Hello,
I am experiencing trouble switching to the r8168 driver for my network card. The system currently uses r8169 (kernel 6.12.28-1-Manjaro`).
Here are the steps I have taken so far:
Attempted to install the network-r8168 package, but received “target not found” errors.
Verified the kernel version with uname -r, which is 6.12.28-1-Manjaro.
Attempted to install the package corresponding to the current kernel, but this was not successful.
Blacklisted r8169 by creating a configuration file and regenerating kernel modules with sudo mkinitcpio -P.
Despite these steps, inxi -n still shows the driver status as NA, although r8168 is listed as installed by Pacman.
Here is the output of inxi:
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
Desktop: i3 v: 4.24 dm: LightDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M-A PRO MAX II (MS-7C52) v: 2.0
serial: <superuser required> BIOS: American Megatrends LLC. v: A.30
date: 07/13/2024
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 550 min/max: 550/4909 boost: enabled cores: 1: 550
2: 550 3: 550 4: 550 5: 550 6: 550 7: 550 8: 550 9: 550 10: 550 11: 550
12: 550 bogomips: 100825
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 570.144 arch: Pascal pcie: speed: 2.5 GT/s lanes: 16 ports: active: none
off: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1 bus-ID: 29:00.0
chip-ID: 10de:1b81
Display: x11 server: X .org v: 1.21.1.16 compositor: Picom v: 12.5 driver:
X: loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080
Monitor-1: HDMI-A-2 mapped: HDMI-1 note: disabled model: VZ27EHF
res: 1920x1080 hz: 60 dpi: 82 diag: 686mm (27")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 1 drv: nouveau
device: 2 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 29:00.1 chip-ID: 10de:10f0
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16 bus-ID: 2b:00.4 chip-ID: 1022:1487
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: speed: 5 GT/s lanes: 1 port: f000 bus-ID: 25:00.0
chip-ID: 10ec:8125
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 953.87 GiB used: 7.06 GiB (0.7%)
ID-1: /dev/sda vendor: MicroFrom model: 1TB SATA3 SSD size: 953.87 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 953.87 GiB used: 7.06 GiB (0.7%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 953.87 GiB used: 7.06 GiB (0.7%) fs: btrfs
dev: /dev/sda1
ID-3: /var/log size: 953.87 GiB used: 7.06 GiB (0.7%) fs: btrfs
dev: /dev/sda1
System Temperatures: cpu: 38.2 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.54 GiB used: 1.58 GiB (10.2%)
Processes: 286 Power: uptime: 13m wakeups: 0 Init: systemd v: 257
default: graphical
Packages: pm: pacman pkgs: 1055 Compilers: gcc: 15.1.1 Shell: Bash
v: 5.2.37 running-in: urxvtd inxi: 3.3.38
Any further guidance or suggestions would be greatly appreciated.
