Hi everybody. If anyone has any experience getting Lokinet up and running, I need some help. I’ve installed Lokinet 0.9.8-1 and I’ve fiddled with the settings for quite awhile now to no avail. I’ve set everything back to the default. I’m running Manjaro KDE. Here is the first part of the output I get when starting lokinet from the command line :
[NFO] [lokinet](966) 2022-01-07 12:12:12.846 GMT [+0.001s] /daemon/lokinet.cpp:238 Using config file: "/home/x/.lokinet/lokinet.ini"
[NFO] [lokinet](966) 2022-01-07 12:12:12.846 GMT [+0.001s] /llarp/context.cpp:64 lokinet-0.9.8-nogit A Series of Tubes
[NFO] [lokinet](966) 2022-01-07 12:12:12.846 GMT [+0.001s] /llarp/context.cpp:65 starting up
[NFO] [lokinet](966) 2022-01-07 12:12:12.847 GMT [+0.002s] /llarp/router/router.cpp:1118 Bound RPC server to tcp://127.0.0.1:1190
[NFO] [lokinet](966) 2022-01-07 12:12:12.849 GMT [+0.004s] /llarp/router/router.cpp:657 Loaded 3 bootstrap routers
[NFO] [lokinet](966) 2022-01-07 12:12:12.849 GMT [+0.004s] /llarp/router/router.cpp:728 router profiling enabled
[NFO] [lokinet](966) 2022-01-07 12:12:12.849 GMT [+0.004s] /llarp/router/router.cpp:735 loading router profiles from "/home/x/.lokinet/profiles.dat"
[NFO] [lokinet](966) 2022-01-07 12:12:12.850 GMT [+0.005s] /llarp/handlers/tun.cpp:171 endpoint:yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy.loki setting to be reachable by default
[NFO] [lokinet](966) 2022-01-07 12:12:12.850 GMT [+0.005s] /llarp/handlers/tun.cpp:338 endpoint:yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy.loki skipping loading addr map at "/home/x/.lokinet/addrmap.dat" as it does not currently exist
[WRN] [](966) 2022-01-07 12:12:12.871 GMT [+0.026s] /llarp/router/systemd_resolved.cpp:202 Failed to set DNS via systemd-resolved: sdbus resolved SetLinkDNS failed: No such file or directory
[WRN] [](966) 2022-01-07 12:12:13.101 GMT [+0.256s] /llarp/path/pathbuilder.cpp:346 endpoint:wodtipnc58a4c3w1wkyejcs9o8zrzbmmsigzr1zu6dup151pgcho.loki has no first hop candidate
[WRN] [](966) 2022-01-07 12:12:13.101 GMT [+0.256s] /llarp/service/endpoint.cpp:118 could not publish descriptors for endpoint endpoint:wodtipnc58a4c3w1wkyejcs9o8zrzbmmsigzr1zu6dup151pgcho.loki because we couldn't get enough valid introductions
