Hi team!!! Hope everything fine overthere…
As title says , i’m unable to uninstall kernel linux-6.17 (which has been marked as EOL ) after install linux-6.18…
I’m getting this error message:
error: failed to prepare transaction (could not satisfy dependencies) :: removing linux617 breaks dependency ‘linux617’ required by linux-meta
Here i let my “inxi --full --admin --filter --width” output:
Kernel: 6.18.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=cc0092ed-8fae-4f26-aee0-4fcc21f7f9ce rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B3604CMA_B3604CMA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: B3604CMA v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: ASUSTeK (Licensed by AMI
LLC.) v: B3604CMA.307 date: 12/12/2024
ID-1: BAT0 charge: 39.6 Wh (77.9%) condition: 50.9/50 Wh (101.7%)
power: 18.4 W volts: 13.09 min: 11.88 model: C490-42 type: Unknown
serial: <filter> charging: status: charging control: start: N/A end: 80%
cycles: 29
Device-1: ps-controller-battery-a0:5a:5d:55:08:45 model: N/A serial: N/A
charge: N/A status: full
Info: model: Intel Core Ultra 5 125U bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x25
Topology: cpus: 1x dies: 1 clusters: 5 cores: 12 threads: 14 mt: 2 tpc: 2
st: 10 smt: enabled cache: L1: 1.2 MiB desc: d-10x32 KiB, 2x48 KiB; i-12x64
KiB L2: 10 MiB desc: 5x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4300:3600:2100 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
bogomips: 75264
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Graphics] vendor: ASUSTeK driver: i915
v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 0000:00:02.0 chip-ID: 8086:7d45 class-ID: 0300
Device-2: BillionPixels USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 322e:2338
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: MSI MP243X serial: <filter> built: 2025
res: 1920x1080 dpi: 92 gamma: 1.2 size: 530x290mm (20.87x11.42")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x1614 built: 2021 res: 1920x1200
dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (MTL)
device-ID: 8086:7d45 memory: 29.94 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu
name: Intel Graphics (MTL) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:7d45 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: gputop, intel_gpu_top,
lsgpu x11: xprop,xrandr
Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-mtl
alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 0000:00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
Device-2: Sony DualShock 4 [CUH-ZCT2x]
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-6.4:8 chip-ID: 054c:09cc class-ID: 0300
API: ALSA v: k6.18.2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Device-2: Intel Ethernet I219-LM driver: e1000e v: kernel port: N/A
bus-ID: 0000:00:1f.6 chip-ID: 8086:550b class-ID: 0200
IF: eno2 state: down mac: <filter>
IF-ID-1: br-539e74b62cc9 state: down mac: <filter>
IF-ID-2: br-74374c568f83 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-ac9ab113a6b3 state: down mac: <filter>
IF-ID-4: br-acaf46c64379 state: down mac: <filter>
IF-ID-5: br-e1c6b159770a state: down mac: <filter>
IF-ID-6: br-f6f4693bad50 state: down mac: <filter>
IF-ID-7: docker0 state: down mac: <filter>
IF-ID-8: veth04e7206 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: veth3c32528 state: up speed: 10000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:9 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
class-ID: 0104
Local Storage: total: 476.94 GiB used: 237.2 GiB (49.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Solidgm model: SSDPFKNU512GZ
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 18.9 C scheme: GPT
ID-1: / raw-size: 80 GiB size: 80 GiB (100.00%) used: 32.48 GiB (40.6%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 512.7 MiB size: 511.6 MiB (99.80%)
used: 648 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 40 GiB size: 40 GiB (100.00%) used: 11.67 GiB (29.2%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 80 GiB size: 80 GiB (100.00%)
used: 32.48 GiB (40.6%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p9 maj-min: 259:9
System Temperatures: cpu: 34.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.66 GiB used: 4.19 GiB (13.7%)
Processes: 439 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 12.25 GiB services: gsd-power, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1563 libs: 363 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9
Happy Hollidays!!!
Thanks in advance!!!
