Hi,
I do not know how to debug the problem I have.
Each time I boot manjaro I have to reach to roll out my computer and unattach and attach my headphones to get them discovered.
So I wonder if it could be a hardware or a software problem.
The best fix would be to get them to be discovered.
Next best would be a workaround that could force output to the headphones/ line out jack.
Suggestions?
About my system:
KDE Plasma Version: 5.24.6
KDE Frameworks Version: 5.96.0
Qt Version: 5.15.5
Kernel Version: 5.15.60-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 à Intel® Core⢠i5-6600K CPU @ 3.50GHz
Memory: 31,3 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 960/PCIe/SSE2
Motherboard: MAXIMUS VIII GENEļ½Motherboardsļ½ASUS USA
Dac:ESS ES9023P DAC
Some software that might have have an impact:
Pulseaudio 16.1-1
alsa-lib 1.2.7.2-1
lib32-alsa-lib 1.2.7.2-1
pipewire 1:0.3.56-1
logs:
inxi -Faz
> System:
> Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
> parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
> root=UUID=d19efa5e-7ae9-4c3a-b241-aaad78ba1b7f rw rootflags=subvol=@
> quiet apparmor=1 security=apparmor udev.log_priority=3
> sysrq_always_enabled=1
> Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
> dm: SDDM Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII GENE v: Rev 1.xx
> serial: <superuser required> UEFI: American Megatrends v: 3007
> date: 11/29/2016
> CPU:
> Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S
> gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
> model-id: 0x5E (94) stepping: 3 microcode: 0xF0
> Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
> desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
> desc: 1x6 MiB
> Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_pstate
> governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28009
> Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> Vulnerabilities:
> Type: itlb_multihit status: KVM: VMX disabled
> Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
> disabled
> Type: mds mitigation: Clear CPU buffers; SMT disabled
> Type: meltdown mitigation: PTI
> Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
> Type: retbleed mitigation: IBRS
> Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
> prctl and seccomp
> Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
> sanitization
> Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
> PBRSB-eIBRS: Not affected
> Type: srbds mitigation: Microcode
> Type: tsx_async_abort mitigation: TSX disabled
> Graphics:
> Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
> v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
> (as of 2022-08) arch: Maxwell code: GMxxx process: TSMC 28nm
> built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
> chip-ID: 10de:1401 class-ID: 0300
> Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
> compositor: kwin_x11 driver: X: loaded: nvidia
> unloaded: modesetting,nouveau,vesa alternate: fbdev,nv gpu: nvidia
> display-ID: :0 screens: 1
> Screen-1: 0 s-res: 7680x2160 s-dpi: 93 s-size: 2098x584mm (82.60x22.99")
> s-diag: 2178mm (85.74")
> Monitor-1: DP-0 pos: primary,top-center res: 3840x2160 dpi: 111
> size: 878x485mm (34.57x19.09") diag: 1003mm (39.49") modes: N/A
> Monitor-2: DP-2.8 pos: top-right res: 1920x1080 hz: 60 dpi: 93
> size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
> Monitor-3: HDMI-0 pos: bottom-l res: 1920x1080 hz: 60 dpi: 94
> size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
> OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA
> 515.65.01 direct render: Yes
> Audio:
> Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
> driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
> class-ID: 0403
> Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
> driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
> bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
> Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
> Sound Server-2: PulseAudio v: 16.1 running: yes
> Sound Server-3: PipeWire v: 0.3.56 running: yes
> Network:
> Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
> port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
> IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
> Drives:
> Local Storage: total: 7.73 TiB used: 337.8 GiB (4.3%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
> 500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
> speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
> temp: 44.9 C scheme: MBR
> ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HMS5C4040BLE640
> size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
> type: HDD rpm: 5700 serial: <filter> rev: A5D0 scheme: GPT
> ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUS724040ALE641
> type: HDD rpm: 7200 serial: <filter> rev: A5F0 scheme: GPT
> Partition:
> ID-1: / raw-size: 465.73 GiB size: 465.73 GiB (100.00%) used: 337.8 GiB
> (72.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
> ID-2: /boot/efi raw-size: 33 MiB size: 32.5 MiB (98.41%) used: 4.8 MiB
> (14.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
> ID-3: /home raw-size: 465.73 GiB size: 465.73 GiB (100.00%) used: 337.8
> GiB (72.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
> ID-4: /var/log raw-size: 465.73 GiB size: 465.73 GiB (100.00%) used: 337.8
> Swap:
> Alert: No swap data was found.
> Sensors:
> System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 45 C
> Fan Speeds (RPM): N/A gpu: nvidia fan: 21%
> Info:
> Processes: 258 Uptime: 15h 2m wakeups: 0 Memory: 31.29 GiB used: 5.53 GiB
> (17.7%) Init: systemd v: 251 default: graphical tool: systemctl
> Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pm: pacman pkgs: 1732
> libs: 414 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
> running-in: konsole inxi: 3.3.21
journalctl -b0 -p4 --no-pager
> aug 30 10:25:21 johlux kernel: x86/cpu: SGX disabled by BIOS.
> aug 30 10:25:21 johlux kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
> aug 30 10:25:21 johlux kernel: nvme nvme0: missing or invalid SUBNQN field.
> aug 30 10:25:21 johlux kernel: resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
> aug 30 10:25:21 johlux kernel: caller pmc_core_probe+0xb7/0x6b0 mapping multiple BARs
> aug 30 10:25:21 johlux kernel: ata3.00: ATA Identify Device Log not supported
> aug 30 10:25:21 johlux kernel: ata6.00: ATA Identify Device Log not supported
> aug 30 10:25:21 johlux kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
> aug 30 10:25:21 johlux systemd[1]: Configuration file /etc/systemd/system/windscribe-helper.service is marked executable. Please remove executable permission bits. Proceeding anyway.
> aug 30 10:25:21 johlux kernel: vboxdrv: loading out-of-tree module taints kernel.
> aug 30 10:25:21 johlux kernel: VBoxNetAdp: Successfully started.
> aug 30 10:25:21 johlux kernel: VBoxNetFlt: Successfully started.
> aug 30 10:25:21 johlux kernel: nvidia: module license 'NVIDIA' taints kernel.
> aug 30 10:25:21 johlux kernel: Disabling lock debugging due to kernel taint
> aug 30 10:25:21 johlux kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
> aug 30 10:25:22 johlux kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
> aug 30 10:25:25 johlux sddm-greeter[910]: QFont::fromString: Invalid description '(empty)'
> aug 30 10:25:26 johlux sddm-greeter[910]: QObject: Cannot create children for a parent that is in a different thread.
> (Parent is QGuiApplication(0x7ffd1d10e0e0), parent's thread is QThread(0x55747e93f450), current thread is QThread(0x55747eafba40)
> aug 30 10:25:26 johlux sddm-greeter[910]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
> aug 30 10:25:26 johlux sddm-greeter[910]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
> aug 30 10:25:26 johlux sddm-greeter[910]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
> aug 30 10:25:26 johlux sddm-greeter[910]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
> aug 30 10:25:27 johlux sddm-greeter[910]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
> aug 30 10:25:27 johlux sddm-greeter[910]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
> aug 30 10:25:27 johlux sddm-greeter[910]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
> aug 30 10:25:27 johlux sddm-greeter[910]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
> aug 30 10:25:27 johlux sddm-greeter[910]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
> aug 30 10:25:28 johlux sddm-greeter[910]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.19'
> aug 30 10:25:28 johlux sddm-greeter[910]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
> aug 30 10:25:31 johlux kernel: kauditd_printk_skb: 225 callbacks suppressed
> aug 30 10:25:39 johlux kernel: ata3.00: ATA Identify Device Log not supported
> aug 30 10:25:47 johlux systemd-xdg-autostart-generator[945]: Configuration file /home/johannes/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
> aug 30 10:25:47 johlux systemd-xdg-autostart-generator[975]: Configuration file /home/johannes/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
> aug 30 10:25:47 johlux ksplashqml[964]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
> aug 30 10:25:47 johlux ksplashqml[964]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
> aug 30 10:25:48 johlux klauncher[985]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
> aug 30 10:25:48 johlux kcminit_startup[990]: QDBusConnection: error: could not send signal to service "" path "//home/johannes/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/johannes/.kde4/share/config/kdeglobals
> aug 30 10:25:48 johlux kwin_x11[1003]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
> aug 30 10:25:48 johlux kwin_x11[1003]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
> aug 30 10:25:48 johlux kwin_x11[1003]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
> aug 30 10:25:48 johlux kded5[1000]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
> aug 30 10:25:48 johlux ksmserver[1034]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 10:25:49 johlux kded5[1000]: kscreen.kded: PowerDevil SuspendSession action not available!
> aug 30 10:25:49 johlux backlighthelper[1152]: org.kde.powerdevil: no kernel backlight interface found
> aug 30 10:25:49 johlux pulseaudio[1064]: stat('/etc/pulse/default.pa.d'): No such file or directory
> aug 30 10:25:49 johlux org_kde_powerdevil[1056]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
> aug 30 10:25:49 johlux org_kde_powerdevil[1056]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
> aug 30 10:25:49 johlux plasmashell[1054]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
> aug 30 10:25:49 johlux plasmashell[1054]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
> aug 30 10:25:50 johlux kwin_x11[1003]: kwin_core: XCB error: 10 (BadAccess), sequence: 919, resource id: 494, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
> aug 30 10:25:50 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1041, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
> aug 30 10:25:50 johlux org_kde_powerdevil[1056]: org.kde.powerdevil: Handle button events action could not check for screen configuration
> aug 30 10:25:50 johlux org_kde_powerdevil[1056]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
> aug 30 10:25:50 johlux org_kde_powerdevil[1056]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
> aug 30 10:25:50 johlux plasmashell[1054]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
> aug 30 10:25:50 johlux plasmashell[1054]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
> aug 30 10:25:51 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1699, resource id: 52428807, major code: 15 (QueryTree), minor code: 0
> aug 30 10:25:51 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1722, resource id: 52428817, major code: 18 (ChangeProperty), minor code: 0
> aug 30 10:25:51 johlux plasmashell[1054]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
> aug 30 10:25:53 johlux plasmashell[1054]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 10. Use 'sequences: [ <key> ]' to bind to all of them.
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 9. Use 'sequences: [ <key> ]' to bind to all of them.
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 8. Use 'sequences: [ <key> ]' to bind to all of them.
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
> aug 30 10:25:53 johlux kernel: kauditd_printk_skb: 12 callbacks suppressed
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
> aug 30 10:25:53 johlux plasmashell[1054]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
> aug 30 10:25:53 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
> aug 30 10:25:54 johlux plasmashell[1054]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
> aug 30 10:25:54 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 3635, resource id: 14680094, major code: 143 (DAMAGE), minor code: 2 (Destroy)
> aug 30 10:25:54 johlux kwin_x11[1003]: kwin_core: XCB error: 3 (BadWindow), sequence: 3636, resource id: 4194325, major code: 129 (SHAPE), minor code: 6 (Input)
> aug 30 10:25:54 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3637, resource id: 4194325, major code: 2 (ChangeWindowAttributes), minor code: 0
> aug 30 10:25:54 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3656, resource id: 4194353, major code: 18 (ChangeProperty), minor code: 0
> aug 30 10:25:54 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 3658, resource id: 14680095, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 10:25:54 johlux plasmashell[1054]: kf.kio.widgets: Failed to convert QUrl("file:///home/johannes/Desktop/IntellijEssentialTraining.m3u") to canonical path
> aug 30 10:25:54 johlux plasmashell[1054]: kf.solid.frontend.devicemanager: Couldn't get StorageAccess for ""/home/johannes/Desktop/IntellijEssentialTraining.m3u"" - File doesn't exist
> aug 30 10:25:55 johlux plasmashell[1054]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
> aug 30 10:26:01 johlux plasmashell[1054]: trying to show an empty dialog
> aug 30 10:26:13 johlux pulseaudio[1064]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
> aug 30 10:26:13 johlux kded5[1000]: kf.bluezqt: PendingCall Error: "Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)"
> aug 30 10:26:23 johlux plasmashell[1054]: file:///usr/lib/qt/qml/org/kde/plasma/core/private/DefaultToolTip.qml:69:13: QML Label: Binding loop detected for property "verticalAlignment"
> aug 30 10:26:29 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14660, resource id: 52428806, major code: 18 (ChangeProperty), minor code: 0
> aug 30 10:30:25 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23133, resource id: 4194312, major code: 18 (ChangeProperty), minor code: 0
> aug 30 10:32:02 johlux kscreenlocker_greet[1474]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 10:32:03 johlux kscreenlocker_greet[1474]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 10:32:03 johlux kscreenlocker_greet[1474]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 10:32:03 johlux kscreenlocker_greet[1474]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 10:32:07 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 10:32:08 johlux plasmashell[1054]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo"
> aug 30 10:32:08 johlux plasmashell[1054]: org.kde.plasma.pulseaudio: No object for name "auto_null.2"
> aug 30 10:40:23 johlux kernel: kauditd_printk_skb: 1 callbacks suppressed
> aug 30 11:06:29 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 11:06:29 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:533 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 11:06:30 johlux plasmashell[1054]: org.kde.plasma.pulseaudio: No object for name "auto_null.2"
> aug 30 11:06:31 johlux kscreenlocker_greet[1474]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 11:06:31 johlux kscreenlocker_greet[1474]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 11:06:31 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26735, resource id: 4194346, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:06:39 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
> aug 30 11:06:40 johlux systemd-coredump[1648]: Process 1644 (firefox) of user 1000 dumped core.
> Module /usr/lib/firefox/liblgpllibs.so with build-id 33615eeab36653f9841f2828e10c6aebbc2463fb
> Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
> Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
> Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
> Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
> Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
> Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
> Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
> Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
> Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
> Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
> Module librt.so.1 with build-id 837ea1d121976e9fa94acdf79939b387a32531db
> Module libplds4.so with build-id 35c8b19ee309f8a4c2a4409568d2ab4f11a6557a
> Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
> Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
> Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
> Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
> Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
> Module libssl3.so with build-id 94040772bf0029a13562ab6314237dc26ea29a60
> Module libplc4.so with build-id d3b585736c213f75d6d1071f8db9a6219f1dd429
> Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
> Module libxul.so with build-id 3bbdbf34b8993b86340f840ae98cccd9ed6425fc
> Module libmozwayland.so with build-id d10ccd85e5bd875d6a89f6f07578976b26ea27f7
> Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
> Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
> Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
> Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
> Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
> Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
> Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
> Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
> Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
> Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
> Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
> Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
> Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
> Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
> Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
> Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
> Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
> Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
> Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
> Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
> Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
> Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
> Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
> Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
> Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
> Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
> Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
> Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
> Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
> Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
> Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
> Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
> Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
> Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
> Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
> Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
> Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
> Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
> Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
> Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
> Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
> Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
> Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
> Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
> Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
> Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
> Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
> Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
> Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
> Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
> Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
> Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
> Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
> Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
> Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
> Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
> Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
> Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
> Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
> Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
> Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
> Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
> Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
> Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
> Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
> Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
> Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
> Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
> Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
> Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
> Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
> Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
> Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
> Module libmozgtk.so with build-id 8027a58caeba8263184a5eed62b27555d21c7736
> Module libmozsqlite3.so with build-id 8d0f4ebe7c073f9b72bab3afb37b00c4b7a15652
> Module libnspr4.so with build-id 64bc745fdf99e414eeda94b9345af6fa6fcce329
> Module libmozsandbox.so with build-id 3c9db5fb3562abc2e78e76bf80291ded455f1f38
> Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
> Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
> Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
> Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
> Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
> Module firefox with build-id 2b8aea238365eb224accff3ca8a61933202c6214
> Stack trace of thread 1644:
> #0 0x00007f19ad8e8814 XDisplayString (libX11.so.6 + 0x2b814)
> #1 0x00007f19a0c21a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
> #2 0x00007f19a08bcc8a n/a (libva.so.2 + 0x3c8a)
> #3 0x00007f19a08c2be1 vaInitialize (libva.so.2 + 0x9be1)
> #4 0x00007f19a915d117 n/a (libxul.so + 0x8533117)
> #5 0x00007f19a915dd29 n/a (libxul.so + 0x8533d29)
> #6 0x00007f19a512db4e n/a (libxul.so + 0x4503b4e)
> #7 0x00007f19a512b955 n/a (libxul.so + 0x4501955)
> #8 0x00007f19a511ebe5 n/a (libxul.so + 0x44f4be5)
> #9 0x00007f19a511dead n/a (libxul.so + 0x44f3ead)
> #10 0x0000563b6f79a972 n/a (firefox + 0x55972)
> #11 0x00007f19af6d52d0 n/a (libc.so.6 + 0x232d0)
> #12 0x00007f19af6d538a __libc_start_main (libc.so.6 + 0x2338a)
> #13 0x0000563b6f7aa0a5 _start (firefox + 0x650a5)
> ELF object binary architecture: AMD x86-64
> aug 30 11:31:33 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46373, resource id: 33554606, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 0, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 1, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 2, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 3, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 4, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 5, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 6, async page read
> aug 30 11:31:34 johlux kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
> aug 30 11:31:34 johlux kernel: Buffer I/O error on dev sr0, logical block 7, async page read
> aug 30 11:31:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46748, resource id: 77594633, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:31:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46752, resource id: 85983234, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:31:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46753, resource id: 85983234, major code: 12 (ConfigureWindow), minor code: 0
> aug 30 11:31:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46754, resource id: 85983234, major code: 12 (ConfigureWindow), minor code: 0
> aug 30 11:31:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46847, resource id: 33554607, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:32:22 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57692, resource id: 85983238, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:52:25 johlux pipewire[1265]: spa.alsa: 'front:0': playback open failed: Device or resource busy
> aug 30 11:52:25 johlux pipewire[1265]: mod.adapter: 0x55ab78dcb7d0: can't get format: Device or resource busy
> aug 30 11:52:25 johlux pipewire-media-session[1266]: ms.core: error id:30 seq:667 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 11:52:31 johlux plasmashell[1054]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
> aug 30 11:52:44 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65104, resource id: 33554633, major code: 18 (ChangeProperty), minor code: 0
> aug 30 11:52:48 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1557, resource id: 14714224, major code: 3 (GetWindowAttributes), minor code: 0
> aug 30 11:52:48 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1558, resource id: 14714224, major code: 14 (GetGeometry), minor code: 0
> aug 30 11:52:48 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1650, resource id: 88080387, major code: 15 (QueryTree), minor code: 0
> aug 30 11:52:48 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 1723, resource id: 14714101, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 12:04:02 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20258, resource id: 69206060, major code: 15 (QueryTree), minor code: 0
> aug 30 12:04:02 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20295, resource id: 4194311, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:07:50 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39147, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:12:51 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53068, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:17:51 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11946, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:22:51 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29467, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:26:30 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42993, resource id: 33554656, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:26:30 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
> aug 30 12:26:30 johlux systemd-coredump[4479]: Process 4477 (firefox) of user 1000 dumped core.
> Stack trace of thread 4477:
> #0 0x00007fd868d73814 XDisplayString (libX11.so.6 + 0x2b814)
> #1 0x00007fd85c0aca1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
> #2 0x00007fd85bd47c8a n/a (libva.so.2 + 0x3c8a)
> #3 0x00007fd85bd4dbe1 vaInitialize (libva.so.2 + 0x9be1)
> #4 0x00007fd8645e8117 n/a (libxul.so + 0x8533117)
> #5 0x00007fd8645e8d29 n/a (libxul.so + 0x8533d29)
> #6 0x00007fd8605b8b4e n/a (libxul.so + 0x4503b4e)
> #7 0x00007fd8605b6955 n/a (libxul.so + 0x4501955)
> #8 0x00007fd8605a9be5 n/a (libxul.so + 0x44f4be5)
> #9 0x00007fd8605a8ead n/a (libxul.so + 0x44f3ead)
> #10 0x000055b4b331b972 n/a (firefox + 0x55972)
> #11 0x00007fd86ab602d0 n/a (libc.so.6 + 0x232d0)
> #12 0x00007fd86ab6038a __libc_start_main (libc.so.6 + 0x2338a)
> #13 0x000055b4b332b0a5 _start (firefox + 0x650a5)
> aug 30 12:27:52 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57381, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 12:33:42 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14627, resource id: 90177719, major code: 15 (QueryTree), minor code: 0
> aug 30 12:35:11 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 39673, resource id: 14747733, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 12:35:11 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39717, resource id: 90177626, major code: 15 (QueryTree), minor code: 0
> aug 30 13:33:12 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
> aug 30 13:33:13 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
> aug 30 13:46:06 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14494, resource id: 90178909, major code: 15 (QueryTree), minor code: 0
> aug 30 13:54:34 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15, resource id: 90177580, major code: 15 (QueryTree), minor code: 0
> aug 30 13:59:35 johlux kscreenlocker_greet[9779]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 13:59:36 johlux kscreenlocker_greet[9779]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 13:59:36 johlux kscreenlocker_greet[9779]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 13:59:36 johlux kscreenlocker_greet[9779]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 13:59:40 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 16:57:49 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 16:57:49 johlux pipewire[1265]: mod.adapter: 0x55ab78dcb7d0: can't get format: Device or resource busy
> aug 30 16:57:49 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:715 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 16:57:52 johlux kscreenlocker_greet[9779]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 16:57:52 johlux kscreenlocker_greet[9779]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 16:57:52 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8087, resource id: 92274734, major code: 18 (ChangeProperty), minor code: 0
> aug 30 17:11:37 johlux kscreenlocker_greet[11434]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 17:11:38 johlux kscreenlocker_greet[11434]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 17:11:38 johlux kscreenlocker_greet[11434]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 17:11:38 johlux kscreenlocker_greet[11434]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 17:11:42 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 17:25:58 johlux plasmashell[1054]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55a4b736f8a0) QQmlContext(0x55a4b56613f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> aug 30 17:25:58 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> aug 30 17:25:58 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> aug 30 17:25:58 johlux plasmashell[1054]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55a4b6814a40) QQmlContext(0x55a4b56613f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> aug 30 17:26:00 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50682, resource id: 33554657, major code: 20 (GetProperty), minor code: 0
> aug 30 17:26:00 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50683, resource id: 33554657, major code: 15 (QueryTree), minor code: 0
> aug 30 17:26:08 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50998, resource id: 33554659, major code: 20 (GetProperty), minor code: 0
> aug 30 17:26:08 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50999, resource id: 33554659, major code: 15 (QueryTree), minor code: 0
> aug 30 17:26:09 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 51028, resource id: 14885736, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 18:02:04 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 18:02:04 johlux pipewire[1265]: mod.adapter: 0x55ab78dcb7d0: can't get format: Device or resource busy
> aug 30 18:02:04 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:754 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 18:07:03 johlux kscreenlocker_greet[11434]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 18:07:03 johlux kscreenlocker_greet[11434]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 18:07:03 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55602, resource id: 92274730, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:07:19 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59465, resource id: 90177867, major code: 15 (QueryTree), minor code: 0
> aug 30 18:07:19 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59504, resource id: 69206023, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:07:25 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61279, resource id: 88083718, major code: 15 (QueryTree), minor code: 0
> aug 30 18:07:52 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 432, resource id: 69206022, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:12:45 johlux kscreenlocker_greet[11796]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 18:12:46 johlux kscreenlocker_greet[11796]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 18:12:47 johlux kscreenlocker_greet[11796]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 18:12:47 johlux kscreenlocker_greet[11796]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 18:12:50 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 18:18:36 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 18:18:36 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:794 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 18:18:39 johlux kscreenlocker_greet[11796]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 18:18:39 johlux kscreenlocker_greet[11796]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 18:18:39 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 2419, resource id: 14886678, major code: 143 (DAMAGE), minor code: 2 (Destroy)
> aug 30 18:18:39 johlux kwin_x11[1003]: kwin_core: XCB error: 3 (BadWindow), sequence: 2420, resource id: 69206035, major code: 129 (SHAPE), minor code: 6 (Input)
> aug 30 18:18:39 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2421, resource id: 69206035, major code: 2 (ChangeWindowAttributes), minor code: 0
> aug 30 18:18:39 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2445, resource id: 69206062, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:22:52 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16577, resource id: 69206023, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:24:23 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17163, resource id: 33554671, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:24:23 johlux systemd-coredump[11955]: Process 11951 (firefox) of user 1000 dumped core.
> Stack trace of thread 11951:
> #0 0x00007fe3bbf23814 XDisplayString (libX11.so.6 + 0x2b814)
> #1 0x00007fe3af265a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
> #2 0x00007fe3aedd4c8a n/a (libva.so.2 + 0x3c8a)
> #3 0x00007fe3aeddabe1 vaInitialize (libva.so.2 + 0x9be1)
> #4 0x00007fe3b77a1117 n/a (libxul.so + 0x8533117)
> #5 0x00007fe3b77a1d29 n/a (libxul.so + 0x8533d29)
> #6 0x00007fe3b3771b4e n/a (libxul.so + 0x4503b4e)
> #7 0x00007fe3b376f955 n/a (libxul.so + 0x4501955)
> #8 0x00007fe3b3762be5 n/a (libxul.so + 0x44f4be5)
> #9 0x00007fe3b3761ead n/a (libxul.so + 0x44f3ead)
> #10 0x000055623c51e972 n/a (firefox + 0x55972)
> #11 0x00007fe3bdd192d0 n/a (libc.so.6 + 0x232d0)
> #12 0x00007fe3bdd1938a __libc_start_main (libc.so.6 + 0x2338a)
> #13 0x000055623c52e0a5 _start (firefox + 0x650a5)
> aug 30 18:32:52 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18292, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:37:53 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20220, resource id: 92274695, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:38:53 johlux kscreenlocker_greet[12659]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 18:38:54 johlux kscreenlocker_greet[12659]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 18:38:54 johlux kscreenlocker_greet[12659]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 18:38:54 johlux kscreenlocker_greet[12659]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:549: TypeError: Value is undefined and could not be converted to an object
> aug 30 18:38:54 johlux kscreenlocker_greet[12659]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 18:38:58 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 18:45:14 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 18:45:14 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:849 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 18:45:17 johlux kscreenlocker_greet[12659]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 18:45:17 johlux kscreenlocker_greet[12659]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 18:45:17 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22191, resource id: 92274734, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:47:53 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42271, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:52:53 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1800, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 18:57:53 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37721, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:02:54 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2341, resource id: 92274694, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:07:54 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20377, resource id: 92274695, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:11:06 johlux kscreenlocker_greet[13770]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 19:11:07 johlux kscreenlocker_greet[13770]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 19:11:08 johlux kscreenlocker_greet[13770]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 19:11:08 johlux kscreenlocker_greet[13770]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 19:11:11 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 19:23:33 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 19:23:33 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:904 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 19:23:35 johlux kscreenlocker_greet[13770]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 19:23:35 johlux kscreenlocker_greet[13770]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 19:23:35 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23101, resource id: 92274734, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:23:45 johlux plasmashell[1054]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> aug 30 19:23:45 johlux plasmashell[1054]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
> aug 30 19:23:50 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27154, resource id: 96468993, major code: 15 (QueryTree), minor code: 0
> aug 30 19:23:50 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 27599, resource id: 14900488, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 19:24:38 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39698, resource id: 98566150, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:25:34 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52383, resource id: 98566150, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:28:36 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11026, resource id: 96469000, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:33:12 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45992, resource id: 33554695, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:46:04 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 617, resource id: 98566150, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:46:13 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1635, resource id: 100663485, major code: 15 (QueryTree), minor code: 0
> aug 30 19:46:13 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1763, resource id: 100663717, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:46:13 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1799, resource id: 33554696, major code: 18 (ChangeProperty), minor code: 0
> aug 30 19:48:41 johlux plasmashell[1054]: kf.sonnet.core: No language dictionaries for the language: "en_US"
> aug 30 19:48:57 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24781, resource id: 98566145, major code: 15 (QueryTree), minor code: 0
> aug 30 19:48:57 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 24967, resource id: 14911290, major code: 143 (DAMAGE), minor code: 3 (Subtract)
> aug 30 19:56:09 johlux kscreenlocker_greet[15361]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 19:56:10 johlux kscreenlocker_greet[15361]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 19:56:10 johlux kscreenlocker_greet[15361]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 19:56:10 johlux kscreenlocker_greet[15361]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:549: TypeError: Value is undefined and could not be converted to an object
> aug 30 19:56:10 johlux kscreenlocker_greet[15361]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 19:56:14 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 20:02:01 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 20:02:01 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:959 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 20:02:04 johlux kscreenlocker_greet[15361]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 20:02:04 johlux kscreenlocker_greet[15361]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 20:02:04 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40225, resource id: 98566190, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:05:58 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 8215, resource id: 14914313, major code: 143 (DAMAGE), minor code: 2 (Destroy)
> aug 30 20:05:58 johlux kwin_x11[1003]: kwin_core: XCB error: 3 (BadWindow), sequence: 8216, resource id: 102760593, major code: 129 (SHAPE), minor code: 6 (Input)
> aug 30 20:05:58 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8217, resource id: 102760593, major code: 2 (ChangeWindowAttributes), minor code: 0
> aug 30 20:13:05 johlux kscreenlocker_greet[16110]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 20:13:06 johlux kscreenlocker_greet[16110]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 20:13:06 johlux kscreenlocker_greet[16110]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 20:13:06 johlux kscreenlocker_greet[16110]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 20:13:07 johlux kscreenlocker_greet[16110]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 20:13:10 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 20:27:59 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 20:27:59 johlux pipewire[1265]: mod.adapter: 0x55ab78dcb7d0: can't get format: Device or resource busy
> aug 30 20:27:59 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:1007 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 20:28:05 johlux kscreenlocker_greet[16110]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 20:28:05 johlux kscreenlocker_greet[16110]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 20:28:05 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26360, resource id: 98566190, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:54:42 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53986, resource id: 98566150, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:54:46 johlux kioslave5[16738]: libpng warning: iCCP: known incorrect sRGB profile
> aug 30 20:54:46 johlux kioslave5[16750]: libpng warning: iCCP: known incorrect sRGB profile
> aug 30 20:54:58 johlux dolphin[16683]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> aug 30 20:54:58 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58915, resource id: 98566175, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:54:58 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58927, resource id: 98566176, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:55:03 johlux dolphin[16683]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
> aug 30 20:55:04 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60512, resource id: 98566179, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:55:09 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62131, resource id: 98566180, major code: 18 (ChangeProperty), minor code: 0
> aug 30 20:55:09 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62135, resource id: 100663304, major code: 18 (ChangeProperty), minor code: 0
> aug 30 21:01:25 johlux kscreenlocker_greet[17001]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 21:01:26 johlux kscreenlocker_greet[17001]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 21:01:26 johlux kscreenlocker_greet[17001]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 21:01:27 johlux kscreenlocker_greet[17001]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 21:01:30 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 21:13:40 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 21:13:40 johlux pipewire[1265]: mod.adapter: 0x55ab78ced180: can't get format: Device or resource busy
> aug 30 21:13:40 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:1046 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 21:13:43 johlux kscreenlocker_greet[17001]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 21:13:43 johlux kscreenlocker_greet[17001]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 21:13:43 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 11635, resource id: 14947031, major code: 143 (DAMAGE), minor code: 2 (Destroy)
> aug 30 21:13:43 johlux kwin_x11[1003]: kwin_core: XCB error: 3 (BadWindow), sequence: 11636, resource id: 98566161, major code: 129 (SHAPE), minor code: 6 (Input)
> aug 30 21:13:43 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11637, resource id: 98566161, major code: 2 (ChangeWindowAttributes), minor code: 0
> aug 30 21:13:43 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11687, resource id: 98566186, major code: 18 (ChangeProperty), minor code: 0
> aug 30 21:13:50 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12848, resource id: 102760623, major code: 18 (ChangeProperty), minor code: 0
> aug 30 21:13:50 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12875, resource id: 33554712, major code: 18 (ChangeProperty), minor code: 0
> aug 30 21:20:42 johlux kscreenlocker_greet[17097]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 21:20:43 johlux kscreenlocker_greet[17097]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 21:20:43 johlux kscreenlocker_greet[17097]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 21:20:43 johlux kscreenlocker_greet[17097]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 21:20:47 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 21:30:39 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 21:30:39 johlux pipewire[1265]: mod.adapter: 0x55ab78ced180: can't get format: Device or resource busy
> aug 30 21:30:39 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:1085 res:-16 (Device or resource busy): can't create node: Device or resource busy
> aug 30 21:30:42 johlux kwin_x11[1003]: kwin_core: XCB error: 152 (BadDamage), sequence: 24584, resource id: 14947828, major code: 143 (DAMAGE), minor code: 2 (Destroy)
> aug 30 21:30:42 johlux kwin_x11[1003]: kwin_core: XCB error: 3 (BadWindow), sequence: 24585, resource id: 98566163, major code: 129 (SHAPE), minor code: 6 (Input)
> aug 30 21:30:42 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24586, resource id: 98566163, major code: 2 (ChangeWindowAttributes), minor code: 0
> aug 30 21:30:42 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24612, resource id: 98566190, major code: 18 (ChangeProperty), minor code: 0
> aug 30 21:43:22 johlux kscreenlocker_greet[17510]: Qt: Session management error: networkIdsList argument is NULL
> aug 30 21:43:23 johlux kscreenlocker_greet[17510]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
> aug 30 21:43:23 johlux kscreenlocker_greet[17510]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
> aug 30 21:43:23 johlux kscreenlocker_greet[17510]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
> aug 30 21:43:27 johlux pipewire-media-session[1266]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
> aug 30 22:13:04 johlux pipewire[1265]: spa.alsa: 'hdmi:1': playback open failed: Device or resource busy
> aug 30 22:13:04 johlux pipewire-media-session[1266]: ms.core: error id:35 seq:1125 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
> aug 30 22:13:07 johlux kscreenlocker_greet[17510]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:15: TypeError: Cannot read property 'width' of null
> aug 30 22:13:07 johlux kscreenlocker_greet[17510]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:33: TypeError: Cannot read property 'height' of null
> aug 30 22:13:07 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58721, resource id: 98566190, major code: 18 (ChangeProperty), minor code: 0
> aug 30 22:24:28 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22646, resource id: 90179524, major code: 15 (QueryTree), minor code: 0
> aug 30 23:32:06 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48358, resource id: 37748742, major code: 15 (QueryTree), minor code: 0
> aug 30 23:32:14 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52005, resource id: 98569348, major code: 15 (QueryTree), minor code: 0
> aug 30 23:33:39 johlux plasmashell[1054]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55a4b76286e0) QQmlContext(0x55a4b56613f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
> aug 30 23:33:39 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
> aug 30 23:33:39 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
> aug 30 23:33:44 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9826, resource id: 33554713, major code: 20 (GetProperty), minor code: 0
> aug 30 23:33:44 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9827, resource id: 33554713, major code: 15 (QueryTree), minor code: 0
> aug 30 23:36:30 johlux plasmashell[1054]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/private/IconLabel.qml:53:9: QML GridLayout: Binding loop detected for property "width"
> aug 30 23:36:30 johlux plasmashell[1054]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
> aug 30 23:44:40 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49589, resource id: 33554727, major code: 18 (ChangeProperty), minor code: 0
> aug 30 23:44:40 johlux plasmashell[1054]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
> aug 30 23:44:40 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49597, resource id: 33554728, major code: 18 (ChangeProperty), minor code: 0
> aug 30 23:44:40 johlux systemsettings[28341]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
> aug 30 23:44:41 johlux systemsettings[28341]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
> aug 30 23:44:41 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50349, resource id: 102760457, major code: 18 (ChangeProperty), minor code: 0
> aug 30 23:44:47 johlux systemsettings[28341]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
> aug 30 23:44:55 johlux kinfocenter[28364]: kf.xmlgui: cannot find .rc file "kinfocenterui.rc" for component "kinfocenter"
> aug 30 23:44:55 johlux kinfocenter[28364]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
> aug 30 23:44:56 johlux kinfocenter[28364]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
> aug 30 23:45:14 johlux kinfocenter[28364]: QLayout::removeWidget: Cannot remove a null widget.
> aug 30 23:45:20 johlux kinfocenter[28364]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
> aug 30 23:45:20 johlux kinfocenter[28364]: file:///usr/lib/qt/qml/org/kde/kinfocenter/private/CommandOutputKCM.qml:20:5: Unable to assign [undefined] to int
> aug 30 23:52:56 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37921, resource id: 33554740, major code: 18 (ChangeProperty), minor code: 0
> aug 30 23:52:57 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38119, resource id: 33554741, major code: 18 (ChangeProperty), minor code: 0
> aug 31 01:08:40 johlux kwin_x11[1003]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63987, resource id: 90177580, major code: 15 (QueryTree), minor code: 0
