Hi. I have had some experience in Linux but using Manjaro for the first time. The OS is really good, quite happy with it at the moment. I can’t seem to run Green with envy in this…I tried optirun gwe
And I got
[ 1359.014783] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[ 1359.014834] [ERROR]Could not connect to bumblebee daemon - is it running?
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2020.11.30 false PCI
Thats the reason,you are not using bumblebee drivers,you are using the newer official nvidia drivers,instead of optirun is prime-run,so you don’t need bumblebee at all,its a driver for older cards so no need to change anything.
As @anon33601770 suggested, I tweaked around with my locale settings…changed all profiles to en_US.UTF-8.
Then, using prime-run gwe i got,
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en-US.UTF-8)
(gwe:3491): Gtk-WARNING **: 09:50:15.760: Locale not supported by C library.
Using the fallback 'C' locale.
ERROR: NV-CONTROL missing!
Running nvidia-settings prints,
(process:3526): Gtk-WARNING **: 09:50:46.876: Locale not supported by C library.
ERROR: Unable to load info from any available system
Should I try changing my locale settings? If so which one should change it to?
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANG=en_IN
LC_CTYPE="en-US.UTF-8"
LC_NUMERIC="en-US.UTF-8"
LC_TIME="en-US.UTF-8"
LC_COLLATE="en-US.UTF-8"
LC_MONETARY="en-US.UTF-8"
LC_MESSAGES="en-US.UTF-8"
LC_PAPER="en-US.UTF-8"
LC_NAME="en-US.UTF-8"
LC_ADDRESS="en-US.UTF-8"
LC_TELEPHONE="en-US.UTF-8"
LC_MEASUREMENT="en-US.UTF-8"
LC_IDENTIFICATION="en-US.UTF-8"
LC_ALL=en-US.UTF-8
Output of locale-a
locale: Cannot set LC_COLLATE to default locale: No such file or directory
C
POSIX
de_DE.utf8
en_IN
en_IN.utf8
en_US.utf8
I don’t know how this can have happened but:
all of your locales are wrong (spelled wrong)
instead of: en-US.UTF-8
it should be: en_US.UTF-8
… although locale -a
says that you have german, US english and indian locales available
I suggest to check /etc/locale.gen
whether the right locales are uncommented there and how they are spelled
then re-generate your locales with locale-gen
Then you likely need to re-login
and check the result.
There are quite a few threads here on the forum addressing locale issues - check them if the above doesn’t fully sort the issue for you.
