IanQ
4 August 2021 02:17
1
Hello all!
I’m running into an issue where I’m unable to run NPM packages. I’m running
npm i -g express
but when I try to run express
, I’m unable to run it. Running
which node
which npm
I get
/usr/bin/node
/usr/bin/npm
Has anyone run into this before?
EDIT:
I’m running into the same issue with nodemon
which, from what I can tell, should be runnable from the terminal.
npm i -g nodemon
$ nodemon
> zsh: command not found: nodemon
Use a node version manager.
If you choose to use sudo npm install
there is a high probability you will get fileconflict when running pacman -Syu
You Can try nvm . It does not need root permission and can install multiple versions of node.
without a copy of your error, it is difficult to answer … (with “-g”) maybe you forget sudo
ps: exists aur nodejs-express
You problem is how to run express et not to install it?
express is a framework for node dev, not an application doc
Exists also in aur nodejs-express-generator
with this package we have a cli app for generate code source (you find this ?)
IanQ
4 August 2021 18:17
5
I’m not using sudo npm install
? I’m just using the -g
flag
Thank you! I’ll be sure to use it
IanQ
4 August 2021 18:21
6
Gotcha! Yeah, the issue is that there is no error… It’s just when I try to run
$ express
> zsh: command not found: express
When installing another app (I’ve reflected the change in the question)
$ nodemon
is in my prev post : express
not have command “express”, this command is in express-generator
is not a manjaro issue, at you to read the doc
as express, for nodemon : use aur nodejs-nodemon
IanQ
11 August 2021 01:18
8
papajoke:
express-generator
Yeah, I did npm install -g express-generator
and no dice. I’m trying to run express
or express-generator
as is listed in the doc you linked but it’s still telling me that there is no command
Right, sure, I can install via aur
but why can’t I use the npm
installed package? What happens if I stumble on a package that isn’t on AUR? That’s my main concern, not whether I can just install it from npm…
For example, I’m trying to install joi - schema validation , but it’s not in the AUR. Maybe I’m misunderstanding what you’re saying?
