Hi,
After 3,5 years of relatively good updates the previous two and latest Stable updates 2023-12-01 are giving me problems.
Today I tried again I get the same behavior.
I use pamac GUI to update.
This update it asked to choose between gstreamer and ffmpeg, I chose ffmpeg.
All seems to go fine up until pamac notifies to reboot.
The first thing I notice is that the panel has become unresponsive to the mouse, alt-tab to the rescue.
I open terminal and see kded5 taking cpu 100% and memory consumption rising to the point where it becomes full.
System becomes slow but can reboot the normal way, via pamac notification.
After the reboot login appears, fill password and then hangs.
Fan ramps up.
Mouse works but becomes slow.
CtrlAltF4
htop shows startplasma-x11 100% cpu and memory fills up to the point that the screen briefly goes blank and then returns to the login screen.
Trying to login again gives the same result.
The above is true for the last three updates and I seem not to be able to solve this one.
Help appreciated,
Thx.
pinxi -Fxxxz
Kernel: 6.6.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma 5.27.9 tk: Qt 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: MEDION product: P6645 MD61379 v: 5.13_VEB_1AUOK026
serial: <filter>
Mobo: MEDION model: M15WKN v: 0.2 serial: <filter>
UEFI: American Megatrends v: 206 date: 10/30/2018
ID-1: BAT0 charge: 36.1 Wh (100.0%) condition: 36.1/41.6 Wh (86.8%)
volts: 12.5 min: 11.4 model: M153137 type: Unknown serial: <filter>
status: Full cycles: 122
Info: 4-Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Whiskey Lake rev: B cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 3601
Speed (MHz): avg: 800 min/max: 400/1801 boost: enabled volts: 0.6 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: MEDION AG
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Pegatron driver: nvidia
v: 535.129.03 bus-ID: 02:00.0 chip-ID: 10de:1d10 class-ID: 0302
Display: server: X.Org 21.1.9 compositor: kwin_x11 driver:
loaded: modesetting resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 23.1.9-manjaro1.1 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0403
Sound Server-1: ALSA v: k6.6.1-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.22 running: no
Sound Server-4: PipeWire v: 0.3.84 running: no
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 689.33 GiB used: 172 GiB (25.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 2B2QEXM7 temp: 26.9 C scheme: GPT
ID-2: /dev/sda vendor: A-Data model: SU630 size: 223.57 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 9A0 temp: 13 C scheme: GPT
ID-1: / size: 457.09 GiB used: 42.64 GiB (9.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 304 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 38.0 C pch: 38.0 C mobo: N/A
Processes: 235 Uptime: 48m wakeups: 1 Memory: 15.51 GiB
used: 2.86 GiB (18.4%) Init: systemd v: 254 Compilers: gcc: 13.2.1
clang: 16.0.6 Packages: pacman: 1912 Shell: Bash (sudo) v: 5.2.15
running-in: yakuake pinxi: 3.3.09-24
