My new monitor has a 75hz refresh rate, but I’m unable to set it at anything higher than 60hz. 75hz is what’s listed on the box. In Winblows, the correct refresh rate is able to be set; I booted in just to verify this.
Notes:
-I’m connected via HDMI, not Displayport.
-I’m able to verify that there is nothing wrong with the HDMI cable or my video card. My other 2 monitors (I have 3 in total), are able to function at 75hz simultaneously.
NOTE I know that I will not be able to have all 3 monitors to function at 75hz because I have 2 HDMI ports and 2 Displayports. I will only be able to have my monitors function at 75hz when connected to the HDMI ports.
KDE Plasma Version: 5.23.4
KDE Frameworks Version: 5.88.0
Qt Version: 5.15.2
Kernel Version: 5.10.83-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 2700X Eight-Core Processor
Memory: 31.4 GiB of RAM
Graphics Processor: AMD Radeon RX 580 Series
Still can’t select the correct refresh rate. Thought I should post this:
$inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2bb84221-8736-478d-8f20-6c17ab04e608 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M GAMING PLUS (MS-7B87) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/11/2020
RAM: total: 31.37 GiB used: 5.12 GiB (16.3%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4091 high: 4099 min/max: N/A cores: 1: 4080 2: 4087
3: 4094 4: 4094 5: 4097 6: 4099 7: 4063 8: 4097 9: 4087 10: 4087 11: 4094
12: 4095 13: 4098 14: 4099 15: 4099 16: 4089 bogomips: 131241
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 29:00.0
chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6:3 chip-ID: 046d:0892
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2240 s-dpi: 96 s-size: 1520x591mm (59.8x23.3")
s-diag: 1631mm (64.2")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.5") diag: 184mm (7.2")
Monitor-3: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-4: HDMI-A-1 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.10.84-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 29:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2b:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Cluetooth 5.1 Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1.3:7 chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
Info: acl-mtu: 1021:5 sco-mtu: 255:11 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 3.09 TiB used: 1.56 TiB (50.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS500G2B0A
type: SSD serial: <filter> rev: 90WD scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0002 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT275MX300SSD1
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R070 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 90WD
scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate
model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 0219 scheme: MBR
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-1: / raw-size: 465.27 GiB size: 456.97 GiB (98.22%)
used: 309.57 GiB (67.7%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 2bb84221-8736-478d-8f20-6c17ab04e608
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 3C6A-0BA3
ID-3: /media/crucial275 raw-size: 256.17 GiB size: 256.17 GiB (100.00%)
used: 144.34 GiB (56.3%) fs: btrfs block-size: 4096 B dev: /dev/sdd1
maj-min: 8:49 label: crucial275 uuid: 91b24d59-0eeb-4601-98db-1ec74349f15d
ID-4: /media/kingston128 raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 67.69 GiB (61.8%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33 label: kingston128GB
uuid: ff1800f1-d3e2-427e-bd0a-0616f1336b99
ID-5: /media/wd1tb raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 702.46 GiB (75.4%) fs: ntfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: WD1TBstorage uuid: 66B100327273B3A7
ID-6: /media/win10disk raw-size: 465.13 GiB size: 465.13 GiB (100.00%)
used: 369.09 GiB (79.4%) fs: ntfs block-size: 4096 B dev: /dev/sde4
maj-min: 8:68 label: N/A uuid: 34E8AB19E8AAD87E
ID-7: /mnt/wdred raw-size: N/A size: 3.58 TiB used: 1.57 TiB (43.8%)
fs: nfs4 remote: 192.168.1.100:/media/wdred
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /media/kingston128/swapfile
ID-1: /dev/sde1 maj-min: 8:65 size: 529 MiB fs: ntfs label: Recovery
uuid: E0069DA0069D786C
ID-2: /dev/sde2 maj-min: 8:66 size: 100 MiB fs: vfat label: N/A
uuid: C29D-F203
ID-3: /dev/sde3 maj-min: 8:67 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdf1 maj-min: 8:81 size: 931.51 GiB fs: ntfs
label: Seagate Expansion Drive uuid: 02608F85608F7DE3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-6:3 info: Logitech C920 HD Pro Webcam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:2 info: Seagate RSS LLC Expansion type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 144mA
chip-ID: 0bc2:2312 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-1.1:4
info: Shenzhen Riitek wireless mini keyboard with touchpad
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1997:2433 class-ID: 0301
Hub-5: 3-1.2:6 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.2.1:8 info: SHARKOON Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0907 class-ID: 0300 serial: <filter>
Device-2: 3-1.3:7 info: Realtek Cluetooth 5.1 Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 3-2:3 info: Cyber Power System CP1500 AVR UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 50mA chip-ID: 0764:0501 class-ID: 0300
Device-4: 3-4:5 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:fc58 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 4-1:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 05e3:0626 class-ID: 0900
System Temperatures: cpu: 42.2 C mobo: 40.0 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 922 fan-3: 437 fan-4: 524 fan-5: 0
gpu: amdgpu fan: 93
Processes: 511 Uptime: 4m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages: 2268 pacman: 2241
lib: 460 flatpak: 22 snap: 5 Shell: Zsh v: 5.8 running-in: terminator
inxi: 3.3.11
rabcor
January 2, 2022, 5:30am
#3
I don’t know why you think you can’t have 75hz on displayport, displayport is generally much higher spec than hdmi so be it resolution or refresh rate, it should be easier to have both higher on displayport than on hdmi usually.
That said, this sounds like it’s probably a hardware problem, HDMI has different versions with different specs/standards, some of those only support up to a certain resolution/refresh rate combination, but often higher resolution at the cost of refresh rate or vice versa if you lower one to raise the other, it’s a bit complicated sometimes I suppose.
You need to figure out the HDMI version of your monitor and the HDMI version of your GPU and make sure your HDMI cable is compatible with that HDMI version (I’m not sure if the cables are different between standards actually, but it can’t hurt to check).
Easiest solution if it’s available would probably just to connect via DP instead of HDMI.
Word of advice tho, you do not want to have mismatched refresh rates between your monitors, you want to run all of them at 75 or all of them at 60, it’s easiest and simplest to do it that way, you’re bound to run into problems if you try to use variable refresh rate, although I heard some wayland compositors support it maybe.
My friend it’s not that I think I can’t have 75hz on displayport, I know that I can’t. I know my setup, I have 4 screens, I know what refresh rates the screens max out at depending on what port I connect the screens to. Also, this really has nothing to do with display ports are hdmi cables (which have already been tested).
In Windows 10, my new monitor runs at the correct refresh rate of 75hz. In Manjaro, however, my new monitor runs at 60hz.
Anyone have any clues as to what’s happening here?
Thanks!
