Unable to Login to KDE under Wayland / KDE apps crashing constantly
Hi all,
After running the latest updates, I have something of an issue with logging into KDE - I don’t think this is the same issue as the other thread currently floating about, but will to admit I’m wrong on this.
So, attempt to log in → black screen → back to SDDM login prompt.
The reason is that it looks like systemd is having a bad day - journalctl shows this :
Oct 13 16:46:36 <host> systemd[1]: Started Process Core Dump (PID 52183/UID 0).
Oct 13 16:46:36 <host> systemd[1]: Started Pass systemd-coredump journal entries to relevant user for potential DrKonqi handling.
Oct 13 16:46:36 <host> systemd-coredump[52188]: [🡕] Process 52174 (baloo_file_extr) of user 1000 dumped core.
                                                Stack trace of thread 52174:
                                                #0  0x00007f53f52a53f4 n/a (libc.so.6 + 0x963f4)
                                                #1  0x00007f53f524c120 raise (libc.so.6 + 0x3d120)
                                                #2  0x00007f53f52334c3 abort (libc.so.6 + 0x244c3)
                                                #3  0x00007f53f4c8c663 n/a (libQt6Core.so.6 + 0x8c663)
                                                #4  0x00007f53f4c8ce07 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce07)
                                                #5  0x00007f53f54daa65 n/a (libQt6Gui.so.6 + 0xdaa65)
                                                #6  0x00007f53f557c3a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17c3a8)
                                                #7  0x00007f53f4d49a2d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x149a2d)
                                                #8  0x00007f53f557c43e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17c43e)
                                                #9  0x00007f53f5574fad _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x174fad)
                                                #10 0x0000607b167d3247 n/a (baloo_file_extractor + 0x8247)
                                                #11 0x00007f53f5234e08 n/a (libc.so.6 + 0x25e08)
                                                #12 0x00007f53f5234ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                #13 0x0000607b167d3595 n/a (baloo_file_extractor + 0x8595)
                                                Stack trace of thread 52182:
                                                #0  0x00007f53f531a63d __poll (libc.so.6 + 0x10b63d)
                                                #1  0x00007f53f451de0d n/a (libglib-2.0.so.0 + 0xbfe0d)
                                                #2  0x00007f53f44ba795 g_main_context_iteration (libglib-2.0.so.0 + 0x5c795)
                                                #3  0x00007f53f4fa82bd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a82bd)
                                                #4  0x00007f53f4d4ff66 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14ff66)
                                                #5  0x00007f53f4e3d650 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23d650)
                                                #6  0x00007f53f5cc0f0e n/a (libQt6DBus.so.6 + 0x2df0e)
                                                #7  0x00007f53f4ecd237 n/a (libQt6Core.so.6 + 0x2cd237)
                                                #8  0x00007f53f52a339d n/a (libc.so.6 + 0x9439d)
                                                #9  0x00007f53f532849c n/a (libc.so.6 + 0x11949c)
Oct 13 16:46:36 <host> systemd[1]: systemd-coredump@2321-52183-0.service: Deactivated successfully.
Oct 13 16:46:36 <host> baloo_file[2924]: kf.baloo: Extractor crashed
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: Failed to create wl_display (No such file or directory)
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: qt.qpa.xcb: could not connect to display :1
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Oct 13 16:46:36 <host> baloo_file_extractor[52195]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                    Available platform plugins are: vkkhrdisplay, xcb, wayland, wayland-egl, eglfs, minimal, linuxfb, offscreen, vnc, minimalegl.
Oct 13 16:46:36 <host> systemd-coredump[52200]: Process 52195 (baloo_file_extr) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Oct 13 16:46:36 <host> systemd[1]: Started Process Core Dump (PID 52200/UID 0).
Oct 13 16:46:36 <host> drkonqi-coredump-processor[52189]: "/usr/lib/kf6/baloo_file_extractor" 52174 "/var/lib/systemd/coredump/core.baloo_file_extr.1000.aeb306d182b24fb4bb74251b558e0d9f.52174.1728834396000000.zst"
Oct 13 16:46:36 <host> drkonqi-coredump-processor[52170]: "/usr/lib/kf6/baloo_file_extractor" 52161 "/var/lib/systemd/coredump/core.baloo_file_extr.1000.aeb306d182b24fb4bb74251b558e0d9f.52161.1728834396000000.zst"
Oct 13 16:46:36 <host> systemd[1]: drkonqi-coredump-processor@2320-52166-0.service: Deactivated successfully.
Oct 13 16:46:36 <host> systemd[2526]: Started Launch DrKonqi for a systemd-coredump crash (PID 52189/UID 0).
Oct 13 16:46:36 <host> systemd[1]: drkonqi-coredump-processor@2321-52183-0.service: Deactivated successfully.
Oct 13 16:46:36 <host> systemd[2526]: Started Launch DrKonqi for a systemd-coredump crash (PID 52170/UID 0).
Oct 13 16:46:36 <host> drkonqi-coredump-launcher[52206]: Unable to find file for pid 52174 expected at "kcrash-metadata/baloo_file_extractor.aeb306d182b24fb4bb74251b558e0d9f.52174.ini"
Oct 13 16:46:36 <host> drkonqi-coredump-launcher[52206]: Nothing handled the dump :O
Oct 13 16:46:36 <host> drkonqi-coredump-launcher[52209]: Unable to find file for pid 52161 expected at "kcrash-metadata/baloo_file_extractor.aeb306d182b24fb4bb74251b558e0d9f.52161.ini"
Oct 13 16:46:36 <host> drkonqi-coredump-launcher[52209]: Nothing handled the dump :O
Using balooctl I have disabled baloo, and purged it a swell, but it looks as if this is pointless as systemd attempts to load it anyway, resulting in this crash. Tried reinstalling baloo and xcb-utils, no avail.
Anyone got any clues?
Baloo always broke my nerves and I remember always disabling it right after installing kde, but can’t remember how. I have the impression I did it within KDE, which I understand is a problem in your case… :upside_down_face:
Anyway, in my system it is disabled (as I just checked with balooctl6 status )
If I were you I would see if there are any systemd service files related to baloo and try to stop and disable them.
(systemctl list-unit-files | grep baloo , then see their status with systemctl status baloo_whatever, stop them with systemctl stop baloo_whatever and disable the enabled ones systemctl disable baloo_whatever)
I have never had any problems with Baloo personally. I’m loathe to start disabling it via systemd given the problems appears to be more qt loading plugins which are actually available. I will try that if no better suggestions come up though
Indeed, looking further at this, it would appear also everything QT related is crashing, generally in libQT6Gui or libQT6Core
I am also seeing missing/incorrect symbols in libKF6XmlGui, something I have seen elsewhere.
Also, if I didn’t know better I would have sai this was trying to boot an X11 session under Wayland???
Edit: Indeed, I can boot under X11… sorta.
Are you fully up to date?
sudo pacman-mirrors -f && sudo pacman -Syu
If basic system libraries are failing … I wonder also about foreign replacements.
pacman -Qmq
And system info is not a bad idea.
inxi -Farz
New crash dumps look like this:
Lots of kApps, all crashing extremely similarly.
Maybe try with an empty session to begin with.
Another ‘test’ might be trying another fresh user. To see if it is isolated to yours.
Ah phew. Turns out I had both the kconfig problem and also a karchive problem, as both had been quietly turned into Aur packages.
For anyone following this, they were not the simplest things to remove either, given they wanted to take out all the things that depended on them (i.e KDE)
The secret is to reinstall kconfig / karchive, which should then prompt you that the aur version and non aur versions are in conflict, and ask if you want to remove the aur version.
EDIT: The solution part was running pacman -Qmq and looking very carefully at the section beginning with ‘k’
