C gpu: amdgpu temp: 33.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1229 libs: 356 tools: pamac pm: flatpak pkgs: 0
    1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    6: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    7: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
  Memory: total: 64 GiB available: 61.95 GiB used: 2.69 GiB (4.3%)
  Processes: 346 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.76 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.37
I just ran it as ordinary user, not as root. If it’s mistake, I’ll repeat it as superuser.
Dear soundofthunder, thank you very much for you advises and help.
I’m trying to learn how to behave correctly on the forum, and I’m still learning, but then I try to eliminate unnecessary inconveniences.
It was unnecessary, as the first instance already contained more information than the second (I have hidden the post).
The following is a full inxi command that I typically offer, which additionally filters any personally identifiable information from the output.
inxi --admin --verbosity=8 --filter --no-host --width
I offer this not for you to use now, but to copy to your personal notes, as system information may be prerequisite for future Support requests.
Dear soundofthunder, thank you very much for your helpful advice, I copied it to my collection of recipes.
A bit silly, as --no-host is included in --filter, --width should not be needed with inxi for some years as it already defaults to an 80 max width, and --admin is redundant with --verbosity=8
inxi --verbosity 8 --filter
Is of course also the long form, so your command can easily become
inxi -zv8
