Unable to mount home partition
Hi there,
After a force shutdown I’ve stuck at emergency mode with no home partition. When I try to chroot with live usb I got mount: /mnt/home: special device /dev/disk/by-uuid/bfeb6b28-92e7-d601-b060-6a2892e7d601 does not exist. error.
      ~  inxi -Fza                                                        ✔
      Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
      parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=tr tz=UTC
      misobasedir=manjaro misolabel=MANJARO_GNOME_2021 quiet
      systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
      radeon.modeset=1
      Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
      Distro: Manjaro Linux
      Type: Laptop System: LENOVO product: 20RBS1L200 v: ThinkPad E14
      serial: <filter> Chassis: type: 10 serial: <filter>
      Mobo: LENOVO model: 20RBS1L200 serial: <filter> UEFI: LENOVO
      v: R16ET28W (1.14 ) date: 09/14/2020
      ID-1: BAT0 charge: 20.1 Wh condition: 45.0/45.0 Wh (100%) volts: 11.3/11.1
      model: LGC 5B10W138 type: Li-poly serial: <filter> status: Discharging
      cycles: 18
      Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
      arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
      microcode: DE L2 cache: 6 MiB
      bogomips: 33615
      Speed: 810 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 810 2: 844
      3: 899 4: 895 5: 887 6: 895 7: 874 8: 847
      Type: srbds mitigation: TSX disabled
      Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
      bus ID: 00:02.0 chip ID: 8086:9b41
      Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
      bus ID: 1-8:4 chip ID: 13d3:5415
      Display: wayland server: X.org 1.20.10 compositor: gnome-shell
      driver: i915 note: n/a (using device driver) - try sudo/root display ID: 0
      OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.1
      direct render: Yes
      Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel
      alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
      Sound Server: ALSA v: k5.9.16-1-MANJARO
      Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
      bus ID: 00:14.3 chip ID: 8086:02f0
      vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
      chip ID: 10ec:8168
      IF: enp4s0 state: down mac: <filter>
      Local Storage: total: 491.85 GiB used: 182.8 MiB (0.0%)
      ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6512G
      size: 476.94 GiB block size: physical: 512 B logical: 512 B
      speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: V1.0 temp: 46.9 C
      ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Glide
      size: 14.91 GiB block size: physical: 512 B logical: 512 B
      serial: <filter> rev: 1.27
      ID-1: / raw size: N/A size: 11.59 GiB used: 182.8 MiB (1.5%) fs: overlay
      source: ERR-102
      System Temperatures: cpu: 41.0 C mobo: 0.0 C
      Fan Speeds (RPM): cpu: 0
      Processes: 273 Uptime: 20m wakeups: 41491 Memory: 15.45 GiB
      used: 2.31 GiB (15.0%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
      pacman: 1285 lib: 368 flatpak: 0 Shell: Zsh v: 5.8
      running in: gnome-terminal inxi: 3.2.01
        ~  lsblk                                                            ✔
    NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
    loop0         7:0    0  75.5M  1 loop /run/miso/sfs/livefs
    loop1         7:1    0 369.5M  1 loop /run/miso/sfs/mhwdfs
    loop2         7:2    0   1.6G  1 loop /run/miso/sfs/desktopfs
    loop3         7:3    0 667.8M  1 loop /run/miso/sfs/rootfs
    sda           8:0    1  14.9G  0 disk /run/miso/bootmnt
    ├─sda1        8:1    1   2.8G  0 part
    └─sda2        8:2    1     4M  0 part
    nvme0n1     259:0    0 476.9G  0 disk
    ├─nvme0n1p1 259:4    0   100M  0 part
    ├─nvme0n1p2 259:5    0    41G  0 part
    └─nvme0n1p3 259:6    0 435.8G  0 part
        ~  blkid                                                            ✔
    /dev/nvme0n1p1: LABEL_FATBOOT="BOOT" LABEL="BOOT" UUID="3463-B740" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="3a576efd-1c07-4709-89e1-d07b90915006"
    /dev/nvme0n1p2: LABEL="root" UUID="c0ffb714-92e7-d601-c095-b61492e7d601" BLOCK_SIZE="2048" TYPE="ext4" PARTUUID="698e6dee-579c-4c00-9710-873616e1fc81"
    /dev/loop0: TYPE="squashfs"
    /dev/loop1: TYPE="squashfs"
    /dev/loop2: TYPE="squashfs"
    /dev/loop3: TYPE="squashfs"
    /dev/sda1: BLOCK_SIZE="2048" UUID="2021-01-03-11-22-21-00" LABEL="MANJARO_GNOME_2021" TYPE="iso9660"
    /dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="784C-16A2" BLOCK_SIZE="512" TYPE="vfat"
        ~  manjaro-chroot -a                                                ✔
    [sudo] password for manjaro:
    grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
    ==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
     --> mount: [/mnt]
     --> mount: [/mnt/boot/efi]
     --> mount: [/mnt/home]
    [manjaro-gnome /]#
Boot into live ISO, don’t mount any partition and then try to repair the partition nvme0n1p3 by
sudo fsck -p /dev/nvme0n1p3
Reference:
fsck - ArchWiki
First of all, you are using Linux kernel 5.9 which is EOL and unsupported. Downgrade to 5.4 LTS or upgrade to 5.10.
sudo fsck -p /dev/nvme0n1p3                        ✔  3h 1m 26s 
fsck from util-linux 2.36.1
fsck.ext2: Bad magic number in super-block while trying to open /dev/nvme0n1p3
/dev/nvme0n1p3:
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
I’ve tried to upgrade 5.10 but computer doesn’t boot into GUI mode. So I restored back with timeshift. I’ll try 5.4 if I resolve partition issue.
Changing kernel will not fix corrupted partition problem. Have you try to do what fsck has suggested in its output?
The issue has resolved after following command.
sudo e2fsck /dev/nvme0n1p3
Now I’m trying kernel downgrade.
Boot live ISO again and determine the location of the backup superblocks by
sudo mke2fs -n
Post output here.
Edit: OK, glad to hear. :grin:
Thanks for help.:slightly_smiling_face: I have another issue too, computer doesn’t boot at first try. It frezzes on black screen without showing splash logo or freezes after login to my account with black screen with cursor. This is why I did force shutdown occasionally. Should I create new topic for this? (I’ve successfully downgraded to lts kernel btw.)
