Hi, I noticed that I have lua5.2
and relate binaries in my Manjaro system. Running sudo pacman -R lua
or sudo pacman -R lua5.2
will yield error: target not found: lua-5.2
. Runnig pacman -S lua
will install lua5.4
alongside lua5.2
. Is it normal to not be able to uninstall this old release or there’s something that I can do to remove it?
Thank you very much for your time.
