Hi there, I know there are two kind of drivers for nvidia. However, when I try to change them with button on the following interface, it still the same.
My laptop has hybrid GPU card (Intel/Nvidia RTX2060)
The first column lists the names of the drivers that are available for your system.
Any driver with a tick in the second (Open-source) column is open source. Those drivers that do not have a tick in the Open-source column are proprietary.
The third column (Installed) indicates if a driver is installed on your system or not.
So, a driver with a tick in the 2nd column but not in the 3rd column is an open source driver that is available for your system but not installed. A driver with no tick in the 2nd column and a tick in the 3rd column is a proprietary driver that is available for your system and installed on your system.
You can also check what drivers are available for your system by running the command:
mhwd -l
(or mhwd -l -d to list available drivers with more detailed info).
Currently installed drivers are listed with the command:
