Unable to use an external display with NVIDIA Optimus, Dell G3
Hello Manjaro Users and Developers,
I have trouble to use an external monitor on my Del G3 laptop (Optimus). I know that HDMI output is connected to the discrete videocard which is NVIDIA GTX 1050 TI Mobile, so I intend to switch it on. But I can’t. What I have tried in different periods of time during last 1.5 years:
  1. To install and enable prime drivers using MHWD. I have been tried different versions of the driver. The error is the same: error when booting the OS (kernel module can’t be loaded), the “NVIDIA driver is not loaded” message when I try to run nvidia-settings, and inxi -G says that the driver for the NVIDIA card is N/A. This I did the last.
  2. To use bumblebee drivers. Didn’t work 1.5 years ago, doesn’t work now. I wouldn’t like to use this solution if it is possible to avoid using it.
  3. To use optimus-manager. I tried it one year ago. I couldn’t get the result. When I switched to dGPU, the screen became black.
I followed the instructions in the several articles on the forum about the topic and the main instructions (PRIME - ArchWiki, NVIDIA Optimus - ArchWiki, Chapter 32. Offloading Graphics Display with RandR 1.4, https://archived.forum.manjaro.org/t/options-for-nvidia-optimus-graphics/75185).
I will appreciate any help. My settings, configuration, error messages are below.
mhwd -li
Installed PCI configs:
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-455xx-prime 2020.10.04 false PCI
network-r8168 2016.04.20 true PCI
inxi -G
Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: N/A
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.9 driver: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.2
inxi -Fxz
Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.14.3 Distro: Manjaro Linux
Type: Laptop System: Dell product: G3 3779 v: N/A serial:
Mobo: Dell model: 0JGKPC v: A00 serial: UEFI: Dell v: 1.5.1
date: 11/01/2018
ID-1: BAT0 charge: 37.7 Wh condition: 37.7/56.0 Wh (67%)
model: BYD DELL 7FHHV8A status: Full
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 9216 KiB
bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 801 10: 800 11: 801 12: 800
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: N/A bus ID: 01:00.0
bus ID: 1-5:4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.77-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel port: 5000 bus ID: 00:14.3
IF: wlo1 state: up mac:
vendor: Dell driver: r8168 v: 8.048.03-NAPI port: 3000 bus ID: 3b:00.0
IF: enp59s0 state: down mac:
IF-ID-1: br-77b21fd869c6 state: down mac:
IF-ID-2: docker0 state: down mac:
Local Storage: total: 1.03 TiB used: 552.00 GiB (52.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-2: /dev/sdb vendor: SK Hynix model: SC311 SATA 128GB size: 119.24 GiB
ID-1: / size: 65.95 GiB used: 32.33 GiB (49.0%) fs: ext4 dev: /dev/sdb4
ID-2: /home size: 354.66 GiB used: 334.00 GiB (94.2%) fs: ext4
dev: /dev/sda2
ID-1: swap-1 type: partition size: 15.98 GiB used: 0 KiB (0.0%)
dev: /dev/sdb2
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 307 Uptime: 42m Memory: 15.50 GiB used: 2.16 GiB (13.9%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1472 Shell: Bash v: 5.0.18
inxi: 3.1.08
dmesg
[    0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-25
[    0.000000] Linux version 5.4.77-1-MANJARO (builder@dbee9b79dde5) (gcc version 10.2.0 (GCC)) #1 SMP PREEMPT Wed Nov 11 12:25:12 UTC 2020
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=64c125e7-e683-4c7b-bebb-136cd37ce540 rw quiet resume=UUID=b4ab5151-ea2c-44ee-838a-5fd1ce3d5d4f
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000069166fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000069167000-0x0000000069167fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000069168000-0x0000000069168fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000069169000-0x0000000078bf3fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000078bf4000-0x000000007a36bfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007a36c000-0x000000007a3e8fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007a3e9000-0x000000007ad5dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007ad5e000-0x000000007b41afff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007b41b000-0x000000007b4fdfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000007b4fe000-0x000000007b4fefff] usable
[    0.000000] BIOS-e820: [mem 0x000000007b4ff000-0x000000007f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi:  ACPI 2.0=0x7a385000  ACPI=0x7a385000  SMBIOS=0xf0000  SMBIOS 3.0=0xf0020  TPMFinalLog=0x7ac9d000  ESRT=0x7b130118  MEMATTR=0x76a28018
[    0.000000] SMBIOS 3.1.1 present.
[    0.000000] DMI: Dell Inc. G3 3779/0JGKPC, BIOS 1.5.1 11/01/2018
[    0.000000] tsc: Detected 2200.000 MHz processor
[    0.003169] tsc: Detected 2199.996 MHz TSC
[    0.003169] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.003170] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.003175] last_pfn = 0x47e800 max_arch_pfn = 0x400000000
[    0.003201] MTRR default type: write-back
[    0.003202] MTRR fixed ranges enabled:
[    0.003203]   00000-9FFFF write-back
[    0.003203]   A0000-BFFFF uncachable
[    0.003204]   C0000-FFFFF write-protect
[    0.003204] MTRR variable ranges enabled:
[    0.003205]   0 base 0080000000 mask 7F80000000 uncachable
[    0.003206]   1 base 007E000000 mask 7FFE000000 uncachable
[    0.003206]   2 base 007D000000 mask 7FFF000000 uncachable
[    0.003207]   3 disabled
[    0.003207]   4 disabled
[    0.003207]   5 disabled
[    0.003207]   6 disabled
[    0.003208]   7 disabled
[    0.003208]   8 disabled
[    0.003208]   9 disabled
[    0.003526] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.003699] last_pfn = 0x7b4ff max_arch_pfn = 0x400000000
[    0.009078] esrt: Reserving ESRT space from 0x000000007b130118 to 0x000000007b130150.
[    0.009083] check: Scanning 1 areas for low memory corruption
[    0.009086] Using GB pages for direct mapping
[    0.009259] Secure boot could not be determined
[    0.009259] RAMDISK: [mem 0x3658f000-0x372befff]
[    0.009271] ACPI: Early table checksum verification disabled
[    0.009273] ACPI: RSDP 0x000000007A385000 000024 (v02 DELL  )
[    0.009276] ACPI: XSDT 0x000000007A3850B8 0000F4 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.009279] ACPI: FACP 0x000000007A3C70E0 000114 (v06 DELL   CBX3     01072009 AMI  00010013)
[    0.009282] ACPI: DSDT 0x000000007A385240 041E9B (v02 DELL   CBX3     01072009 INTL 20160527)
[    0.009284] ACPI: FACS 0x000000007AD5CC00 000040
[    0.009286] ACPI: APIC 0x000000007A3C71F8 0000F4 (v04 DELL   CBX3     01072009 AMI  00010013)
[    0.009287] ACPI: FPDT 0x000000007A3C72F0 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.009289] ACPI: FIDT 0x000000007A3C7338 00009C (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.009290] ACPI: MCFG 0x000000007A3C73D8 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.009292] ACPI: SSDT 0x000000007A3C7418 000761 (v01 SataRe SataTabl 00001000 INTL 20160527)
[    0.009294] ACPI: SSDT 0x000000007A3C7B80 0017D5 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
[    0.009295] ACPI: BOOT 0x000000007A3C9358 000028 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.009297] ACPI: SSDT 0x000000007A3C9380 001336 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
[    0.009299] ACPI: SSDT 0x000000007A3CA6B8 0025EE (v02 PegSsd PegSsdt  00001000 INTL 20160527)
[    0.009300] ACPI: HPET 0x000000007A3CCCA8 000038 (v01 INTEL  CBX3     00000002      01000013)
[    0.009302] ACPI: SSDT 0x000000007A3CCCE0 002A07 (v02 INTEL  xh_cfhd4 00000000 INTL 20160527)
[    0.009304] ACPI: UEFI 0x000000007A3CF6E8 000048 (v01 DELL\x CBX3     00000002      01000013)
[    0.009305] ACPI: LPIT 0x000000007A3CF730 00005C (v01 INTEL  CBX3     00000002      01000013)
[    0.009307] ACPI: SSDT 0x000000007A3CF790 0027DE (v02 INTEL  PtidDevc 00001000 INTL 20160527)
[    0.009308] ACPI: SSDT 0x000000007A3D1F70 000FFE (v02 INTEL  TbtTypeC 00000000 INTL 20160527)
[    0.009310] ACPI: DBGP 0x000000007A3D2F70 000034 (v01 DELL\x CBX3     00000002      01000013)
[    0.009312] ACPI: DBG2 0x000000007A3D2FA8 000054 (v00 DELL\x CBX3     00000002      01000013)
[    0.009313] ACPI: SSDT 0x000000007A3D3000 0007E8 (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
[    0.009315] ACPI: SSDT 0x000000007A3D37E8 006193 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
[    0.009316] ACPI: SSDT 0x000000007A3D9980 000144 (v02 Intel  ADebTabl 00001000 INTL 20160527)
[    0.009318] ACPI: SSDT 0x000000007A3D9AC8 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160527)
[    0.009320] ACPI: DMAR 0x000000007A3D9B78 0000A8 (v01 INTEL  EDK2     00000002      01000013)
[    0.009321] ACPI: BGRT 0x000000007A3D9C20 000038 (v00                 01072009 AMI  00010013)
[    0.009323] ACPI: TPM2 0x000000007A3D9C58 000034 (v04 DELL\x CBX3     00000001 AMI  00000000)
[    0.009324] ACPI: SSDT 0x000000007A3D9C90 001F98 (v01 OptRef OptTabl  00001000 INTL 20160527)
[    0.009330] ACPI: Local APIC address 0xfee00000
[    0.009583] No NUMA configuration found
[    0.009583] Faking a node at [mem 0x0000000000000000-0x000000047e7fffff]
[    0.009586] NODE_DATA(0) allocated [mem 0x47e7fc000-0x47e7fffff]
[    0.009607] Zone ranges:
[    0.009607]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.009608]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.009609]   Normal   [mem 0x0000000100000000-0x000000047e7fffff]
[    0.009609]   Device   empty
[    0.009610] Movable zone start for each node
[    0.009610] Early memory node ranges
[    0.009611]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.009611]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
[    0.009612]   node   0: [mem 0x0000000000100000-0x0000000069166fff]
[    0.009612]   node   0: [mem 0x0000000069169000-0x0000000078bf3fff]
[    0.009613]   node   0: [mem 0x000000007b4fe000-0x000000007b4fefff]
[    0.009613]   node   0: [mem 0x0000000100000000-0x000000047e7fffff]
[    0.009789] Zeroed struct page in unavailable ranges: 35951 pages
[    0.009790] Initmem setup node 0 [mem 0x0000000000001000-0x000000047e7fffff]
[    0.009791] On node 0 totalpages: 4158353
[    0.009792]   DMA zone: 64 pages used for memmap
[    0.009792]   DMA zone: 23 pages reserved
[    0.009792]   DMA zone: 3998 pages, LIFO batch:0
[    0.009827]   DMA32 zone: 7664 pages used for memmap
[    0.009827]   DMA32 zone: 490483 pages, LIFO batch:63
[    0.016331]   Normal zone: 57248 pages used for memmap
[    0.016331]   Normal zone: 3663872 pages, LIFO batch:63
[    0.046752] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.046779] Reserving Intel graphics memory at [mem 0x7d800000-0x7f7fffff]
[    0.047524] ACPI: PM-Timer IO Port: 0x1808
[    0.047525] ACPI: Local APIC address 0xfee00000
[    0.047529] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.047530] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.047530] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.047531] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.047531] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.047531] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.047532] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.047532] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.047532] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.047533] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.047533] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.047533] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.047596] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.047597] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.047598] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.047599] ACPI: IRQ0 used by override.
[    0.047599] ACPI: IRQ9 used by override.
[    0.047600] Using ACPI (MADT) for SMP configuration information
[    0.047601] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.047605] e820: update [mem 0x743c0000-0x74446fff] usable ==> reserved
[    0.047610] TSC deadline timer available
[    0.047611] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.047623] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.047624] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[    0.047625] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.047626] PM: Registered nosave memory: [mem 0x69167000-0x69167fff]
[    0.047626] PM: Registered nosave memory: [mem 0x69168000-0x69168fff]
[    0.047627] PM: Registered nosave memory: [mem 0x743c0000-0x74446fff]
[    0.047628] PM: Registered nosave memory: [mem 0x78bf4000-0x7a36bfff]
[    0.047628] PM: Registered nosave memory: [mem 0x7a36c000-0x7a3e8fff]
[    0.047629] PM: Registered nosave memory: [mem 0x7a3e9000-0x7ad5dfff]
[    0.047629] PM: Registered nosave memory: [mem 0x7ad5e000-0x7b41afff]
[    0.047629] PM: Registered nosave memory: [mem 0x7b41b000-0x7b4fdfff]
[    0.047630] PM: Registered nosave memory: [mem 0x7b4ff000-0x7f7fffff]
[    0.047631] PM: Registered nosave memory: [mem 0x7f800000-0xefffffff]
[    0.047631] PM: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.047631] PM: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
[    0.047632] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.047632] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.047632] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.047633] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.047633] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.047633] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.047634] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.047635] [mem 0x7f800000-0xefffffff] available for PCI devices
[    0.047635] Booting paravirtualized kernel on bare hardware
[    0.047637] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.112701] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:12 nr_node_ids:1
[    0.112957] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
[    0.112963] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
[    0.112964] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.112980] Built 1 zonelists, mobility grouping on.  Total pages: 4093354
[    0.112980] Policy zone: Normal
[    0.112981] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=64c125e7-e683-4c7b-bebb-136cd37ce540 rw quiet resume=UUID=b4ab5151-ea2c-44ee-838a-5fd1ce3d5d4f
[    0.113600] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.113883] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.113962] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[    0.116242] Calgary: detecting Calgary via BIOS EBDA area
[    0.116243] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.140908] Memory: 16191656K/16633412K available (12291K kernel code, 1330K rwdata, 4096K rodata, 1648K init, 3396K bss, 441756K reserved, 0K cma-reserved)
[    0.140913] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[    0.141021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.141032] Kernel/User page tables isolation: enabled
[    0.141048] ftrace: allocating 37574 entries in 147 pages
[    0.150600] rcu: Preemptible hierarchical RCU implementation.
[    0.150601] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.150602] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=12.
[    0.150602] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.150603] 	Tasks RCU enabled.
[    0.150603] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.150604] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.152317] NR_IRQS: 20736, nr_irqs: 2152, preallocated irqs: 16
[    0.152923] Console: colour dummy device 80x25
[    0.152926] printk: console [tty0] enabled
[    0.152937] ACPI: Core revision 20190816
[    0.153141] APIC: Switch to symmetric I/O mode setup
[    0.153143] DMAR: Host address width 39
[    0.153144] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.153148] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.153149] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.153151] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.153151] DMAR: RMRR base: 0x0000007aedd000 end: 0x0000007b126fff
[    0.153152] DMAR: RMRR base: 0x0000007d000000 end: 0x0000007f7fffff
[    0.153153] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.153154] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.153154] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.156212] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.156213] x2apic enabled
[    0.156244] Switched APIC routing to cluster x2apic.
[    0.165391] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb62f12e8c, max_idle_ns: 440795238402 ns
[    0.165395] Calibrating delay loop (skipped), value calculated using timer frequency.. 4401.32 BogoMIPS (lpj=7333320)
[    0.165396] pid_max: default: 32768 minimum: 301
[    0.167319] LSM: Security Framework initializing
[    0.167321] Yama: becoming mindful.
[    0.167354] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.167372] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.167380] *** VALIDATE tmpfs ***
[    0.167474] *** VALIDATE proc ***
[    0.167506] *** VALIDATE cgroup1 ***
[    0.167506] *** VALIDATE cgroup2 ***
[    0.167555] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.167572] process: using mwait in idle threads
[    0.167574] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.167574] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.167577] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.167578] Spectre V2 : Mitigation: Full generic retpoline
[    0.167578] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.167578] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.167579] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.167580] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.167580] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.167583] SRBDS: Mitigation: Microcode
[    0.167584] MDS: Mitigation: Clear CPU buffers
[    0.167809] Freeing SMP alternatives memory: 32K
[    0.168726] smpboot: CPU0: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.168726] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.168726] ... version:                4
[    0.168726] ... bit width:              48
[    0.168726] ... generic registers:      4
[    0.168726] ... value mask:             0000ffffffffffff
[    0.168726] ... max period:             00007fffffffffff
[    0.168726] ... fixed-purpose events:   3
[    0.168726] ... event mask:             000000070000000f
[    0.168726] rcu: Hierarchical SRCU implementation.
[    0.168726] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.168726] smp: Bringing up secondary CPUs ...
[    0.168726] x86: Booting SMP configuration:
[    0.168726] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.173588] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.173588]   #7  #8  #9 #10 #11
[    0.175797] smp: Brought up 1 node, 12 CPUs
[    0.175797] smpboot: Max logical packages: 1
[    0.175797] smpboot: Total of 12 processors activated (52821.90 BogoMIPS)
[    0.179099] devtmpfs: initialized
[    0.179099] x86/mm: Memory block size: 128MB
[    0.179794] PM: Registering ACPI NVS region [mem 0x69167000-0x69167fff] (4096 bytes)
[    0.179794] PM: Registering ACPI NVS region [mem 0x7a3e9000-0x7ad5dfff] (9916416 bytes)
[    0.179794] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.179794] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.179794] pinctrl core: initialized pinctrl subsystem
[    0.179794] PM: RTC time: 20:31:29, date: 2020-11-21
[    0.179794] NET: Registered protocol family 16
[    0.179794] audit: initializing netlink subsys (disabled)
[    0.179794] audit: type=2000 audit(1605990689.013:1): state=initialized audit_enabled=0 res=1
[    0.179794] cpuidle: using governor ladder
[    0.179794] cpuidle: using governor menu
[    0.179794] Simple Boot Flag at 0x47 set to 0x80
[    0.179794] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.179794] ACPI: bus type PCI registered
[    0.179794] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.179794] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.179794] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.179794] PCI: Using configuration type 1 for base access
[    0.179794] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.182570] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.182570] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.182570] ACPI: Added _OSI(Module Device)
[    0.182570] ACPI: Added _OSI(Processor Device)
[    0.182570] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.182570] ACPI: Added _OSI(Processor Aggregator Device)
[    0.182570] ACPI: Added _OSI(Linux-Dell-Video)
[    0.182570] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.182570] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.246814] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.255602] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.263489] ACPI: Dynamic OEM Table Load:
[    0.263493] ACPI: SSDT 0xFFFF91646BB5D800 0005BE (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.264900] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.265909] ACPI: Dynamic OEM Table Load:
[    0.265913] ACPI: SSDT 0xFFFF91646B08D800 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.267254] ACPI: Dynamic OEM Table Load:
[    0.267257] ACPI: SSDT 0xFFFF91646B22F600 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
[    0.268550] ACPI: Dynamic OEM Table Load:
[    0.268553] ACPI: SSDT 0xFFFF91646BB5F800 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
[    0.270182] ACPI: Dynamic OEM Table Load:
[    0.270186] ACPI: SSDT 0xFFFF91646BBA9000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.272190] ACPI: Dynamic OEM Table Load:
[    0.272193] ACPI: SSDT 0xFFFF91646B08AC00 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    0.273566] ACPI: Dynamic OEM Table Load:
[    0.273568] ACPI: SSDT 0xFFFF91646B08DC00 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.278330] ACPI: EC: EC started
[    0.278330] ACPI: EC: interrupt blocked
[    0.283967] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
[    0.283969] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.283970] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
[    0.283970] ACPI: Interpreter enabled
[    0.284002] ACPI: (supports S0 S3 S4 S5)
[    0.284002] ACPI: Using IOAPIC for interrupt routing
[    0.284033] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.284764] ACPI: Enabled 9 GPEs in block 00 to 7F
[    0.287027] ACPI: Power Resource [PG00] (on)
[    0.335564] ACPI: Power Resource [USBC] (on)
[    0.339464] ACPI: Power Resource [V0PR] (on)
[    0.339937] ACPI: Power Resource [V1PR] (on)
[    0.340402] ACPI: Power Resource [V2PR] (on)
[    0.346225] ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/psparse-529)
[    0.346232] ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/uteval-68)
[    0.347403] ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/psparse-529)
[    0.347409] ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/uteval-68)
[    0.348329] ACPI: Power Resource [WRST] (on)
[    0.356852] ACPI: Power Resource [PIN] (off)
[    0.357227] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[    0.357232] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.357409] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
[    0.357576] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR]
[    0.357577] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.358483] PCI host bridge to bus 0000:00
[    0.358485] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.358486] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.358486] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.358487] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.358488] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.358488] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.358489] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.358489] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.358490] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.358491] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.358491] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.358492] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
[    0.358492] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.358493] pci_bus 0000:00: root bus resource [bus 00-7e]
[    0.358500] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
[    0.358606] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.358639] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.358867] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    0.358874] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
[    0.358878] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[    0.358880] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.358892] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.359008] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.359016] pci 0000:00:04.0: reg 0x10: [mem 0xed310000-0xed317fff 64bit]
[    0.359182] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.359189] pci 0000:00:08.0: reg 0x10: [mem 0xed32c000-0xed32cfff 64bit]
[    0.359389] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.359431] pci 0000:00:12.0: reg 0x10: [mem 0xed32b000-0xed32bfff 64bit]
[    0.359742] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.359785] pci 0000:00:14.0: reg 0x10: [mem 0xed300000-0xed30ffff 64bit]
[    0.359920] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.360299] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.360334] pci 0000:00:14.2: reg 0x10: [mem 0xed322000-0xed323fff 64bit]
[    0.360352] pci 0000:00:14.2: reg 0x18: [mem 0xed32a000-0xed32afff 64bit]
[    0.361133] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    0.362562] pci 0000:00:14.3: reg 0x10: [mem 0xed31c000-0xed31ffff 64bit]
[    0.367531] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.369111] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    0.369842] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.372467] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    0.373198] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.375648] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.375688] pci 0000:00:16.0: reg 0x10: [mem 0xed327000-0xed327fff 64bit]
[    0.375804] pci 0000:00:16.0: PME# supported from D3hot
[    0.376037] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
[    0.376074] pci 0000:00:17.0: reg 0x10: [mem 0xed320000-0xed321fff]
[    0.376088] pci 0000:00:17.0: reg 0x14: [mem 0xed326000-0xed3260ff]
[    0.376102] pci 0000:00:17.0: reg 0x18: [io  0x5090-0x5097]
[    0.376116] pci 0000:00:17.0: reg 0x1c: [io  0x5080-0x5083]
[    0.376130] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
[    0.376145] pci 0000:00:17.0: reg 0x24: [mem 0xed325000-0xed3257ff]
[    0.376225] pci 0000:00:17.0: PME# supported from D3hot
[    0.376450] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[    0.376655] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.376686] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[    0.376950] pci 0000:00:1d.0: [8086:a335] type 01 class 0x060400
[    0.377143] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.377175] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.377439] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    0.377725] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.377804] pci 0000:00:1f.3: reg 0x10: [mem 0xed318000-0xed31bfff 64bit]
[    0.377877] pci 0000:00:1f.3: reg 0x20: [mem 0xed100000-0xed1fffff 64bit]
[    0.378027] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.378688] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.378859] pci 0000:00:1f.4: reg 0x10: [mem 0xed324000-0xed3240ff 64bit]
[    0.379061] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    0.379407] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.379434] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.379655] pci 0000:01:00.0: [10de:1c8c] type 00 class 0x030200
[    0.379680] pci 0000:01:00.0: reg 0x10: [mem 0xec000000-0xecffffff]
[    0.379695] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.379710] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.379720] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.379730] pci 0000:01:00.0: reg 0x30: [mem 0xed000000-0xed07ffff pref]
[    0.379819] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8 GT/s x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[    0.379906] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[    0.379925] pci 0000:01:00.1: reg 0x10: [mem 0xed080000-0xed083fff]
[    0.380094] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.380096] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.380097] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.380099] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.380248] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[    0.380257] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.380265] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.380425] pci 0000:3b:00.0: [10ec:8168] type 00 class 0x020000
[    0.380466] pci 0000:3b:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.380502] pci 0000:3b:00.0: reg 0x18: [mem 0xed204000-0xed204fff 64bit]
[    0.380525] pci 0000:3b:00.0: reg 0x20: [mem 0xed200000-0xed203fff 64bit]
[    0.380670] pci 0000:3b:00.0: supports D1 D2
[    0.380670] pci 0000:3b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.380863] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[    0.380868] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
[    0.380872] pci 0000:00:1d.0:   bridge window [mem 0xed200000-0xed2fffff]
[    0.382381] ACPI: PCI Interrupt Link [LNKA] (IRQs) *0
[    0.382412] ACPI: PCI Interrupt Link [LNKB] (IRQs) *1
[    0.382442] ACPI: PCI Interrupt Link [LNKC] (IRQs) *0
[    0.382471] ACPI: PCI Interrupt Link [LNKD] (IRQs) *0
[    0.382500] ACPI: PCI Interrupt Link [LNKE] (IRQs) *0
[    0.382529] ACPI: PCI Interrupt Link [LNKF] (IRQs) *0
[    0.382558] ACPI: PCI Interrupt Link [LNKG] (IRQs) *0
[    0.382587] ACPI: PCI Interrupt Link [LNKH] (IRQs) *0
[    0.386817] ACPI: EC: interrupt unblocked
[    0.386834] ACPI: EC: event unblocked
[    0.386845] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.386846] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions and events
[    0.386929] iommu: Default domain type: Translated
[    0.386946] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.386946] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.386946] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.386946] vgaarb: loaded
[    0.386946] ACPI: bus type USB registered
[    0.386946] usbcore: registered new interface driver usbfs
[    0.386946] usbcore: registered new interface driver hub
[    0.386946] usbcore: registered new device driver usb
[    0.386946] pps_core: LinuxPPS API ver. 1 registered
[    0.386946] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.386946] PTP clock support registered
[    0.386946] EDAC MC: Ver: 3.0.0
[    0.386946] Registered efivars operations
[    0.386946] PCI: Using ACPI for IRQ routing
[    0.415950] PCI: pci_cache_line_size set to 64 bytes
[    0.416306] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.416307] e820: reserve RAM buffer [mem 0x69167000-0x6bffffff]
[    0.416307] e820: reserve RAM buffer [mem 0x743c0000-0x77ffffff]
[    0.416308] e820: reserve RAM buffer [mem 0x78bf4000-0x7bffffff]
[    0.416309] e820: reserve RAM buffer [mem 0x7b4ff000-0x7bffffff]
[    0.416309] e820: reserve RAM buffer [mem 0x47e800000-0x47fffffff]
[    0.416369] NetLabel: Initializing
[    0.416369] NetLabel:  domain hash size = 128
[    0.416370] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.416378] NetLabel:  unlabeled traffic allowed by default
[    0.416381] clocksource: Switched to clocksource tsc-early
[    0.422398] *** VALIDATE bpf ***
[    0.422439] VFS: Disk quotas dquot_6.6.0
[    0.422449] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.422464] *** VALIDATE ramfs ***
[    0.422466] *** VALIDATE hugetlbfs ***
[    0.422494] pnp: PnP ACPI init
[    0.422695] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.422696] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.422700] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.422713] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.422794] system 00:02: [io  0x1854-0x1857] has been reserved
[    0.422796] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.422875] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.422887] pnp 00:04: Plug and Play ACPI device, IDs DLL0870 PNP0f13 (active)
[    0.423042] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.423043] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.423044] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.423045] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.423045] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.423046] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.423047] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.423048] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.423050] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.423243] system 00:06: [io  0x1800-0x18fe] could not be reserved
[    0.423244] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.423245] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    0.423246] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.423247] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.423247] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.423248] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.423250] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.423507] system 00:07: [io  0x2000-0x20fe] has been reserved
[    0.423509] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.424452] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.430434] pnp: PnP ACPI: found 9 devices
[    0.431734] thermal_sys: Registered thermal governor 'fair_share'
[    0.431735] thermal_sys: Registered thermal governor 'bang_bang'
[    0.431740] thermal_sys: Registered thermal governor 'step_wise'
[    0.431741] thermal_sys: Registered thermal governor 'user_space'
[    0.431742] thermal_sys: Registered thermal governor 'power_allocator'
[    0.436277] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.436305] pci 0000:00:1b.0: bridge window [io  0x1000-0x0fff] to [bus 02-3a] add_size 1000
[    0.436318] pci 0000:00:15.0: BAR 0: assigned [mem 0x7f800000-0x7f800fff 64bit]
[    0.436593] pci 0000:00:15.1: BAR 0: assigned [mem 0x7f801000-0x7f801fff 64bit]
[    0.436861] pci 0000:00:1b.0: BAR 13: assigned [io  0x6000-0x6fff]
[    0.436863] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.436865] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.436867] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
[    0.436869] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.436872] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
[    0.436880] pci 0000:00:1b.0:   bridge window [io  0x6000-0x6fff]
[    0.436886] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
[    0.436891] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.436900] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[    0.436903] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
[    0.436910] pci 0000:00:1d.0:   bridge window [mem 0xed200000-0xed2fffff]
[    0.436924] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.436925] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.436926] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.436927] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.436928] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.436929] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.436930] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.436931] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.436932] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.436933] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.436934] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.436935] pci_bus 0000:00: resource 15 [mem 0x7f800000-0xefffffff window]
[    0.436936] pci_bus 0000:00: resource 16 [mem 0xfc800000-0xfe7fffff window]
[    0.436937] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.436938] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
[    0.436939] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.436940] pci_bus 0000:02: resource 0 [io  0x6000-0x6fff]
[    0.436941] pci_bus 0000:02: resource 1 [mem 0xd4000000-0xea0fffff]
[    0.436942] pci_bus 0000:02: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
[    0.436943] pci_bus 0000:3b: resource 0 [io  0x3000-0x3fff]
[    0.436943] pci_bus 0000:3b: resource 1 [mem 0xed200000-0xed2fffff]
[    0.437143] NET: Registered protocol family 2
[    0.437264] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.437339] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.437506] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.437573] TCP: Hash tables configured (established 131072 bind 65536)
[    0.437620] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.437661] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.437751] NET: Registered protocol family 1
[    0.437755] NET: Registered protocol family 44
[    0.437766] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.438262] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.438317] PCI: CLS 64 bytes, default 64
[    0.438345] Trying to unpack rootfs image as initramfs...
[    0.543747] Freeing initrd memory: 13504K
[    0.562096] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.562101] software IO TLB: mapped [mem 0x703c0000-0x743c0000] (64MB)
[    0.562324] check: Scanning for low memory corruption every 60 seconds
[    0.562739] Initialise system trusted keyrings
[    0.562751] Key type blacklist registered
[    0.562793] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.563964] zbud: loaded
[    0.567216] Key type asymmetric registered
[    0.567218] Asymmetric key parser 'x509' registered
[    0.567223] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.567264] io scheduler mq-deadline registered
[    0.567264] io scheduler kyber registered
[    0.567289] io scheduler bfq registered
[    0.572123] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.572191] efifb: probing for efifb
[    0.572204] efifb: showing boot graphics
[    0.573072] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[    0.573073] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.573073] efifb: scrolling: redraw
[    0.573074] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.573104] fbcon: Deferring console take-over
[    0.573105] fb0: EFI VGA frame buffer device
[    0.573111] intel_idle: MWAIT substates: 0x11142120
[    0.573111] intel_idle: v0.4.1 model 0x9E
[    0.573676] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.573754] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.575479] ACPI: Lid Switch [LID0]
[    0.575508] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.575564] ACPI: Power Button [PBTN]
[    0.575590] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    0.575601] ACPI: Sleep Button [SBTN]
[    0.575630] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.578815] ACPI: Power Button [PWRF]
[    0.582050] thermal LNXTHERM:00: registered as thermal_zone0
[    0.582051] ACPI: Thermal Zone [THM] (25 C)
[    0.582276] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.582988] hpet_acpi_add: no address or irqs in _CRS
[    0.583010] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.583011] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.584104] usbcore: registered new interface driver usbserial_generic
[    0.584106] usbserial: USB Serial support registered for generic
[    0.584129] rtc_cmos 00:01: RTC can wake from S4
[    0.585201] rtc_cmos 00:01: registered as rtc0
[    0.585209] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[    0.585243] intel_pstate: Intel P-state driver initializing
[    0.585285] intel_pstate: Disabling energy efficiency optimization
[    0.586115] intel_pstate: HWP enabled
[    0.586660] ledtrig-cpu: registered to indicate activity on CPUs
[    0.586715] intel_pmc_core INT33A1:00:  initialized
[    0.586757] drop_monitor: Initializing network drop monitor service
[    0.586929] NET: Registered protocol family 10
[    0.590731] Segment Routing with IPv6
[    0.590744] NET: Registered protocol family 17
[    0.591685] RAS: Correctable Errors collector initialized.
[    0.591738] microcode: sig=0x906ea, pf=0x20, revision=0xde
[    0.592058] microcode: Microcode Update Driver: v2.2.
[    0.592064] IPI shorthand broadcast: enabled
[    0.592069] sched_clock: Marking stable (579421136, 12640084)->(603371475, -11310255)
[    0.592340] registered taskstats version 1
[    0.592344] Loading compiled-in X.509 certificates
[    0.594201] Loaded X.509 cert 'Build time autogenerated kernel key: 48555b30a6394738c2a2997f562c395b7d8a5e48'
[    0.594230] zswap: loaded using pool lzo/zbud
[    0.594440] Key type ._fscrypt registered
[    0.594440] Key type .fscrypt registered
[    0.597822] Key type big_key registered
[    0.599629] PM:   Magic number: 12:210:549
[    0.599638] clockevents clockevent0: hash matches
[    0.599655] acpi PNP0C0F:00: hash matches
[    0.599990] rtc_cmos 00:01: setting system clock to 2020-11-21T20:31:30 UTC (1605990690)
[    0.600963] Freeing unused decrypted memory: 2040K
[    0.601252] Freeing unused kernel image memory: 1648K
[    0.628942] Write protecting the kernel read-only data: 18432k
[    0.629534] Freeing unused kernel image memory: 2008K
[    0.637821] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.637822] x86/mm: Checking user space page tables
[    0.644333] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.644334] Run /init as init process
[    0.814306] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.814828] i8042: Warning: Keylock active
[    0.816338] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.816377] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.822588] SCSI subsystem initialized
[    0.824750] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.824755] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.825904] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    0.825912] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.826147] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.826148] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.826149] usb usb1: Product: xHCI Host Controller
[    0.826151] usb usb1: Manufacturer: Linux 5.4.77-1-MANJARO xhci-hcd
[    0.826152] usb usb1: SerialNumber: 0000:00:14.0
[    0.826261] hub 1-0:1.0: USB hub found
[    0.826297] hub 1-0:1.0: 16 ports detected
[    0.826876] libata version 3.00 loaded.
[    0.828679] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.828683] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.828687] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.828746] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.828748] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.828749] usb usb2: Product: xHCI Host Controller
[    0.828750] usb usb2: Manufacturer: Linux 5.4.77-1-MANJARO xhci-hcd
[    0.828751] usb usb2: SerialNumber: 0000:00:14.0
[    0.828856] hub 2-0:1.0: USB hub found
[    0.828874] hub 2-0:1.0: 8 ports detected
[    0.828875] ahci 0000:00:17.0: version 3.0
[    0.829171] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[    0.829207] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    0.829208] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
[    0.832581] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    0.838918] scsi host0: ahci
[    0.838993] scsi host1: ahci
[    0.839038] ata1: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325100 irq 126
[    0.839040] ata2: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325180 irq 126
[    1.155546] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    1.155573] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.168506] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.168512] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.168517] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.168724] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.205978] ata1.00: ATA-10: ST1000LM035-1RK172, SDM3, max UDMA/133
[    1.205983] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.231019] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.231026] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.231030] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.231312] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.268506] ata1.00: configured for UDMA/133
[    1.269963] scsi 0:0:0:0: Direct-Access     ATA      ST1000LM035-1RK1 SDM3 PQ: 0 ANSI: 5
[    1.299970] usb 1-1: New USB device found, idVendor=056a, idProduct=030e, bcdDevice= 1.00
[    1.299975] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.299978] usb 1-1: Product: Intuos PS
[    1.299981] usb 1-1: Manufacturer: Wacom Co.,Ltd.
[    1.309966] hidraw: raw HID events driver (C) Jiri Kosina
[    1.317218] usbcore: registered new interface driver usbhid
[    1.317218] usbhid: USB HID core driver
[    1.318676] hid-generic 0003:056A:030E.0001: hiddev0,hidraw0: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input0
[    1.318768] hid-generic 0003:056A:030E.0002: hiddev1,hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input1
[    1.318834] input: Wacom Co.,Ltd. Intuos PS as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:056A:030E.0003/input/input6
[    1.318860] hid-generic 0003:056A:030E.0003: input,hidraw2: USB HID v1.10 Mouse [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input2
[    1.425472] usb 1-3: new low-speed USB device number 3 using xhci_hcd
[    1.571120] usb 1-3: New USB device found, idVendor=0461, idProduct=0010, bcdDevice= 1.04
[    1.571125] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.571129] usb 1-3: Product: USB Keyboard
[    1.571131] usb 1-3: Manufacturer: NOVATEK
[    1.576265] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0461:0010.0004/input/input7
[    1.578828] tsc: Refined TSC clocksource calibration: 2208.004 MHz
[    1.578846] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fd3bc108c2, max_idle_ns: 440795311349 ns
[    1.578940] clocksource: Switched to clocksource tsc
[    1.582870] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.586855] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.586861] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.586865] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.587034] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.587803] ata2.00: ATA-10: SK hynix SC311 SATA 128GB, 70000P10, max UDMA/133
[    1.587808] ata2.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.591250] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.591256] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.591260] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.591428] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[    1.592644] ata2.00: configured for UDMA/133
[    1.594205] scsi 1:0:0:0: Direct-Access     ATA      SK hynix SC311 S 0P10 PQ: 0 ANSI: 5
[    1.604013] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.604018] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.604057] sd 1:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    1.604063] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    1.604070] sd 0:0:0:0: [sda] Write Protect is off
[    1.604076] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.604105] sd 1:0:0:0: [sdb] Write Protect is off
[    1.604110] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.604159] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.604216] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.622185]  sdb: sdb1 sdb2 sdb3 sdb4
[    1.623495] sd 1:0:0:0: [sdb] Attached SCSI disk
[    1.632357] hid-generic 0003:0461:0010.0004: input,hidraw3: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:14.0-3/input0
[    1.636963] input: NOVATEK USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0461:0010.0005/input/input8
[    1.681721]  sda: sda1 sda2 sda3
[    1.683031] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.692139] input: NOVATEK USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0461:0010.0005/input/input9
[    1.692227] hid-generic 0003:0461:0010.0005: input,hidraw4: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:14.0-3/input1
[    1.747536] random: fast init done
[    1.815503] usb 1-5: new high-speed USB device number 4 using xhci_hcd
[    1.971394] usb 1-5: New USB device found, idVendor=0c45, idProduct=6a06, bcdDevice=64.26
[    1.971400] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    1.971403] usb 1-5: Product: Integrated_Webcam_HD
[    1.971407] usb 1-5: Manufacturer: CNFFH37O034400223E02
[    2.095491] usb 1-6: new high-speed USB device number 5 using xhci_hcd
[    2.236255] usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    2.236260] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.236264] usb 1-6: Product: USB2.0-CRW
[    2.236267] usb 1-6: Manufacturer: Generic
[    2.236269] usb 1-6: SerialNumber: 20100201396000000
[    2.246577] usbcore: registered new interface driver rtsx_usb
[    2.362168] usb 1-14: new full-speed USB device number 6 using xhci_hcd
[    2.507005] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    2.507011] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.518549] PM: Image not found (code -22)
[    2.561934] EXT4-fs (sdb4): mounted filesystem with ordered data mode. Opts: (null)
[    2.814400] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    2.828981] systemd[1]: Detected architecture x86-64.
[    2.861696] systemd[1]: Set hostname to <lmalaptop>.
[    3.249846] systemd[1]: Queued start job for default target Graphical Interface.
[    3.251997] systemd[1]: Created slice system-getty.slice.
[    3.252489] systemd[1]: Created slice system-modprobe.slice.
[    3.252951] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.253430] systemd[1]: Created slice User and Session Slice.
[    3.253526] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.253605] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.253964] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.254025] systemd[1]: Reached target Local Encrypted Volumes.
[    3.254044] systemd[1]: Reached target Login Prompts.
[    3.254087] systemd[1]: Reached target Remote File Systems.
[    3.254104] systemd[1]: Reached target Slices.
[    3.254134] systemd[1]: Reached target System Time Set.
[    3.254161] systemd[1]: Reached target System Time Synchronized.
[    3.254277] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.254824] systemd[1]: Listening on LVM2 metadata daemon socket.
[    3.254931] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.257223] systemd[1]: Listening on Process Core Dump Socket.
[    3.257396] systemd[1]: Listening on Journal Audit Socket.
[    3.257507] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.257636] systemd[1]: Listening on Journal Socket.
[    3.259070] systemd[1]: Listening on udev Control Socket.
[    3.259190] systemd[1]: Listening on udev Kernel Socket.
[    3.260280] systemd[1]: Mounting Huge Pages File System...
[    3.261382] systemd[1]: Mounting POSIX Message Queue File System...
[    3.262439] systemd[1]: Mounting Kernel Debug File System...
[    3.263381] systemd[1]: Mounting Kernel Trace File System...
[    3.264546] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.265915] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    3.266769] systemd[1]: Starting Load Kernel Module drm...
[    3.267279] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.267324] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    3.269010] systemd[1]: Starting Journal Service...
[    3.271148] systemd[1]: Starting Load Kernel Modules...
[    3.271911] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.271973] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    3.272688] systemd[1]: Starting Coldplug All udev Devices...
[    3.273779] systemd[1]: Mounted Huge Pages File System.
[    3.273876] systemd[1]: Mounted POSIX Message Queue File System.
[    3.273961] systemd[1]: Mounted Kernel Debug File System.
[    3.274040] systemd[1]: Mounted Kernel Trace File System.
[    3.274500] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.274727] systemd[1]: modprobe@drm.service: Succeeded.
[    3.274994] systemd[1]: Finished Load Kernel Module drm.
[    3.279058] EXT4-fs (sdb4): re-mounted. Opts: discard
[    3.279993] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.280068] acpi_call: loading out-of-tree module taints kernel.
[    3.280080] acpi_call: module verification failed: signature and/or required key missing - tainting kernel
[    3.280104] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    3.281979] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    3.282579] systemd[1]: Starting Load/Save Random Seed...
[    3.282624] systemd[1]: Condition check resulted in Create System Users being skipped.
[    3.283171] random: lvm: uninitialized urandom read (4 bytes read)
[    3.283344] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.288886] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.288909] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    3.299453] *** VALIDATE vboxsf ***
[    3.305716] systemd[1]: Finished Create Static Device Nodes in /dev.
[    3.306828] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    3.314058] vboxdrv: Found 12 processor cores
[    3.330098] systemd[1]: Finished Coldplug All udev Devices.
[    3.335710] vboxdrv: TSC mode is Invariant, tentative frequency 2207996586 Hz
[    3.335711] vboxdrv: Successfully loaded version 6.1.16 (interface 0x00300000)
[    3.336875] VBoxNetAdp: Successfully started.
[    3.338582] VBoxNetFlt: Successfully started.
[    3.353488] Linux agpgart interface v0.103
[    3.404314] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[    3.404382] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
[    3.404717] systemd[1]: Failed to start Load Kernel Modules.
[    3.404736] fbcon: Taking over console
[    3.404903] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    3.405526] systemd[1]: Mounting Kernel Configuration File System...
[    3.405848] Console: switching to colour frame buffer device 240x67
[    3.406186] systemd[1]: Starting Apply Kernel Variables...
[    3.407296] systemd[1]: Mounted Kernel Configuration File System.
[    3.412436] systemd[1]: Finished Apply Kernel Variables.
[    3.415717] systemd[1]: Starting CLI Netfilter Manager...
[    3.424365] systemd[1]: Finished CLI Netfilter Manager.
[    3.516250] systemd[1]: Started Journal Service.
[    3.516337] audit: type=1130 audit(1605990693.412:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.687319] audit: type=1130 audit(1605990693.582:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.691166] audit: type=1130 audit(1605990693.585:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.736162] ACPI: AC Adapter [AC] (on-line)
[    3.746838] input: Intel HID events as /devices/platform/INT33D5:00/input/input10
[    3.746937] intel-hid INT33D5:00: platform supports 5 button array
[    3.746971] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input11
[    3.748525] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
[    3.799728] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    3.803156] audit: type=1130 audit(1605990693.699:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.808768] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    3.811490] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    3.813448] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    3.835101] random: mktemp: uninitialized urandom read (6 bytes read)
[    3.852617] intel_rapl_common: Found RAPL domain package
[    3.852618] intel_rapl_common: Found RAPL domain dram
[    3.853270] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[    3.935768] battery: ACPI: Battery Slot [BAT0] (battery present)
[    3.940423] r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
[    3.951497] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.954070] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.955719] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    3.957741] r8168  Copyright (C) 2020  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    4.005825] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    4.006054] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    4.072560] i2c_hid i2c-DELL0870:00: i2c-DELL0870:00 supply vdd not found, using dummy regulator
[    4.072580] i2c_hid i2c-DELL0870:00: i2c-DELL0870:00 supply vddl not found, using dummy regulator
[    4.209989] random: crng init done
[    4.222780] input: DELL0870:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input12
[    4.222826] input: DELL0870:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input13
[    4.222857] hid-generic 0018:06CB:7E92.0006: input,hidraw5: I2C HID v1.00 Mouse [DELL0870:00 06CB:7E92] on i2c-DELL0870:00
[    4.925502] Adding 16756732k swap on /dev/sdb2.  Priority:-2 extents:1 across:16756732k SSDscFS
[    4.935103] input: PC Speaker as /devices/platform/pcspkr/input/input15
[    4.993645] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[    4.995669] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    4.995786] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    5.069800] Setting dangerous option enable_fbc - tainting kernel
[    5.071561] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[    5.071562] fb0: switching to inteldrmfb from EFI VGA
[    5.071603] Console: switching to colour dummy device 80x25
[    5.071626] i915 0000:00:02.0: vgaarb: deactivate vga console
[    5.077983] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.077984] [drm] Driver supports precise vblank timestamp query.
[    5.128929] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    5.140220] Intel(R) Wireless WiFi driver for Linux
[    5.140221] Copyright(c) 2003- 2015 Intel Corporation
[    5.140273] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    5.161242] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[    5.170442] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    5.170689] audit: type=1130 audit(1605990695.065:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.170895] r8168 0000:3b:00.0 enp59s0: renamed from eth0
[    5.176554] iwlwifi 0000:00:14.3: loaded firmware version 46.4d093a30.0 op_mode iwlmvm
[    5.202814] intel_rapl_common: Found RAPL domain package
[    5.202815] intel_rapl_common: Found RAPL domain core
[    5.202816] intel_rapl_common: Found RAPL domain uncore
[    5.202817] intel_rapl_common: Found RAPL domain dram
[    5.203164] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input17
[    5.214487] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    5.247642] input: DELL0870:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input18
[    5.247726] input: DELL0870:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input19
[    5.247772] hid-multitouch 0018:06CB:7E92.0006: input,hidraw5: I2C HID v1.00 Mouse [DELL0870:00 06CB:7E92] on i2c-DELL0870:00
[    5.259620] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    5.259621] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    5.259621] RAPL PMU: hw unit of domain package 2^-14 Joules
[    5.259622] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    5.259622] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    5.259623] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    5.269913] cryptd: max_cpu_qlen set to 1000
[    5.269991] mousedev: PS/2 mouse device common for all mice
[    5.458075] AVX2 version of gcm_enc/dec engaged.
[    5.458075] AES CTR mode by8 optimization enabled
[    5.468665] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    5.473479] audit: type=1130 audit(1605990695.369:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.484492] iTCO_vendor_support: vendor-support=0
[    5.487787] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9462, REV=0x318
[    5.491885] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    5.492239] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    5.492464] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    5.511930] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input21
[    5.512360] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[    5.512394] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input22
[    5.512655] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.538086] iwlwifi 0000:00:14.3: base HW address: f4:d1:08:b2:95:99
[    5.546973] fbcon: i915drmfb (fb0) is primary device
[    5.581746] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    5.582137] thermal thermal_zone7: failed to read out thermal zone (-61)
[    5.584445] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[    5.591819] audit: type=1130 audit(1605990695.485:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.619303] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    5.619305] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.619305] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    5.619306] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.619306] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.619307] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[    5.619308] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
[    5.619308] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    5.675300] audit: type=1130 audit(1605990695.569:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:dell::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.686338] audit: type=1130 audit(1605990695.582:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fb415fd3\x2d88b9\x2d49a9\x2db3f4\x2d35f109dbf56e comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.762625] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    5.899129] audit: type=1130 audit(1605990695.795:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-faa2a134\x2d1d9d\x2d4dc3\x2d98ac\x2d14425269465b comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.102682] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    6.228748] audit: type=1130 audit(1605990696.122:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.234625] audit: type=1127 audit(1605990696.129:13): pid=790 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    6.236782] audit: type=1130 audit(1605990696.132:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.240227] audit: type=1130 audit(1605990696.135:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.241901] audit: type=1130 audit(1605990696.135:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.313402] mc: Linux media interface: v0.10
[    6.313745] input: Wacom Intuos S Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:056A:030E.0001/input/input24
[    6.313835] wacom 0003:056A:030E.0001: hidraw0: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input0
[    6.313994] input: Wacom Intuos S Pad as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:056A:030E.0002/input/input29
[    6.314116] wacom 0003:056A:030E.0002: hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input1
[    6.332656] videodev: Linux video capture interface: v2.00
[    6.368921] Bluetooth: Core ver 2.22
[    6.368935] NET: Registered protocol family 31
[    6.368936] Bluetooth: HCI device and connection manager initialized
[    6.368939] Bluetooth: HCI socket layer initialized
[    6.368941] Bluetooth: L2CAP socket layer initialized
[    6.368943] Bluetooth: SCO socket layer initialized
[    6.379000] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    6.379049] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[    6.379096] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[    6.379135] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[    6.379180] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[    6.379223] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input34
[    6.379264] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input35
[    6.492402] usbcore: registered new interface driver btusb
[    6.492869] Bluetooth: hci0: Firmware revision 0.1 build 241 week 36 2020
[    6.500067] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6a06)
[    6.507940] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input36
[    6.508028] usbcore: registered new interface driver uvcvideo
[    6.508029] USB Video Class driver (1.1.1)
[    6.521681] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    6.521682] Bluetooth: BNEP filters: protocol multicast
[    6.521686] Bluetooth: BNEP socket layer initialized
[    6.561405] NET: Registered protocol family 38
[    6.578765] aufs 5.4-20200622
[    6.662958] Console: switching to colour frame buffer device 240x67
[    6.690609] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[    6.702180] enp59s0: 0xffffb5b3c0295000, 3c:2c:30:eb:05:d3, IRQ 128
[    7.208462] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[    7.218383] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[    7.426607] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
[    7.436684] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[   10.233255] fuse: init (API version 7.31)
[   10.233275] *** VALIDATE fuse ***
[   10.233278] *** VALIDATE fuse ***
[   11.508197] kauditd_printk_skb: 22 callbacks suppressed
[   11.508200] audit: type=1131 audit(1605990701.402:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.998074] audit: type=1130 audit(1605990702.892:40): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.086262] audit: type=1130 audit(1605990702.982:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.630419] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   13.632482] Bridge firewalling registered
[   13.655241] audit: type=1325 audit(1605990703.549:42): table=nat family=2 entries=0
[   13.659561] audit: type=1325 audit(1605990703.555:43): table=filter family=2 entries=0
[   13.673753] audit: type=1325 audit(1605990703.569:44): table=nat family=2 entries=5
[   13.674885] audit: type=1325 audit(1605990703.569:45): table=filter family=2 entries=4
[   13.676053] audit: type=1325 audit(1605990703.572:46): table=filter family=2 entries=6
[   13.677232] audit: type=1325 audit(1605990703.572:47): table=filter family=2 entries=8
[   13.678555] audit: type=1325 audit(1605990703.572:48): table=filter family=2 entries=10
[   13.689430] Initializing XFRM netlink socket
[   16.509180] kauditd_printk_skb: 53 callbacks suppressed
[   16.509181] audit: type=1101 audit(1605990706.405:102): pid=1351 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.509194] audit: type=1103 audit(1605990706.405:103): pid=1351 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="human" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   16.509232] audit: type=1006 audit(1605990706.405:104): pid=1351 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   16.509939] audit: type=1105 audit(1605990706.405:105): pid=1351 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="human" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.850063] audit: type=1130 audit(1605990706.745:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.880142] audit: type=1105 audit(1605990706.775:107): pid=1000 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[   16.923925] audit: type=1112 audit(1605990706.819:108): pid=1000 uid=0 auid=1000 ses=2 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
[   17.016740] audit: type=1131 audit(1605990706.912:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   18.876682] audit: type=1130 audit(1605990708.772:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.263779] Bluetooth: RFCOMM TTY layer initialized
[   19.263783] Bluetooth: RFCOMM socket layer initialized
[   19.263786] Bluetooth: RFCOMM ver 1.11
[   20.251491] audit: type=1130 audit(1605990710.145:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.118640] wlo1: authenticate with d4:60:e3:5a:e3:11
[   23.127154] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
[   23.150664] wlo1: authenticated
[   23.151952] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
[   23.153737] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=1)
[   23.154999] wlo1: associated
[   23.190973] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[   23.208911] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by d4:60:e3:5a:e3:11
[   25.220046] kauditd_printk_skb: 3 callbacks suppressed
[   25.220048] audit: type=1130 audit(1605990715.115:115): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.753138] audit: type=1131 audit(1605990716.649:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.761324] audit: type=1131 audit(1605990716.655:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.024034] audit: type=1131 audit(1605990724.919:118): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   36.638391] audit: type=1131 audit(1605990726.532:119): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   50.798355] audit: type=1131 audit(1605990740.696:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  793.241943] audit: type=1130 audit(1605991482.912:121): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  823.275162] audit: type=1131 audit(1605991512.948:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  947.105240] audit: type=1130 audit(1605991636.784:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  947.105249] audit: type=1131 audit(1605991636.784:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1706.967908] audit: type=1100 audit(1605992396.679:125): pid=3397 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1706.968643] audit: type=1101 audit(1605992396.679:126): pid=3397 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1706.968814] audit: type=1110 audit(1605992396.679:127): pid=3397 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1706.970179] audit: type=1105 audit(1605992396.679:128): pid=3397 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
ls -l /etc/X11/xorg.conf.d/
total 12
-rw-r–r-- 1 root root 00-keyboard.conf
-rw-r–r-- 1 root root 10-intel-nvidia-drm-outputclass.conf
lrwxrwxrwx 1 root root 90-mhwd.conf → /etc/X11/mhwd.d/nvidia.conf
-rw-r–r-- 1 root root 99-intel.conf.bak
cat /etc/X11/xorg.conf.d/10-intel-nvidia-drm-outputclass.conf
Section “OutputClass”
Identifier “intel”
MatchDriver “i915”
Driver “modesetting”
EndSection
Identifier “nvidia”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
Option “PrimaryGPU” “yes”
ModulePath “/usr/lib/nvidia/xorg”
ModulePath “/usr/lib/xorg/modules”
EndSection
lsmod
Module Size Used by
ccm 20480 3
rfcomm 90112 16
xt_conntrack 16384 2
xt_MASQUERADE 20480 2
nf_conntrack_netlink 57344 0
nfnetlink 16384 2 nf_conntrack_netlink
xfrm_user 45056 1
xfrm_algo 16384 1 xfrm_user
xt_addrtype 16384 2
iptable_filter 16384 1
iptable_nat 16384 1
nf_nat 49152 2 iptable_nat,xt_MASQUERADE
nf_conntrack 163840 4 xt_conntrack,nf_nat,nf_conntrack_netlink,xt_MASQUERADE
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
libcrc32c 16384 2 nf_conntrack,nf_nat
br_netfilter 32768 0
bridge 217088 1 br_netfilter
stp 16384 1 bridge
llc 16384 2 bridge,stp
fuse 135168 3
aufs 315392 0
cmac 16384 2
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 28672 6 algif_hash,algif_skcipher
bnep 28672 2
rtsx_usb_ms 24576 0
memstick 20480 1 rtsx_usb_ms
uvcvideo 114688 0
btusb 65536 0
btrtl 24576 1 btusb
btbcm 16384 1 btusb
videobuf2_vmalloc 20480 1 uvcvideo
btintel 28672 1 btusb
videobuf2_memops 20480 1 videobuf2_vmalloc
snd_hda_codec_hdmi 73728 1
videobuf2_v4l2 28672 1 uvcvideo
bluetooth 692224 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
videobuf2_common 57344 2 videobuf2_v4l2,uvcvideo
overlay 135168 0
videodev 249856 3 videobuf2_v4l2,uvcvideo,videobuf2_common
ecdh_generic 16384 1 bluetooth
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
wacom 126976 0
ecc 32768 1 ecdh_generic
snd_sof_pci 20480 0
snd_sof_intel_byt 20480 1 snd_sof_pci
snd_sof_intel_ipc 20480 1 snd_sof_intel_byt
snd_sof_xtensa_dsp 16384 1 snd_sof_pci
snd_sof_intel_hda_common 73728 1 snd_sof_pci
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common
x86_pkg_temp_thermal 20480 0
snd_sof 122880 4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc
intel_powerclamp 20480 0
coretemp 20480 0
kvm_intel 323584 0
snd_hda_codec_realtek 143360 1
snd_soc_skl 180224 0
snd_hda_codec_generic 94208 1 snd_hda_codec_realtek
kvm 802816 1 kvm_intel
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_soc_sst_dsp 40960 1 snd_soc_skl
snd_hda_ext_core 32768 4 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
snd_soc_acpi_intel_match 32768 3 snd_sof_pci,snd_sof_intel_hda_common,snd_soc_skl
snd_soc_acpi 16384 3 snd_sof_pci,snd_soc_acpi_intel_match,snd_soc_skl
irqbypass 16384 1 kvm
crct10dif_pclmul 16384 1
iTCO_wdt 16384 0
crc32_pclmul 16384 0
iTCO_vendor_support 16384 1 iTCO_wdt
ghash_clmulni_intel 16384 0
iwlmvm 450560 0
snd_soc_core 290816 4 snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl
aesni_intel 372736 5
joydev 28672 0
crypto_simd 16384 1 aesni_intel
mousedev 24576 0
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
glue_helper 16384 1 aesni_intel
snd_compress 28672 1 snd_soc_core
rapl 16384 0
mac80211 995328 1 iwlmvm
ac97_bus 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_hda_intel 53248 3
snd_intel_nhlt 20480 3 snd_hda_intel,snd_sof_intel_hda_common,snd_soc_skl
dell_laptop 28672 0
libarc4 16384 1 mac80211
hid_multitouch 32768 0
ledtrig_audio 16384 3 snd_hda_codec_generic,snd_hda_codec_realtek,dell_laptop
mei_hdcp 24576 0
intel_rapl_msr 20480 0
dell_wmi 20480 0
intel_cstate 16384 0
snd_hda_codec 159744 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
intel_uncore 147456 0
iwlwifi 380928 1 iwlmvm
dell_smbios 32768 2 dell_wmi,dell_laptop
wmi_bmof 16384 0
intel_wmi_thunderbolt 20480 0
mxm_wmi 16384 0
psmouse 184320 0
snd_hda_core 102400 10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
dell_wmi_descriptor 20480 2 dell_wmi,dell_smbios
i915 2396160 22
i2c_i801 36864 0
dcdbas 20480 1 dell_smbios
input_leds 16384 0
pcspkr 16384 0
snd_hwdep 16384 1 snd_hda_codec
cfg80211 851968 3 iwlmvm,iwlwifi,mac80211
r8168 573440 0
snd_pcm 143360 9 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_sof,snd_sof_intel_hda_common,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
mei_me 45056 1
ucsi_acpi 16384 0
snd_timer 40960 1 snd_pcm
intel_lpss_pci 20480 0
tpm_crb 20480 0
typec_ucsi 45056 1 ucsi_acpi
mei 118784 3 mei_hdcp,mei_me
snd 110592 16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
intel_lpss 16384 1 intel_lpss_pci
processor_thermal_device 24576 0
rfkill 28672 8 bluetooth,dell_laptop,cfg80211
tpm_tis 16384 0
idma64 20480 0
i2c_algo_bit 16384 1 i915
intel_rapl_common 28672 2 intel_rapl_msr,processor_thermal_device
tpm_tis_core 28672 1 tpm_tis
soundcore 16384 1 snd
intel_pch_thermal 16384 0
intel_gtt 24576 1 i915
intel_soc_dts_iosf 20480 1 processor_thermal_device
typec 49152 1 typec_ucsi
i2c_hid 32768 0
battery 20480 0
int3403_thermal 20480 0
tpm 77824 3 tpm_tis,tpm_crb,tpm_tis_core
int3400_thermal 20480 0
int340x_thermal_zone 16384 2 int3403_thermal,processor_thermal_device
acpi_thermal_rel 16384 1 int3400_thermal
wmi 36864 6 intel_wmi_thunderbolt,dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor,mxm_wmi
intel_hid 24576 0
rng_core 16384 1 tpm
evdev 28672 27
mac_hid 16384 0
sparse_keymap 16384 2 intel_hid,dell_wmi
ac 16384 0
vboxvideo 40960 0
drm_vram_helper 20480 1 vboxvideo
ttm 118784 1 drm_vram_helper
uinput 20480 0
drm_kms_helper 221184 2 vboxvideo,i915
drm 520192 15 drm_kms_helper,drm_vram_helper,vboxvideo,i915,ttm
agpgart 53248 3 intel_gtt,ttm,drm
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
vboxnetflt 32768 0
vboxnetadp 28672 0
vboxdrv 503808 2 vboxnetadp,vboxnetflt
vboxsf 40960 0
vboxguest 45056 1 vboxsf
sg 40960 0
crypto_user 16384 0
acpi_call 16384 0
ip_tables 36864 2 iptable_filter,iptable_nat
x_tables 49152 5 xt_conntrack,iptable_filter,xt_addrtype,ip_tables,xt_MASQUERADE
ext4 786432 3
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 135168 1 ext4
rtsx_usb_sdmmc 32768 0
mmc_core 184320 1 rtsx_usb_sdmmc
rtsx_usb 24576 2 rtsx_usb_sdmmc,rtsx_usb_ms
sd_mod 61440 6
hid_generic 16384 0
usbhid 65536 1 wacom
hid 143360 5 i2c_hid,wacom,usbhid,hid_multitouch,hid_generic
serio_raw 20480 0
atkbd 36864 0
libps2 20480 2 atkbd,psmouse
ahci 40960 4
libahci 40960 1 ahci
libata 286720 2 libahci,ahci
xhci_pci 20480 0
crc32c_intel 24576 7
xhci_hcd 282624 1 xhci_pci
scsi_mod 253952 3 sd_mod,libata,sg
i8042 32768 1 dell_laptop
serio 28672 6 serio_raw,atkbd,psmouse,i8042
Hello,
Remove video-linux. Use Optimus-Manager for more control of your GPUs. This might help even tho is for KDE Plasma and you are on Xfce, the logic is the same to an extent:
https://archived.forum.manjaro.org/t/dual-monitor-setup-in-manjaro-kde/156068/11
Isn’t the issue with dual monitor solved by the video-hybrid-inde-nvidia-455xx-prime ? I thought it solved the problem for some people
Thank you for your reply. I have read this article again. As you proposed,
  1. I removed linux-video
  2. I installed optimus-manager (with Qt visual interface from the Official Repositories)
Optimus-manager shows Intel icon in the tray. When I try to change it to Nvidia or to Hybrid and log out and log in again, nothing changes. The icon is still Intel. It looks like I can’t load the NVIDIA driver and don’t have a dGPU, optimus-manager can’t load the driver too.
Other watched behavior are
  1. No errors about loaded Kernel Modules during booting
  2. MHWD doesn’t contain anything to install for the discrete videocard (it even doesn’t contai any information of the dGPU:
The result for the usual commands:
mhwd -li
Installed PCI configs:
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-455xx-prime 2020.10.04 false PCI
network-r8168 2016.04.20 true PCI
inxi -G
Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.9 driver: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.2
After I rebooted the same command showed me the dGPU:
inxi -G
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: N/A
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
sudo nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
dmesg
> [    0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-25
> [    0.000000] Linux version 5.4.78-1-MANJARO (builduser@LEGION) (gcc version 10.2.0 (GCC)) #1 SMP PREEMPT Wed Nov 18 21:31:46 UTC 2020
> [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=64c125e7-e683-4c7b-bebb-136cd37ce540 rw quiet resume=UUID=b4ab5151-ea2c-44ee-838a-5fd1ce3d5d4f
> [    0.000000] KERNEL supported cpus:
> [    0.000000]   Intel GenuineIntel
> [    0.000000]   AMD AuthenticAMD
> [    0.000000]   Hygon HygonGenuine
> [    0.000000]   Centaur CentaurHauls
> [    0.000000]   zhaoxin   Shanghai
> [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
> [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
> [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
> [    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
> [    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
> [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
> [    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
> [    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
> [    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
> [    0.000000] BIOS-provided physical RAM map:
> [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
> [    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
> [    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
> [    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
> [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000069166fff] usable
> [    0.000000] BIOS-e820: [mem 0x0000000069167000-0x0000000069167fff] ACPI NVS
> [    0.000000] BIOS-e820: [mem 0x0000000069168000-0x0000000069168fff] reserved
> [    0.000000] BIOS-e820: [mem 0x0000000069169000-0x0000000078bf3fff] usable
> [    0.000000] BIOS-e820: [mem 0x0000000078bf4000-0x000000007a36bfff] reserved
> [    0.000000] BIOS-e820: [mem 0x000000007a36c000-0x000000007a3e8fff] ACPI data
> [    0.000000] BIOS-e820: [mem 0x000000007a3e9000-0x000000007ad5dfff] ACPI NVS
> [    0.000000] BIOS-e820: [mem 0x000000007ad5e000-0x000000007b41afff] reserved
> [    0.000000] BIOS-e820: [mem 0x000000007b41b000-0x000000007b4fdfff] type 20
> [    0.000000] BIOS-e820: [mem 0x000000007b4fe000-0x000000007b4fefff] usable
> [    0.000000] BIOS-e820: [mem 0x000000007b4ff000-0x000000007f7fffff] reserved
> [    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
> [    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
> [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
> [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
> [    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
> [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047e7fffff] usable
> [    0.000000] NX (Execute Disable) protection: active
> [    0.000000] efi: EFI v2.70 by American Megatrends
> [    0.000000] efi:  ACPI 2.0=0x7a385000  ACPI=0x7a385000  SMBIOS=0xf0000  SMBIOS 3.0=0xf0020  TPMFinalLog=0x7ac9d000  ESRT=0x7b130118  MEMATTR=0x76a28018
> [    0.000000] SMBIOS 3.1.1 present.
> [    0.000000] DMI: Dell Inc. G3 3779/0JGKPC, BIOS 1.5.1 11/01/2018
> [    0.000000] tsc: Detected 2200.000 MHz processor
> [    0.003316] tsc: Detected 2199.996 MHz TSC
> [    0.003316] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
> [    0.003317] e820: remove [mem 0x000a0000-0x000fffff] usable
> [    0.003322] last_pfn = 0x47e800 max_arch_pfn = 0x400000000
> [    0.003349] MTRR default type: write-back
> [    0.003349] MTRR fixed ranges enabled:
> [    0.003350]   00000-9FFFF write-back
> [    0.003351]   A0000-BFFFF uncachable
> [    0.003351]   C0000-FFFFF write-protect
> [    0.003351] MTRR variable ranges enabled:
> [    0.003352]   0 base 0080000000 mask 7F80000000 uncachable
> [    0.003353]   1 base 007E000000 mask 7FFE000000 uncachable
> [    0.003353]   2 base 007D000000 mask 7FFF000000 uncachable
> [    0.003354]   3 disabled
> [    0.003354]   4 disabled
> [    0.003354]   5 disabled
> [    0.003355]   6 disabled
> [    0.003355]   7 disabled
> [    0.003355]   8 disabled
> [    0.003356]   9 disabled
> [    0.003685] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
> [    0.003850] last_pfn = 0x7b4ff max_arch_pfn = 0x400000000
> [    0.009203] esrt: Reserving ESRT space from 0x000000007b130118 to 0x000000007b130150.
> [    0.009207] check: Scanning 1 areas for low memory corruption
> [    0.009210] Using GB pages for direct mapping
> [    0.009324] Secure boot could not be determined
> [    0.009325] RAMDISK: [mem 0x3658d000-0x372bdfff]
> [    0.009337] ACPI: Early table checksum verification disabled
> [    0.009339] ACPI: RSDP 0x000000007A385000 000024 (v02 DELL  )
> [    0.009341] ACPI: XSDT 0x000000007A3850B8 0000F4 (v01 DELL   CBX3     01072009 AMI  00010013)
> [    0.009344] ACPI: FACP 0x000000007A3C70E0 000114 (v06 DELL   CBX3     01072009 AMI  00010013)
> [    0.009348] ACPI: DSDT 0x000000007A385240 041E9B (v02 DELL   CBX3     01072009 INTL 20160527)
> [    0.009350] ACPI: FACS 0x000000007AD5CC00 000040
> [    0.009351] ACPI: APIC 0x000000007A3C71F8 0000F4 (v04 DELL   CBX3     01072009 AMI  00010013)
> [    0.009353] ACPI: FPDT 0x000000007A3C72F0 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
> [    0.009354] ACPI: FIDT 0x000000007A3C7338 00009C (v01 DELL   CBX3     01072009 AMI  00010013)
> [    0.009356] ACPI: MCFG 0x000000007A3C73D8 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
> [    0.009357] ACPI: SSDT 0x000000007A3C7418 000761 (v01 SataRe SataTabl 00001000 INTL 20160527)
> [    0.009359] ACPI: SSDT 0x000000007A3C7B80 0017D5 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
> [    0.009361] ACPI: BOOT 0x000000007A3C9358 000028 (v01 DELL   CBX3     01072009 AMI  00010013)
> [    0.009362] ACPI: SSDT 0x000000007A3C9380 001336 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
> [    0.009364] ACPI: SSDT 0x000000007A3CA6B8 0025EE (v02 PegSsd PegSsdt  00001000 INTL 20160527)
> [    0.009365] ACPI: HPET 0x000000007A3CCCA8 000038 (v01 INTEL  CBX3     00000002      01000013)
> [    0.009367] ACPI: SSDT 0x000000007A3CCCE0 002A07 (v02 INTEL  xh_cfhd4 00000000 INTL 20160527)
> [    0.009369] ACPI: UEFI 0x000000007A3CF6E8 000048 (v01 DELL\x CBX3     00000002      01000013)
> [    0.009370] ACPI: LPIT 0x000000007A3CF730 00005C (v01 INTEL  CBX3     00000002      01000013)
> [    0.009372] ACPI: SSDT 0x000000007A3CF790 0027DE (v02 INTEL  PtidDevc 00001000 INTL 20160527)
> [    0.009373] ACPI: SSDT 0x000000007A3D1F70 000FFE (v02 INTEL  TbtTypeC 00000000 INTL 20160527)
> [    0.009375] ACPI: DBGP 0x000000007A3D2F70 000034 (v01 DELL\x CBX3     00000002      01000013)
> [    0.009376] ACPI: DBG2 0x000000007A3D2FA8 000054 (v00 DELL\x CBX3     00000002      01000013)
> [    0.009378] ACPI: SSDT 0x000000007A3D3000 0007E8 (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
> [    0.009379] ACPI: SSDT 0x000000007A3D37E8 006193 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
> [    0.009381] ACPI: SSDT 0x000000007A3D9980 000144 (v02 Intel  ADebTabl 00001000 INTL 20160527)
> [    0.009383] ACPI: SSDT 0x000000007A3D9AC8 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160527)
> [    0.009384] ACPI: DMAR 0x000000007A3D9B78 0000A8 (v01 INTEL  EDK2     00000002      01000013)
> [    0.009386] ACPI: BGRT 0x000000007A3D9C20 000038 (v00                 01072009 AMI  00010013)
> [    0.009387] ACPI: TPM2 0x000000007A3D9C58 000034 (v04 DELL\x CBX3     00000001 AMI  00000000)
> [    0.009389] ACPI: SSDT 0x000000007A3D9C90 001F98 (v01 OptRef OptTabl  00001000 INTL 20160527)
> [    0.009394] ACPI: Local APIC address 0xfee00000
> [    0.009646] No NUMA configuration found
> [    0.009647] Faking a node at [mem 0x0000000000000000-0x000000047e7fffff]
> [    0.009649] NODE_DATA(0) allocated [mem 0x47e7fc000-0x47e7fffff]
> [    0.009671] Zone ranges:
> [    0.009672]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
> [    0.009673]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
> [    0.009673]   Normal   [mem 0x0000000100000000-0x000000047e7fffff]
> [    0.009674]   Device   empty
> [    0.009674] Movable zone start for each node
> [    0.009675] Early memory node ranges
> [    0.009675]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
> [    0.009676]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
> [    0.009676]   node   0: [mem 0x0000000000100000-0x0000000069166fff]
> [    0.009677]   node   0: [mem 0x0000000069169000-0x0000000078bf3fff]
> [    0.009677]   node   0: [mem 0x000000007b4fe000-0x000000007b4fefff]
> [    0.009678]   node   0: [mem 0x0000000100000000-0x000000047e7fffff]
> [    0.009854] Zeroed struct page in unavailable ranges: 35951 pages
> [    0.009855] Initmem setup node 0 [mem 0x0000000000001000-0x000000047e7fffff]
> [    0.009855] On node 0 totalpages: 4158353
> [    0.009856]   DMA zone: 64 pages used for memmap
> [    0.009856]   DMA zone: 23 pages reserved
> [    0.009857]   DMA zone: 3998 pages, LIFO batch:0
> [    0.009888]   DMA32 zone: 7664 pages used for memmap
> [    0.009889]   DMA32 zone: 490483 pages, LIFO batch:63
> [    0.015881]   Normal zone: 57248 pages used for memmap
> [    0.015881]   Normal zone: 3663872 pages, LIFO batch:63
> [    0.044302] x86/hpet: Will disable the HPET for this platform because it's not reliable
> [    0.044328] Reserving Intel graphics memory at [mem 0x7d800000-0x7f7fffff]
> [    0.045039] ACPI: PM-Timer IO Port: 0x1808
> [    0.045040] ACPI: Local APIC address 0xfee00000
> [    0.045044] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
> [    0.045044] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
> [    0.045045] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
> [    0.045045] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
> [    0.045045] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
> [    0.045046] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
> [    0.045046] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
> [    0.045047] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
> [    0.045047] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
> [    0.045047] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
> [    0.045048] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
> [    0.045048] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
> [    0.045112] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
> [    0.045113] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
> [    0.045114] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
> [    0.045114] ACPI: IRQ0 used by override.
> [    0.045115] ACPI: IRQ9 used by override.
> [    0.045116] Using ACPI (MADT) for SMP configuration information
> [    0.045117] ACPI: HPET id: 0x8086a201 base: 0xfed00000
> [    0.045121] e820: update [mem 0x743c0000-0x74446fff] usable ==> reserved
> [    0.045126] TSC deadline timer available
> [    0.045127] smpboot: Allowing 12 CPUs, 0 hotplug CPUs
> [    0.045139] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
> [    0.045140] PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
> [    0.045141] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
> [    0.045142] PM: Registered nosave memory: [mem 0x69167000-0x69167fff]
> [    0.045142] PM: Registered nosave memory: [mem 0x69168000-0x69168fff]
> [    0.045143] PM: Registered nosave memory: [mem 0x743c0000-0x74446fff]
> [    0.045144] PM: Registered nosave memory: [mem 0x78bf4000-0x7a36bfff]
> [    0.045144] PM: Registered nosave memory: [mem 0x7a36c000-0x7a3e8fff]
> [    0.045145] PM: Registered nosave memory: [mem 0x7a3e9000-0x7ad5dfff]
> [    0.045145] PM: Registered nosave memory: [mem 0x7ad5e000-0x7b41afff]
> [    0.045145] PM: Registered nosave memory: [mem 0x7b41b000-0x7b4fdfff]
> [    0.045146] PM: Registered nosave memory: [mem 0x7b4ff000-0x7f7fffff]
> [    0.045147] PM: Registered nosave memory: [mem 0x7f800000-0xefffffff]
> [    0.045147] PM: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
> [    0.045147] PM: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
> [    0.045148] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
> [    0.045148] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
> [    0.045148] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
> [    0.045149] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
> [    0.045149] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
> [    0.045149] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
> [    0.045150] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
> [    0.045151] [mem 0x7f800000-0xefffffff] available for PCI devices
> [    0.045151] Booting paravirtualized kernel on bare hardware
> [    0.045153] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
> [    0.115791] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:12 nr_node_ids:1
> [    0.116042] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
> [    0.116047] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
> [    0.116048] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
> [    0.116063] Built 1 zonelists, mobility grouping on.  Total pages: 4093354
> [    0.116064] Policy zone: Normal
> [    0.116065] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=64c125e7-e683-4c7b-bebb-136cd37ce540 rw quiet resume=UUID=b4ab5151-ea2c-44ee-838a-5fd1ce3d5d4f
> [    0.116686] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
> [    0.116967] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
> [    0.117046] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
> [    0.119331] Calgary: detecting Calgary via BIOS EBDA area
> [    0.119332] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
> [    0.143960] Memory: 16191652K/16633412K available (12291K kernel code, 1330K rwdata, 4096K rodata, 1644K init, 3396K bss, 441760K reserved, 0K cma-reserved)
> [    0.143965] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
> [    0.144064] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
> [    0.144075] Kernel/User page tables isolation: enabled
> [    0.144086] ftrace: allocating 37576 entries in 147 pages
> [    0.153941] rcu: Preemptible hierarchical RCU implementation.
> [    0.153941] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
> [    0.153942] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=12.
> [    0.153943] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
> [    0.153943] 	Tasks RCU enabled.
> [    0.153943] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
> [    0.153944] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
> [    0.155664] NR_IRQS: 20736, nr_irqs: 2152, preallocated irqs: 16
> [    0.156268] Console: colour dummy device 80x25
> [    0.156271] printk: console [tty0] enabled
> [    0.156281] ACPI: Core revision 20190816
> [    0.156512] APIC: Switch to symmetric I/O mode setup
> [    0.156514] DMAR: Host address width 39
> [    0.156515] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
> [    0.156518] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
> [    0.156519] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
> [    0.156521] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
> [    0.156522] DMAR: RMRR base: 0x0000007aedd000 end: 0x0000007b126fff
> [    0.156522] DMAR: RMRR base: 0x0000007d000000 end: 0x0000007f7fffff
> [    0.156523] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
> [    0.156524] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
> [    0.156524] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
> [    0.159597] DMAR-IR: Enabled IRQ remapping in x2apic mode
> [    0.159597] x2apic enabled
> [    0.159629] Switched APIC routing to cluster x2apic.
> [    0.168720] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb62f12e8c, max_idle_ns: 440795238402 ns
> [    0.168723] Calibrating delay loop (skipped), value calculated using timer frequency.. 4401.32 BogoMIPS (lpj=7333320)
> [    0.168724] pid_max: default: 32768 minimum: 301
> [    0.170638] LSM: Security Framework initializing
> [    0.170640] Yama: becoming mindful.
> [    0.170673] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
> [    0.170691] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
> [    0.170699] *** VALIDATE tmpfs ***
> [    0.170791] *** VALIDATE proc ***
> [    0.170823] *** VALIDATE cgroup1 ***
> [    0.170824] *** VALIDATE cgroup2 ***
> [    0.170879] mce: CPU0: Thermal monitoring enabled (TM1)
> [    0.170896] process: using mwait in idle threads
> [    0.170898] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
> [    0.170899] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
> [    0.170901] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
> [    0.170902] Spectre V2 : Mitigation: Full generic retpoline
> [    0.170902] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
> [    0.170903] Spectre V2 : Enabling Restricted Speculation for firmware calls
> [    0.170904] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
> [    0.170904] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
> [    0.170905] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
> [    0.170908] SRBDS: Mitigation: Microcode
> [    0.170909] MDS: Mitigation: Clear CPU buffers
> [    0.171129] Freeing SMP alternatives memory: 32K
> [    0.172055] smpboot: CPU0: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (family: 0x6, model: 0x9e, stepping: 0xa)
> [    0.172055] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
> [    0.172055] ... version:                4
> [    0.172055] ... bit width:              48
> [    0.172055] ... generic registers:      4
> [    0.172055] ... value mask:             0000ffffffffffff
> [    0.172055] ... max period:             00007fffffffffff
> [    0.172055] ... fixed-purpose events:   3
> [    0.172055] ... event mask:             000000070000000f
> [    0.172055] rcu: Hierarchical SRCU implementation.
> [    0.172055] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
> [    0.172055] smp: Bringing up secondary CPUs ...
> [    0.172055] x86: Booting SMP configuration:
> [    0.172055] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
> [    0.176918] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
> [    0.176918]   #7  #8  #9 #10 #11
> [    0.179126] smp: Brought up 1 node, 12 CPUs
> [    0.179126] smpboot: Max logical packages: 1
> [    0.179126] smpboot: Total of 12 processors activated (52821.90 BogoMIPS)
> [    0.182421] devtmpfs: initialized
> [    0.182421] x86/mm: Memory block size: 128MB
> [    0.183113] PM: Registering ACPI NVS region [mem 0x69167000-0x69167fff] (4096 bytes)
> [    0.183113] PM: Registering ACPI NVS region [mem 0x7a3e9000-0x7ad5dfff] (9916416 bytes)
> [    0.183113] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
> [    0.183113] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
> [    0.183113] pinctrl core: initialized pinctrl subsystem
> [    0.183113] PM: RTC time: 17:46:03, date: 2020-11-22
> [    0.183113] NET: Registered protocol family 16
> [    0.183113] audit: initializing netlink subsys (disabled)
> [    0.183113] audit: type=2000 audit(1606067163.013:1): state=initialized audit_enabled=0 res=1
> [    0.183113] cpuidle: using governor ladder
> [    0.183113] cpuidle: using governor menu
> [    0.183113] Simple Boot Flag at 0x47 set to 0x80
> [    0.183113] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
> [    0.183113] ACPI: bus type PCI registered
> [    0.183113] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
> [    0.183113] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
> [    0.183113] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
> [    0.183113] PCI: Using configuration type 1 for base access
> [    0.183113] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
> [    0.185800] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
> [    0.185800] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
> [    0.185800] ACPI: Added _OSI(Module Device)
> [    0.185800] ACPI: Added _OSI(Processor Device)
> [    0.185800] ACPI: Added _OSI(3.0 _SCP Extensions)
> [    0.185800] ACPI: Added _OSI(Processor Aggregator Device)
> [    0.185800] ACPI: Added _OSI(Linux-Dell-Video)
> [    0.185800] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
> [    0.185800] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
> [    0.251311] ACPI: 13 ACPI AML tables successfully acquired and loaded
> [    0.259970] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
> [    0.268015] ACPI: Dynamic OEM Table Load:
> [    0.268020] ACPI: SSDT 0xFFFF8C7FAB231800 0005BE (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
> [    0.269433] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
> [    0.270460] ACPI: Dynamic OEM Table Load:
> [    0.270463] ACPI: SSDT 0xFFFF8C7FAB089000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
> [    0.271816] ACPI: Dynamic OEM Table Load:
> [    0.271819] ACPI: SSDT 0xFFFF8C7FAB17D400 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
> [    0.273114] ACPI: Dynamic OEM Table Load:
> [    0.273117] ACPI: SSDT 0xFFFF8C7FAB235000 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
> [    0.274748] ACPI: Dynamic OEM Table Load:
> [    0.274753] ACPI: SSDT 0xFFFF8C7FABBAA000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
> [    0.276781] ACPI: Dynamic OEM Table Load:
> [    0.276784] ACPI: SSDT 0xFFFF8C7FAB08B800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
> [    0.278167] ACPI: Dynamic OEM Table Load:
> [    0.278170] ACPI: SSDT 0xFFFF8C7FAB08D800 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
> [    0.283054] ACPI: EC: EC started
> [    0.283055] ACPI: EC: interrupt blocked
> [    0.289459] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
> [    0.289461] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
> [    0.289461] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
> [    0.289462] ACPI: Interpreter enabled
> [    0.289495] ACPI: (supports S0 S3 S4 S5)
> [    0.289495] ACPI: Using IOAPIC for interrupt routing
> [    0.289527] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
> [    0.290272] ACPI: Enabled 9 GPEs in block 00 to 7F
> [    0.292539] ACPI: Power Resource [PG00] (on)
> [    0.341858] ACPI: Power Resource [USBC] (on)
> [    0.345609] ACPI: Power Resource [V0PR] (on)
> [    0.346037] ACPI: Power Resource [V1PR] (on)
> [    0.346457] ACPI: Power Resource [V2PR] (on)
> [    0.352067] ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/psparse-529)
> [    0.352073] ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/uteval-68)
> [    0.353192] ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/psparse-529)
> [    0.353198] ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20190816/uteval-68)
> [    0.354136] ACPI: Power Resource [WRST] (on)
> [    0.361804] ACPI: Power Resource [PIN] (off)
> [    0.362187] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
> [    0.362192] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
> [    0.362371] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
> [    0.362540] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR]
> [    0.362541] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
> [    0.363444] PCI host bridge to bus 0000:00
> [    0.363446] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
> [    0.363446] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
> [    0.363447] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
> [    0.363448] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
> [    0.363448] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
> [    0.363449] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
> [    0.363449] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
> [    0.363450] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
> [    0.363450] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
> [    0.363451] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
> [    0.363452] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
> [    0.363452] pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
> [    0.363453] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
> [    0.363454] pci_bus 0000:00: root bus resource [bus 00-7e]
> [    0.363460] pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
> [    0.363568] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
> [    0.363601] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
> [    0.363821] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
> [    0.363828] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
> [    0.363832] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
> [    0.363835] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
> [    0.363846] pci 0000:00:02.0: BAR 2: assigned to efifb
> [    0.363962] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
> [    0.363970] pci 0000:00:04.0: reg 0x10: [mem 0xed310000-0xed317fff 64bit]
> [    0.364138] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
> [    0.364146] pci 0000:00:08.0: reg 0x10: [mem 0xed32c000-0xed32cfff 64bit]
> [    0.364345] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
> [    0.364387] pci 0000:00:12.0: reg 0x10: [mem 0xed32b000-0xed32bfff 64bit]
> [    0.364694] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
> [    0.364738] pci 0000:00:14.0: reg 0x10: [mem 0xed300000-0xed30ffff 64bit]
> [    0.364871] pci 0000:00:14.0: PME# supported from D3hot D3cold
> [    0.365258] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
> [    0.365293] pci 0000:00:14.2: reg 0x10: [mem 0xed322000-0xed323fff 64bit]
> [    0.365311] pci 0000:00:14.2: reg 0x18: [mem 0xed32a000-0xed32afff 64bit]
> [    0.366093] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
> [    0.367539] pci 0000:00:14.3: reg 0x10: [mem 0xed31c000-0xed31ffff 64bit]
> [    0.372496] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
> [    0.374073] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
> [    0.374804] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
> [    0.377420] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
> [    0.378150] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
> [    0.380631] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
> [    0.380672] pci 0000:00:16.0: reg 0x10: [mem 0xed327000-0xed327fff 64bit]
> [    0.380788] pci 0000:00:16.0: PME# supported from D3hot
> [    0.381026] pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
> [    0.381061] pci 0000:00:17.0: reg 0x10: [mem 0xed320000-0xed321fff]
> [    0.381076] pci 0000:00:17.0: reg 0x14: [mem 0xed326000-0xed3260ff]
> [    0.381089] pci 0000:00:17.0: reg 0x18: [io  0x5090-0x5097]
> [    0.381103] pci 0000:00:17.0: reg 0x1c: [io  0x5080-0x5083]
> [    0.381117] pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
> [    0.381132] pci 0000:00:17.0: reg 0x24: [mem 0xed325000-0xed3257ff]
> [    0.381212] pci 0000:00:17.0: PME# supported from D3hot
> [    0.381440] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
> [    0.381643] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
> [    0.381672] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
> [    0.381936] pci 0000:00:1d.0: [8086:a335] type 01 class 0x060400
> [    0.382130] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
> [    0.382159] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
> [    0.382424] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
> [    0.382710] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
> [    0.382788] pci 0000:00:1f.3: reg 0x10: [mem 0xed318000-0xed31bfff 64bit]
> [    0.382862] pci 0000:00:1f.3: reg 0x20: [mem 0xed100000-0xed1fffff 64bit]
> [    0.383012] pci 0000:00:1f.3: PME# supported from D3hot D3cold
> [    0.383690] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
> [    0.383871] pci 0000:00:1f.4: reg 0x10: [mem 0xed324000-0xed3240ff 64bit]
> [    0.384062] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
> [    0.384423] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
> [    0.384451] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
> [    0.384671] pci 0000:01:00.0: [10de:1c8c] type 00 class 0x030200
> [    0.384695] pci 0000:01:00.0: reg 0x10: [mem 0xec000000-0xecffffff]
> [    0.384710] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
> [    0.384726] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
> [    0.384736] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
> [    0.384746] pci 0000:01:00.0: reg 0x30: [mem 0xed000000-0xed07ffff pref]
> [    0.384834] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8 GT/s x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
> [    0.384921] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
> [    0.384941] pci 0000:01:00.1: reg 0x10: [mem 0xed080000-0xed083fff]
> [    0.385110] pci 0000:00:01.0: PCI bridge to [bus 01]
> [    0.385111] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
> [    0.385112] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
> [    0.385115] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
> [    0.385264] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
> [    0.385272] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
> [    0.385280] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
> [    0.385443] pci 0000:3b:00.0: [10ec:8168] type 00 class 0x020000
> [    0.385485] pci 0000:3b:00.0: reg 0x10: [io  0x3000-0x30ff]
> [    0.385521] pci 0000:3b:00.0: reg 0x18: [mem 0xed204000-0xed204fff 64bit]
> [    0.385543] pci 0000:3b:00.0: reg 0x20: [mem 0xed200000-0xed203fff 64bit]
> [    0.385687] pci 0000:3b:00.0: supports D1 D2
> [    0.385688] pci 0000:3b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
> [    0.385880] pci 0000:00:1d.0: PCI bridge to [bus 3b]
> [    0.385885] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
> [    0.385889] pci 0000:00:1d.0:   bridge window [mem 0xed200000-0xed2fffff]
> [    0.387420] ACPI: PCI Interrupt Link [LNKA] (IRQs) *0
> [    0.387452] ACPI: PCI Interrupt Link [LNKB] (IRQs) *1
> [    0.387482] ACPI: PCI Interrupt Link [LNKC] (IRQs) *0
> [    0.387512] ACPI: PCI Interrupt Link [LNKD] (IRQs) *0
> [    0.387542] ACPI: PCI Interrupt Link [LNKE] (IRQs) *0
> [    0.387572] ACPI: PCI Interrupt Link [LNKF] (IRQs) *0
> [    0.387601] ACPI: PCI Interrupt Link [LNKG] (IRQs) *0
> [    0.387631] ACPI: PCI Interrupt Link [LNKH] (IRQs) *0
> [    0.391895] ACPI: EC: interrupt unblocked
> [    0.391912] ACPI: EC: event unblocked
> [    0.391923] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
> [    0.391924] ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions and events
> [    0.391997] iommu: Default domain type: Translated
> [    0.392066] pci 0000:00:02.0: vgaarb: setting as boot VGA device
> [    0.392069] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
> [    0.392073] pci 0000:00:02.0: vgaarb: bridge control possible
> [    0.392073] vgaarb: loaded
> [    0.392217] ACPI: bus type USB registered
> [    0.392231] usbcore: registered new interface driver usbfs
> [    0.392236] usbcore: registered new interface driver hub
> [    0.392260] usbcore: registered new device driver usb
> [    0.392279] pps_core: LinuxPPS API ver. 1 registered
> [    0.392280] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
> [    0.392281] PTP clock support registered
> [    0.392287] EDAC MC: Ver: 3.0.0
> [    0.392721] Registered efivars operations
> [    0.392721] PCI: Using ACPI for IRQ routing
> [    0.421022] PCI: pci_cache_line_size set to 64 bytes
> [    0.421375] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
> [    0.421376] e820: reserve RAM buffer [mem 0x69167000-0x6bffffff]
> [    0.421376] e820: reserve RAM buffer [mem 0x743c0000-0x77ffffff]
> [    0.421377] e820: reserve RAM buffer [mem 0x78bf4000-0x7bffffff]
> [    0.421378] e820: reserve RAM buffer [mem 0x7b4ff000-0x7bffffff]
> [    0.421378] e820: reserve RAM buffer [mem 0x47e800000-0x47fffffff]
> [    0.421437] NetLabel: Initializing
> [    0.421437] NetLabel:  domain hash size = 128
> [    0.421438] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
> [    0.421445] NetLabel:  unlabeled traffic allowed by default
> [    0.422055] clocksource: Switched to clocksource tsc-early
> [    0.428997] *** VALIDATE bpf ***
> [    0.429040] VFS: Disk quotas dquot_6.6.0
> [    0.429050] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
> [    0.429066] *** VALIDATE ramfs ***
> [    0.429068] *** VALIDATE hugetlbfs ***
> [    0.429095] pnp: PnP ACPI init
> [    0.429291] system 00:00: [io  0x0680-0x069f] has been reserved
> [    0.429292] system 00:00: [io  0x164e-0x164f] has been reserved
> [    0.429295] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
> [    0.429309] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
> [    0.429390] system 00:02: [io  0x1854-0x1857] has been reserved
> [    0.429392] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
> [    0.429472] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
> [    0.429483] pnp 00:04: Plug and Play ACPI device, IDs DLL0870 PNP0f13 (active)
> [    0.429637] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
> [    0.429638] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
> [    0.429639] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
> [    0.429640] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
> [    0.429641] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
> [    0.429642] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
> [    0.429642] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
> [    0.429643] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
> [    0.429645] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
> [    0.429844] system 00:06: [io  0x1800-0x18fe] could not be reserved
> [    0.429845] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
> [    0.429845] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
> [    0.429846] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
> [    0.429847] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
> [    0.429848] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
> [    0.429849] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
> [    0.429850] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
> [    0.430118] system 00:07: [io  0x2000-0x20fe] has been reserved
> [    0.430120] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
> [    0.431088] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
> [    0.435480] pnp: PnP ACPI: found 9 devices
> [    0.436217] thermal_sys: Registered thermal governor 'fair_share'
> [    0.436217] thermal_sys: Registered thermal governor 'bang_bang'
> [    0.436218] thermal_sys: Registered thermal governor 'step_wise'
> [    0.436218] thermal_sys: Registered thermal governor 'user_space'
> [    0.436218] thermal_sys: Registered thermal governor 'power_allocator'
> [    0.440741] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
> [    0.440762] pci 0000:00:1b.0: bridge window [io  0x1000-0x0fff] to [bus 02-3a] add_size 1000
> [    0.440771] pci 0000:00:15.0: BAR 0: assigned [mem 0x7f800000-0x7f800fff 64bit]
> [    0.441044] pci 0000:00:15.1: BAR 0: assigned [mem 0x7f801000-0x7f801fff 64bit]
> [    0.441312] pci 0000:00:1b.0: BAR 13: assigned [io  0x6000-0x6fff]
> [    0.441313] pci 0000:00:01.0: PCI bridge to [bus 01]
> [    0.441314] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
> [    0.441316] pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
> [    0.441317] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
> [    0.441320] pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
> [    0.441328] pci 0000:00:1b.0:   bridge window [io  0x6000-0x6fff]
> [    0.441334] pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
> [    0.441338] pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
> [    0.441347] pci 0000:00:1d.0: PCI bridge to [bus 3b]
> [    0.441350] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
> [    0.441356] pci 0000:00:1d.0:   bridge window [mem 0xed200000-0xed2fffff]
> [    0.441369] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
> [    0.441370] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
> [    0.441370] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
> [    0.441371] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
> [    0.441372] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
> [    0.441372] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
> [    0.441373] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
> [    0.441373] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
> [    0.441374] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
> [    0.441375] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
> [    0.441375] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
> [    0.441376] pci_bus 0000:00: resource 15 [mem 0x7f800000-0xefffffff window]
> [    0.441377] pci_bus 0000:00: resource 16 [mem 0xfc800000-0xfe7fffff window]
> [    0.441377] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
> [    0.441378] pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
> [    0.441378] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
> [    0.441379] pci_bus 0000:02: resource 0 [io  0x6000-0x6fff]
> [    0.441380] pci_bus 0000:02: resource 1 [mem 0xd4000000-0xea0fffff]
> [    0.441380] pci_bus 0000:02: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
> [    0.441381] pci_bus 0000:3b: resource 0 [io  0x3000-0x3fff]
> [    0.441381] pci_bus 0000:3b: resource 1 [mem 0xed200000-0xed2fffff]
> [    0.441515] NET: Registered protocol family 2
> [    0.441598] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
> [    0.441659] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
> [    0.441772] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
> [    0.441817] TCP: Hash tables configured (established 131072 bind 65536)
> [    0.441848] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
> [    0.441877] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
> [    0.441941] NET: Registered protocol family 1
> [    0.441944] NET: Registered protocol family 44
> [    0.441951] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
> [    0.442376] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
> [    0.442426] PCI: CLS 64 bytes, default 64
> [    0.442451] Trying to unpack rootfs image as initramfs...
> [    0.546057] Freeing initrd memory: 13508K
> [    0.575438] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
> [    0.575459] software IO TLB: mapped [mem 0x703c0000-0x743c0000] (64MB)
> [    0.575663] check: Scanning for low memory corruption every 60 seconds
> [    0.576069] Initialise system trusted keyrings
> [    0.576083] Key type blacklist registered
> [    0.576118] workingset: timestamp_bits=41 max_order=22 bucket_order=0
> [    0.577406] zbud: loaded
> [    0.581163] Key type asymmetric registered
> [    0.581164] Asymmetric key parser 'x509' registered
> [    0.581173] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
> [    0.581223] io scheduler mq-deadline registered
> [    0.581224] io scheduler kyber registered
> [    0.581251] io scheduler bfq registered
> [    0.586348] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
> [    0.586424] efifb: probing for efifb
> [    0.586438] efifb: showing boot graphics
> [    0.587415] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
> [    0.587416] efifb: mode is 1920x1080x32, linelength=7680, pages=1
> [    0.587416] efifb: scrolling: redraw
> [    0.587417] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
> [    0.587450] fbcon: Deferring console take-over
> [    0.587451] fb0: EFI VGA frame buffer device
> [    0.587458] intel_idle: MWAIT substates: 0x11142120
> [    0.587459] intel_idle: v0.4.1 model 0x9E
> [    0.588129] intel_idle: lapic_timer_reliable_states 0xffffffff
> [    0.588229] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
> [    0.588811] ACPI: Lid Switch [LID0]
> [    0.588846] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
> [    0.588913] ACPI: Power Button [PBTN]
> [    0.588946] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
> [    0.588962] ACPI: Sleep Button [SBTN]
> [    0.588991] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
> [    0.592140] ACPI: Power Button [PWRF]
> [    0.595693] thermal LNXTHERM:00: registered as thermal_zone0
> [    0.595694] ACPI: Thermal Zone [THM] (25 C)
> [    0.595960] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
> [    0.596780] hpet_acpi_add: no address or irqs in _CRS
> [    0.596805] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
> [    0.596806] AMD-Vi: AMD IOMMUv2 functionality not available on this system
> [    0.597840] usbcore: registered new interface driver usbserial_generic
> [    0.597843] usbserial: USB Serial support registered for generic
> [    0.597866] rtc_cmos 00:01: RTC can wake from S4
> [    0.598964] rtc_cmos 00:01: registered as rtc0
> [    0.598977] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
> [    0.599017] intel_pstate: Intel P-state driver initializing
> [    0.599028] intel_pstate: Disabling energy efficiency optimization
> [    0.600149] intel_pstate: HWP enabled
> [    0.600434] ledtrig-cpu: registered to indicate activity on CPUs
> [    0.600479] intel_pmc_core INT33A1:00:  initialized
> [    0.600526] drop_monitor: Initializing network drop monitor service
> [    0.600635] NET: Registered protocol family 10
> [    0.604468] Segment Routing with IPv6
> [    0.604482] NET: Registered protocol family 17
> [    0.605378] RAS: Correctable Errors collector initialized.
> [    0.605425] microcode: sig=0x906ea, pf=0x20, revision=0xde
> [    0.605728] microcode: Microcode Update Driver: v2.2.
> [    0.605731] IPI shorthand broadcast: enabled
> [    0.605737] sched_clock: Marking stable (593103342, 12622658)->(612506640, -6780640)
> [    0.605869] registered taskstats version 1
> [    0.605874] Loading compiled-in X.509 certificates
> [    0.608227] Loaded X.509 cert 'Build time autogenerated kernel key: bf3d2cd35392e4eba039fc1c6122630afacc9067'
> [    0.608258] zswap: loaded using pool lzo/zbud
> [    0.608457] Key type ._fscrypt registered
> [    0.608458] Key type .fscrypt registered
> [    0.612929] Key type big_key registered
> [    0.614696] PM:   Magic number: 12:723:795
> [    0.614714] platform MSFT0101:00: hash matches
> [    0.614720] acpi MSFT0101:00: hash matches
> [    0.615039] rtc_cmos 00:01: setting system clock to 2020-11-22T17:46:03 UTC (1606067163)
> [    0.615999] Freeing unused decrypted memory: 2040K
> [    0.616284] Freeing unused kernel image memory: 1644K
> [    0.668920] Write protecting the kernel read-only data: 18432k
> [    0.670208] Freeing unused kernel image memory: 2008K
> [    0.680199] x86/mm: Checked W+X mappings: passed, no W+X pages found.
> [    0.680200] x86/mm: Checking user space page tables
> [    0.686872] x86/mm: Checked W+X mappings: passed, no W+X pages found.
> [    0.686872] Run /init as init process
> [    0.850543] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
> [    0.851059] i8042: Warning: Keylock active
> [    0.852568] serio: i8042 KBD port at 0x60,0x64 irq 1
> [    0.852593] serio: i8042 AUX port at 0x60,0x64 irq 12
> [    0.860446] SCSI subsystem initialized
> [    0.862953] xhci_hcd 0000:00:14.0: xHCI Host Controller
> [    0.862959] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
> [    0.864107] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
> [    0.864114] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
> [    0.864371] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
> [    0.864373] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
> [    0.864374] usb usb1: Product: xHCI Host Controller
> [    0.864374] usb usb1: Manufacturer: Linux 5.4.78-1-MANJARO xhci-hcd
> [    0.864375] usb usb1: SerialNumber: 0000:00:14.0
> [    0.864475] hub 1-0:1.0: USB hub found
> [    0.864518] hub 1-0:1.0: 16 ports detected
> [    0.865285] libata version 3.00 loaded.
> [    0.866793] xhci_hcd 0000:00:14.0: xHCI Host Controller
> [    0.866797] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
> [    0.866799] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
> [    0.866852] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
> [    0.866853] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
> [    0.866854] usb usb2: Product: xHCI Host Controller
> [    0.866855] usb usb2: Manufacturer: Linux 5.4.78-1-MANJARO xhci-hcd
> [    0.866855] usb usb2: SerialNumber: 0000:00:14.0
> [    0.866927] hub 2-0:1.0: USB hub found
> [    0.866947] hub 2-0:1.0: 8 ports detected
> [    0.867980] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
> [    0.868662] ahci 0000:00:17.0: version 3.0
> [    0.868899] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
> [    0.882310] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
> [    0.882311] ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
> [    0.892663] scsi host0: ahci
> [    0.892992] scsi host1: ahci
> [    0.893031] ata1: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325100 irq 126
> [    0.893034] ata2: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325180 irq 126
> [    1.195502] usb 1-1: new full-speed USB device number 2 using xhci_hcd
> [    1.207797] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
> [    1.220764] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
> [    1.220769] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
> [    1.220773] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
> [    1.221088] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
> [    1.258299] ata1.00: ATA-10: ST1000LM035-1RK172, SDM3, max UDMA/133
> [    1.258304] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
> [    1.283640] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
> [    1.283646] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
> [    1.283650] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
> [    1.284011] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
> [    1.321287] ata1.00: configured for UDMA/133
> [    1.322764] scsi 0:0:0:0: Direct-Access     ATA      ST1000LM035-1RK1 SDM3 PQ: 0 ANSI: 5
> [    1.340294] usb 1-1: New USB device found, idVendor=056a, idProduct=030e, bcdDevice= 1.00
> [    1.340299] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
> [    1.340302] usb 1-1: Product: Intuos PS
> [    1.340305] usb 1-1: Manufacturer: Wacom Co.,Ltd.
> [    1.350057] hidraw: raw HID events driver (C) Jiri Kosina
> [    1.357812] usbcore: registered new interface driver usbhid
> [    1.357814] usbhid: USB HID core driver
> [    1.362879] hid-generic 0003:056A:030E.0001: hiddev0,hidraw0: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input0
> [    1.363418] hid-generic 0003:056A:030E.0002: hiddev1,hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input1
> [    1.363813] input: Wacom Co.,Ltd. Intuos PS as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:056A:030E.0003/input/input6
> [    1.363994] hid-generic 0003:056A:030E.0003: input,hidraw2: USB HID v1.10 Mouse [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input2
> [    1.465496] usb 1-3: new low-speed USB device number 3 using xhci_hcd
> [    1.582106] tsc: Refined TSC clocksource calibration: 2208.004 MHz
> [    1.582124] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fd3bc108c2, max_idle_ns: 440795311349 ns
> [    1.582216] clocksource: Switched to clocksource tsc
> [    1.611112] usb 1-3: New USB device found, idVendor=0461, idProduct=0010, bcdDevice= 1.04
> [    1.611118] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
> [    1.611121] usb 1-3: Product: USB Keyboard
> [    1.611124] usb 1-3: Manufacturer: NOVATEK
> [    1.616119] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0461:0010.0004/input/input7
> [    1.636575] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
> [    1.640521] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
> [    1.640527] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
> [    1.640531] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
> [    1.640608] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
> [    1.641196] ata2.00: ATA-10: SK hynix SC311 SATA 128GB, 70000P10, max UDMA/133
> [    1.641201] ata2.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 32), AA
> [    1.644560] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
> [    1.644565] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
> [    1.644569] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
> [    1.644628] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
> [    1.645535] ata2.00: configured for UDMA/133
> [    1.647028] scsi 1:0:0:0: Direct-Access     ATA      SK hynix SC311 S 0P10 PQ: 0 ANSI: 5
> [    1.656591] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
> [    1.656598] sd 0:0:0:0: [sda] 4096-byte physical blocks
> [    1.656695] sd 0:0:0:0: [sda] Write Protect is off
> [    1.656701] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
> [    1.656761] sd 1:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
> [    1.656766] sd 1:0:0:0: [sdb] 4096-byte physical blocks
> [    1.656799] sd 1:0:0:0: [sdb] Write Protect is off
> [    1.656803] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
> [    1.656849] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
> [    1.656853] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
> [    1.672419] hid-generic 0003:0461:0010.0004: input,hidraw3: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:14.0-3/input0
> [    1.676927] input: NOVATEK USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0461:0010.0005/input/input8
> [    1.692318]  sdb: sdb1 sdb2 sdb3 sdb4
> [    1.693410] sd 1:0:0:0: [sdb] Attached SCSI disk
> [    1.732271] input: NOVATEK USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0461:0010.0005/input/input9
> [    1.732480] hid-generic 0003:0461:0010.0005: input,hidraw4: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:14.0-3/input1
> [    1.752006]  sda: sda1 sda2 sda3
> [    1.753293] sd 0:0:0:0: [sda] Attached SCSI disk
> [    1.855497] usb 1-5: new high-speed USB device number 4 using xhci_hcd
> [    1.855855] random: fast init done
> [    2.011473] usb 1-5: New USB device found, idVendor=0c45, idProduct=6a06, bcdDevice=64.26
> [    2.011478] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
> [    2.011482] usb 1-5: Product: Integrated_Webcam_HD
> [    2.011484] usb 1-5: Manufacturer: CNFFH37O034400223E02
> [    2.135470] usb 1-6: new high-speed USB device number 5 using xhci_hcd
> [    2.276246] usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
> [    2.276251] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
> [    2.276254] usb 1-6: Product: USB2.0-CRW
> [    2.276257] usb 1-6: Manufacturer: Generic
> [    2.276259] usb 1-6: SerialNumber: 20100201396000000
> [    2.286621] usbcore: registered new interface driver rtsx_usb
> [    2.402154] usb 1-14: new full-speed USB device number 6 using xhci_hcd
> [    2.533147] PM: Image not found (code -22)
> [    2.543738] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
> [    2.543743] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
> [    2.603899] EXT4-fs (sdb4): mounted filesystem with ordered data mode. Opts: (null)
> [    2.876151] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
> [    2.892343] systemd[1]: Detected architecture x86-64.
> [    2.930969] systemd[1]: Set hostname to <lmalaptop>.
> [    3.328691] systemd[1]: Queued start job for default target Graphical Interface.
> [    3.330090] systemd[1]: Created slice system-getty.slice.
> [    3.330473] systemd[1]: Created slice system-modprobe.slice.
> [    3.330832] systemd[1]: Created slice system-systemd\x2dfsck.slice.
> [    3.331209] systemd[1]: Created slice User and Session Slice.
> [    3.331285] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
> [    3.331343] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
> [    3.331632] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
> [    3.331679] systemd[1]: Reached target Local Encrypted Volumes.
> [    3.331695] systemd[1]: Reached target Login Prompts.
> [    3.331729] systemd[1]: Reached target Remote File Systems.
> [    3.331744] systemd[1]: Reached target Slices.
> [    3.331769] systemd[1]: Reached target System Time Set.
> [    3.331792] systemd[1]: Reached target System Time Synchronized.
> [    3.331880] systemd[1]: Listening on Device-mapper event daemon FIFOs.
> [    3.332252] systemd[1]: Listening on LVM2 metadata daemon socket.
> [    3.332353] systemd[1]: Listening on LVM2 poll daemon socket.
> [    3.334502] systemd[1]: Listening on Process Core Dump Socket.
> [    3.334703] systemd[1]: Listening on Journal Audit Socket.
> [    3.334816] systemd[1]: Listening on Journal Socket (/dev/log).
> [    3.334946] systemd[1]: Listening on Journal Socket.
> [    3.336363] systemd[1]: Listening on udev Control Socket.
> [    3.336503] systemd[1]: Listening on udev Kernel Socket.
> [    3.337682] systemd[1]: Mounting Huge Pages File System...
> [    3.338826] systemd[1]: Mounting POSIX Message Queue File System...
> [    3.339924] systemd[1]: Mounting Kernel Debug File System...
> [    3.341027] systemd[1]: Mounting Kernel Trace File System...
> [    3.342277] systemd[1]: Starting Create list of static device nodes for the current kernel...
> [    3.343406] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
> [    3.344381] systemd[1]: Starting Load Kernel Module drm...
> [    3.345794] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
> [    3.345835] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
> [    3.347683] systemd[1]: Starting Journal Service...
> [    3.349443] systemd[1]: Starting Load Kernel Modules...
> [    3.350319] systemd[1]: Starting Remount Root and Kernel File Systems...
> [    3.350376] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
> [    3.351351] systemd[1]: Starting Coldplug All udev Devices...
> [    3.352666] systemd[1]: Mounted Huge Pages File System.
> [    3.352776] systemd[1]: Mounted POSIX Message Queue File System.
> [    3.352863] systemd[1]: Mounted Kernel Debug File System.
> [    3.352947] systemd[1]: Mounted Kernel Trace File System.
> [    3.353530] systemd[1]: Finished Create list of static device nodes for the current kernel.
> [    3.353771] systemd[1]: modprobe@drm.service: Succeeded.
> [    3.354060] systemd[1]: Finished Load Kernel Module drm.
> [    3.358173] EXT4-fs (sdb4): re-mounted. Opts: discard
> [    3.358261] acpi_call: loading out-of-tree module taints kernel.
> [    3.358276] acpi_call: module verification failed: signature and/or required key missing - tainting kernel
> [    3.359383] systemd[1]: Finished Remount Root and Kernel File Systems.
> [    3.359522] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
> [    3.360915] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
> [    3.361292] random: lvm: uninitialized urandom read (4 bytes read)
> [    3.361929] systemd[1]: Starting Load/Save Random Seed...
> [    3.363109] systemd[1]: Starting Create System Users...
> [    3.367806] sd 0:0:0:0: Attached scsi generic sg0 type 0
> [    3.367835] sd 1:0:0:0: Attached scsi generic sg1 type 0
> [    3.381679] *** VALIDATE vboxsf ***
> [    3.396742] vboxdrv: Found 12 processor cores
> [    3.397235] systemd[1]: Finished Create System Users.
> [    3.397902] systemd[1]: Starting Create Static Device Nodes in /dev...
> [    3.418194] systemd[1]: Finished Create Static Device Nodes in /dev.
> [    3.418891] vboxdrv: TSC mode is Invariant, tentative frequency 2207998300 Hz
> [    3.418891] vboxdrv: Successfully loaded version 6.1.16 (interface 0x00300000)
> [    3.419253] systemd[1]: Starting Rule-based Manager for Device Events and Files...
> [    3.419840] VBoxNetAdp: Successfully started.
> [    3.421558] VBoxNetFlt: Successfully started.
> [    3.425451] systemd[1]: Finished Coldplug All udev Devices.
> [    3.435145] Linux agpgart interface v0.103
> [    3.479621] systemd[1]: Finished Load Kernel Modules.
> [    3.479812] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
> [    3.480631] systemd[1]: Mounting Kernel Configuration File System...
> [    3.481356] systemd[1]: Starting Apply Kernel Variables...
> [    3.482442] systemd[1]: Mounted Kernel Configuration File System.
> [    3.487953] systemd[1]: Finished Apply Kernel Variables.
> [    3.490748] systemd[1]: Starting CLI Netfilter Manager...
> [    3.499559] systemd[1]: Finished CLI Netfilter Manager.
> [    3.620885] systemd[1]: Started Journal Service.
> [    3.620943] audit: type=1130 audit(1606067166.500:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    3.820434] audit: type=1130 audit(1606067166.700:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    3.823217] audit: type=1130 audit(1606067166.703:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    3.861011] ACPI: AC Adapter [AC] (on-line)
> [    3.867786] input: Intel HID events as /devices/platform/INT33D5:00/input/input10
> [    3.870175] intel-hid INT33D5:00: platform supports 5 button array
> [    3.870208] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input11
> [    3.875085] wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
> [    3.934380] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
> [    3.934712] idma64 idma64.0: Found Intel integrated DMA 64-bit
> [    3.935962] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
> [    3.936538] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
> [    3.968639] audit: type=1130 audit(1606067166.847:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    3.971365] random: mktemp: uninitialized urandom read (6 bytes read)
> [    3.971436] random: mktemp: uninitialized urandom read (6 bytes read)
> [    3.974406] intel_rapl_common: Found RAPL domain package
> [    3.974408] intel_rapl_common: Found RAPL domain dram
> [    3.974865] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
> [    3.999246] battery: ACPI: Battery Slot [BAT0] (battery present)
> [    4.009407] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
> [    4.009641] idma64 idma64.1: Found Intel integrated DMA 64-bit
> [    4.021026] i801_smbus 0000:00:1f.4: SPD Write Disable is set
> [    4.021118] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
> [    4.023626] r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
> [    4.031142] cfg80211: Loading compiled-in X.509 certificates for regulatory database
> [    4.035599] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
> [    4.039445] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
> [    4.041723] r8168  Copyright (C) 2020  Realtek NIC software team <nicfae@realtek.com>
>                 This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
>                 This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
> [    4.042071] i2c_hid i2c-DELL0870:00: i2c-DELL0870:00 supply vdd not found, using dummy regulator
> [    4.042079] i2c_hid i2c-DELL0870:00: i2c-DELL0870:00 supply vddl not found, using dummy regulator
> [    4.188983] random: crng init done
> [    4.193859] input: DELL0870:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input12
> [    4.193973] input: DELL0870:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input13
> [    4.194155] hid-generic 0018:06CB:7E92.0006: input,hidraw5: I2C HID v1.00 Mouse [DELL0870:00 06CB:7E92] on i2c-DELL0870:00
> [    5.048133] Adding 16756732k swap on /dev/sdb2.  Priority:-2 extents:1 across:16756732k SSDscFS
> [    5.117892] input: PC Speaker as /devices/platform/pcspkr/input/input15
> [    5.118240] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
> [    5.143787] Setting dangerous option enable_fbc - tainting kernel
> [    5.236860] checking generic (80000000 7f0000) vs hw (80000000 10000000)
> [    5.236861] fb0: switching to inteldrmfb from EFI VGA
> [    5.236911] i915 0000:00:02.0: vgaarb: deactivate vga console
> [    5.291311] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
> [    5.291314] [drm] Driver supports precise vblank timestamp query.
> [    5.291460] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
> [    5.305085] r8168 0000:3b:00.0 enp59s0: renamed from eth0
> [    5.305729] audit: type=1130 audit(1606067168.187:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.306020] input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input17
> [    5.306421] iTCO_vendor_support: vendor-support=0
> [    5.307741] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
> [    5.308932] intel_rapl_common: Found RAPL domain package
> [    5.308933] intel_rapl_common: Found RAPL domain core
> [    5.308934] intel_rapl_common: Found RAPL domain uncore
> [    5.308935] intel_rapl_common: Found RAPL domain dram
> [    5.311715] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
> [    5.311999] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
> [    5.312140] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
> [    5.327547] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
> [    5.343950] Intel(R) Wireless WiFi driver for Linux
> [    5.343951] Copyright(c) 2003- 2015 Intel Corporation
> [    5.344035] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
> [    5.344079] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
> [    5.344080] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
> [    5.344081] RAPL PMU: hw unit of domain package 2^-14 Joules
> [    5.344081] RAPL PMU: hw unit of domain dram 2^-14 Joules
> [    5.344082] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
> [    5.344082] RAPL PMU: hw unit of domain psys 2^-14 Joules
> [    5.352501] iwlwifi 0000:00:14.3: loaded firmware version 46.4d093a30.0 op_mode iwlmvm
> [    5.364069] cryptd: max_cpu_qlen set to 1000
> [    5.370162] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
> [    5.373610] AVX2 version of gcm_enc/dec engaged.
> [    5.373611] AES CTR mode by8 optimization enabled
> [    5.393154] audit: type=1130 audit(1606067168.273:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.429712] input: DELL0870:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input18
> [    5.429797] input: DELL0870:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DELL0870:00/0018:06CB:7E92.0006/input/input19
> [    5.429916] hid-multitouch 0018:06CB:7E92.0006: input,hidraw5: I2C HID v1.00 Mouse [DELL0870:00 06CB:7E92] on i2c-DELL0870:00
> [    5.638059] mousedev: PS/2 mouse device common for all mice
> [    5.662606] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
> [    5.695399] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input21
> [    5.695496] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
> [    5.695522] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input22
> [    5.695704] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
> [    5.699745] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9462, REV=0x318
> [    5.715162] audit: type=1130 audit(1606067168.593:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fb415fd3\x2d88b9\x2d49a9\x2db3f4\x2d35f109dbf56e comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.728944] fbcon: i915drmfb (fb0) is primary device
> [    5.728945] fbcon: Deferring console take-over
> [    5.728947] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
> [    5.750191] iwlwifi 0000:00:14.3: base HW address: f4:d1:08:b2:95:99
> [    5.792448] audit: type=1130 audit(1606067168.673:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.795157] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
> [    5.795409] thermal thermal_zone8: failed to read out thermal zone (-61)
> [    5.797732] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
> [    5.801791] audit: type=1130 audit(1606067168.683:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.802666] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
> [    5.802667] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
> [    5.802668] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
> [    5.802668] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
> [    5.802669] snd_hda_codec_realtek hdaudioC0D0:    inputs:
> [    5.802670] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
> [    5.802670] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
> [    5.802671] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
> [    5.828785] audit: type=1130 audit(1606067168.710:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:dell::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.919465] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
> [    5.955832] audit: type=1130 audit(1606067168.840:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-faa2a134\x2d1d9d\x2d4dc3\x2d98ac\x2d14425269465b comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    5.984122] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
> [    6.071281] audit: type=1130 audit(1606067168.950:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    6.076781] audit: type=1127 audit(1606067168.957:14): pid=787 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
> [    6.079629] audit: type=1130 audit(1606067168.960:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [    6.460371] mc: Linux media interface: v0.10
> [    6.473340] input: Wacom Intuos S Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:056A:030E.0001/input/input24
> [    6.473424] wacom 0003:056A:030E.0001: hidraw0: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input0
> [    6.473553] input: Wacom Intuos S Pad as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:056A:030E.0002/input/input29
> [    6.473649] wacom 0003:056A:030E.0002: hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:00:14.0-1/input1
> [    6.480243] videodev: Linux video capture interface: v2.00
> [    6.490015] Bluetooth: Core ver 2.22
> [    6.490025] NET: Registered protocol family 31
> [    6.490026] Bluetooth: HCI device and connection manager initialized
> [    6.490028] Bluetooth: HCI socket layer initialized
> [    6.490030] Bluetooth: L2CAP socket layer initialized
> [    6.490032] Bluetooth: SCO socket layer initialized
> [    6.556093] aufs 5.4-20200622
> [    6.562986] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
> [    6.563026] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
> [    6.563067] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
> [    6.563095] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
> [    6.563125] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
> [    6.563161] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input34
> [    6.563190] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input35
> [    6.609037] usbcore: registered new interface driver btusb
> [    6.610487] Bluetooth: hci0: Firmware revision 0.1 build 241 week 36 2020
> [    6.613226] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6a06)
> [    6.621200] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input36
> [    6.621250] usbcore: registered new interface driver uvcvideo
> [    6.621250] USB Video Class driver (1.1.1)
> [    6.639054] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
> [    6.639055] Bluetooth: BNEP filters: protocol multicast
> [    6.639058] Bluetooth: BNEP socket layer initialized
> [    6.658343] enp59s0: 0xffff986b802e9000, 3c:2c:30:eb:05:d3, IRQ 128
> [    6.944039] NET: Registered protocol family 38
> [    6.975396] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975487] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975559] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975627] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975691] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975757] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975820] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975884] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    6.975945] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.157002] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
> [    7.166034] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
> [    7.169617] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.169962] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.170271] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.170568] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.170860] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.171152] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.171438] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.171725] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.172011] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.172341] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.172617] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
> [    7.363931] iwlwifi 0000:00:14.3: Conflict between TLV & NVM regarding enabling LAR (TLV = enabled NVM =disabled)
> [    7.373038] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
> [   10.509649] fuse: init (API version 7.31)
> [   10.509693] *** VALIDATE fuse ***
> [   10.509698] *** VALIDATE fuse ***
> [   11.620235] kauditd_printk_skb: 27 callbacks suppressed
> [   11.620237] audit: type=1131 audit(1606067174.500:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   12.950471] audit: type=1130 audit(1606067175.830:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   13.039157] audit: type=1130 audit(1606067175.920:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   13.650136] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
> [   13.653456] Bridge firewalling registered
> [   13.681304] audit: type=1325 audit(1606067176.560:46): table=nat family=2 entries=0
> [   13.686542] audit: type=1325 audit(1606067176.567:47): table=filter family=2 entries=0
> [   13.704473] audit: type=1325 audit(1606067176.583:48): table=nat family=2 entries=5
> [   13.705935] audit: type=1325 audit(1606067176.587:49): table=filter family=2 entries=4
> [   13.707467] audit: type=1325 audit(1606067176.587:50): table=filter family=2 entries=6
> [   13.708961] audit: type=1325 audit(1606067176.590:51): table=filter family=2 entries=8
> [   13.710458] audit: type=1325 audit(1606067176.590:52): table=filter family=2 entries=10
> [   13.721725] Initializing XFRM netlink socket
> [   16.821665] kauditd_printk_skb: 46 callbacks suppressed
> [   16.821666] audit: type=1100 audit(1606067179.700:99): pid=1013 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   16.822594] audit: type=1101 audit(1606067179.704:100): pid=1013 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   16.889260] audit: type=1106 audit(1606067179.770:101): pid=964 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   16.889369] audit: type=1104 audit(1606067179.770:102): pid=964 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   16.896476] audit: type=1103 audit(1606067179.777:103): pid=1013 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   16.896624] audit: type=1006 audit(1606067179.777:104): pid=1013 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
> [   16.913611] audit: type=1130 audit(1606067179.794:105): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   16.918027] audit: type=1101 audit(1606067179.797:106): pid=1359 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   16.918029] audit: type=1103 audit(1606067179.797:107): pid=1359 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="human" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
> [   16.918088] audit: type=1006 audit(1606067179.797:108): pid=1359 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
> [   19.760127] Bluetooth: RFCOMM TTY layer initialized
> [   19.760131] Bluetooth: RFCOMM socket layer initialized
> [   19.760133] Bluetooth: RFCOMM ver 1.11
> [   27.026167] kauditd_printk_skb: 10 callbacks suppressed
> [   27.026169] audit: type=1131 audit(1606067189.907:119): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   27.033427] audit: type=1131 audit(1606067189.914:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   31.692212] wlo1: authenticate with d4:60:e3:5a:e3:11
> [   31.700848] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [   31.722748] wlo1: authenticated
> [   31.725191] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [   31.759495] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [   31.761192] wlo1: associated
> [   31.802887] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
> [   31.818458] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by d4:60:e3:5a:e3:11
> [   35.078678] audit: type=1130 audit(1606067197.960:121): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   36.675650] audit: type=1131 audit(1606067199.557:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   45.027022] audit: type=1131 audit(1606067207.907:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   50.991704] audit: type=1131 audit(1606067213.874:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   71.383610] audit: type=1105 audit(1606067234.264:125): pid=2127 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [   71.393234] audit: type=1113 audit(1606067234.274:126): pid=1013 uid=0 auid=1000 ses=2 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [   71.419874] audit: type=1106 audit(1606067234.301:127): pid=1013 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   71.419899] audit: type=1104 audit(1606067234.301:128): pid=1013 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   71.439131] audit: type=1130 audit(1606067234.321:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   71.440520] wlo1: deauthenticating from d4:60:e3:5a:e3:11 by local choice (Reason: 3=DEAUTH_LEAVING)
> [   73.949356] audit: type=1103 audit(1606067236.831:130): pid=2154 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   73.974986] audit: type=1130 audit(1606067236.858:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   73.979571] audit: type=1101 audit(1606067236.861:132): pid=2158 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   73.979573] audit: type=1103 audit(1606067236.861:133): pid=2158 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
> [   73.979636] audit: type=1006 audit(1606067236.861:134): pid=2158 uid=0 old-auid=4294967295 auid=620 tty=(none) old-ses=4294967295 ses=4 res=1
> [   79.475337] kauditd_printk_skb: 3 callbacks suppressed
> [   79.475338] audit: type=1100 audit(1606067242.358:138): pid=2202 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.476287] audit: type=1101 audit(1606067242.358:139): pid=2202 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.509714] audit: type=1106 audit(1606067242.391:140): pid=2154 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.509795] audit: type=1104 audit(1606067242.391:141): pid=2154 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.513611] audit: type=1103 audit(1606067242.394:142): pid=2202 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.513708] audit: type=1006 audit(1606067242.394:143): pid=2202 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=5 res=1
> [   79.532259] audit: type=1105 audit(1606067242.414:144): pid=2202 uid=0 auid=1000 ses=5 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [   79.830027] audit: type=1112 audit(1606067242.711:145): pid=2202 uid=0 auid=1000 ses=5 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [   81.458012] audit: type=1105 audit(1606067244.341:146): pid=2596 uid=1000 auid=1000 ses=5 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [   81.700325] audit: type=1130 audit(1606067244.581:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   89.782608] kauditd_printk_skb: 1 callbacks suppressed
> [   89.782609] audit: type=1131 audit(1606067252.664:149): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [   89.789232] audit: type=1131 audit(1606067252.671:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  109.985941] audit: type=1130 audit(1606067272.868:151): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  111.732723] audit: type=1131 audit(1606067274.615:152): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  113.705940] wlo1: authenticate with d4:60:e3:5a:e3:11
> [  113.714662] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [  113.735519] wlo1: authenticated
> [  113.737504] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [  113.739263] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [  113.740722] wlo1: associated
> [  113.746486] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
> [  114.328693] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
> [  114.328753] wlo1: Connection to AP d4:60:e3:5a:e3:11 lost
> [  115.195784] wlo1: authenticate with d4:60:e3:5a:e3:11
> [  115.205832] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [  115.226778] wlo1: authenticated
> [  115.227460] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [  115.228687] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [  115.230343] wlo1: associated
> [  115.819876] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
> [  115.819945] wlo1: Connection to AP d4:60:e3:5a:e3:11 lost
> [  118.708068] wlo1: authenticate with d4:60:e3:5a:e3:11
> [  118.715298] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [  118.736227] wlo1: authenticated
> [  118.737428] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [  118.738663] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [  118.740693] wlo1: associated
> [  118.755690] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by d4:60:e3:5a:e3:11
> [  130.443650] audit: type=1130 audit(1606067293.325:153): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  140.016557] audit: type=1131 audit(1606067302.898:154): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  141.022804] audit: type=1131 audit(1606067303.905:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  170.917836] audit: type=1113 audit(1606067333.802:156): pid=2202 uid=0 auid=1000 ses=5 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [  170.919561] audit: type=1105 audit(1606067333.802:157): pid=2951 uid=1000 auid=1000 ses=5 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [  170.946398] audit: type=1106 audit(1606067333.829:158): pid=2202 uid=0 auid=1000 ses=5 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  170.946453] audit: type=1104 audit(1606067333.829:159): pid=2202 uid=0 auid=1000 ses=5 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  170.959245] audit: type=1130 audit(1606067333.842:160): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  170.960312] wlo1: deauthenticating from d4:60:e3:5a:e3:11 by local choice (Reason: 3=DEAUTH_LEAVING)
> [  173.502417] audit: type=1103 audit(1606067336.385:161): pid=2979 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  173.512694] audit: type=1130 audit(1606067336.395:162): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  173.517553] audit: type=1101 audit(1606067336.402:163): pid=2983 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  173.517580] audit: type=1103 audit(1606067336.402:164): pid=2983 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
> [  173.517625] audit: type=1006 audit(1606067336.402:165): pid=2983 uid=0 old-auid=4294967295 auid=620 tty=(none) old-ses=4294967295 ses=6 res=1
> [  178.996244] kauditd_printk_skb: 3 callbacks suppressed
> [  178.996245] audit: type=1100 audit(1606067341.879:169): pid=3027 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  178.997213] audit: type=1101 audit(1606067341.882:170): pid=3027 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  179.026848] audit: type=1106 audit(1606067341.912:171): pid=2979 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  179.026918] audit: type=1104 audit(1606067341.912:172): pid=2979 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  179.029872] audit: type=1103 audit(1606067341.912:173): pid=3027 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  179.029899] audit: type=1006 audit(1606067341.912:174): pid=3027 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=7 res=1
> [  179.056802] audit: type=1105 audit(1606067341.942:175): pid=3027 uid=0 auid=1000 ses=7 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  179.098533] audit: type=1112 audit(1606067341.982:176): pid=3027 uid=0 auid=1000 ses=7 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [  179.722215] wlo1: authenticate with d4:60:e3:5a:e3:11
> [  179.725580] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [  179.769235] wlo1: authenticated
> [  179.770003] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [  179.806454] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [  179.808416] wlo1: associated
> [  179.845762] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
> [  179.888563] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by d4:60:e3:5a:e3:11
> [  180.794192] audit: type=1105 audit(1606067343.679:177): pid=3412 uid=1000 auid=1000 ses=7 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [  181.013465] audit: type=1131 audit(1606067343.899:178): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  189.269185] kauditd_printk_skb: 2 callbacks suppressed
> [  189.269186] audit: type=1131 audit(1606067352.152:181): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  189.276207] audit: type=1131 audit(1606067352.159:182): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  192.025195] audit: type=1131 audit(1606067354.909:183): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  192.295734] audit: type=1105 audit(1606067355.179:184): pid=3625 uid=1000 auid=1000 ses=7 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [  192.298006] audit: type=1113 audit(1606067355.182:185): pid=3027 uid=0 auid=1000 ses=7 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [  192.325887] audit: type=1106 audit(1606067355.209:186): pid=3027 uid=0 auid=1000 ses=7 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  192.326092] audit: type=1104 audit(1606067355.209:187): pid=3027 uid=0 auid=1000 ses=7 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  192.361646] audit: type=1130 audit(1606067355.246:188): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  192.362547] wlo1: deauthenticating from d4:60:e3:5a:e3:11 by local choice (Reason: 3=DEAUTH_LEAVING)
> [  194.952051] audit: type=1103 audit(1606067357.836:189): pid=3651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  194.995530] audit: type=1130 audit(1606067357.879:190): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  195.014991] audit: type=1101 audit(1606067357.899:191): pid=3655 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  195.015408] audit: type=1103 audit(1606067357.899:192): pid=3655 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
> [  195.015416] audit: type=1006 audit(1606067357.899:193): pid=3655 uid=0 old-auid=4294967295 auid=620 tty=(none) old-ses=4294967295 ses=8 res=1
> [  195.018687] audit: type=1105 audit(1606067357.902:194): pid=3655 uid=0 auid=620 ses=8 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  195.176363] audit: type=1130 audit(1606067358.059:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  195.180438] audit: type=1105 audit(1606067358.066:196): pid=3651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.163304] audit: type=1100 audit(1606067363.049:197): pid=3699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.164222] audit: type=1101 audit(1606067363.049:198): pid=3699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.196387] audit: type=1106 audit(1606067363.079:199): pid=3651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.196389] audit: type=1104 audit(1606067363.082:200): pid=3651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.198591] audit: type=1103 audit(1606067363.082:201): pid=3699 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.198597] audit: type=1006 audit(1606067363.082:202): pid=3699 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=9 res=1
> [  200.216519] audit: type=1105 audit(1606067363.102:203): pid=3699 uid=0 auid=1000 ses=9 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="human" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
> [  200.255850] audit: type=1112 audit(1606067363.139:204): pid=3699 uid=0 auid=1000 ses=9 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=lmalaptop addr=? terminal=/dev/tty7 res=success'
> [  201.221766] wlo1: authenticate with d4:60:e3:5a:e3:11
> [  201.225059] wlo1: send auth to d4:60:e3:5a:e3:11 (try 1/3)
> [  201.246894] wlo1: authenticated
> [  201.249675] wlo1: associate with d4:60:e3:5a:e3:11 (try 1/3)
> [  201.250784] wlo1: RX AssocResp from d4:60:e3:5a:e3:11 (capab=0x411 status=0 aid=3)
> [  201.252904] wlo1: associated
> [  201.258292] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
> [  201.290689] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by d4:60:e3:5a:e3:11
> [  201.885702] audit: type=1105 audit(1606067364.769:205): pid=4092 uid=1000 auid=1000 ses=9 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
> [  203.012278] audit: type=1131 audit(1606067365.896:206): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  210.270151] audit: type=1131 audit(1606067373.156:207): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  210.277731] audit: type=1131 audit(1606067373.163:208): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  211.080325] audit: type=1131 audit(1606067373.966:209): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  245.602758] audit: type=1100 audit(1606067408.490:210): pid=4327 uid=1000 auid=1000 ses=9 msg='op=PAM:authentication grantors=? acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'
> [  252.377852] audit: type=1100 audit(1606067415.263:211): pid=4327 uid=1000 auid=1000 ses=9 msg='op=PAM:authentication grantors=? acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'
> [  258.801880] audit: type=1100 audit(1606067421.686:212): pid=4327 uid=1000 auid=1000 ses=9 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  258.801947] audit: type=1101 audit(1606067421.686:213): pid=4327 uid=1000 auid=1000 ses=9 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  258.802110] audit: type=1110 audit(1606067421.686:214): pid=4327 uid=0 auid=1000 ses=9 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  258.803549] audit: type=1105 audit(1606067421.690:215): pid=4327 uid=0 auid=1000 ses=9 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  259.064091] audit: type=1106 audit(1606067421.950:216): pid=4327 uid=0 auid=1000 ses=9 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  259.064400] audit: type=1104 audit(1606067421.950:217): pid=4327 uid=0 auid=1000 ses=9 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  288.371784] audit: type=1130 audit(1606067451.254:218): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  318.406762] audit: type=1131 audit(1606067481.291:219): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
> [  695.729125] audit: type=1100 audit(1606067859.083:220): pid=5479 uid=1000 auid=1000 ses=9 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  695.729895] audit: type=1101 audit(1606067859.083:221): pid=5479 uid=1000 auid=1000 ses=9 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="human" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  695.730101] audit: type=1110 audit(1606067859.083:222): pid=5479 uid=0 auid=1000 ses=9 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
> [  695.731448] audit: type=1105 audit(1606067859.087:223): pid=5479 uid=0 auid=1000 ses=9 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
What can I do next?
It looks like it doesn’t. At least, in my case.
When you boot a live usb drive does inxi -G show the dGPU?
After I rebooted several minutes ago inxi -G showed the dGPU. I didn’t use a Live USB.
Does manjaro settings manager shows the nvidia drivers?
Yes, it does (after the reboot).
Try using the nvidia drivers you have
How can I switch them on (to load them)?
Have you tried to use the other monitor?
Yes, It works on another laptop with Manjaro with one GPU (Intel) and the other desktop on FreeBSD.
Sorry, but I was saying for you to test with the computer you are talking about here
The second monitor doesn’t appear at the Display settings of Manjaro. It’s logical because the NVIDIA driver is not loaded for some reason.
Well, It is loaded on the Manjaro Settings Manager. It’s not being used by the desktop manager. I’d wait for @anon89812132 to answer if there’s something more you can do
That is not working like that with prime …
prime-run nvidia-settings
Best to make sure you followed this, even tho is a bit outdated
https://archived.forum.manjaro.org/t/guide-install-and-configure-optimus-manager-for-hybrid-gpu-setups-intel-nvidia/92196
No idea why is not loading the nvidia drivers in your case.
Thank you for your ideas.
I had not enough time to spent more to manage with the issue. I had already spend 3-4 hours this time.
I changed the OS to PopOS (which is based on Ubuntu), and the second monitor works out of the box as well as the stuff I use.
I don’t want to let Manjaro go (I have been using it for 1.5 years every day). When I have free time, I will reinstall Manjaro and try your ideas from the scratch, and will reply to this thread on my results.
I have the same model and I use optimus-switch without any problem. HDMI is working, speed is better than prime, and battery with nvidia last 2-3 hours and 4-4.30 with only intel.
I reinstalled the operating system from the latest release (20.2.1), chose the proprietary video driver during the boot and the problem gone. The second monitor works out-of-box, no additional software or settings were set up.
