Hi, I fell for the memes and am using a Thinkpad x200, however one thing that I have a problem with is that Bluetooth LED icon right next to Wifi is turning on after I’ve turned it off.
I am turning it off with:
$bluetooth off
And the output says:
bluetooth = off (software)
I’ve also tried to turn it off using GUI on my Manjaro XFCE, but that did not make any difference whatsoever.
I’ve also tried to stop the Bluetooth service in systemd, with:
$sudo systemctl stop bluetooth.service
And then disable it with:
$sudo systemctl disable bluetooth.service
And even check if it is inded turned off with:
$systemctl status bluetooth.service
However, none of this helps in the long run. It does help immediately, but within a few 10s of minutes or sometimes even seconds the Bluetooth LED turns on and when I check the state it says that it is, indeed, turned ON. It’s not just a phony LED indication.
Is there anything I can do to permanently turn off Bluetooth? Or at least for as long as I want, until I explicitly turn it on?
