Hi,
I was without internet for a few weeks. After I reconnected and updated my laptop. The system crashed, so it kept going to the bios.
I burnt a live usb and booting it I can still see the data on my internal drive. However, every time I try to so anything with it, the program crashes.
Any idea on how to move that data on an external drive?
Unfortunately, I can’t provide adjourned data. This is from my last post:
Kernel: 5.15.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a2516510-96ae-4a13-ba0c-413ba8b9a795 rw quiet
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 5570 v: N/A
Mobo: Dell model: 0DRPKR v: X07 serial: <superuser required> UEFI: Dell
v: 1.0.0 date: 08/07/2017
ID-1: BAT0 charge: 31.4 Wh (100.0%) condition: 31.4/42.0 Wh (74.8%)
volts: 12.8 min: 11.4 model: SMP DELL Y3F7Y6B type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_5 model: Logitech MX Keys Wireless Keyboard
status: discharging
RAM: total: 7.54 GiB used: 3.55 GiB (47.0%)
RAM Report:
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 797 high: 800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 790 2: 797 3: 800 4: 792
5: 800 6: 800 7: 800 8: 800 bogomips: 28808
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel ports:
active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile]
vendor: Dell driver: amdgpu v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 1002:6900 class-ID: 0380
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:6a06 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: amdgpu,modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
s-diag: 599mm (23.6")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: HP LA2405x
serial: <filter> built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: eDP-1 pos: primary model: BOE Display 0x06a9 built: 2015
res: 1680x1050 dpi: 124 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.36-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:6
chip-ID: 0cf3:e009 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 34 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 149.3 GiB (62.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P10 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C2
dev-links: cdrom
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 149.3 GiB (64.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a2516510-96ae-4a13-ba0c-413ba8b9a795
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F8AA-DE62
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:77 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-2:80 info: Logitech USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c06a class-ID: 0301
Device-3: 1-3:81 info: Dell Keyboard SK-8115 type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 70mA chip-ID: 413c:2003 class-ID: 0301
Device-4: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
Device-5: 1-6:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-6: 1-7:6 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C pch: 47.0 C mobo: 44.0 C sodimm: SODIMM C
gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): cpu: 2802
Processes: 283 Uptime: 12d 3h 32m wakeups: 353 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1598
lib: 343 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
-> Updating rstudio git repo...
Fetching origin
-> Found gin-2.1.2.zip
-> Found gwt-2.9.0.zip
-> Found qt.conf
-> Found cran_multithread.patch
-> Found nodejs-external.patch
rstudio ... Skipped
gin-2.1.2.zip ... Passed
gwt-2.9.0.zip ... Passed
qt.conf ... Passed
cran_multithread.patch ... Passed
nodejs-external.patch ... Passed
==> Extracting sources...
-> Creating working copy of rstudio git repo...
Cloning into 'rstudio'...
done.
Updating files: 100% (8447/8447), done.
-> Extracting gwt-2.9.0.zip with bsdtar
==> Starting prepare()...
Checking patch src/gwt/build.xml...
error: while searching for:
</target>
<!-- panmirror typescript library -->
<property name="node.version" value="10.19.0"/>
<property name="node.dir" value="../../dependencies/common/node/${node.version}"/>
<condition property="node.bin" value="../../../${node.dir}/bin/node">
<not>
<os family="windows" />
</not>
</condition>
<condition property="node.bin" value="${node.dir}/node.exe">
</condition>
<!-- use node from /opt/rstudio-tools if installed (typical for Docker) -->
<available
property="node.bin"
value="/opt/rstudio-tools/dependencies/common/node/${node.version}/bin/node"
file="/opt/rstudio-tools/dependencies/common/node/${node.version}/bin/node"/>
<property name="panmirror.dir" value="./panmirror/src/editor"/>
<property name="panmirror.build.dir" value="./www/js/panmirror"/>
