if that’s the solution, any clue on what to add?
It might be since my file is a lot fuller of settings including 3 highlight colours, but i forgot i have customized the theme a little with the GUI of Kvantum Manager so it seems it put copies of the customized files in the home config folder.
In your case the theme should then be
In order to use kvantum in a gtk-based environment like Xfce, you need to select kvantum as the qt theme in qt6ct. Only then can you specify which kvantum theme to use in the Kvantum Manager.
I presume you mean:
1/ Apperance>style field.
2/ kvantum-dark can be acceptable
Would be worthwhile to mention, that in Kvantum manager itself.
Now, in Kvantum manager, I understand that the tab modifify theme is for all KDE apps, while the tab apps theme is for specific application.
Now, if that’s correct, then whatever theme I chose, no change happens.
Just one thought.
I never bothered (it never bothered me) with having consistent theming when using QT applications in GTK based environments.
I do use Xfce …
The thought:
There is a setting in
xfce4-settings-manager
in “Session and Startup” → the “Advanced” tab on the far right:
“Launch KDE services on startup”
I don’t know if it was disabled/not checked by default, but it is not checked here at the moment.
