Unable to login with LXDM after update
I just updated this week and now my system will not allow me to login thru LXDM.
The greeter screen still shows up, but the only thing on it are the words ‘manjaro openbox’ and a black background. The user select and language options are not present and there doesn’t seem to be any response to mouseclicks or keypresses.
I can still login if I hit CTRL F2 or similar, login using the TTY and then I can startx as normal.
My configuration for LXDM appears to be valid as far as I can determine, so what could have happened?
EDIT:
Here is my system info per below:
  Kernel: 6.1.159-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3072b7ae-2e8e-460d-9ad2-263ca4dbee42 rw
    resume=UUID=f1a790de-29c7-43a9-b2ca-91e972ea786d quiet splash
  Desktop: i3 v: 4.24 with: i3bar tools:
    avail: i3lock,lxlock,xautolock,xlock vt: 2 dm: LXDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: MSI model: B85-G41 PC Mate(MS-7850) v: 1.0
    serial: <superuser required> uuid: <superuser required> Firmware: BIOS
    vendor: American Megatrends v: 2.8 date: 07/17/2014
  System RAM: total: 8 GiB available: 7.69 GiB used: 3.55 GiB (46.1%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: curr: 2 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M378B5273DH0-CH9 serial: <filter>
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    total: 64 manufacturer: 0000 part-no: N/A serial: N/A
  Info: model: Intel Pentium G3260 bits: 64 type: MCP arch: Haswell level: v2
    built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
    microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 smt: <unsupported> cache:
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 800/3300 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 bogomips: 13204
  Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
    ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb
    ibpb_exit_to_user ibrs invpcid invpcid_single lahf_lm lm mca mce md_clear
    mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
    v: 580.105.08 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s ports: active: none off: DVI-D-1,HDMI-A-1
    empty: none bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
  Display: unspecified server: X.Org v: 21.1.21 driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 95 s-size: 1027x292mm (40.43x11.50")
    s-diag: 1068mm (42.04")
  Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: primary,left
    model: Dell S2340M serial: <filter> built: 2013 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 96 gamma: 1.2 chroma: red: x: 0.635 y: 0.333 green:
    x: 0.310 y: 0.624 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
    modes: 1920x1080, 1280x1024, 1152x864, 1024x768, 800x600, 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
    model: HP 27es serial: <filter> built: 2016 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
    x: 0.318 y: 0.612 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: gpu: nvidia-settings,nvidia-smi wl: swaymsg x11: xdriinfo,
    xdpyinfo, xprop, xrandr
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb8
    class-ID: 0403
  API: ALSA v: k6.1.159-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off tools: pw-cli
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Info: services: mld,NetworkManager,nfsd,ntpd
  Local Storage: total: 447.13 GiB used: 388.79 GiB (87.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: L5Lite3D480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0A scheme: MBR
  Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7190S rev: 1.00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 38.25 GiB size: 37.5 GiB (98.04%) used: 29.41 GiB (78.4%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 3072b7ae-2e8e-460d-9ad2-263ca4dbee42
  ID-2: /home raw-size: 400.72 GiB size: 393.86 GiB (98.29%)
    used: 359.24 GiB (91.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 5530d1ed-d107-48dd-be89-530db07c4723
  ID-1: swap-1 type: partition size: 8.16 GiB used: 142.2 MiB (1.7%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: f1a790de-29c7-43a9-b2ca-91e972ea786d
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Brother Industries HL-L2395DW series type: printer
    driver: usbfs interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 2mA chip-ID: 04f9:0429 class-ID: 0701 serial: <filter>
  Device-2: 3-9:3 info: Microsoft Wired Keyboard 600 (model 1576)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 045e:07f8 class-ID: 0300
  Device-3: 3-10:4 info: Sunplus Innovation Optical Mouse type: mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:0005 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 33 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: pm: pacman pkgs: 2028 libs: 441 tools: octopi,pamac,yaourt,yay
    pm: flatpak pkgs: 0
    1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 217
  1: cpu: 2.4% command: brave pid: 971 mem: 312.0 MiB (3.9%)
  2: cpu: 1.4% command: brave pid: 1148 mem: 157.0 MiB (1.9%)
  3: cpu: 1.1% command: brave pid: 933 mem: 588.4 MiB (7.4%)
  4: cpu: 0.4% command: brave pid: 3165 mem: 308.2 MiB (3.9%)
  5: cpu: 0.4% command: brave pid: 19593 mem: 107.3 MiB (1.3%)
  Memory top: 5 of 217
  1: mem: 588.4 MiB (7.4%) command: brave pid: 933 cpu: 1.1%
  2: mem: 443.8 MiB (5.6%) command: brave pid: 1139 cpu: 0.1%
  3: mem: 312.0 MiB (3.9%) command: brave pid: 971 cpu: 2.4%
  4: mem: 308.2 MiB (3.9%) command: brave pid: 3165 cpu: 0.4%
  5: mem: 251.3 MiB (3.1%) command: brave pid: 2318 cpu: 0.1%
  Processes: 217 Power: uptime: 11h 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.06 GiB Init: systemd v: 258
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.8
    running-in: terminator inxi: 3.3.40
[16.962s] --> [0]
I’ll note that LXDM hasn’t been supported by Manjaro for some time. I understand that it was once one of the Community editions, but is no longer available for download:
Some (rather old) forum topics that might be of interest:
Please help others to help you, by providing your system information as described (below) along with any other detail that might be relevant.
I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
lxdm supported both gtk2 and gtk3 - I don’t remember if it was one or two packages.
Even so - the current lxdm package is gtk3 only - so the greeter theme you are using may be gtk2 - not functional.
Try editing the lxdm.conf to use Industrial as theme. Just recently another member had issues with lxdm and I looked into it.
I tested with a virtual machine running xfce - I could get it to work - but not easily.
Only the default Industrial theme is supported. Any other theme will cause errors in one way or another. Most - if not all - of the lxdm themes in AUR will require some work to be functional.
Screenshot
Thank you, I’ve made this change, but the issue persists. (Same black splashscreen that has the words ‘Manjaro Openbox’ but nothing else.
Here is my lxdm.conf
[base]
## uncomment and set autologin username to enable autologin
# autologin=dgod
## uncomment and set timeout to enable timeout autologin,
## the value should >=5
# timeout=10
## default session or desktop used when no systemwide config
session=/usr/bin/openbox-session
## uncomment and set to set numlock on your keyboard
# numlock=0
## set this if you don't want to put xauth file at ~/.Xauthority
# xauth_path=/tmp
# not ask password for users who have empty password
# skip_password=1
## greeter used to welcome the user
greeter=/usr/lib/lxdm/lxdm-greeter-gtk
[server]
## arg used to start xserver, not fully function
arg=/usr/bin/X -background vt1
# uncomment this if you really want xserver listen to tcp
# tcp_listen=1
# uncoment this if you want reset the xserver after logou
# reset=1
[display]
## gtk theme used by greeter
##gtk_theme=ManjaroFlatDark
gtk_theme=Industrial
## background of the greeter
#bg=/usr/share/backgrounds/evodark.png
## if show bottom pane
bottom_pane=1
## if show language select control
lang=1
## if show keyboard layout select control
keyboard=0
## the theme of greeter
theme=Manjaro
hide_sessions=0
hide_exit=0
hide_time=0
[input]
[userlist]
## if disable the user list control at greeter
disable=0
## whitelist user
white=
## blacklist user
black=
Here is my lxdm.log
** Message: 08:41:55.965: start greeter on /var/run/lxdm/lxdm-:0.auth
(lxdm-greeter-gtk:629): Gtk-WARNING **: 08:41:56.109: Theme parsing error: gtk.css:10:7: not a number
(lxdm-greeter-gtk:629): Gtk-WARNING **: 08:41:56.109: Theme parsing error: gtk.css:10:14: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
(lxdm-greeter-gtk:629): GLib-GObject-CRITICAL **: 08:41:56.166: invalid (NULL) pointer instance
(lxdm-greeter-gtk:629): GLib-GObject-CRITICAL **: 08:41:56.166: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.166: gtk_label_set_text: assertion ‘GTK_IS_LABEL (label)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.166: gtk_widget_set_name: assertion ‘GTK_IS_WIDGET (widget)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.166: gtk_bin_get_child: assertion ‘GTK_IS_BIN (bin)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.166: gtk_editable_set_editable: assertion ‘GTK_IS_EDITABLE (editable)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.166: gtk_widget_set_can_focus: assertion ‘GTK_IS_WIDGET (widget)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_combo_box_set_model: assertion ‘GTK_IS_COMBO_BOX (combo_box)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_combo_box_set_entry_text_column: assertion ‘GTK_IS_COMBO_BOX (combo_box)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_combo_box_set_active_iter: assertion ‘GTK_IS_COMBO_BOX (combo_box)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_widget_set_name: assertion ‘GTK_IS_WIDGET (widget)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_bin_get_child: assertion ‘GTK_IS_BIN (bin)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_editable_set_editable: assertion ‘GTK_IS_EDITABLE (editable)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_widget_set_can_focus: assertion ‘GTK_IS_WIDGET (widget)’ failed
(lxdm-greeter-gtk:629): GLib-GObject-CRITICAL **: 08:41:56.169: invalid (NULL) pointer instance
(lxdm-greeter-gtk:629): GLib-GObject-CRITICAL **: 08:41:56.169: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.169: gtk_combo_box_set_active: assertion ‘GTK_IS_COMBO_BOX (combo_box)’ failed
(lxdm-greeter-gtk:629): Gtk-CRITICAL **: 08:41:56.204: gtk_widget_grab_focus: assertion ‘GTK_IS_WIDGET (widget)’ failed[2.126s] → [0]
This is where you change the theme
theme=Industrial
The theme in this section is something different
gtk_theme should be an existing theme e.g. Adwaita
Thank you! That was the problem. I’ve been living with LXDM for quite some time without issue so I wonder if I flubbed resolving a pacnew file after the latest update.
At any rate, I shall investigate migrating to a better supported display manager.
