Unable to open flatpakref in Pamac
I visited this flatpak and clicked Install:
This downloads a .flatpakref file. When I open the file (f.e. double click the file in Gnome Files) the Pamac GUI opens, but then nothing happens.
I am, however, able to install the Tidal flatpak using the CLI just fine:
flatpak install flathub com.mastermindzh.tidal-hifi
What information should I provide to help debug?
There is nothing to debug.
Anyone can package an application in flatpak format and provide it for download at an arbitrary location.
A .flatpakref file is reference file pointing the the location of the flatpak.
I strongly advise anyone downloading a flatpakref; only download from a trusted source; evaluate the origin; evaluate the content; make an informed decision about trust before installing the application.
flatpak install <package-name>.flatpakref
EDIT
Added information the flatpakref file format
→ Repositories - Flatpak documentation
If you believe there is an error with the Add / Remove Software application you can create an issue at
And inspect it with a texteditor.
GitHub - Mastermindzh/tidal-hifi: The web version of Tidal running in electron with hifi support thanks to widevine.
Arch Linux users can use the AUR to install TIDAL Hi-Fi
AUR (en) - Packages - tidal-hifi
Name Version Last Updated
tidal-hifi-bin 5.19.0-1 2025-04-22 13:19 (UTC)
tidal-hifi 5.19.0-2 2025-05-07 15:09 (UTC)
tidal-hifi-appimage 5.19.0-1 2025-04-22 13:28 (UTC)
tidal-hifi-git 5.19.0.r0.g79bbab6-1 2025-04-22 11:53 (UTC)
Thanks. I get it, verify installed software as usual. (I did.)
I’m pointing out that I was unable to install using Add / Remove Software, so I thought to be a bug.
Made an issue to describe the expected behavior:
Noooooo thanks. I want stability. AUR is very often not in sync with main repos, so for unofficial packages I’d much rather use flatpak. (I know it may take more disk space but I have plenty).
It is Manjaro Stable that is behind, that cause a lot of issue with AUR unless you know some things about packaging
That is downloaded from flathub
Yep, exactly. Also, even on main Arch Linux sometimes the AUR package maintainers don’t always keep immediately up to date with the base dependencies, and things still break.
wget https://github.com/Mastermindzh/tidal-hifi/releases/download/5.19.0/tidal-hifi-5.19.0.AppImage
chmod +x tidal-hifi-5.19.0.AppImage
./tidal-hifi-5.19..0.AppImage
