Here’s the ~/.local/share/xorg/Xorg.0.log from my last attempt to log in using Xorg.
[ 75.174] (--) Log file renamed from "/home/ploca14/.local/share/xorg/Xorg.pid-2613.log" to "/home/ploca14/.local/share/xorg/Xorg.0.log"
[ 75.174]
X.Org X Server 1.21.1.12
[ 75.174] Current Operating System: Linux Vojta-XPS 5.15.154-1-MANJARO #1 SMP PREEMPT Wed Apr 10 19:10:26 UTC 2024 x86_64
[ 75.174] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d9f0c8d2-ed5c-4df8-a127-c4919bbca09f rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 75.174]
[ 75.174] Current version of pixman: 0.43.4
[ 75.174] Before reporting problems, check http://wiki.x.org
[ 75.174] Markers: (--) probed, (**) from config file, (==) default setting,
[ 75.174] (==) Log file: "/home/ploca14/.local/share/xorg/Xorg.0.log", Time: Thu May 2 09:58:23 2024
[ 75.175] (==) Using config file: "/etc/X11/xorg.conf"
[ 75.175] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 75.175] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 75.176] (==) ServerLayout "layout"
[ 75.176] (**) |-->Screen "Screen0" (0)
[ 75.176] (**) | |-->Monitor "Monitor0"
[ 75.176] (**) | |-->Device "Device0"
[ 75.176] (**) Allowing byte-swapped clients
[ 75.176] (==) Automatically adding devices
[ 75.176] (==) Automatically enabling devices
[ 75.176] (==) Automatically adding GPU devices
[ 75.176] (==) Automatically binding GPU devices
[ 75.176] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 75.176] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 75.176] Entry deleted from font path.
[ 75.176] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 75.176] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 75.176] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 75.176] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 75.176] (==) FontPath set to:
/usr/share/fonts/TTF
[ 75.176] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 75.176] (II) The server relies on udev to provide the list of input devices.
[ 75.176] (II) Module ABI versions:
[ 75.176] X.Org ANSI C Emulation: 0.4
[ 75.176] X.Org Video Driver: 25.2
[ 75.176] X.Org XInput driver : 24.4
[ 75.176] X.Org Server Extension : 10.0
[ 75.176] (++) using VT number 2
[ 75.177] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 75.178] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 75.178] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 75.178] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[ 75.178] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 75.178] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 75.178] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 15 paused 0
[ 75.179] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 75.179] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 75.180] (--) PCI:*(0@0:2:0) 8086:9a60:1028:0a61 rev 1, Mem @ 0x6162000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 75.180] (--) PCI: (1@0:0:0) 10de:25a0:1028:0a61 rev 161, Mem @ 0x9e000000/16777216, 0x6000000000/4294967296, 0x6100000000/33554432, I/O @ 0x00003000/128
[ 75.180] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 75.180] (II) LoadModule: "glx"
[ 75.181] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 75.182] (II) Module glx: vendor="X.Org Foundation"
[ 75.182] compiled for 1.21.1.12, module version = 1.0.0
[ 75.182] ABI class: X.Org Server Extension, version 10.0
[ 75.182] (II) LoadModule: "nvidia"
[ 75.182] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 75.185] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 75.185] compiled for 1.6.99.901, module version = 1.0.0
[ 75.185] Module class: X.Org Video Driver
[ 75.185] (II) NVIDIA dlloader X Driver 550.67 Tue Mar 12 23:32:46 UTC 2024
[ 75.185] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 75.185] (II) systemd-logind: releasing fd for 226:1
[ 75.185] (II) Loading sub module "fb"
[ 75.185] (II) LoadModule: "fb"
[ 75.185] (II) Module "fb" already built-in
[ 75.185] (II) Loading sub module "wfb"
[ 75.185] (II) LoadModule: "wfb"
[ 75.185] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 75.186] (II) Module wfb: vendor="X.Org Foundation"
[ 75.186] compiled for 1.21.1.12, module version = 1.0.0
[ 75.186] ABI class: X.Org ANSI C Emulation, version 0.4
[ 75.187] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 75.187] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 75.187] (==) NVIDIA(0): RGB weight 888
[ 75.187] (==) NVIDIA(0): Default visual is TrueColor
[ 75.187] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 75.187] (**) Option "AllowNVIDIAGpuScreens"
[ 75.187] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 75.187] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 75.187] (**) NVIDIA(0): Enabling 2D acceleration
[ 75.187] (II) Loading sub module "glxserver_nvidia"
[ 75.187] (II) LoadModule: "glxserver_nvidia"
[ 75.187] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 75.204] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 75.204] compiled for 1.6.99.901, module version = 1.0.0
[ 75.204] Module class: X.Org Server Extension
[ 75.204] (II) NVIDIA GLX Module 550.67 Tue Mar 12 23:40:29 UTC 2024
[ 75.204] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 75.205] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 3050 Ti Laptop GPU (GA107-A) at
[ 75.205] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 75.205] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 75.205] (--) NVIDIA(0): VideoBIOS: 94.07.3b.80.44
[ 75.205] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 75.205] (II) NVIDIA(0): Validated MetaModes:
[ 75.205] (II) NVIDIA(0): "NULL"
[ 75.205] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 75.205] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 75.205] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 75.205] (WW) NVIDIA: Failed to bind sideband socket to
[ 75.205] (WW) NVIDIA: '/var/run/nvidia-xdriver-bbda48d0' Permission denied
[ 75.205] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 75.205] (II) NVIDIA: access.
[ 75.216] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 75.216] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 75.216] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 75.216] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 75.216] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 75.216] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 75.216] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 75.216] (II) NVIDIA(0): Config Options in the README.
[ 75.230] (II) NVIDIA(0): Setting mode "NULL"
[ 75.234] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 75.234] (==) NVIDIA(0): Backing store enabled
[ 75.234] (==) NVIDIA(0): Silken mouse enabled
[ 75.234] (**) NVIDIA(0): DPMS enabled
[ 75.234] (II) Loading sub module "dri2"
[ 75.234] (II) LoadModule: "dri2"
[ 75.234] (II) Module "dri2" already built-in
[ 75.234] (II) NVIDIA(0): [DRI2] Setup complete
[ 75.234] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 75.234] (II) Initializing extension Generic Event Extension
[ 75.234] (II) Initializing extension SHAPE
[ 75.235] (II) Initializing extension MIT-SHM
[ 75.235] (II) Initializing extension XInputExtension
[ 75.235] (II) Initializing extension XTEST
[ 75.235] (II) Initializing extension BIG-REQUESTS
[ 75.235] (II) Initializing extension SYNC
[ 75.235] (II) Initializing extension XKEYBOARD
[ 75.235] (II) Initializing extension XC-MISC
[ 75.235] (II) Initializing extension SECURITY
[ 75.235] (II) Initializing extension XFIXES
[ 75.235] (II) Initializing extension RENDER
[ 75.235] (II) Initializing extension RANDR
[ 75.235] (II) Initializing extension COMPOSITE
[ 75.235] (II) Initializing extension DAMAGE
[ 75.235] (II) Initializing extension MIT-SCREEN-SAVER
[ 75.235] (II) Initializing extension DOUBLE-BUFFER
[ 75.235] (II) Initializing extension RECORD
[ 75.235] (II) Initializing extension DPMS
[ 75.235] (II) Initializing extension Present
[ 75.235] (II) Initializing extension DRI3
[ 75.235] (II) Initializing extension X-Resource
[ 75.236] (II) Initializing extension XVideo
[ 75.236] (II) Initializing extension XVideo-MotionCompensation
[ 75.236] (II) Initializing extension GLX
[ 75.236] (II) Indirect GLX disabled.
[ 75.236] (II) GLX: Another vendor is already registered for screen 0
[ 75.236] (II) Initializing extension XFree86-VidModeExtension
[ 75.236] (II) Initializing extension XFree86-DGA
[ 75.236] (II) Initializing extension XFree86-DRI
[ 75.236] (II) Initializing extension DRI2
[ 75.236] (II) Initializing extension NV-GLX
[ 75.236] (II) Initializing extension NV-CONTROL
[ 75.277] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 75.277] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 75.277] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 75.277] (**) Video Bus: Applying InputClass "system-keyboard"
[ 75.277] (II) LoadModule: "libinput"
[ 75.277] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 75.278] (II) Module libinput: vendor="X.Org Foundation"
[ 75.278] compiled for 1.21.1.8, module version = 1.4.0
[ 75.278] Module class: X.Org XInput Driver
[ 75.278] ABI class: X.Org XInput driver, version 24.4
[ 75.278] (II) Using input driver 'libinput' for 'Video Bus'
[ 75.279] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 38 paused 0
[ 75.279] (**) Video Bus: always reports core events
[ 75.279] (**) Option "Device" "/dev/input/event15"
[ 75.280] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 75.280] (II) event15 - Video Bus: device is a keyboard
[ 75.280] (II) event15 - Video Bus: device removed
[ 75.280] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input25/event15"
[ 75.280] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 75.280] (**) Option "xkb_layout" "cz"
[ 75.288] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 75.288] (II) event15 - Video Bus: device is a keyboard
[ 75.288] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[ 75.288] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 75.288] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 75.288] (**) Video Bus: Applying InputClass "system-keyboard"
[ 75.288] (II) Using input driver 'libinput' for 'Video Bus'
[ 75.289] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 41 paused 0
[ 75.289] (**) Video Bus: always reports core events
[ 75.289] (**) Option "Device" "/dev/input/event14"
[ 75.289] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 75.289] (II) event14 - Video Bus: device is a keyboard
[ 75.289] (II) event14 - Video Bus: device removed
[ 75.289] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input24/event14"
[ 75.289] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 75.289] (**) Option "xkb_layout" "cz"
[ 75.290] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[ 75.290] (II) event14 - Video Bus: device is a keyboard
[ 75.290] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 75.290] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 75.290] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 75.290] (**) Power Button: Applying InputClass "system-keyboard"
[ 75.290] (II) Using input driver 'libinput' for 'Power Button'
[ 75.290] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[ 75.290] (**) Power Button: always reports core events
[ 75.290] (**) Option "Device" "/dev/input/event1"
[ 75.291] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 75.291] (II) event1 - Power Button: device is a keyboard
[ 75.291] (II) event1 - Power Button: device removed
[ 75.291] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 75.291] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 75.291] (**) Option "xkb_layout" "cz"
[ 75.291] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 75.291] (II) No input driver specified, ignoring this device.
[ 75.291] (II) This device may have been added with another device file.
[ 75.292] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event16)
[ 75.292] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 75.292] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 75.292] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 75.292] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 75.292] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 43 paused 0
[ 75.292] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 75.292] (**) Option "Device" "/dev/input/event16"
[ 75.293] (II) event16 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 75.293] (II) event16 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 75.293] (II) event16 - Integrated_Webcam_HD: Integrate: device removed
[ 75.293] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.0/input/input26/event16"
[ 75.293] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 9)
[ 75.293] (**) Option "xkb_layout" "cz"
[ 75.294] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event17)
[ 75.294] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[ 75.294] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[ 75.294] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[ 75.294] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[ 75.294] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 44 paused 0
[ 75.294] (**) Integrated_Webcam_HD: Integrate: always reports core events
[ 75.294] (**) Option "Device" "/dev/input/event17"
[ 75.294] (II) event17 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 75.294] (II) event17 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 75.295] (II) event17 - Integrated_Webcam_HD: Integrate: device removed
[ 75.295] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.2/input/input27/event17"
[ 75.295] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 10)
[ 75.295] (**) Option "xkb_layout" "cz"
[ 75.295] (II) event17 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[ 75.295] (II) event17 - Integrated_Webcam_HD: Integrate: device is a keyboard
[ 75.295] (II) config/udev: Adding input device ELAN2D25:00 04F3:2D25 (/dev/input/event7)
[ 75.296] (**) ELAN2D25:00 04F3:2D25: Applying InputClass "evdev touchscreen catchall"
[ 75.296] (**) ELAN2D25:00 04F3:2D25: Applying InputClass "libinput touchscreen catchall"
[ 75.296] (II) Using input driver 'libinput' for 'ELAN2D25:00 04F3:2D25'
[ 75.296] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[ 75.296] (**) ELAN2D25:00 04F3:2D25: always reports core events
[ 75.296] (**) Option "Device" "/dev/input/event7"
[ 75.296] (II) event7 - ELAN2D25:00 04F3:2D25: is tagged by udev as: Touchscreen
[ 75.296] (II) event7 - ELAN2D25:00 04F3:2D25: device is a touch device
[ 75.296] (II) event7 - ELAN2D25:00 04F3:2D25: device removed
[ 75.296] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN2D25:00/0018:04F3:2D25.0001/input/input17/event7"
[ 75.296] (II) XINPUT: Adding extended input device "ELAN2D25:00 04F3:2D25" (type: TOUCHSCREEN, id 11)
[ 75.296] (**) Option "AccelerationScheme" "none"
[ 75.296] (**) ELAN2D25:00 04F3:2D25: (accel) selected scheme none/0
[ 75.296] (**) ELAN2D25:00 04F3:2D25: (accel) acceleration factor: 2.000
[ 75.296] (**) ELAN2D25:00 04F3:2D25: (accel) acceleration threshold: 4
[ 75.297] (II) event7 - ELAN2D25:00 04F3:2D25: is tagged by udev as: Touchscreen
[ 75.297] (II) event7 - ELAN2D25:00 04F3:2D25: device is a touch device
[ 75.297] (II) config/udev: Adding input device ELAN2D25:00 04F3:2D25 (/dev/input/mouse0)
[ 75.297] (II) No input driver specified, ignoring this device.
[ 75.297] (II) This device may have been added with another device file.
[ 75.297] (II) config/udev: Adding input device ELAN2D25:00 04F3:2D25 UNKNOWN (/dev/input/event8)
[ 75.298] (II) config/udev: Adding input device ELAN2D25:00 04F3:2D25 UNKNOWN (/dev/input/event12)
[ 75.298] (II) No input driver specified, ignoring this device.
[ 75.298] (II) This device may have been added with another device file.
[ 75.298] (II) config/udev: Adding input device DLL0945:00 04F3:311C Mouse (/dev/input/event9)
[ 75.298] (**) DLL0945:00 04F3:311C Mouse: Applying InputClass "evdev pointer catchall"
[ 75.298] (**) DLL0945:00 04F3:311C Mouse: Applying InputClass "libinput pointer catchall"
[ 75.298] (II) Using input driver 'libinput' for 'DLL0945:00 04F3:311C Mouse'
[ 75.298] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 46 paused 0
[ 75.298] (**) DLL0945:00 04F3:311C Mouse: always reports core events
[ 75.298] (**) Option "Device" "/dev/input/event9"
[ 75.299] (II) event9 - DLL0945:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 75.299] (II) event9 - DLL0945:00 04F3:311C Mouse: device is a pointer
[ 75.299] (II) event9 - DLL0945:00 04F3:311C Mouse: device removed
[ 75.299] (II) libinput: DLL0945:00 04F3:311C Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 75.299] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DLL0945:00/0018:04F3:311C.0002/input/input21/event9"
[ 75.299] (II) XINPUT: Adding extended input device "DLL0945:00 04F3:311C Mouse" (type: MOUSE, id 12)
[ 75.299] (**) Option "AccelerationScheme" "none"
[ 75.299] (**) DLL0945:00 04F3:311C Mouse: (accel) selected scheme none/0
[ 75.299] (**) DLL0945:00 04F3:311C Mouse: (accel) acceleration factor: 2.000
[ 75.299] (**) DLL0945:00 04F3:311C Mouse: (accel) acceleration threshold: 4
[ 75.300] (II) event9 - DLL0945:00 04F3:311C Mouse: is tagged by udev as: Mouse Pointingstick
[ 75.300] (II) event9 - DLL0945:00 04F3:311C Mouse: device is a pointer
[ 75.300] (II) config/udev: Adding input device DLL0945:00 04F3:311C Mouse (/dev/input/mouse1)
[ 75.300] (II) No input driver specified, ignoring this device.
[ 75.300] (II) This device may have been added with another device file.
[ 75.301] (II) config/udev: Adding input device DLL0945:00 04F3:311C Touchpad (/dev/input/event10)
[ 75.301] (**) DLL0945:00 04F3:311C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 75.301] (**) DLL0945:00 04F3:311C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 75.301] (II) Using input driver 'libinput' for 'DLL0945:00 04F3:311C Touchpad'
[ 75.301] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 47 paused 0
[ 75.301] (**) DLL0945:00 04F3:311C Touchpad: always reports core events
[ 75.301] (**) Option "Device" "/dev/input/event10"
[ 75.301] (II) event10 - DLL0945:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 75.302] (II) event10 - DLL0945:00 04F3:311C Touchpad: device is a touchpad
[ 75.302] (II) event10 - DLL0945:00 04F3:311C Touchpad: device removed
[ 75.302] (II) libinput: DLL0945:00 04F3:311C Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 75.302] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-DLL0945:00/0018:04F3:311C.0002/input/input22/event10"
[ 75.302] (II) XINPUT: Adding extended input device "DLL0945:00 04F3:311C Touchpad" (type: TOUCHPAD, id 13)
[ 75.303] (**) Option "AccelerationScheme" "none"
[ 75.303] (**) DLL0945:00 04F3:311C Touchpad: (accel) selected scheme none/0
[ 75.303] (**) DLL0945:00 04F3:311C Touchpad: (accel) acceleration factor: 2.000
[ 75.303] (**) DLL0945:00 04F3:311C Touchpad: (accel) acceleration threshold: 4
[ 75.303] (II) event10 - DLL0945:00 04F3:311C Touchpad: is tagged by udev as: Touchpad
[ 75.304] (II) event10 - DLL0945:00 04F3:311C Touchpad: device is a touchpad
[ 75.304] (II) config/udev: Adding input device DLL0945:00 04F3:311C Touchpad (/dev/input/mouse2)
[ 75.304] (II) No input driver specified, ignoring this device.
[ 75.304] (II) This device may have been added with another device file.
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event18)
[ 75.305] (II) No input driver specified, ignoring this device.
[ 75.305] (II) This device may have been added with another device file.
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event19)
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event20)
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event21)
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event22)
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event23)
[ 75.305] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=11 (/dev/input/event24)
[ 75.306] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=12 (/dev/input/event25)
[ 75.306] (II) No input driver specified, ignoring this device.
[ 75.306] (II) This device may have been added with another device file.
[ 75.306] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=13 (/dev/input/event26)
[ 75.306] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=14 (/dev/input/event27)
[ 75.306] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=15 (/dev/input/event28)
[ 75.307] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=16 (/dev/input/event29)
[ 75.307] (II) No input driver specified, ignoring this device.
[ 75.307] (II) This device may have been added with another device file.
[ 75.307] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=17 (/dev/input/event30)
[ 75.307] (II) config/udev: Adding input device Intel HID events (/dev/input/event3)
[ 75.307] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 75.307] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 75.307] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 75.307] (II) Using input driver 'libinput' for 'Intel HID events'
[ 75.307] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 48 paused 0
[ 75.307] (**) Intel HID events: always reports core events
[ 75.307] (**) Option "Device" "/dev/input/event3"
[ 75.308] (II) event3 - Intel HID events: is tagged by udev as: Keyboard
[ 75.308] (II) event3 - Intel HID events: device is a keyboard
[ 75.308] (II) event3 - Intel HID events: device removed
[ 75.308] (**) Option "config_info" "udev:/sys/devices/platform/INTC1051:00/input/input4/event3"
[ 75.308] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 14)
[ 75.308] (**) Option "xkb_layout" "cz"
[ 75.308] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event4)
[ 75.308] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 75.308] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 75.309] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 75.309] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 75.309] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 49 paused 0
[ 75.309] (**) Intel HID 5 button array: always reports core events
[ 75.309] (**) Option "Device" "/dev/input/event4"
[ 75.309] (II) event4 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 75.309] (II) event4 - Intel HID 5 button array: device is a keyboard
[ 75.309] (II) event4 - Intel HID 5 button array: device removed
[ 75.309] (**) Option "config_info" "udev:/sys/devices/platform/INTC1051:00/input/input5/event4"
[ 75.309] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 15)
[ 75.309] (**) Option "xkb_layout" "cz"
[ 75.310] (II) config/udev: Adding input device Dell Privacy Driver (/dev/input/event6)
[ 75.310] (**) Dell Privacy Driver: Applying InputClass "evdev keyboard catchall"
[ 75.310] (**) Dell Privacy Driver: Applying InputClass "libinput keyboard catchall"
[ 75.310] (**) Dell Privacy Driver: Applying InputClass "system-keyboard"
[ 75.310] (II) Using input driver 'libinput' for 'Dell Privacy Driver'
[ 75.310] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 50 paused 0
[ 75.310] (**) Dell Privacy Driver: always reports core events
[ 75.310] (**) Option "Device" "/dev/input/event6"
[ 75.310] (II) event6 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 75.310] (II) event6 - Dell Privacy Driver: device is a keyboard
[ 75.311] (II) event6 - Dell Privacy Driver: device removed
[ 75.311] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/6932965F-1671-4CEB-B988-D3AB0A901919/input/input15/event6"
[ 75.311] (II) XINPUT: Adding extended input device "Dell Privacy Driver" (type: KEYBOARD, id 16)
[ 75.311] (**) Option "xkb_layout" "cz"
[ 75.311] (II) event6 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 75.311] (II) event6 - Dell Privacy Driver: device is a keyboard
[ 75.311] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event11)
[ 75.311] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 75.311] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 75.311] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 75.311] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 75.312] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 51 paused 0
[ 75.312] (**) Dell WMI hotkeys: always reports core events
[ 75.312] (**) Option "Device" "/dev/input/event11"
[ 75.312] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 75.312] (II) event11 - Dell WMI hotkeys: device is a keyboard
[ 75.312] (II) event11 - Dell WMI hotkeys: device removed
[ 75.312] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input16/event11"
[ 75.312] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 17)
[ 75.312] (**) Option "xkb_layout" "cz"
[ 75.313] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 75.313] (II) event11 - Dell WMI hotkeys: device is a keyboard
[ 75.313] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 75.313] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 75.313] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 75.313] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 75.313] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 75.313] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 52 paused 0
[ 75.313] (**) AT Translated Set 2 keyboard: always reports core events
[ 75.313] (**) Option "Device" "/dev/input/event2"
[ 75.314] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 75.314] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 75.315] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 75.315] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 75.315] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[ 75.315] (**) Option "xkb_layout" "cz"
[ 75.315] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 75.315] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 75.316] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event13)
[ 75.316] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[ 75.316] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[ 75.316] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 75.316] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 53 paused 0
[ 75.316] (**) PS/2 Generic Mouse: always reports core events
[ 75.316] (**) Option "Device" "/dev/input/event13"
[ 75.316] (II) event13 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 75.316] (II) event13 - PS/2 Generic Mouse: device is a pointer
[ 75.317] (II) event13 - PS/2 Generic Mouse: device removed
[ 75.317] (II) libinput: PS/2 Generic Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 75.317] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event13"
[ 75.317] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 19)
[ 75.317] (**) Option "AccelerationScheme" "none"
[ 75.317] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[ 75.317] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 75.317] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 75.317] (II) event13 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 75.317] (II) event13 - PS/2 Generic Mouse: device is a pointer
[ 75.317] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse3)
[ 75.317] (II) No input driver specified, ignoring this device.
[ 75.317] (II) This device may have been added with another device file.
[ 75.318] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 75.318] (II) No input driver specified, ignoring this device.
[ 75.318] (II) This device may have been added with another device file.
[ 75.319] (II) config/udev: Adding input device LogiOps Virtual Input (/dev/input/event31)
[ 75.319] (**) LogiOps Virtual Input: Applying InputClass "evdev keyboard catchall"
[ 75.319] (**) LogiOps Virtual Input: Applying InputClass "libinput keyboard catchall"
[ 75.319] (**) LogiOps Virtual Input: Applying InputClass "system-keyboard"
[ 75.319] (II) Using input driver 'libinput' for 'LogiOps Virtual Input'
[ 75.319] (II) systemd-logind: got fd for /dev/input/event31 13:95 fd 54 paused 0
[ 75.319] (**) LogiOps Virtual Input: always reports core events
[ 75.319] (**) Option "Device" "/dev/input/event31"
[ 75.319] (II) event31 - LogiOps Virtual Input: is tagged by udev as: Keyboard
[ 75.319] (II) event31 - LogiOps Virtual Input: device is a keyboard
[ 75.319] (II) event31 - LogiOps Virtual Input: device removed
[ 75.319] (**) Option "config_info" "udev:/sys/devices/virtual/input/input41/event31"
[ 75.319] (II) XINPUT: Adding extended input device "LogiOps Virtual Input" (type: KEYBOARD, id 20)
[ 75.319] (**) Option "xkb_layout" "cz"
[ 75.320] (II) event31 - LogiOps Virtual Input: is tagged by udev as: Keyboard
[ 75.320] (II) event31 - LogiOps Virtual Input: device is a keyboard
[ 75.429] (**) Option "fd" "38"
[ 75.429] (II) event15 - Video Bus: device removed
[ 75.429] (**) Option "fd" "41"
[ 75.429] (II) event14 - Video Bus: device removed
[ 75.429] (**) Option "fd" "42"
[ 75.429] (II) event1 - Power Button: device removed
[ 75.429] (**) Option "fd" "43"
[ 75.429] (II) event16 - Integrated_Webcam_HD: Integrate: device removed
[ 75.429] (**) Option "fd" "44"
[ 75.429] (II) event17 - Integrated_Webcam_HD: Integrate: device removed
[ 75.429] (**) Option "fd" "45"
[ 75.429] (II) event7 - ELAN2D25:00 04F3:2D25: device removed
[ 75.429] (**) Option "fd" "46"
[ 75.429] (II) event9 - DLL0945:00 04F3:311C Mouse: device removed
[ 75.429] (**) Option "fd" "47"
[ 75.429] (II) event10 - DLL0945:00 04F3:311C Touchpad: device removed
[ 75.429] (**) Option "fd" "48"
[ 75.429] (II) event3 - Intel HID events: device removed
[ 75.429] (**) Option "fd" "49"
[ 75.429] (II) event4 - Intel HID 5 button array: device removed
[ 75.429] (**) Option "fd" "50"
[ 75.429] (II) event6 - Dell Privacy Driver: device removed
[ 75.429] (**) Option "fd" "51"
[ 75.429] (II) event11 - Dell WMI hotkeys: device removed
[ 75.429] (**) Option "fd" "52"
[ 75.429] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 75.429] (**) Option "fd" "53"
[ 75.429] (II) event13 - PS/2 Generic Mouse: device removed
[ 75.429] (**) Option "fd" "54"
[ 75.429] (II) event31 - LogiOps Virtual Input: device removed
[ 75.431] (II) UnloadModule: "libinput"
[ 75.431] (II) systemd-logind: releasing fd for 13:95
[ 75.431] (II) systemd-logind: releasing fd for 13:77
[ 75.432] (II) UnloadModule: "libinput"
[ 75.432] (II) systemd-logind: releasing fd for 13:66
[ 75.432] (II) systemd-logind: releasing fd for 13:75
[ 75.432] (II) systemd-logind: releasing fd for 13:70
[ 75.432] (II) systemd-logind: releasing fd for 13:68
[ 75.433] (II) UnloadModule: "libinput"
[ 75.433] (II) systemd-logind: releasing fd for 13:67
[ 75.433] (II) systemd-logind: releasing fd for 13:74
[ 75.433] (II) systemd-logind: releasing fd for 13:73
[ 75.433] (II) systemd-logind: releasing fd for 13:71
[ 75.433] (II) systemd-logind: releasing fd for 13:81
[ 75.433] (II) systemd-logind: releasing fd for 13:80
[ 75.433] (II) systemd-logind: releasing fd for 13:65
[ 75.433] (II) systemd-logind: releasing fd for 13:78
[ 75.434] (II) UnloadModule: "libinput"
[ 75.434] (II) systemd-logind: releasing fd for 13:79
[ 75.440] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 75.441] (II) Server terminated successfully (0). Closing log file.
