I can’t switch Chinese input method when using the search in overview.
I use fcitx5-rime
And if you switch it before accessing Overview is working?
It works fine unless in overview.
There is your answer, and i bet is the same with Desktop Grid and the Present Windows effects. Probably only if Overview will get a similar code as KRunner it will be possible to change layouts while on search …
OK.Thank you
