Hi all.
I tried to update but i get always dipendency errors
impossibile soddisfare le dipendenze:
- unable to satisfy dependency 'perl<5.37' required by perl-io-interface
any pacman -Syyu or -Syu failed
Thanks in advance for any help
inxi -Fxz 1 ✘
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: KDE Plasma v: 5.27.6 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: F2A55-M LK v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 6305
date: 07/09/2013
Info: dual core model: AMD A4-5300 APU with Radeon HD Graphics bits: 64
type: MT MCP arch: Piledriver rev: 1 cache: L1: 96 KiB L2: 1024 KiB
Speed (MHz): avg: 1926 high: 2284 min/max: 1400/3400 boost: enabled cores:
1: 2284 2: 1569 bogomips: 14013
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Device-1: AMD Trinity 2 [Radeon HD 7480D] vendor: ASUSTeK driver: radeon
v: kernel arch: TeraScale-3 bus-ID: 00:01.0
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: radeon
unloaded: modesetting dri: r600 gpu: radeon resolution: 1280x1024~60Hz
API: OpenGL v: 4.5 Mesa 23.0.4 renderer: AMD ARUBA (DRM 2.50.0 /
6.1.41-1-MANJARO LLVM 15.0.7) direct-render: Yes
Device-1: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.75 status: off
Server-3: PulseAudio v: 16.1 status: active
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
Device-2: Ralink RT2870/RT3070 Wireless Adapter driver: rt2800usb
type: USB bus-ID: 1-2:3
IF: wlp0s18f2u2 state: up mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
Local Storage: total: 1.36 TiB used: 58.43 GiB (4.2%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPCX-24UE4T0
ID-2: /dev/sdb vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
ID-1: / size: 447.71 GiB used: 58.43 GiB (13.1%) fs: ext4 dev: /dev/sdb1
ID-1: swap-1 type: partition size: 9.82 GiB used: 768 KiB (0.0%)
dev: /dev/sdb2
System Temperatures: cpu: 30.8 C mobo: N/A gpu: radeon temp: 17.0 C
Processes: 247 Uptime: 32m Memory: total: 8 GiB note: est.
available: 8.93 GiB used: 5.83 GiB (65.3%) Init: systemd Compilers:
gcc: 13.1.1 clang: 15.0.7 Packages: 1450 Shell: Zsh v: 5.9 inxi: 3.3.28
