I have probably same problem with anbox. Couldn’t get it run…
$ ANBOX_LOG_LEVEL=debug anbox session-manager
[ 2021-01-02 14:07:25] [Renderer.cpp:165@initialize] Using a surfaceless EGL context
[ 2021-01-02 14:07:25] [Renderer.cpp:248@initialize] Successfully initialized EGL
[ 2021-01-02 14:07:26] [client.cpp:48@start] Failed to start container: Failed to start container: Failed to start container
[ 2021-01-02 14:07:26] [session_manager.cpp:161@operator()] Lost connection to container manager, terminating.
[ 2021-01-02 14:07:26] [daemon.cpp:61@Run] Container is not running
terminate called after throwing an instance of 'boost::wrapexcept<boost::exception_detail::error_info_injector<boost::log::v2_mt_posix::system_error> >'
what(): Failed to set TLS value: Invalid argument
Stack trace (most recent call last) in thread 358327:
#16 Object "", at 0xffffffffffffffff, in
I should have kernel settings ok: (kernel 5.10.2-2-MANJARO)
$ zgrep -i -e android -e ashmem /proc/config.gz
# Android
CONFIG_ASHMEM=y
# end of Android
# Android
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
# CONFIG_ANDROID_BINDER_IPC_SELFTEST is not set
# end of Android
also have created dir /dev/binderfs
$ mount | grep binder
binder on /dev/binderfs type binder (rw,relatime,max=1048576)
I’m little bit concerned about the modules though…
$ modprobe -a binder-linux ashmem-linux
modprobe: WARNING: Module binder-linux not found in directory /lib/modules/5.10.2-2-MANJARO
modprobe: WARNING: Module ashmem-linux not found in directory /lib/modules/5.10.2-2-MANJARO
in anbox system-info it seems that just binder mod is missing…
$ anbox system-info
version: local-6c10125
cpu:
arch: x86
brand: Intel(R) Core(TM) i7-5600U CPU @ 2.60GHz
features:
- aes
- sse4_1
- sse4_2
- avx
- avx2
os:
version:
snap-based: false
kernel:
version: Linux version 5.10.2-2-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020
binder: false
ashmem: true
I have created network connection trough nmcli:
$ nmcli connection show anbox-net
connection.id: anbox-net
connection.uuid: 634fd1a0-0b7b-4047-adb0-6d5b318ce088
connection.stable-id: --
connection.type: bridge
connection.interface-name: anbox0
connection.autoconnect: yes
connection.autoconnect-priority: 0
connection.autoconnect-retries: -1 (default)
connection.multi-connect: 0 (default)
connection.auth-retries: -1
connection.timestamp: 1609597328
connection.read-only: no
connection.permissions: --
connection.zone: --
connection.master: --
connection.slave-type: --
connection.autoconnect-slaves: -1 (default)
connection.secondaries: --
connection.gateway-ping-timeout: 0
connection.metered: unknown
connection.lldp: default
connection.mdns: -1 (default)
connection.llmnr: -1 (default)
connection.wait-device-timeout: -1
ipv4.method: shared
ipv4.dns: --
ipv4.dns-search: --
ipv4.dns-options: --
ipv4.dns-priority: 0
ipv4.addresses: 192.168.250.1/24
ipv4.gateway: --
ipv4.routes: --
ipv4.route-metric: -1
ipv4.route-table: 0 (unspec)
ipv4.routing-rules: --
ipv4.ignore-auto-routes: no
ipv4.ignore-auto-dns: no
ipv4.dhcp-client-id: --
ipv4.dhcp-iaid: --
ipv4.dhcp-timeout: 0 (default)
ipv4.dhcp-send-hostname: yes
ipv4.dhcp-hostname: --
ipv4.dhcp-fqdn: --
ipv4.dhcp-hostname-flags: 0x0 (none)
when I run the “.desktop” launcher there’s just “Starting” image & then it crashes:
$ anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
[ 2021-01-02 14:31:01] [daemon.cpp:61@Run] [org.freedesktop.DBus.Error.ServiceUnknown] The name org.anbox was not provided by any .service files
btw. I have installed these anbox aur packages:
$ pacman -Qs anbox
local/anbox-git 1:r1319.6c10125-1
Running Android in a container
local/anbox-image-gapps-magisk 2018.07.19-17
Android image for running in Anbox, with OpenGApps, Houdini and Magisk (Bootless)
when I try to run adb…
$ adb shell
adb: no devices/emulators found
there are some errors in /var/lib/anbox/logs/container.log
lxc 20210102143012.386 ERROR conf - conf.c:turn_into_dependent_mounts:3012 - Invalid argument - Failed to copy "/proc/self/mountinfo"
lxc 20210102143012.387 DEBUG storage - storage/storage.c:storage_query:233 - Detected rootfs type "dir"
lxc 20210102143012.765 ERROR dir - storage/dir.c:dir_mount:152 - No space left on device - Failed to mount "/var/lib/anbox/rootfs" on "/usr/lib/lxc/rootfs"
lxc 20210102143012.765 ERROR conf - conf.c:lxc_mount_rootfs:1256 - Failed to mount rootfs "/var/lib/anbox/rootfs" onto "/usr/lib/lxc/rootfs" with options "(null)"
lxc 20210102143012.765 ERROR conf - conf.c:lxc_setup_rootfs_prepare_root:3141 - Failed to setup rootfs for
lxc 20210102143012.765 ERROR conf - conf.c:lxc_setup:3277 - Failed to setup rootfs
lxc 20210102143012.765 ERROR start - start.c:do_start:1218 - Failed to setup container "default"
lxc 20210102143012.765 TRACE sync - sync.c:lxc_sync_wake_parent:78 - Child waking parent with sequence error
lxc 20210102143012.765 ERROR sync - sync.c:__sync_wait:36 - An error occurred in another process (expected sequence number 5)
lxc 20210102143012.765 DEBUG network - network.c:lxc_delete_network:3665 - Deleted network devices
lxc 20210102143012.765 TRACE start - start.c:lxc_serve_state_socket_pair:502 - Sent container state "ABORTING" to 13
lxc 20210102143012.765 TRACE start - start.c:lxc_serve_state_clients:438 - Set container state to ABORTING
lxc 20210102143012.765 TRACE start - start.c:lxc_serve_state_clients:441 - No state clients registered
lxc 20210102143012.765 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:859 - Received container state "ABORTING" instead of "RUNNING"
lxc 20210102143012.765 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "default"
What can we do about this…?
P.S.: I just found some weird behavior in mount
output - there is repeatedly this:
/dev/loop1 on /usr/lib/lxc/rootfs type squashfs (ro,relatime)
/dev/sdb1 on /usr/lib/lxc/rootfs/cache type ext4 (rw,noatime)
/dev/sdb1 on /usr/lib/lxc/rootfs/data type ext4 (rw,noatime)
none on /usr/lib/lxc/rootfs/dev type tmpfs (rw,relatime,size=492k,mode=755,inode64)
proc on /usr/lib/lxc/rootfs/proc type proc (rw,nosuid,nodev,noexec,relatime)
proc on /usr/lib/lxc/rootfs/proc/tty type proc (rw,nosuid,nodev,noexec,relatime)
proc on /usr/lib/lxc/rootfs/proc/sys type proc (rw,nosuid,nodev,noexec,relatime)
$ mount | wc -l
28751
There is probably some infinite loop when mounting devices…?
