I’ve installed grub-customizer and tried to fix my previous problem. Also I’ve tried to make windows 11 the default choice in grub.
It didn’t work and it did some damage, now I don’t see a menu and it simply boots into manjaro by default.
I’ve tried things like
sudo os-prober
sudo update-grub
I’ve also tried:
sudo pamac reinstall grub
At reboot, I get an error like: sparse file not allowed. Press any key to continue…
I’ve tried this solution with no luck.
What can I do to fix it? I need to occasionally boot into windows.
UPDATE 1: I’ve fix the error, but grub still doen’t appear. I’ve tried this, but still nothing.
UPDATE 2: Grub now appears but windows 11 is not listed.
