I am unable to update/build caph-libs, electron16 & pdfsam
Whenever I attempt update/build, system works on update for hours without success. System also becomes very slow/unresponsive.
I am not good at Linux. If these packages are not useful, someone may please let me know so that I may delete them.
My system information is as follows (inxi --admin --verbosity=7 --filter --width)
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=a40dd108-0b61-471c-9b2a-27897097fc0d rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=8298410a-9a85-4c83-8bfb-ca2244a1e1d4 udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81D2 v: Lenovo ideapad 330-15ARR
serial: Chassis: type: 10 v: Lenovo ideapad 330-15ARR
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN
serial: UEFI: LENOVO v: 7VCN46WW date: 12/10/2018
ID-1: BAT0 charge: 14.2 Wh (57.7%) condition: 24.6/35.0 Wh (70.2%)
volts: 8.1 min: 7.6 model: LGC L17L2PF0 type: Li-poly serial:
status: charging
RAM: total: 7.32 GiB used: 5.33 GiB (72.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2631 high: 2718 min/max: 1600/2500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2619 2: 2548
3: 2718 4: 2639 bogomips: 19969
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300 temp: 50.0 C
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 13d3:5a02 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x38ed built: 2014
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RAVEN (LLVM 14.0.6 DRM 3.42 5.15.74-3-MANJARO) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:c821
class-ID: 0280
IF: wlp1s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac:
WAN IP:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2:3 chip-ID: 0bda:c024 class-ID: e001 serial:
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 328.44 GiB (35.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: rev: 3E scheme: GPT
ID-1: / raw-size: 898.44 GiB size: 898.44 GiB (100.00%) used: 327.72 GiB
(36.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a40dd108-0b61-471c-9b2a-27897097fc0d
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 568 KiB
(0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 0446-FDF2
ID-3: /home raw-size: 898.44 GiB size: 898.44 GiB (100.00%) used: 327.72
GiB (36.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
ID-4: /home//SharedNtfs raw-size: 23.98 GiB size: 23.98 GiB
(100.00%) used: 65.2 MiB (0.3%) fs: ntfs dev: /dev/sda4 maj-min: 8:4
label: SharedNtfs uuid: 25178C1655C6781F
ID-5: /var/cache raw-size: 898.44 GiB size: 898.44 GiB (100.00%)
used: 327.72 GiB (36.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
ID-6: /var/log raw-size: 898.44 GiB size: 898.44 GiB (100.00%) used: 327.72
ID-1: swap-1 type: partition size: 8.8 GiB used: 670.4 MiB (7.4%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 8298410a-9a85-4c83-8bfb-ca2244a1e1d4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: IMC Networks EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02
Device-2: 3-2:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 268 Uptime: 2d 1h 13m wakeups: 3176 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1551 libs: 380 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
