When i select wayland and enter password in login screen the screen goes black for a while and then prompts me back to login.
inxi -Gazy output
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s
lanes: 4 link-max: lanes: 8 ports: active: none off: HDMI-A-1
empty: DVI-D-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-2:2 chip-ID: 046d:082b class-ID: 0102
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
output of cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES="nvidia nvidia_modeset nvidia_uvm nvidia_drm"
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
output of cat etc/default/grub
GRUB_DEFAULT="Advanced options for Manjaro Linux>Manjaro Linux (Kernel: 5.10.102-1-MANJARO x64 - fallback initramfs)"
GRUB_TIMEOUT=20
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 nvidia-drm.modeset=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
I have the following packages installed
egl-wayland 2:1.1.9+r3+g582b2d3-1 extra 83.1 kB
kwayland 5.91.0-1 extra 7.6 MB
kwayland-integration 5.24.3-1 extra 154.0 kB
kwayland-server 5.24.3-1 extra 3.4 MB
lib32-wayland 1.20.0-1 multilib 191.8 kB
plasma-wayland-session 5.24.3-1 extra 3.3 kB
qt5-wayland 5.15.3+kde+r40-1 extra 6.4 MB
qt6-wayland 6.2.3-2 extra 6.0 MB
wayland 1.20.0-1 extra 815.2 kB
wayland-protocols 1.25-1 extra 473.9 kB
wayland-utils 1.0.0-2 extra 45.1 kB
xorg-xwayland 22.1.0-1 extra 2.3 MB
