Unable to play minecraft
Unable to play minecraft on latest unstable
Log
however you installed it
of which we know nothing about
if the thing depends on any AUR packages at all
these have to be
(or rather: might need to be)
rebuilt after an update of the underlying system files
I installed it with prism launcher (Flatpak) and tried to start different versions with java 17 in this log (jdk17-openjdk) from official repos and jre8-openjdk in other try
So used no AUR packages for it
Update:
After further testing, I discovered that:
(I guess my mistake was attaching the picture)
|        minecraft                                                          |
|        GLFW error 65544: EGL: Failed to clear current context: An EGLDisplay argument does not name a valid EGL display connection. |
|  πŸ›‘        |
|      Please make sure you have up-to-date drivers (see aka.ms/mcdriver for instructions).                                           |
|        | OK |  |
that
Oh wait, this isn’t Reddit. :stuck_out_tongue_winking_eye:
Please see:
