Unable to resume from suspend with blinking caps-lock
capslock flashing recurs once per day (regularly on resume from suspend) with unable to boot or switch TTY.
Details:
$ inxi -b
 Kernel: 5.15.25-1-MANJARO x86_64 bits: 64
    Desktop: KDE Plasma 5.24.2 Distro: Manjaro Linux
  Type: Laptop System: Dell product: G3 3779 v: N/A
    serial: ***
  Mobo: Dell model: 04R93M v: A00 serial: *** UEFI: Dell
    v: 1.2.1 date: 07/18/2018
  ID-1: BAT0 charge: 12.8 Wh (100.0%) condition: 12.8/56.0 Wh (22.9%)
  Info: 6-core Intel Core i7-8750H [MT MCP] speed (MHz): avg: 1071
    min/max: 800/4100
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
  Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia
    v: 510.54
  Device-3: Realtek Integrated Webcam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X:
    loaded: modesetting,nvidia gpu: i915,nvidia resolution: 1920x1080~60Hz
  OpenGL: renderer: NVIDIA GeForce GTX 1060 with Max-Q Design/PCIe/SSE2
    v: 4.6.0 NVIDIA 510.54
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
    driver: r8169
  Local Storage: total: 2.05 TiB used: 369.24 GiB (17.6%)
  Processes: 352 Uptime: 23m Memory: 15.49 GiB used: 4.25 GiB (27.4%)
  Shell: Bash inxi: 3.3.13
If you do more than one consecutive suspends and resumes from suspend, you can bet you will have issues from time to time. Regardless the systems i tested, 3 resumes from suspend turned out to be, in my opinion, one suspend too much :upside_down_face:
Today I got 2 mentioned crashes. It appears more frequently.
Those crashes happen also after a clean boot, no suspend ?
Maybe there is something else to investigate. The logs show something that could give a hint?
Currently, it happens only on resume from suspend (usually I close the lid from 3 to 6 times a day)
Got the issue again 20 minutes ago.
I see some errors there, but not sure they are causing the main issue:
бер 29 15:10:03 roman-pc kernel: microcode: microcode updated early to revision 0xec, date = 2021-04-28
бер 29 15:10:03 roman-pc kernel: Linux version 5.15.28-1-MANJARO (builduser@fv-az82-631) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Fri Mar 11 14:12:57 UTC 2022
бер 29 15:10:03 roman-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a3d17ce4-9aaf-437d-a73a-439edc842272 rw acpi_rev_override=1 pcie_port_pm=off resume=UUID=1a692f9b-337c-4cfa-81e9-a514be6aa511
бер 29 15:10:03 roman-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
бер 29 15:10:03 roman-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
бер 29 15:10:03 roman-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
бер 29 15:10:03 roman-pc kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
бер 29 15:10:03 roman-pc kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
бер 29 15:10:03 roman-pc kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
бер 29 15:10:03 roman-pc kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
бер 29 15:10:03 roman-pc kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
бер 29 15:10:03 roman-pc kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
бер 29 15:10:03 roman-pc kernel: signal: max sigframe size: 2032
бер 29 15:10:03 roman-pc kernel: BIOS-provided physical RAM map:
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009cfff] usable
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000000009d000-0x000000000009dfff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] usable
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000069164fff] usable
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000069165000-0x0000000069165fff] ACPI NVS
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000069166000-0x0000000069166fff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000069167000-0x0000000078c0cfff] usable
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000078c0d000-0x000000007a384fff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007a385000-0x000000007a401fff] ACPI data
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007a402000-0x000000007ad76fff] ACPI NVS
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007ad77000-0x000000007b41afff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007b41b000-0x000000007b4fdfff] type 20
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007b4fe000-0x000000007b4fefff] usable
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x000000007b4ff000-0x000000007f7fffff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
бер 29 15:10:03 roman-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000047e7fffff] usable
бер 29 15:10:03 roman-pc kernel: NX (Execute Disable) protection: active
бер 29 15:10:03 roman-pc kernel: efi: EFI v2.60 by American Megatrends
бер 29 15:10:03 roman-pc kernel: efi: ACPI 2.0=0x7a39e000 ACPI=0x7a39e000 SMBIOS=0xf0000 SMBIOS 3.0=0xf0020 TPMFinalLog=0x7acb6000 ESRT=0x7b126018 MEMATTR=0x76990018
бер 29 15:10:03 roman-pc kernel: SMBIOS 3.1.1 present.
бер 29 15:10:03 roman-pc kernel: DMI: Dell Inc. G3 3779/04R93M, BIOS 1.2.1 07/18/2018
бер 29 15:10:03 roman-pc kernel: tsc: Detected 2200.000 MHz processor
бер 29 15:10:03 roman-pc kernel: tsc: Detected 2199.996 MHz TSC
бер 29 15:10:03 roman-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
бер 29 15:10:03 roman-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
бер 29 15:10:03 roman-pc kernel: last_pfn = 0x47e800 max_arch_pfn = 0x400000000
бер 29 15:10:03 roman-pc kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
бер 29 15:10:03 roman-pc kernel: last_pfn = 0x7b4ff max_arch_pfn = 0x400000000
бер 29 15:10:03 roman-pc kernel: esrt: Reserving ESRT space from 0x000000007b126018 to 0x000000007b126050.
бер 29 15:10:03 roman-pc kernel: Using GB pages for direct mapping
бер 29 15:10:03 roman-pc kernel: Secure boot could not be determined
бер 29 15:10:03 roman-pc kernel: RAMDISK: [mem 0x366eb000-0x3736cfff]
бер 29 15:10:03 roman-pc kernel: ACPI: Early table checksum verification disabled
бер 29 15:10:03 roman-pc kernel: ACPI: RSDP 0x000000007A39E000 000024 (v02 DELL  )
бер 29 15:10:03 roman-pc kernel: ACPI: XSDT 0x000000007A39E0B8 0000EC (v01 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: FACP 0x000000007A3DCF10 000114 (v06 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: DSDT 0x000000007A39E230 03ECDB (v02 DELL   CBX3     01072009 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: FACS 0x000000007AD75B80 000040
бер 29 15:10:03 roman-pc kernel: ACPI: APIC 0x000000007A3DD028 0000F4 (v04 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: FPDT 0x000000007A3DD120 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: FIDT 0x000000007A3DD168 00009C (v01 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: MCFG 0x000000007A3DD208 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3DD248 00067B (v01 SataRe SataTabl 00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3DD8C8 0017D5 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: BOOT 0x000000007A3DF0A0 000028 (v01 DELL   CBX3     01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3DF0C8 001336 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E0400 002240 (v02 PegSsd PegSsdt  00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: HPET 0x000000007A3E2640 000038 (v01 INTEL  CBX3     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E2678 002A07 (v02 INTEL  xh_cfhd4 00000000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: UEFI 0x000000007A3E5080 000048 (v01 DELL\x CBX3     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: LPIT 0x000000007A3E50C8 00005C (v01 INTEL  CBX3     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E5128 0027DE (v02 INTEL  PtidDevc 00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E7908 000FFE (v02 INTEL  TbtTypeC 00000000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: DBGP 0x000000007A3E8908 000034 (v01 DELL\x CBX3     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: DBG2 0x000000007A3E8940 000054 (v00 DELL\x CBX3     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E8998 0007E9 (v02 DELL\x UsbCTabl 00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3E9188 006193 (v02 DptfTa DptfTabl 00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3EF320 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: DMAR 0x000000007A3EF3D0 0000A8 (v01 INTEL  EDK2     00000002      01000013)
бер 29 15:10:03 roman-pc kernel: ACPI: TPM2 0x000000007A3EF478 000034 (v04 DELL\x CBX3     00000001 AMI  00000000)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0x000000007A3EF4B0 001F98 (v01 OptRef OptTabl  00001000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: BGRT 0x000000007A3F1448 000038 (v00                 01072009 AMI  00010013)
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving FACP table memory at [mem 0x7a3dcf10-0x7a3dd023]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving DSDT table memory at [mem 0x7a39e230-0x7a3dcf0a]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving FACS table memory at [mem 0x7ad75b80-0x7ad75bbf]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving APIC table memory at [mem 0x7a3dd028-0x7a3dd11b]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving FPDT table memory at [mem 0x7a3dd120-0x7a3dd163]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving FIDT table memory at [mem 0x7a3dd168-0x7a3dd203]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving MCFG table memory at [mem 0x7a3dd208-0x7a3dd243]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3dd248-0x7a3dd8c2]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3dd8c8-0x7a3df09c]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving BOOT table memory at [mem 0x7a3df0a0-0x7a3df0c7]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3df0c8-0x7a3e03fd]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e0400-0x7a3e263f]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving HPET table memory at [mem 0x7a3e2640-0x7a3e2677]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e2678-0x7a3e507e]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving UEFI table memory at [mem 0x7a3e5080-0x7a3e50c7]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving LPIT table memory at [mem 0x7a3e50c8-0x7a3e5123]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e5128-0x7a3e7905]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e7908-0x7a3e8905]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving DBGP table memory at [mem 0x7a3e8908-0x7a3e893b]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving DBG2 table memory at [mem 0x7a3e8940-0x7a3e8993]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e8998-0x7a3e9180]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3e9188-0x7a3ef31a]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3ef320-0x7a3ef3cd]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving DMAR table memory at [mem 0x7a3ef3d0-0x7a3ef477]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving TPM2 table memory at [mem 0x7a3ef478-0x7a3ef4ab]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving SSDT table memory at [mem 0x7a3ef4b0-0x7a3f1447]
бер 29 15:10:03 roman-pc kernel: ACPI: Reserving BGRT table memory at [mem 0x7a3f1448-0x7a3f147f]
бер 29 15:10:03 roman-pc kernel: No NUMA configuration found
бер 29 15:10:03 roman-pc kernel: Faking a node at [mem 0x0000000000000000-0x000000047e7fffff]
бер 29 15:10:03 roman-pc kernel: NODE_DATA(0) allocated [mem 0x47e7fc000-0x47e7fffff]
бер 29 15:10:03 roman-pc kernel: Zone ranges:
бер 29 15:10:03 roman-pc kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
бер 29 15:10:03 roman-pc kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
бер 29 15:10:03 roman-pc kernel:   Normal   [mem 0x0000000100000000-0x000000047e7fffff]
бер 29 15:10:03 roman-pc kernel:   Device   empty
бер 29 15:10:03 roman-pc kernel: Movable zone start for each node
бер 29 15:10:03 roman-pc kernel: Early memory node ranges
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x0000000000001000-0x000000000009cfff]
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x000000000009e000-0x000000000009ffff]
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x0000000000100000-0x0000000069164fff]
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x0000000069167000-0x0000000078c0cfff]
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x000000007b4fe000-0x000000007b4fefff]
бер 29 15:10:03 roman-pc kernel:   node   0: [mem 0x0000000100000000-0x000000047e7fffff]
бер 29 15:10:03 roman-pc kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000047e7fffff]
бер 29 15:10:03 roman-pc kernel: On node 0, zone DMA: 1 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: On node 0, zone DMA: 96 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: On node 0, zone DMA32: 2 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: On node 0, zone DMA32: 10481 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: On node 0, zone Normal: 19201 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: On node 0, zone Normal: 6144 pages in unavailable ranges
бер 29 15:10:03 roman-pc kernel: Reserving Intel graphics memory at [mem 0x7d800000-0x7f7fffff]
бер 29 15:10:03 roman-pc kernel: ACPI: PM-Timer IO Port: 0x1808
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
бер 29 15:10:03 roman-pc kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
бер 29 15:10:03 roman-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
бер 29 15:10:03 roman-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
бер 29 15:10:03 roman-pc kernel: ACPI: Using ACPI (MADT) for SMP configuration information
бер 29 15:10:03 roman-pc kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
бер 29 15:10:03 roman-pc kernel: e820: update [mem 0x743d4000-0x7445afff] usable ==> reserved
бер 29 15:10:03 roman-pc kernel: TSC deadline timer available
бер 29 15:10:03 roman-pc kernel: smpboot: Allowing 12 CPUs, 0 hotplug CPUs
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x69165000-0x69165fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x69166000-0x69166fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x743d4000-0x7445afff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x78c0d000-0x7a384fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7a385000-0x7a401fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7a402000-0x7ad76fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7ad77000-0x7b41afff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7b41b000-0x7b4fdfff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7b4ff000-0x7f7fffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0x7f800000-0xefffffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
бер 29 15:10:03 roman-pc kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
бер 29 15:10:03 roman-pc kernel: [mem 0x7f800000-0xefffffff] available for PCI devices
бер 29 15:10:03 roman-pc kernel: Booting paravirtualized kernel on bare hardware
бер 29 15:10:03 roman-pc kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
бер 29 15:10:03 roman-pc kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:12 nr_node_ids:1
бер 29 15:10:03 roman-pc kernel: percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
бер 29 15:10:03 roman-pc kernel: pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
бер 29 15:10:03 roman-pc kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
бер 29 15:10:03 roman-pc kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4093243
бер 29 15:10:03 roman-pc kernel: Policy zone: Normal
бер 29 15:10:03 roman-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a3d17ce4-9aaf-437d-a73a-439edc842272 rw acpi_rev_override=1 pcie_port_pm=off resume=UUID=1a692f9b-337c-4cfa-81e9-a514be6aa511
бер 29 15:10:03 roman-pc kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
бер 29 15:10:03 roman-pc kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
бер 29 15:10:03 roman-pc kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
бер 29 15:10:03 roman-pc kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
бер 29 15:10:03 roman-pc kernel: Memory: 16176652K/16633512K available (14344K kernel code, 2097K rwdata, 10880K rodata, 1864K init, 3776K bss, 456600K reserved, 0K cma-reserved)
бер 29 15:10:03 roman-pc kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
бер 29 15:10:03 roman-pc kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
бер 29 15:10:03 roman-pc kernel: Kernel/User page tables isolation: enabled
бер 29 15:10:03 roman-pc kernel: ftrace: allocating 44461 entries in 174 pages
бер 29 15:10:03 roman-pc kernel: ftrace: allocated 174 pages with 5 groups
бер 29 15:10:03 roman-pc kernel: rcu: Preemptible hierarchical RCU implementation.
бер 29 15:10:03 roman-pc kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
бер 29 15:10:03 roman-pc kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=12.
бер 29 15:10:03 roman-pc kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
бер 29 15:10:03 roman-pc kernel:         Trampoline variant of Tasks RCU enabled.
бер 29 15:10:03 roman-pc kernel:         Rude variant of Tasks RCU enabled.
бер 29 15:10:03 roman-pc kernel:         Tracing variant of Tasks RCU enabled.
бер 29 15:10:03 roman-pc kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
бер 29 15:10:03 roman-pc kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
бер 29 15:10:03 roman-pc kernel: NR_IRQS: 20736, nr_irqs: 2152, preallocated irqs: 16
бер 29 15:10:03 roman-pc kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
бер 29 15:10:03 roman-pc kernel: Console: colour dummy device 80x25
бер 29 15:10:03 roman-pc kernel: printk: console [tty0] enabled
бер 29 15:10:03 roman-pc kernel: ACPI: Core revision 20210730
бер 29 15:10:03 roman-pc kernel: ACPI: OSL: Overriding _REV return value to 5
бер 29 15:10:03 roman-pc kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
бер 29 15:10:03 roman-pc kernel: APIC: Switch to symmetric I/O mode setup
бер 29 15:10:03 roman-pc kernel: DMAR: Host address width 39
бер 29 15:10:03 roman-pc kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
бер 29 15:10:03 roman-pc kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
бер 29 15:10:03 roman-pc kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
бер 29 15:10:03 roman-pc kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
бер 29 15:10:03 roman-pc kernel: DMAR: RMRR base: 0x0000007a2da000 end: 0x0000007a2f9fff
бер 29 15:10:03 roman-pc kernel: DMAR: RMRR base: 0x0000007d000000 end: 0x0000007f7fffff
бер 29 15:10:03 roman-pc kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
бер 29 15:10:03 roman-pc kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
бер 29 15:10:03 roman-pc kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
бер 29 15:10:03 roman-pc kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
бер 29 15:10:03 roman-pc kernel: x2apic enabled
бер 29 15:10:03 roman-pc kernel: Switched APIC routing to cluster x2apic.
бер 29 15:10:03 roman-pc kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
бер 29 15:10:03 roman-pc kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb62f12e8c, max_idle_ns: 440795238402 ns
бер 29 15:10:03 roman-pc kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4401.32 BogoMIPS (lpj=7333320)
бер 29 15:10:03 roman-pc kernel: pid_max: default: 32768 minimum: 301
бер 29 15:10:03 roman-pc kernel: LSM: Security Framework initializing
бер 29 15:10:03 roman-pc kernel: landlock: Up and running.
бер 29 15:10:03 roman-pc kernel: Yama: becoming mindful.
бер 29 15:10:03 roman-pc kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
бер 29 15:10:03 roman-pc kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
бер 29 15:10:03 roman-pc kernel: x86/cpu: SGX disabled by BIOS.
бер 29 15:10:03 roman-pc kernel: CPU0: Thermal monitoring enabled (TM1)
бер 29 15:10:03 roman-pc kernel: process: using mwait in idle threads
бер 29 15:10:03 roman-pc kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
бер 29 15:10:03 roman-pc kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
бер 29 15:10:03 roman-pc kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
бер 29 15:10:03 roman-pc kernel: Spectre V2 : Mitigation: Retpolines
бер 29 15:10:03 roman-pc kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
бер 29 15:10:03 roman-pc kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
бер 29 15:10:03 roman-pc kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
бер 29 15:10:03 roman-pc kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
бер 29 15:10:03 roman-pc kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
бер 29 15:10:03 roman-pc kernel: SRBDS: Mitigation: Microcode
бер 29 15:10:03 roman-pc kernel: MDS: Mitigation: Clear CPU buffers
бер 29 15:10:03 roman-pc kernel: Freeing SMP alternatives memory: 36K
бер 29 15:10:03 roman-pc kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1861
бер 29 15:10:03 roman-pc kernel: smpboot: CPU0: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (family: 0x6, model: 0x9e, stepping: 0xa)
бер 29 15:10:03 roman-pc kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
бер 29 15:10:03 roman-pc kernel: ... version:                4
бер 29 15:10:03 roman-pc kernel: ... bit width:              48
бер 29 15:10:03 roman-pc kernel: ... generic registers:      4
бер 29 15:10:03 roman-pc kernel: ... value mask:             0000ffffffffffff
бер 29 15:10:03 roman-pc kernel: ... max period:             00007fffffffffff
бер 29 15:10:03 roman-pc kernel: ... fixed-purpose events:   3
бер 29 15:10:03 roman-pc kernel: ... event mask:             000000070000000f
бер 29 15:10:03 roman-pc kernel: rcu: Hierarchical SRCU implementation.
бер 29 15:10:03 roman-pc kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
бер 29 15:10:03 roman-pc kernel: smp: Bringing up secondary CPUs ...
бер 29 15:10:03 roman-pc kernel: x86: Booting SMP configuration:
бер 29 15:10:03 roman-pc kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
бер 29 15:10:03 roman-pc kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
бер 29 15:10:03 roman-pc kernel:   #7  #8  #9 #10 #11
бер 29 15:10:03 roman-pc kernel: smp: Brought up 1 node, 12 CPUs
бер 29 15:10:03 roman-pc kernel: smpboot: Max logical packages: 1
бер 29 15:10:03 roman-pc kernel: smpboot: Total of 12 processors activated (52821.90 BogoMIPS)
бер 29 15:10:03 roman-pc kernel: devtmpfs: initialized
бер 29 15:10:03 roman-pc kernel: x86/mm: Memory block size: 128MB
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Registering ACPI NVS region [mem 0x69165000-0x69165fff] (4096 bytes)
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Registering ACPI NVS region [mem 0x7a402000-0x7ad76fff] (9916416 bytes)
бер 29 15:10:03 roman-pc kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
бер 29 15:10:03 roman-pc kernel: futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
бер 29 15:10:03 roman-pc kernel: pinctrl core: initialized pinctrl subsystem
бер 29 15:10:03 roman-pc kernel: PM: RTC time: 12:09:59, date: 2022-03-29
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
бер 29 15:10:03 roman-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
бер 29 15:10:03 roman-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
бер 29 15:10:03 roman-pc kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
бер 29 15:10:03 roman-pc kernel: audit: initializing netlink subsys (disabled)
бер 29 15:10:03 roman-pc kernel: audit: type=2000 audit(1648555799.036:1): state=initialized audit_enabled=0 res=1
бер 29 15:10:03 roman-pc kernel: thermal_sys: Registered thermal governor 'fair_share'
бер 29 15:10:03 roman-pc kernel: thermal_sys: Registered thermal governor 'bang_bang'
бер 29 15:10:03 roman-pc kernel: thermal_sys: Registered thermal governor 'step_wise'
бер 29 15:10:03 roman-pc kernel: thermal_sys: Registered thermal governor 'user_space'
бер 29 15:10:03 roman-pc kernel: thermal_sys: Registered thermal governor 'power_allocator'
бер 29 15:10:03 roman-pc kernel: cpuidle: using governor ladder
бер 29 15:10:03 roman-pc kernel: cpuidle: using governor menu
бер 29 15:10:03 roman-pc kernel: Simple Boot Flag at 0x47 set to 0x80
бер 29 15:10:03 roman-pc kernel: HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
бер 29 15:10:03 roman-pc kernel: ACPI: bus type PCI registered
бер 29 15:10:03 roman-pc kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
бер 29 15:10:03 roman-pc kernel: PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
бер 29 15:10:03 roman-pc kernel: PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
бер 29 15:10:03 roman-pc kernel: PCI: Using configuration type 1 for base access
бер 29 15:10:03 roman-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
бер 29 15:10:03 roman-pc kernel: Kprobes globally optimized
бер 29 15:10:03 roman-pc kernel: HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
бер 29 15:10:03 roman-pc kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
бер 29 15:10:03 roman-pc kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
бер 29 15:10:03 roman-pc kernel: fbcon: Taking over console
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Module Device)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Processor Device)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Processor Aggregator Device)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Linux-Dell-Video)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
бер 29 15:10:03 roman-pc kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
бер 29 15:10:03 roman-pc kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
бер 29 15:10:03 roman-pc kernel: ACPI Error: No pointer back to namespace node in package 00000000df6b9eff (20210730/dsargs-301)
бер 29 15:10:03 roman-pc kernel: ACPI Error: No pointer back to namespace node in package 00000000d50e31da (20210730/dsargs-301)
бер 29 15:10:03 roman-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
бер 29 15:10:03 roman-pc kernel: ACPI: Dynamic OEM Table Load:
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D41706000 0005BE (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D416F2400 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D402AC200 00010A (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D41701800 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D4012A000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D416F6400 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: SSDT 0xFFFF949D416F6800 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
бер 29 15:10:03 roman-pc kernel: ACPI: EC: EC started
бер 29 15:10:03 roman-pc kernel: ACPI: EC: interrupt blocked
бер 29 15:10:03 roman-pc kernel: ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
бер 29 15:10:03 roman-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
бер 29 15:10:03 roman-pc kernel: ACPI: Interpreter enabled
бер 29 15:10:03 roman-pc kernel: ACPI: PM: (supports S0 S3 S4 S5)
бер 29 15:10:03 roman-pc kernel: ACPI: Using IOAPIC for interrupt routing
бер 29 15:10:03 roman-pc kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
бер 29 15:10:03 roman-pc kernel: ACPI: Enabled 9 GPEs in block 00 to 7F
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [PG00]
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [USBC]
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [V0PR]
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [V1PR]
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [V2PR]
бер 29 15:10:03 roman-pc kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/psparse-529)
бер 29 15:10:03 roman-pc kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/uteval-68)
бер 29 15:10:03 roman-pc kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/psparse-529)
бер 29 15:10:03 roman-pc kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/uteval-68)
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [WRST]
бер 29 15:10:03 roman-pc kernel: ACPI: PM: Power Resource [PIN]
бер 29 15:10:03 roman-pc kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
бер 29 15:10:03 roman-pc kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
бер 29 15:10:03 roman-pc kernel: acpi PNP0A08:00: _OSC: platform does not support [AER]
бер 29 15:10:03 roman-pc kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
бер 29 15:10:03 roman-pc kernel: PCI host bridge to bus 0000:00
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0x7f800000-0xefffffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: root bus resource [bus 00-7e]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:00.0: [8086:3ec4] type 00 class 0x060000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:04.0: reg 0x10: [mem 0xed310000-0xed317fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:08.0: reg 0x10: [mem 0xed32c000-0xed32cfff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:12.0: reg 0x10: [mem 0xed32b000-0xed32bfff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.0: reg 0x10: [mem 0xed300000-0xed30ffff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.2: reg 0x10: [mem 0xed322000-0xed323fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.2: reg 0x18: [mem 0xed32a000-0xed32afff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.3: reg 0x10: [mem 0xed31c000-0xed31ffff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:16.0: reg 0x10: [mem 0xed327000-0xed327fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:16.0: PME# supported from D3hot
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: [8086:a353] type 00 class 0x010601
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x10: [mem 0xed320000-0xed321fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x14: [mem 0xed326000-0xed3260ff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x18: [io  0x5090-0x5097]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x1c: [io  0x5080-0x5083]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x20: [io  0x5060-0x507f]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: reg 0x24: [mem 0xed325000-0xed3257ff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:17.0: PME# supported from D3hot
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0: [8086:a335] type 01 class 0x060400
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xed318000-0xed31bfff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.3: reg 0x20: [mem 0xed100000-0xed1fffff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.4: reg 0x10: [mem 0xed324000-0xed3240ff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: [10de:1c20] type 00 class 0x030200
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: reg 0x10: [mem 0xec000000-0xecffffff]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: reg 0x30: [mem 0xed000000-0xed07ffff pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.1: [10de:10f1] type 00 class 0x040300
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.1: reg 0x10: [mem 0xed080000-0xed083fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0:   bridge window [mem 0xec000000-0xed0fffff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: PCI bridge to [bus 02-3a]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0:   bridge window [mem 0xd4000000-0xea0fffff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0:   bridge window [mem 0x90000000-0xb1ffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: [10ec:8168] type 00 class 0x020000
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: reg 0x10: [io  0x3000-0x30ff]
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: reg 0x18: [mem 0xed204000-0xed204fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: reg 0x20: [mem 0xed200000-0xed203fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: supports D1 D2
бер 29 15:10:03 roman-pc kernel: pci 0000:3b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0: PCI bridge to [bus 3b]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1d.0:   bridge window [mem 0xed200000-0xed2fffff]
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 1
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
бер 29 15:10:03 roman-pc kernel: ACPI: EC: interrupt unblocked
бер 29 15:10:03 roman-pc kernel: ACPI: EC: event unblocked
бер 29 15:10:03 roman-pc kernel: ACPI: EC: GPE=0x6e
бер 29 15:10:03 roman-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
бер 29 15:10:03 roman-pc kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
бер 29 15:10:03 roman-pc kernel: iommu: Default domain type: Translated
бер 29 15:10:03 roman-pc kernel: iommu: DMA domain TLB invalidation policy: lazy mode
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
бер 29 15:10:03 roman-pc kernel: pci 0000:00:02.0: vgaarb: bridge control possible
бер 29 15:10:03 roman-pc kernel: vgaarb: loaded
бер 29 15:10:03 roman-pc kernel: SCSI subsystem initialized
бер 29 15:10:03 roman-pc kernel: libata version 3.00 loaded.
бер 29 15:10:03 roman-pc kernel: ACPI: bus type USB registered
бер 29 15:10:03 roman-pc kernel: usbcore: registered new interface driver usbfs
бер 29 15:10:03 roman-pc kernel: usbcore: registered new interface driver hub
бер 29 15:10:03 roman-pc kernel: usbcore: registered new device driver usb
бер 29 15:10:03 roman-pc kernel: pps_core: LinuxPPS API ver. 1 registered
бер 29 15:10:03 roman-pc kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
бер 29 15:10:03 roman-pc kernel: PTP clock support registered
бер 29 15:10:03 roman-pc kernel: EDAC MC: Ver: 3.0.0
бер 29 15:10:03 roman-pc kernel: Registered efivars operations
бер 29 15:10:03 roman-pc kernel: NetLabel: Initializing
бер 29 15:10:03 roman-pc kernel: NetLabel:  domain hash size = 128
бер 29 15:10:03 roman-pc kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
бер 29 15:10:03 roman-pc kernel: NetLabel:  unlabeled traffic allowed by default
бер 29 15:10:03 roman-pc kernel: PCI: Using ACPI for IRQ routing
бер 29 15:10:03 roman-pc kernel: PCI: pci_cache_line_size set to 64 bytes
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x0009d000-0x0009ffff]
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x69165000-0x6bffffff]
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x743d4000-0x77ffffff]
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x78c0d000-0x7bffffff]
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x7b4ff000-0x7bffffff]
бер 29 15:10:03 roman-pc kernel: e820: reserve RAM buffer [mem 0x47e800000-0x47fffffff]
бер 29 15:10:03 roman-pc kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
бер 29 15:10:03 roman-pc kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
бер 29 15:10:03 roman-pc kernel: clocksource: Switched to clocksource tsc-early
бер 29 15:10:03 roman-pc kernel: VFS: Disk quotas dquot_6.6.0
бер 29 15:10:03 roman-pc kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
бер 29 15:10:03 roman-pc kernel: pnp: PnP ACPI init
бер 29 15:10:03 roman-pc kernel: system 00:00: [io  0x0680-0x069f] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:00: [io  0x164e-0x164f] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:02: [io  0x1854-0x1857] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [io  0x1800-0x18fe] could not be reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:06: [mem 0xff000000-0xffffffff] has been reserved
бер 29 15:10:03 roman-pc kernel: system 00:07: [io  0x2000-0x20fe] has been reserved
бер 29 15:10:03 roman-pc kernel: pnp: PnP ACPI: found 9 devices
бер 29 15:10:03 roman-pc kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_INET protocol family
бер 29 15:10:03 roman-pc kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
бер 29 15:10:03 roman-pc kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
бер 29 15:10:03 roman-pc kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
бер 29 15:10:03 roman-pc kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
бер 29 15:10:03 roman-pc kernel: TCP: Hash tables configured (established 131072 bind 65536)
бер 29 15:10:03 roman-pc kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
бер 29 15:10:03 roman-pc kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
бер 29 15:10:03 roman-pc kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_XDP protocol family
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: bridge window [io  0x1000-0x0fff] to [bus 02-3a] add_size 1000
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.0: BAR 0: assigned [mem 0x7f800000-0x7f800fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:15.1: BAR 0: assigned [mem 0x7f801000-0x7f801fff 64bit]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0: BAR 13: assigned [io  0x6000-0x6fff]
бер 29 15:10:03 roman-pc kernel: pci 0000:00:1b.0:   bridge window [io  0x6000-0x6fff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 15 [mem 0x7f800000-0xefffffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:00: resource 16 [mem 0xfc800000-0xfe7fffff window]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:01: resource 1 [mem 0xec000000-0xed0fffff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:02: resource 0 [io  0x6000-0x6fff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:02: resource 1 [mem 0xd4000000-0xea0fffff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:02: resource 2 [mem 0x90000000-0xb1ffffff 64bit pref]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:3b: resource 0 [io  0x3000-0x3fff]
бер 29 15:10:03 roman-pc kernel: pci_bus 0000:3b: resource 1 [mem 0xed200000-0xed2fffff]
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
бер 29 15:10:03 roman-pc kernel: PCI: CLS 64 bytes, default 64
бер 29 15:10:03 roman-pc kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
бер 29 15:10:03 roman-pc kernel: software IO TLB: mapped [mem 0x00000000703d4000-0x00000000743d4000] (64MB)
бер 29 15:10:03 roman-pc kernel: Trying to unpack rootfs image as initramfs...
бер 29 15:10:03 roman-pc kernel: Initialise system trusted keyrings
бер 29 15:10:03 roman-pc kernel: Key type blacklist registered
бер 29 15:10:03 roman-pc kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
бер 29 15:10:03 roman-pc kernel: zbud: loaded
бер 29 15:10:03 roman-pc kernel: Key type asymmetric registered
бер 29 15:10:03 roman-pc kernel: Asymmetric key parser 'x509' registered
бер 29 15:10:03 roman-pc kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
бер 29 15:10:03 roman-pc kernel: io scheduler mq-deadline registered
бер 29 15:10:03 roman-pc kernel: io scheduler kyber registered
бер 29 15:10:03 roman-pc kernel: io scheduler bfq registered
бер 29 15:10:03 roman-pc kernel: pcieport 0000:00:01.0: PME: Signaling with IRQ 122
бер 29 15:10:03 roman-pc kernel: pcieport 0000:00:1b.0: PME: Signaling with IRQ 123
бер 29 15:10:03 roman-pc kernel: pcieport 0000:00:1b.0: pciehp: Slot #24 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
бер 29 15:10:03 roman-pc kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 124
бер 29 15:10:03 roman-pc kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
бер 29 15:10:03 roman-pc kernel: ACPI: AC: AC Adapter [AC] (on-line)
бер 29 15:10:03 roman-pc kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
бер 29 15:10:03 roman-pc kernel: ACPI: button: Lid Switch [LID0]
бер 29 15:10:03 roman-pc kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
бер 29 15:10:03 roman-pc kernel: ACPI: button: Power Button [PBTN]
бер 29 15:10:03 roman-pc kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
бер 29 15:10:03 roman-pc kernel: ACPI: button: Sleep Button [SBTN]
бер 29 15:10:03 roman-pc kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
бер 29 15:10:03 roman-pc kernel: ACPI: button: Power Button [PWRF]
бер 29 15:10:03 roman-pc kernel: thermal LNXTHERM:00: registered as thermal_zone0
бер 29 15:10:03 roman-pc kernel: ACPI: thermal: Thermal Zone [THM] (25 C)
бер 29 15:10:03 roman-pc kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
бер 29 15:10:03 roman-pc kernel: Non-volatile memory driver v1.3
бер 29 15:10:03 roman-pc kernel: Linux agpgart interface v0.103
бер 29 15:10:03 roman-pc kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
бер 29 15:10:03 roman-pc kernel: ahci 0000:00:17.0: version 3.0
бер 29 15:10:03 roman-pc kernel: ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
бер 29 15:10:03 roman-pc kernel: ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
бер 29 15:10:03 roman-pc kernel: ahci 0000:00:17.0: flags: 64bit ncq sntf stag pm clo only pio slum part ems deso sadm sds apst
бер 29 15:10:03 roman-pc kernel: scsi host0: ahci
бер 29 15:10:03 roman-pc kernel: scsi host1: ahci
бер 29 15:10:03 roman-pc kernel: ata1: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325100 irq 125
бер 29 15:10:03 roman-pc kernel: ata2: SATA max UDMA/133 abar m2048@0xed325000 port 0xed325180 irq 125
бер 29 15:10:03 roman-pc kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
бер 29 15:10:03 roman-pc kernel: ehci-pci: EHCI PCI platform driver
бер 29 15:10:03 roman-pc kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
бер 29 15:10:03 roman-pc kernel: ohci-pci: OHCI PCI platform driver
бер 29 15:10:03 roman-pc kernel: uhci_hcd: USB Universal Host Controller Interface driver
бер 29 15:10:03 roman-pc kernel: usbcore: registered new interface driver usbserial_generic
бер 29 15:10:03 roman-pc kernel: usbserial: USB Serial support registered for generic
бер 29 15:10:03 roman-pc kernel: rtc_cmos 00:01: RTC can wake from S4
бер 29 15:10:03 roman-pc kernel: rtc_cmos 00:01: registered as rtc0
бер 29 15:10:03 roman-pc kernel: rtc_cmos 00:01: setting system clock to 2022-03-29T12:10:00 UTC (1648555800)
бер 29 15:10:03 roman-pc kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
бер 29 15:10:03 roman-pc kernel: intel_pstate: Intel P-state driver initializing
бер 29 15:10:03 roman-pc kernel: intel_pstate: Disabling energy efficiency optimization
бер 29 15:10:03 roman-pc kernel: intel_pstate: HWP enabled
бер 29 15:10:03 roman-pc kernel: ledtrig-cpu: registered to indicate activity on CPUs
бер 29 15:10:03 roman-pc kernel: efifb: probing for efifb
бер 29 15:10:03 roman-pc kernel: efifb: framebuffer at 0x80000000, using 8128k, total 8128k
бер 29 15:10:03 roman-pc kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
бер 29 15:10:03 roman-pc kernel: efifb: scrolling: redraw
бер 29 15:10:03 roman-pc kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
бер 29 15:10:03 roman-pc kernel: Console: switching to colour frame buffer device 240x67
бер 29 15:10:03 roman-pc kernel: fb0: EFI VGA frame buffer device
бер 29 15:10:03 roman-pc kernel: hid: raw HID events driver (C) Jiri Kosina
бер 29 15:10:03 roman-pc kernel: ashmem: initialized
бер 29 15:10:03 roman-pc kernel: intel_pmc_core INT33A1:00:  initialized
бер 29 15:10:03 roman-pc kernel: drop_monitor: Initializing network drop monitor service
бер 29 15:10:03 roman-pc kernel: Initializing XFRM netlink socket
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_INET6 protocol family
бер 29 15:10:03 roman-pc kernel: ACPI: battery: Slot [BAT0] (battery present)
бер 29 15:10:03 roman-pc kernel: Freeing initrd memory: 12808K
бер 29 15:10:03 roman-pc kernel: Segment Routing with IPv6
бер 29 15:10:03 roman-pc kernel: RPL Segment Routing with IPv6
бер 29 15:10:03 roman-pc kernel: In-situ OAM (IOAM) with IPv6
бер 29 15:10:03 roman-pc kernel: NET: Registered PF_PACKET protocol family
бер 29 15:10:03 roman-pc kernel: microcode: sig=0x906ea, pf=0x20, revision=0xec
бер 29 15:10:03 roman-pc kernel: microcode: Microcode Update Driver: v2.2.
бер 29 15:10:03 roman-pc kernel: IPI shorthand broadcast: enabled
бер 29 15:10:03 roman-pc kernel: sched_clock: Marking stable (459301694, 7506120)->(492886666, -26078852)
бер 29 15:10:03 roman-pc kernel: registered taskstats version 1
бер 29 15:10:03 roman-pc kernel: Loading compiled-in X.509 certificates
бер 29 15:10:03 roman-pc kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 43fc9945725818abff4eb549eed62d04b329cee2'
бер 29 15:10:03 roman-pc kernel: zswap: loaded using pool zstd/z3fold
бер 29 15:10:03 roman-pc kernel: Key type ._fscrypt registered
бер 29 15:10:03 roman-pc kernel: Key type .fscrypt registered
бер 29 15:10:03 roman-pc kernel: Key type fscrypt-provisioning registered
бер 29 15:10:03 roman-pc kernel: PM:   Magic number: 14:50:179
бер 29 15:10:03 roman-pc kernel: acpi device:0f: hash matches
бер 29 15:10:03 roman-pc kernel: RAS: Correctable Errors collector initialized.
бер 29 15:10:03 roman-pc kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
бер 29 15:10:03 roman-pc kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
бер 29 15:10:03 roman-pc kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
бер 29 15:10:03 roman-pc kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
бер 29 15:10:03 roman-pc kernel: ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
бер 29 15:10:03 roman-pc kernel: ata1.00: ATA-10: ST2000LM007-1R8174, SDM2, max UDMA/133
бер 29 15:10:03 roman-pc kernel: ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
бер 29 15:10:03 roman-pc kernel: ata1.00: configured for UDMA/133
бер 29 15:10:03 roman-pc kernel: scsi 0:0:0:0: Direct-Access     ATA      ST2000LM007-1R81 SDM2 PQ: 0 ANSI: 5
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] Write Protect is off
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
бер 29 15:10:03 roman-pc kernel:  sda: sda1 sda2 sda3 sda4
бер 29 15:10:03 roman-pc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
бер 29 15:10:03 roman-pc kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
бер 29 15:10:03 roman-pc kernel: ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
бер 29 15:10:03 roman-pc kernel: ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
бер 29 15:10:03 roman-pc kernel: ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
бер 29 15:10:03 roman-pc kernel: ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
бер 29 15:10:03 roman-pc kernel: ata2.00: ATA-10: SK hynix SC311 SATA 256GB, 70000P10, max UDMA/133
бер 29 15:10:03 roman-pc kernel: ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
бер 29 15:10:03 roman-pc kernel: ata2.00: Features: Dev-Sleep
бер 29 15:10:03 roman-pc kernel: ata2.00: configured for UDMA/133
бер 29 15:10:03 roman-pc kernel: scsi 1:0:0:0: Direct-Access     ATA      SK hynix SC311 S 0P10 PQ: 0 ANSI: 5
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] Write Protect is off
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
бер 29 15:10:03 roman-pc kernel:  sdb: sdb1 sdb2 sdb3 sdb4
бер 29 15:10:03 roman-pc kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
бер 29 15:10:03 roman-pc kernel: Freeing unused decrypted memory: 2036K
бер 29 15:10:03 roman-pc kernel: Freeing unused kernel image (initmem) memory: 1864K
бер 29 15:10:03 roman-pc kernel: Write protecting the kernel read-only data: 28672k
бер 29 15:10:03 roman-pc kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
бер 29 15:10:03 roman-pc kernel: Freeing unused kernel image (rodata/data gap) memory: 1408K
бер 29 15:10:03 roman-pc kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
бер 29 15:10:03 roman-pc kernel: rodata_test: all tests were successful
бер 29 15:10:03 roman-pc kernel: x86/mm: Checking user space page tables
бер 29 15:10:03 roman-pc kernel: tsc: Refined TSC clocksource calibration: 2207.999 MHz
бер 29 15:10:03 roman-pc kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fd3b75da7f, max_idle_ns: 440795296082 ns
бер 29 15:10:03 roman-pc kernel: Run /init as init process
бер 29 15:10:03 roman-pc kernel:   with arguments:
бер 29 15:10:03 roman-pc kernel:     /init
бер 29 15:10:03 roman-pc kernel:   with environment:
бер 29 15:10:03 roman-pc kernel:     HOME=/
бер 29 15:10:03 roman-pc kernel:     TERM=linux
бер 29 15:10:03 roman-pc kernel:     BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
бер 29 15:10:03 roman-pc kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
бер 29 15:10:03 roman-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
бер 29 15:10:03 roman-pc kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000000009810
бер 29 15:10:03 roman-pc kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
бер 29 15:10:03 roman-pc kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
бер 29 15:10:03 roman-pc kernel: usb usb1: Product: xHCI Host Controller
бер 29 15:10:03 roman-pc kernel: usb usb1: Manufacturer: Linux 5.15.28-1-MANJARO xhci-hcd
бер 29 15:10:03 roman-pc kernel: usb usb1: SerialNumber: 0000:00:14.0
бер 29 15:10:03 roman-pc kernel: hub 1-0:1.0: USB hub found
бер 29 15:10:03 roman-pc kernel: hub 1-0:1.0: 16 ports detected
бер 29 15:10:03 roman-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
бер 29 15:10:03 roman-pc kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
бер 29 15:10:03 roman-pc kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
бер 29 15:10:03 roman-pc kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
бер 29 15:10:03 roman-pc kernel: usb usb2: Product: xHCI Host Controller
бер 29 15:10:03 roman-pc kernel: usb usb2: Manufacturer: Linux 5.15.28-1-MANJARO xhci-hcd
бер 29 15:10:03 roman-pc kernel: usb usb2: SerialNumber: 0000:00:14.0
бер 29 15:10:03 roman-pc kernel: hub 2-0:1.0: USB hub found
бер 29 15:10:03 roman-pc kernel: hub 2-0:1.0: 8 ports detected
бер 29 15:10:03 roman-pc kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
бер 29 15:10:03 roman-pc kernel: i8042: Warning: Keylock active
бер 29 15:10:03 roman-pc kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
бер 29 15:10:03 roman-pc kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
бер 29 15:10:03 roman-pc kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
бер 29 15:10:03 roman-pc kernel: random: fast init done
бер 29 15:10:03 roman-pc kernel: usb 1-5: new high-speed USB device number 2 using xhci_hcd
бер 29 15:10:03 roman-pc kernel: usb 1-5: New USB device found, idVendor=0bda, idProduct=568a, bcdDevice=65.10
бер 29 15:10:03 roman-pc kernel: usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
бер 29 15:10:03 roman-pc kernel: usb 1-5: Product: Integrated Webcam
бер 29 15:10:03 roman-pc kernel: usb 1-5: Manufacturer: CNFFH36O3264100749B2
бер 29 15:10:03 roman-pc kernel: usb 1-5: SerialNumber: 0x0001
бер 29 15:10:03 roman-pc kernel: usb 1-6: new high-speed USB device number 3 using xhci_hcd
бер 29 15:10:03 roman-pc kernel: usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
бер 29 15:10:03 roman-pc kernel: usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
бер 29 15:10:03 roman-pc kernel: usb 1-6: Product: USB2.0-CRW
бер 29 15:10:03 roman-pc kernel: usb 1-6: Manufacturer: Generic
бер 29 15:10:03 roman-pc kernel: usb 1-6: SerialNumber: 20100201396000000
бер 29 15:10:03 roman-pc kernel: usbcore: registered new interface driver rtsx_usb
бер 29 15:10:03 roman-pc kernel: usb 1-14: new full-speed USB device number 4 using xhci_hcd
бер 29 15:10:03 roman-pc kernel: usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
бер 29 15:10:03 roman-pc kernel: usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
бер 29 15:10:03 roman-pc kernel: PM: Image not found (code -22)
бер 29 15:10:03 roman-pc kernel: EXT4-fs (sdb2): recovery complete
бер 29 15:10:03 roman-pc kernel: EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
бер 29 15:10:03 roman-pc systemd[1]: systemd 250.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
бер 29 15:10:03 roman-pc systemd[1]: Detected architecture x86-64.
бер 29 15:10:03 roman-pc systemd[1]: Hostname set to <roman-pc>.
бер 29 15:10:03 roman-pc systemd[1]: /usr/lib/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
бер 29 15:10:03 roman-pc systemd[1]: Queued start job for default target Graphical Interface.
бер 29 15:10:03 roman-pc systemd[1]: Created slice Slice /system/getty.
бер 29 15:10:03 roman-pc systemd[1]: Created slice Slice /system/modprobe.
бер 29 15:10:03 roman-pc systemd[1]: Created slice Slice /system/systemd-fsck.
бер 29 15:10:03 roman-pc systemd[1]: Created slice User and Session Slice.
бер 29 15:10:03 roman-pc systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
бер 29 15:10:03 roman-pc systemd[1]: Started Forward Password Requests to Wall Directory Watch.
бер 29 15:10:03 roman-pc systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Local Encrypted Volumes.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Login Prompts.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Local Integrity Protected Volumes.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Path Units.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Remote File Systems.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Slice Units.
бер 29 15:10:03 roman-pc systemd[1]: Reached target Local Verity Protected Volumes.
бер 29 15:10:03 roman-pc systemd[1]: Listening on Device-mapper event daemon FIFOs.
бер 29 15:10:03 roman-pc systemd[1]: Listening on LVM2 poll daemon socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on Process Core Dump Socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on Journal Audit Socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on Journal Socket (/dev/log).
бер 29 15:10:03 roman-pc systemd[1]: Listening on Journal Socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on Network Service Netlink Socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on udev Control Socket.
бер 29 15:10:03 roman-pc systemd[1]: Listening on udev Kernel Socket.
бер 29 15:10:03 roman-pc systemd[1]: Mounting Huge Pages File System...
бер 29 15:10:03 roman-pc systemd[1]: Mounting POSIX Message Queue File System...
бер 29 15:10:03 roman-pc systemd[1]: Mounting Kernel Debug File System...
бер 29 15:10:03 roman-pc systemd[1]: Mounting Kernel Trace File System...
бер 29 15:10:03 roman-pc systemd[1]: Starting Create List of Static Device Nodes...
бер 29 15:10:03 roman-pc systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
бер 29 15:10:03 roman-pc systemd[1]: Starting Load Kernel Module configfs...
бер 29 15:10:03 roman-pc systemd[1]: Starting Load Kernel Module drm...
бер 29 15:10:03 roman-pc systemd[1]: Starting Load Kernel Module fuse...
бер 29 15:10:03 roman-pc systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
бер 29 15:10:03 roman-pc systemd[1]: Starting Journal Service...
бер 29 15:10:03 roman-pc systemd[1]: Starting Load Kernel Modules...
бер 29 15:10:03 roman-pc systemd[1]: Starting Generate network units from Kernel command line...
бер 29 15:10:03 roman-pc systemd[1]: Starting Remount Root and Kernel File Systems...
бер 29 15:10:03 roman-pc systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
бер 29 15:10:03 roman-pc systemd[1]: Starting Coldplug All udev Devices...
бер 29 15:10:03 roman-pc kernel: random: lvm: uninitialized urandom read (4 bytes read)
бер 29 15:10:03 roman-pc systemd[1]: Mounted Huge Pages File System.
бер 29 15:10:03 roman-pc systemd[1]: Mounted POSIX Message Queue File System.
бер 29 15:10:03 roman-pc kernel: EXT4-fs (sdb2): re-mounted. Opts: discard. Quota mode: none.
бер 29 15:10:03 roman-pc systemd[1]: Mounted Kernel Debug File System.
бер 29 15:10:03 roman-pc systemd[1]: Mounted Kernel Trace File System.
бер 29 15:10:03 roman-pc kernel: bbswitch: loading out-of-tree module taints kernel.
бер 29 15:10:03 roman-pc kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
бер 29 15:10:03 roman-pc kernel: bbswitch: version 0.8
бер 29 15:10:03 roman-pc kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
бер 29 15:10:03 roman-pc kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
бер 29 15:10:03 roman-pc kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
бер 29 15:10:03 roman-pc kernel: bbswitch: detected an Optimus _DSM function
бер 29 15:10:03 roman-pc kernel: pci 0000:01:00.0: enabling device (0006 -> 0007)
бер 29 15:10:03 roman-pc systemd[1]: Finished Create List of Static Device Nodes.
бер 29 15:10:03 roman-pc kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is on
бер 29 15:10:03 roman-pc systemd[1]: modprobe@configfs.service: Deactivated successfully.
бер 29 15:10:03 roman-pc systemd[1]: Finished Load Kernel Module configfs.
бер 29 15:10:03 roman-pc systemd[1]: modprobe@drm.service: Deactivated successfully.
бер 29 15:10:03 roman-pc systemd[1]: Finished Load Kernel Module drm.
бер 29 15:10:03 roman-pc systemd[1]: Finished Generate network units from Kernel command line.
бер 29 15:10:03 roman-pc kernel: audit: type=1130 audit(1648555803.630:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: Finished Remount Root and Kernel File Systems.
бер 29 15:10:03 roman-pc kernel: fuse: init (API version 7.34)
бер 29 15:10:03 roman-pc kernel: audit: type=1130 audit(1648555803.633:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: modprobe@fuse.service: Deactivated successfully.
бер 29 15:10:03 roman-pc systemd[1]: Finished Load Kernel Module fuse.
бер 29 15:10:03 roman-pc kernel: audit: type=1130 audit(1648555803.633:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc kernel: audit: type=1131 audit(1648555803.633:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: Reached target Preparation for Network.
бер 29 15:10:03 roman-pc systemd[1]: Mounting FUSE Control File System...
бер 29 15:10:03 roman-pc systemd[1]: Mounting Kernel Configuration File System...
бер 29 15:10:03 roman-pc systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
бер 29 15:10:03 roman-pc systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
бер 29 15:10:03 roman-pc systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
бер 29 15:10:03 roman-pc systemd[1]: Starting Create Static Device Nodes in /dev...
бер 29 15:10:03 roman-pc systemd[1]: Mounted FUSE Control File System.
бер 29 15:10:03 roman-pc systemd[1]: Mounted Kernel Configuration File System.
бер 29 15:10:03 roman-pc systemd-journald[313]: Journal started
бер 29 15:10:03 roman-pc systemd-journald[313]: Runtime Journal (/run/log/journal/5f506f02647b4d059ed0512003d1d641) is 8.0M, max 793.0M, 785.0M free.
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd-modules-load[314]: Inserted module 'bbswitch'
бер 29 15:10:03 roman-pc systemd[1]: Started Journal Service.
бер 29 15:10:03 roman-pc systemd-modules-load[314]: Inserted module 'crypto_user'
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd-modules-load[314]: Inserted module 'acpi_call'
бер 29 15:10:03 roman-pc kernel: audit: type=1130 audit(1648555803.660:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: Finished Create Static Device Nodes in /dev.
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc audit: BPF prog-id=6 op=LOAD
бер 29 15:10:03 roman-pc audit: BPF prog-id=7 op=LOAD
бер 29 15:10:03 roman-pc audit: BPF prog-id=8 op=LOAD
бер 29 15:10:03 roman-pc kernel: audit: type=1130 audit(1648555803.670:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc kernel: audit: type=1334 audit(1648555803.670:8): prog-id=6 op=LOAD
бер 29 15:10:03 roman-pc kernel: audit: type=1334 audit(1648555803.670:9): prog-id=7 op=LOAD
бер 29 15:10:03 roman-pc kernel: audit: type=1334 audit(1648555803.670:10): prog-id=8 op=LOAD
бер 29 15:10:03 roman-pc systemd[1]: Starting Rule-based Manager for Device Events and Files...
бер 29 15:10:03 roman-pc systemd[1]: Finished Coldplug All udev Devices.
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc systemd[1]: Reached target Preparation for Local File Systems.
бер 29 15:10:03 roman-pc systemd-udevd[324]: Configuration file /usr/lib/udev/rules.d/77-mm-fibocom-port-types.rules is marked executable. Please remove executable permission bits. Proceeding anyway.
бер 29 15:10:03 roman-pc systemd[1]: Started Rule-based Manager for Device Events and Files.
бер 29 15:10:03 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:03 roman-pc kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
бер 29 15:10:03 roman-pc kernel: input: Intel HID events as /devices/platform/INT33D5:00/input/input6
бер 29 15:10:03 roman-pc kernel: intel-hid INT33D5:00: platform supports 5 button array
бер 29 15:10:03 roman-pc kernel: wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
бер 29 15:10:03 roman-pc kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
бер 29 15:10:03 roman-pc kernel: input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input7
бер 29 15:10:03 roman-pc kernel: random: key-mapper-cont: uninitialized urandom read (24 bytes read)
бер 29 15:10:03 roman-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
бер 29 15:10:03 roman-pc kernel: Disabling lock debugging due to kernel taint
бер 29 15:10:04 roman-pc kernel: intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
бер 29 15:10:04 roman-pc kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
бер 29 15:10:04 roman-pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
бер 29 15:10:04 roman-pc kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
бер 29 15:10:04 roman-pc mtp-probe[388]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5"
бер 29 15:10:04 roman-pc mtp-probe[388]: bus: 1, device: 2 was not an MTP device
бер 29 15:10:04 roman-pc kernel: intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
бер 29 15:10:04 roman-pc kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
бер 29 15:10:04 roman-pc systemd-udevd[339]: input2: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[361]: input1: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[347]: input0: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[333]: input3: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:04 roman-pc mtp-probe[399]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6"
бер 29 15:10:04 roman-pc mtp-probe[399]: bus: 1, device: 3 was not an MTP device
бер 29 15:10:04 roman-pc kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
бер 29 15:10:04 roman-pc kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
бер 29 15:10:04 roman-pc systemd-udevd[356]: sda4: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda4/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc systemd-udevd[325]: sda1: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda1/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc systemd-udevd[334]: sda2: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda2/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc kernel: ioremap error for 0x7ace6000-0x7ace7000, requested 0x2, got 0x0
бер 29 15:10:04 roman-pc kernel: ucsi_acpi: probe of USBC000:00 failed with error -12
бер 29 15:10:04 roman-pc systemd-udevd[340]: sdb1: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb/sdb1/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc systemd-udevd[343]: sdb2: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb/sdb2/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc systemd-udevd[336]: sda3: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda/sda3/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  510.54  Tue Feb  8 04:42:21 UTC 2022
бер 29 15:10:04 roman-pc systemd-udevd[339]: event2: Process '/bin/key-mapper-control --command autoload --device /dev/input/event2' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[339]: sdb3: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb/sdb3/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc kernel: mc: Linux media interface: v0.10
бер 29 15:10:04 roman-pc systemd-udevd[347]: event0: Process '/bin/key-mapper-control --command autoload --device /dev/input/event0' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[361]: event1: Process '/bin/key-mapper-control --command autoload --device /dev/input/event1' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[333]: event3: Process '/bin/key-mapper-control --command autoload --device /dev/input/event3' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd-udevd[347]: sdb4: /etc/udev/rules.d/99-disable-polling.rules:1 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb/sdb4/events_poll_msecs}, ignoring: No such file or directory
бер 29 15:10:04 roman-pc systemd[1]: Found device ST2000LM007-1R8174 var.
бер 29 15:10:04 roman-pc systemd[1]: Found device ST2000LM007-1R8174 Video.
бер 29 15:10:04 roman-pc systemd[1]: Found device ST2000LM007-1R8174 Music.
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/04b74089-4a64-43f4-afa9-ffea7b6cb0b5...
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/821ea29a-ea1f-4aeb-8658-e293f9046d4b...
бер 29 15:10:04 roman-pc kernel: input: DELL0886:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0886:00/0018:06CB:7E92.0001/input/input8
бер 29 15:10:04 roman-pc kernel: input: DELL0886:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0886:00/0018:06CB:7E92.0001/input/input9
бер 29 15:10:04 roman-pc kernel: hid-generic 0018:06CB:7E92.0001: input,hidraw0: I2C HID v1.00 Mouse [DELL0886:00 06CB:7E92] on i2c-DELL0886:00
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/a51c81a4-a4b9-422e-912f-e08a5c8d0d31...
бер 29 15:10:04 roman-pc systemd[1]: Found device SK_hynix_SC311_SATA_256GB EFI.
бер 29 15:10:04 roman-pc systemd-udevd[356]: input4: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:04 roman-pc systemd[1]: Found device ST2000LM007-1R8174 Data.
бер 29 15:10:04 roman-pc systemd[1]: Found device SK_hynix_SC311_SATA_256GB 3.
бер 29 15:10:04 roman-pc systemd[1]: Found device SK_hynix_SC311_SATA_256GB 4.
бер 29 15:10:04 roman-pc systemd[1]: Activating swap /dev/disk/by-uuid/1a692f9b-337c-4cfa-81e9-a514be6aa511...
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/27bc111f-0627-4f8e-aad9-f5b08eb60e14...
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/45D5-9BC5...
бер 29 15:10:04 roman-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/f19fe205-c411-40ff-b63a-165435acb85d...
бер 29 15:10:04 roman-pc systemd-modules-load[314]: Inserted module 'nvidia'
бер 29 15:10:04 roman-pc kernel: checking generic (80000000 7f0000) vs hw (eb000000 1000000)
бер 29 15:10:04 roman-pc kernel: checking generic (80000000 7f0000) vs hw (80000000 10000000)
бер 29 15:10:04 roman-pc kernel: fb0: switching to i915 from EFI VGA
бер 29 15:10:04 roman-pc kernel: Console: switching to colour dummy device 80x25
бер 29 15:10:04 roman-pc kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
бер 29 15:10:04 roman-pc kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  510.54  Tue Feb  8 04:34:06 UTC 2022
бер 29 15:10:04 roman-pc kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
бер 29 15:10:04 roman-pc kernel: i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
бер 29 15:10:04 roman-pc kernel: i915 0000:00:02.0: [drm] [ENCODER:118:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
бер 29 15:10:04 roman-pc systemd-fsck[432]: var: recovering journal
бер 29 15:10:04 roman-pc kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
бер 29 15:10:04 roman-pc systemd-udevd[356]: event4: Process '/bin/key-mapper-control --command autoload --device /dev/input/event4' failed with exit code 1.
бер 29 15:10:04 roman-pc kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
бер 29 15:10:04 roman-pc kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
бер 29 15:10:04 roman-pc kernel: ACPI: video: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
бер 29 15:10:04 roman-pc kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input13
бер 29 15:10:04 roman-pc kernel: RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
бер 29 15:10:04 roman-pc kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
бер 29 15:10:04 roman-pc kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
бер 29 15:10:04 roman-pc kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
бер 29 15:10:04 roman-pc kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
бер 29 15:10:04 roman-pc kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
бер 29 15:10:04 roman-pc kernel: videodev: Linux video capture interface: v2.00
бер 29 15:10:04 roman-pc kernel: Bluetooth: Core ver 2.22
бер 29 15:10:04 roman-pc kernel: NET: Registered PF_BLUETOOTH protocol family
бер 29 15:10:04 roman-pc kernel: Bluetooth: HCI device and connection manager initialized
бер 29 15:10:04 roman-pc kernel: Bluetooth: HCI socket layer initialized
бер 29 15:10:04 roman-pc kernel: Bluetooth: L2CAP socket layer initialized
бер 29 15:10:04 roman-pc kernel: Bluetooth: SCO socket layer initialized
бер 29 15:10:04 roman-pc kernel: random: crng init done
бер 29 15:10:04 roman-pc kernel: random: 7 urandom warning(s) missed due to ratelimiting
бер 29 15:10:04 roman-pc systemd-udevd[358]: input6: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:05 roman-pc kernel: fbcon: i915drmfb (fb0) is primary device
бер 29 15:10:05 roman-pc systemd-udevd[358]: event5: Process '/bin/key-mapper-control --command autoload --device /dev/input/event5' failed with exit code 1.
бер 29 15:10:05 roman-pc systemd-udevd[358]: input7: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:05 roman-pc kernel: cryptd: max_cpu_qlen set to 1000
бер 29 15:10:05 roman-pc kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
бер 29 15:10:05 roman-pc kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
бер 29 15:10:05 roman-pc kernel: i2c i2c-9: 2/2 memory slots populated (from DMI)
бер 29 15:10:05 roman-pc kernel: i2c i2c-9: Successfully instantiated SPD at 0x50
бер 29 15:10:05 roman-pc systemd-udevd[345]: event6: Process '/bin/key-mapper-control --command autoload --device /dev/input/event6' failed with exit code 1.
бер 29 15:10:05 roman-pc kernel: Adding 17907708k swap on /dev/sdb4.  Priority:-2 extents:1 across:17907708k SSDscFS
бер 29 15:10:05 roman-pc kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
бер 29 15:10:05 roman-pc systemd[1]: Activated swap /dev/disk/by-uuid/1a692f9b-337c-4cfa-81e9-a514be6aa511.
бер 29 15:10:05 roman-pc kernel: dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
бер 29 15:10:05 roman-pc kernel: intel_rapl_common: Found RAPL domain package
бер 29 15:10:05 roman-pc kernel: intel_rapl_common: Found RAPL domain core
бер 29 15:10:05 roman-pc kernel: intel_rapl_common: Found RAPL domain uncore
бер 29 15:10:05 roman-pc kernel: intel_rapl_common: Found RAPL domain dram
бер 29 15:10:05 roman-pc kernel: intel_rapl_common: Found RAPL domain psys
бер 29 15:10:05 roman-pc kernel: Intel(R) Wireless WiFi driver for Linux
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
бер 29 15:10:05 roman-pc systemd-udevd[357]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
бер 29 15:10:05 roman-pc kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
бер 29 15:10:05 roman-pc systemd-udevd[345]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \  -f 1) 255'' failed with exit code 1.
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
бер 29 15:10:05 roman-pc kernel: iwlwifi 0000:00:14.3: loaded firmware version 46.fae53a8b.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
бер 29 15:10:05 roman-pc kernel: AVX2 version of gcm_enc/dec engaged.
бер 29 15:10:05 roman-pc kernel: AES CTR mode by8 optimization enabled
бер 29 15:10:05 roman-pc kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
бер 29 15:10:05 roman-pc systemd-udevd[327]: input12: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:05 roman-pc systemd-udevd[357]: input13: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:05 roman-pc systemd-udevd[363]: video4linux: Process '/usr/lib/snapd/snap-device-helper add snap_skype_skype /class/video4linux 0:0' failed with exit code 1.
бер 29 15:10:05 roman-pc systemd-fsck[496]: /dev/sdb3: recovering journal
бер 29 15:10:05 roman-pc kernel: input: DELL0886:00 06CB:7E92 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0886:00/0018:06CB:7E92.0001/input/input14
бер 29 15:10:05 roman-pc kernel: input: DELL0886:00 06CB:7E92 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0886:00/0018:06CB:7E92.0001/input/input15
бер 29 15:10:05 roman-pc kernel: hid-multitouch 0018:06CB:7E92.0001: input,hidraw0: I2C HID v1.00 Mouse [DELL0886:00 06CB:7E92] on i2c-DELL0886:00
бер 29 15:10:05 roman-pc systemd-fsck[516]: fsck.fat 4.2 (2021-01-31)
бер 29 15:10:05 roman-pc systemd-fsck[516]: There are differences between boot sector and its backup.
бер 29 15:10:05 roman-pc systemd-fsck[516]: This is mostly harmless. Differences: (offset:original/backup)
бер 29 15:10:05 roman-pc systemd-fsck[516]:   65:01/00
бер 29 15:10:05 roman-pc systemd-fsck[516]:   Not automatically fixing this.
бер 29 15:10:05 roman-pc systemd-fsck[516]: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
бер 29 15:10:05 roman-pc systemd-fsck[516]:  Automatically removing dirty bit.
бер 29 15:10:05 roman-pc systemd-fsck[516]: *** Filesystem was changed ***
бер 29 15:10:05 roman-pc systemd-fsck[516]: Writing changes.
бер 29 15:10:05 roman-pc systemd-fsck[516]: /dev/sdb1: 10 files, 70/76646 clusters
бер 29 15:10:05 roman-pc systemd-udevd[327]: event9: Process '/bin/key-mapper-control --command autoload --device /dev/input/event9' failed with exit code 1.
бер 29 15:10:05 roman-pc systemd-udevd[357]: event10: Process '/bin/key-mapper-control --command autoload --device /dev/input/event10' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2405896 (uid=1000, gid=1000, mode=0100644, size=20380)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2405893 (uid=1000, gid=1000, mode=0100644, size=59656)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2405890 (uid=1000, gid=1000, mode=0100644, size=44216)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2387362 (uid=1000, gid=1000, mode=0100644, size=38140)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2893640 (uid=1000, gid=1000, mode=0100644, size=32768)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2893621 (uid=1000, gid=1000, mode=0100600, size=153816)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2388934 (uid=1000, gid=1000, mode=0100644, size=10492)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2388904 (uid=1000, gid=1000, mode=0100644, size=1200021)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2389162 (uid=1000, gid=1000, mode=0100644, size=10492)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2893332 (uid=1000, gid=1000, mode=0100644, size=32768)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2892767 (uid=1000, gid=1000, mode=0100600, size=152092)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2755900 (uid=1000, gid=1000, mode=040700, size=4096)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: Clearing orphaned inode 2387130 (uid=1000, gid=1000, mode=0100600, size=4194304)
бер 29 15:10:06 roman-pc systemd-fsck[496]: /dev/sdb3: clean, 311726/12664832 files, 7829084/50634240 blocks
бер 29 15:10:06 roman-pc kernel: Console: switching to colour frame buffer device 240x67
бер 29 15:10:06 roman-pc kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
бер 29 15:10:06 roman-pc kernel: intel-spi 0000:00:1f.5: w25q128 (16384 Kbytes)
бер 29 15:10:06 roman-pc kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
бер 29 15:10:06 roman-pc kernel: mousedev: PS/2 mouse device common for all mice
бер 29 15:10:06 roman-pc kernel: Creating 1 MTD partitions on "0000:00:1f.5":
бер 29 15:10:06 roman-pc kernel: 0x000000000000-0x000001000000 : "BIOS"
бер 29 15:10:06 roman-pc kernel: ACPI Error: No pointer back to namespace node in package 00000000df6b9eff (20210730/dsargs-301)
бер 29 15:10:06 roman-pc kernel: ACPI Error: Aborting method \_SB.PCI0.B0D4.PPCC due to previous error (AE_AML_INTERNAL) (20210730/psparse-529)
бер 29 15:10:06 roman-pc kernel: input: Dell WMI hotkeys as /devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input17
бер 29 15:10:06 roman-pc kernel: r8169 0000:3b:00.0 eth0: RTL8168h/8111h, 3c:2c:30:99:09:d6, XID 541, IRQ 136
бер 29 15:10:06 roman-pc kernel: r8169 0000:3b:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
бер 29 15:10:06 roman-pc kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
бер 29 15:10:06 roman-pc kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
бер 29 15:10:06 roman-pc kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
бер 29 15:10:06 roman-pc kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
бер 29 15:10:06 roman-pc kernel: iTCO_vendor_support: vendor-support=0
бер 29 15:10:06 roman-pc kernel: usb 1-5: Found UVC 1.00 device Integrated Webcam (0bda:568a)
бер 29 15:10:06 roman-pc systemd-udevd[346]: input8: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[327]: input9: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: input: Integrated Webcam: Integrated W as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input18
бер 29 15:10:06 roman-pc kernel: usbcore: registered new interface driver uvcvideo
бер 29 15:10:06 roman-pc kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x318
бер 29 15:10:06 roman-pc systemd-udevd[353]: Using default interface naming scheme 'v250'.
бер 29 15:10:06 roman-pc kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
бер 29 15:10:06 roman-pc kernel: ee1004 9-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
бер 29 15:10:06 roman-pc kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
бер 29 15:10:06 roman-pc kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
бер 29 15:10:06 roman-pc systemd-udevd[360]: mice: Process '/bin/key-mapper-control --command autoload --device /dev/input/mice' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: intel_tcc_cooling: Programmable TCC Offset detected
бер 29 15:10:06 roman-pc kernel: iwlwifi 0000:00:14.3: base HW address: b4:69:21:52:16:d8
бер 29 15:10:06 roman-pc systemd[1]: Finished File System Check on /dev/disk/by-uuid/45D5-9BC5.
бер 29 15:10:06 roman-pc systemd[1]: Finished File System Check on /dev/disk/by-uuid/f19fe205-c411-40ff-b63a-165435acb85d.
бер 29 15:10:06 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-45D5\x2d9BC5 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:06 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-f19fe205\x2dc411\x2d40ff\x2db63a\x2d165435acb85d comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:06 roman-pc systemd-udevd[356]: input17: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: kauditd_printk_skb: 3 callbacks suppressed
бер 29 15:10:06 roman-pc kernel: audit: type=1130 audit(1648555806.473:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-45D5\x2d9BC5 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:06 roman-pc kernel: audit: type=1130 audit(1648555806.473:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-f19fe205\x2dc411\x2d40ff\x2db63a\x2d165435acb85d comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:06 roman-pc systemd-udevd[346]: event7: Process '/bin/key-mapper-control --command autoload --device /dev/input/event7' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd[1]: Created slice Slice /system/systemd-backlight.
бер 29 15:10:06 roman-pc systemd[1]: Reached target Swaps.
бер 29 15:10:06 roman-pc systemd[1]: Mounting /boot/efi...
бер 29 15:10:06 roman-pc systemd[1]: Mounting /home...
бер 29 15:10:06 roman-pc systemd[1]: Mounting /tmp...
бер 29 15:10:06 roman-pc systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
бер 29 15:10:06 roman-pc systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
бер 29 15:10:06 roman-pc systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
бер 29 15:10:06 roman-pc systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
бер 29 15:10:06 roman-pc systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
бер 29 15:10:06 roman-pc systemd-udevd[332]: input18: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd[1]: Mounted /tmp.
бер 29 15:10:06 roman-pc kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
бер 29 15:10:06 roman-pc systemd-udevd[344]: Using default interface naming scheme 'v250'.
бер 29 15:10:06 roman-pc systemd[1]: Mounted /home.
бер 29 15:10:06 roman-pc kernel: EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: discard. Quota mode: none.
бер 29 15:10:06 roman-pc systemd-udevd[334]: event8: Process '/bin/key-mapper-control --command autoload --device /dev/input/event8' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: usbcore: registered new interface driver btusb
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Device revision is 2
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Secure boot is enabled
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: OTP lock is enabled
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: API lock is enabled
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Debug lock is disabled
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
бер 29 15:10:06 roman-pc kernel: Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
бер 29 15:10:06 roman-pc systemd[1]: Mounted /boot/efi.
бер 29 15:10:06 roman-pc systemd-udevd[360]: event11: Process '/bin/key-mapper-control --command autoload --device /dev/input/event11' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[364]: input14: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[346]: input15: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[329]: event12: Process '/bin/key-mapper-control --command autoload --device /dev/input/event12' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[345]: nvidia: Process '/usr/bin/bash -c 'for i in $(cat /proc/driver/nvidia/gpus/*/information | grep Minor | cut -d \  -f 4); do /usr/bin/mknod -Z -m 666 /dev/nvidia${i} c $(grep nvidia-frontend /proc/devices | cut -d \  -f 1) ${i}; done'' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[360]: event7: Process '/bin/key-mapper-control --command autoload --device /dev/input/event7' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
бер 29 15:10:06 roman-pc kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
бер 29 15:10:06 roman-pc kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
бер 29 15:10:06 roman-pc kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
бер 29 15:10:06 roman-pc kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
бер 29 15:10:06 roman-pc systemd-udevd[358]: input21: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[357]: controlC1: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
бер 29 15:10:06 roman-pc systemd-udevd[336]: input19: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[327]: input22: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[334]: input20: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-modules-load[314]: Inserted module 'nvidia_drm'
бер 29 15:10:06 roman-pc kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
бер 29 15:10:06 roman-pc systemd-udevd[364]: event8: Process '/bin/key-mapper-control --command autoload --device /dev/input/event8' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
бер 29 15:10:06 roman-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
бер 29 15:10:06 roman-pc systemd-udevd[333]: event15: Process '/bin/key-mapper-control --command autoload --device /dev/input/event15' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[329]: event16: Process '/bin/key-mapper-control --command autoload --device /dev/input/event16' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[334]: mouse1: Process '/bin/key-mapper-control --command autoload --device /dev/input/mouse1' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[346]: event14: Process '/bin/key-mapper-control --command autoload --device /dev/input/event14' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[364]: mouse0: Process '/bin/key-mapper-control --command autoload --device /dev/input/mouse0' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[360]: event13: Process '/bin/key-mapper-control --command autoload --device /dev/input/event13' failed with exit code 1.
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
бер 29 15:10:06 roman-pc kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
бер 29 15:10:06 roman-pc systemd-udevd[341]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
бер 29 15:10:06 roman-pc systemd-udevd[327]: input26: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[331]: input28: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[358]: input25: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[340]: input23: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[357]: input27: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:06 roman-pc systemd-udevd[330]: input24: Process '/bin/key-mapper-control --command autoload --device ' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[360]: event22: Process '/bin/key-mapper-control --command autoload --device /dev/input/event22' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[333]: event20: Process '/bin/key-mapper-control --command autoload --device /dev/input/event20' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[364]: event19: Process '/bin/key-mapper-control --command autoload --device /dev/input/event19' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[329]: event17: Process '/bin/key-mapper-control --command autoload --device /dev/input/event17' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[342]: event21: Process '/bin/key-mapper-control --command autoload --device /dev/input/event21' failed with exit code 1.
бер 29 15:10:07 roman-pc systemd-udevd[346]: event18: Process '/bin/key-mapper-control --command autoload --device /dev/input/event18' failed with exit code 1.
бер 29 15:10:07 roman-pc kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
бер 29 15:10:07 roman-pc systemd-modules-load[314]: Inserted module 'nvidia_uvm'
бер 29 15:10:07 roman-pc kernel: nvidia-uvm: Loaded the UVM driver, major device number 507.
бер 29 15:10:07 roman-pc systemd-modules-load[314]: Inserted module 'uinput'
бер 29 15:10:07 roman-pc systemd[1]: Finished Load Kernel Modules.
бер 29 15:10:07 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc kernel: audit: type=1130 audit(1648555807.047:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc systemd[1]: Starting Apply Kernel Variables...
бер 29 15:10:07 roman-pc systemd[1]: Finished Apply Kernel Variables.
бер 29 15:10:07 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc audit: BPF prog-id=9 op=LOAD
бер 29 15:10:07 roman-pc systemd[1]: Starting Network Configuration...
бер 29 15:10:07 roman-pc kernel: audit: type=1130 audit(1648555807.067:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc kernel: audit: type=1334 audit(1648555807.067:18): prog-id=9 op=LOAD
бер 29 15:10:07 roman-pc systemd-networkd[694]: lo: Link UP
бер 29 15:10:07 roman-pc systemd-networkd[694]: lo: Gained carrier
бер 29 15:10:07 roman-pc systemd-networkd[694]: Enumeration completed
бер 29 15:10:07 roman-pc systemd[1]: Started Network Configuration.
бер 29 15:10:07 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc kernel: audit: type=1130 audit(1648555807.110:19): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:07 roman-pc systemd[1]: Starting Wait for Network to be Configured...
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Waiting for firmware download to complete
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Firmware loaded in 1623569 usecs
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Waiting for device to boot
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Device booted in 13668 usecs
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
бер 29 15:10:08 roman-pc kernel: Bluetooth: hci0: Firmware revision 0.1 build 174 week 4 2022
бер 29 15:10:11 roman-pc systemd-fsck[432]: var: clean, 161162/6111232 files, 5281281/24415232 blocks
бер 29 15:10:11 roman-pc systemd[1]: Finished File System Check on /dev/disk/by-uuid/a51c81a4-a4b9-422e-912f-e08a5c8d0d31.
бер 29 15:10:11 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-a51c81a4\x2da4b9\x2d422e\x2d912f\x2de08a5c8d0d31 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:11 roman-pc systemd[1]: var.mount: Directory /var to mount over is not empty, mounting anyway.
бер 29 15:10:11 roman-pc kernel: audit: type=1130 audit(1648555811.203:20): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-a51c81a4\x2da4b9\x2d422e\x2d912f\x2de08a5c8d0d31 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:11 roman-pc systemd[1]: Mounting /var...
бер 29 15:10:11 roman-pc kernel: EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
бер 29 15:10:11 roman-pc systemd[1]: Mounted /var.
бер 29 15:10:11 roman-pc systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
бер 29 15:10:11 roman-pc systemd-fsck[696]: Video: recovering journal
бер 29 15:10:11 roman-pc systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for bare, revision 5...
бер 29 15:10:12 roman-pc kernel: loop: module loaded
бер 29 15:10:12 roman-pc kernel: loop0: detected capacity change from 0 to 8
бер 29 15:10:12 roman-pc kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for core18, revision 2284...
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for core18, revision 2344...
бер 29 15:10:12 roman-pc kernel: loop1: detected capacity change from 0 to 113680
бер 29 15:10:12 roman-pc kernel: loop2: detected capacity change from 0 to 113696
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 145...
бер 29 15:10:12 roman-pc kernel: loop3: detected capacity change from 0 to 333552
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 161...
бер 29 15:10:12 roman-pc kernel: loop4: detected capacity change from 0 to 337424
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for gnome-3-34-1804, revision 77...
бер 29 15:10:12 roman-pc kernel: loop5: detected capacity change from 0 to 448512
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1515...
бер 29 15:10:12 roman-pc kernel: loop6: detected capacity change from 0 to 133320
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1519...
бер 29 15:10:12 roman-pc kernel: loop7: detected capacity change from 0 to 133552
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for skype, revision 203...
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for skype, revision 206...
бер 29 15:10:12 roman-pc kernel: loop8: detected capacity change from 0 to 311600
бер 29 15:10:12 roman-pc kernel: loop9: detected capacity change from 0 to 312088
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for snapd, revision 14978...
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for snapd, revision 15177...
бер 29 15:10:12 roman-pc kernel: loop10: detected capacity change from 0 to 89264
бер 29 15:10:12 roman-pc kernel: loop11: detected capacity change from 0 to 89352
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for video-downloader, revision 857...
бер 29 15:10:12 roman-pc systemd[1]: Mounting Mount unit for video-downloader, revision 860...
бер 29 15:10:12 roman-pc systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
бер 29 15:10:12 roman-pc kernel: loop12: detected capacity change from 0 to 47512
бер 29 15:10:12 roman-pc systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:dell::kbd_backlight...
бер 29 15:10:12 roman-pc kernel: loop13: detected capacity change from 0 to 48168
бер 29 15:10:12 roman-pc systemd[1]: Starting Flush Journal to Persistent Storage...
бер 29 15:10:12 roman-pc systemd[1]: Starting Load/Save Random Seed...
бер 29 15:10:12 roman-pc systemd-journald[313]: Time spent on flushing to /var/log/journal/5f506f02647b4d059ed0512003d1d641 is 15.856ms for 1307 entries.
бер 29 15:10:12 roman-pc systemd-journald[313]: System Journal (/var/log/journal/5f506f02647b4d059ed0512003d1d641) is 61.1M, max 50.0M, 0B free.
бер 29 15:10:16 roman-pc systemd-journald[313]: Received client request to flush runtime journal.
бер 29 15:10:16 roman-pc kernel: audit: type=1130 audit(1648555813.233:21): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:dell::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:16 roman-pc kernel: audit: type=1130 audit(1648555813.263:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:16 roman-pc kernel: audit: type=1130 audit(1648555813.443:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:16 roman-pc kernel: audit: type=1130 audit(1648555813.647:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:16 roman-pc systemd-journald[313]: File /var/log/journal/5f506f02647b4d059ed0512003d1d641/system.journal corrupted or uncleanly shut down, renaming and replacing.
бер 29 15:10:13 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:dell::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:13 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:13 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:13 roman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for bare, revision 5.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for core18, revision 2284.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for core18, revision 2344.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 145.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 161.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for gnome-3-34-1804, revision 77.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1519.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for snapd, revision 15177.
бер 29 15:10:12 roman-pc systemd[1]: Starting Load/Save RF Kill Switch Status...
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for skype, revision 206.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for skype, revision 203.
бер 29 15:10:12 roman-pc systemd[1]: Mounted Mount unit for video-downloader, revision 860.
бер 29 15:10:13 roman-pc systemd[1]: Mounted Mount unit for snapd, revision 14978.
бер 29 15:10:13 roman-pc systemd[1]: Mounted Mount unit for video-downloader, revision 857.
бер 29 15:10:13 roman-pc systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:dell::kbd_backlight.
бер 29 15:10:13 roman-pc systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
бер 29 15:10:13 roman-pc systemd[1]: Started Load/Save RF Kill Switch Status.
бер 29 15:10:13 roman-pc systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1515.
бер 29 15:10:13 roman-pc systemd[1]: Finished Load/Save Random Seed.
бер 29 15:10:13 roman-pc systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
бер 29 15:10:16 roman-pc systemd[1]: Finished Flush Journal to Persistent Storage.
UPD: now it happens every day (more crappy).
I see no kernel panic anywhere in the logs provided
vs. what the topic and title is …
so, the actual issue might be … a different one
I just presumed basing on some old archived manjaro/arch topics like Kernel panic on laptop even with different hdd, [SOLVED]Blinking Caps lock LED / Kernel & Hardware / Arch Linux Forums
Changed the title to “Unable to resume from suspend with blinking caps-lock”, (but that won’t solve the issue) now it craps every day (losing all my activated virtual environments and some opened applications).
This looks like systemctl -b0 output instead of systemctl -b-1 output.
I’d figure a kernal panic would be logged here but it’s entirely possible it doesn’t get a chance as the ArchWiki points out.
kdump could be configured. but it appears to be involved since you might need to compile your own version of the kernel to enable the flags to allow kdump to work. Turns out the current Arch (and by consequence Manjaro) might already have these flags configured. It’ll store a dump on disk when configured correctly for investigation.
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate
Approximately the last 6 months I’m experiencing an explicit dependency between the implied problem and specific system event.
The blinking caps-lock crash on resume now seems to be tied to a hidden, ongoing plasma-discover updates.
A typical chronology:
I suspend the laptop → Trying to resume: having caps-lock crash → Performing power Off/power On → Login in and seeing plasma-discover pop-up with an upcoming updates which I could not be aware/noticed of.|
And the above happens systematically (in terms of their dependency).
Is there any way to make plasma-discover to show its pop-up before crashing the machine?
This could be related to packagekit and discover - please see KDE - ArchWiki
It is strange to see Nvidia drivers loaded using flatpak.
If that is the cause - I suggest you remove the flatpak version - then install the drivers supplied using the repo.
If I uncheck a flatpak source, would it make a positive impact on the issue?
$ flatpak list
Name                  Application ID                                Version      Branch       Installation
Skype                 com.skype.Client                              8.109.0.209  stable       system
Freedesktop Platform  org.freedesktop.Platform                      22.08.23     22.08        system
Mesa                  org.freedesktop.Platform.GL.default           24.0.3       22.08        system
Mesa (Extra)          org.freedesktop.Platform.GL.default           24.0.3       22.08-extra  system
nvidia-550-54-14      org.freedesktop.Platform.GL.nvidia-550-54-14               1.4          system
Intel                 org.freedesktop.Platform.VAAPI.Intel                       22.08        system
openh264              org.freedesktop.Platform.openh264             2.1.0        2.2.0        system
I don’t know - no harm done trying
Ok, thanks. I’ll try that, if no success - I’ll follow your topic [root tip] [How To] Removing a flatpak app for removing flatpak with sudo pacman -Rns flatpak libpamac-flatpak-plugin & pacman -Syu
