Hey all, I’ve now for vm purposes finally gottwn the IOMMU groups split for my two cards, but I can only get a display on either vm using the RTX 2070, or the integrated graphics, but none from the GTTX 1050Ti, I’ve tried every driver available, the good news is that lspci -nnk is no longer saying the 1050 is using the vfio-pci kernel driver but I’m still not getting a display. Here’s the startx error output
X.Org X Server 1.20.10
Build Operating System: Linux Manjaro Linux
Current Operating System: Linux jamesbuild1 5.10.6-arch1-1-vfio #1 SMP PREEMPT Wed, 13 Jan 2021 06:07:54 +0000 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux-vfio root=UUID=8664d69c-2452-4d25-918d-da21dec591ab rw intel_iommu=on iommu=pt vfio_iommu_type1.allow_unsafe_interrupts=1 pcie_acs_override=downstream,multifunction vfio-pci.ids=10de:1f07,10de:10f9
Build Date: 16 December 2020 10:33:32PMCurrent version of pixman: 0.40.0
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.1.log”, Time: Wed Jan 13 19:45:14 2021
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
Failed to connect to bus: Operation not permitted
dbus-update-activation-environment: error: unable to connect to D-Bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
dbus[2723]: Unable to set up transient service directory: XDG_RUNTIME_DIR “/run/user/1000” is owned by uid 1000, not our uid 0
Couldn’t exec startkde: No such file or directory
xinit: connection to X server lostwaiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
