Unable to mount iPhone 8 Plus on Manjaro KDE
Hello Friends,
I am using Manjaro KDE on my home desktop Lenovo AIO A340 for a few months now. I recall connecting my iPhone 8 Plus with OS 14.6 to download pictures onto the desktop without any hassles. But for past few days, I am facing a challenge in doing so.
That is when I connect my phone to the desktop, I see that desktop is recognizing a device connected, but shows it as camera. Then when I click mount and open option from Disks and Devices icon in system tray, nothing gets mounted. I tried searching for the device in Dolphin and command line, but not successful, Here are a few screenshots I have taken in this regard. Any pointers to resolve this issue will be highly appreciated. Thank you.
[ganeshp@anuganeshdesktop-a34024iwl ~]$ mtp-detect
libmtp version: 1.1.18
Listing raw device(s)
No raw devices found.
[ganeshp@anuganeshdesktop-a34024iwl ~]$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 174f:243e Syntek Integrated Camera
Bus 001 Device 005: ID 05ac:12a8 Apple, Inc. iPhone 5/5C/5S/6/SE
Bus 001 Device 002: ID 17ef:60a9 Lenovo Lenovo Essential Wireless Keyboard and M
ouse Combo
Bus 001 Device 004: ID 8087:0a2a Intel Corp. Bluetooth wireless interface
[ganeshp@anuganeshdesktop-a34024iwl ~]$ cat /usr/lib/udev/rules.d/69-libmtp.rule
s
# UDEV-style hotplug map for libmtp
# Put this file in /etc/udev/rules.d
ACTION!="add", ACTION!="bind", GOTO="libmtp_rules_end"
ENV{MAJOR}!="?*", GOTO="libmtp_rules_end"
SUBSYSTEM=="usb", GOTO="libmtp_usb_rules"
LABEL="libmtp_usb_rules"
# If we have a hwdb entry for this device, act immediately!
ENV{ID_MTP_DEVICE}=="1", SYMLINK+="libmtp-%k", GOTO="libmtp_rules_end"
# Fall back to probing.
# Some sensitive devices we surely don't wanna probe
# Color instruments
ATTR{idVendor}=="0670", GOTO="libmtp_rules_end"
ATTR{idVendor}=="0765", GOTO="libmtp_rules_end"
ATTR{idVendor}=="085c", GOTO="libmtp_rules_end"
ATTR{idVendor}=="0971", GOTO="libmtp_rules_end"
# Canon scanners that look like MTP devices (PID 0x22nn)
ATTR{idVendor}=="04a9", ATTR{idProduct}=="22*", GOTO="libmtp_rules_end"
# Canon digital camera (EOS 3D) that looks like MTP device (PID 0x3113)
ATTR{idVendor}=="04a9", ATTR{idProduct}=="3113", GOTO="libmtp_rules_end"
# Sensitive Atheros devices that look like MTP devices
ATTR{idVendor}=="0cf3", GOTO="libmtp_rules_end"
# Sensitive Atmel JTAG programmers
ATTR{idVendor}=="03eb", GOTO="libmtp_rules_end"
# Sensitive Philips device
ATTR{idVendor}=="0471", ATTR{idProduct}=="083f", GOTO="libmtp_rules_end"
# DUALi NFC readers
ATTR{idVendor}=="1db2", ATTR{idProduct}=="060*", GOTO="libmtp_rules_end"
# HP printers
ATTR{idVendor}=="03f0", ENV{ID_USB_INTERFACES}=="*:0701??:*|*:ffcc00:", GOTO="li
bmtp_rules_end"
# Printers
ENV{ID_USB_INTERFACES}=="*:0701??:*", GOTO="libmtp_rules_end"
# Autoprobe vendor-specific, communication and PTP devices
ENV{ID_MTP_DEVICE}!="1", ENV{MTP_NO_PROBE}!="1", ENV{COLOR_MEASUREMENT_DEVICE}!=
"1", ENV{ID_GPHOTO}!="1", ENV{libsane_matched}!="yes", ATTR{bDeviceClass}=="00|0
2|06|ef|ff", PROGRAM="/usr/lib/udev/mtp-probe /sys$env{DEVPATH} $attr{busnum} $a
ttr{devnum}", RESULT=="1", SYMLINK+="libmtp-%k", ENV{ID_MTP_DEVICE}="1", ENV{ID_
MEDIA_PLAYER}="1"
LABEL="libmtp_rules_end"
iPhone device presence is acknowledged as Camera -
disksanddevices
When I typed mtp: in url section of dolphin -
Regards
Ganesh
Possible cause/solution?
I would make sure i go once more time trough this iOS - ArchWiki
Hello @anon89812132,
Thank you for your timely advise. I followed the steps as mentioned in the write up. I found ifuse package was not installed on my computer. I installed it from AUR repo using pamac GUI. Created a folder by name iphone in my home folder. Now I am able to open not only photos, but multiple other folders and files. Only one concern though. Each time I try to connect iPhone, I have to run the following commands, without which it wont connect -
idevicepair unpair
ifuse -o allow_other ~/iphone
I wasn’t sure how to unmount, so tried only the following command -
idevicepair unpair
I see a message saying SUCCESS: Unpaired with device xxxxxxxxxx. But even after that I am able to access the phone contents. So I have two queries - first one is there any way I can connect to my phone without running any commands on konsole and second how do I cleanly unpair and disconnect my phone?
Thank you so much.
Regards
Ganesh
Not sure if you don’t have to add your user to a special group, either related to usbmuxd or the ifuse … i’ll have to read more about, as i don’t have any apple device.
I tried a couple of things today to achieve my goal. None of them gave me the results though -
  1. I found one special group relevant to this context usbmux. I added my user id to that group. Restarted the computer. No changes in the behavior. So reverted back to earlier setting.
  2. I found one article in arch forum which said we can comment the last line which will result in usbmuxd exit when device is removed. After commenting i restarted the computer. After restart no change. So reverted back to earlier setting.
[ganeshp@anuganeshdesktop-a34024iwl ~]$ cat /lib/udev/rules.d/39-usbmuxd.rules
'# usbmuxd (Apple Mobile Device Muxer listening on /var/run/usbmuxd)
'# systemd should receive all events relating to device
SUBSYSTEM==“usb”, ENV{DEVTYPE}==“usb_device”, ENV{PRODUCT}==“5ac/12[9a][0-9a-f]/
|5ac/8600/”, TAG+=“systemd”
'# Initialize iOS devices into “deactivated” USB configuration state and activate
usbmuxd
|5ac/8600/”, ACTION==“add”, ENV{USBMUX_SUPPORTED}=“1”, ATTR{bConfigurationValu
e}=“0”, OWNER=“usbmux”, ENV{SYSTEMD_WANTS}=“usbmuxd.service”
'# Make sure properties don’t get lost when bind action is called
|5ac/8600/”, ACTION==“bind”, ENV{USBMUX_SUPPORTED}=“1”, OWNER=“usbmux”, ENV{SY
'# Exit usbmuxd when the last device is removed
|5ac/8600/”, ACTION==“remove”, RUN+=“/usr/bin/usbmuxd -x”
So all I see is I am close to the solution, but not there yet. For now I will manage with the two commands to be executed at konsole i.e. idevicepair pair and ifuse -o allow_other ~/iPhone. Hopefully some better solution will emerge in immediate future. Thanks again.
Regards
Ganesh
Maybe you need to edit the /etc/fuse.conf and uncomment the user_allow_other
Also is interesting that on the ifuse github they still mention to add user to the fuse group
