Is this normal? I think they are supposed to report the same, but maybe I am just wrong there.
My setup is a multi-boot system using rEFInd
, and I select the kernel using rEFInd
at boot (actually, it is set to boot the latest kernel automatically, but I can manually select a different one).
I have a separate /boot
partition and a separate /boot/efi
partition, but both appear to be properly designated in /etc/fstab
and both boot correctly every time. I note this b/c my searching resulted in a lot of forums stating that the user somehow updated their kernel to the wrong /boot
--> but I only have one.
I did notice that the kernel that shows up in uname -r
(e.g., 5.8.3-2) appears as Running
and Installed
in the Manjaro Settings Manager
. Whereas the kernel that shows up from pacman -Q linux
is always the LTS version that is listed as Installed
(e.g., 5.4.60-2) in MSM.
