It happens. No worries.
I can’t see anything, either. that’s why I’m consulting the experts.
The information is also poor. Since startx works, you could take a look at unlocking the debug information.
Wasn’t that possible with the GUI kdebugsettings ? Don’t know if that’s also possible with sddm.
So turn it on and send the journal again with debug information.
That was the output from the previous boot on my PC. (I only have the one, so that’s what there is.)
I got the output from a chroot environment, there’s (sadly) nothing else I know of.
Also, my day is ending, so I’ve got to be off.
I guess i catched the problem:
Jul 20 15:00:48 ksplashqml[731]: file:///home/mirdarthos/.local/share/plasma/look-and-feel/manjaro.circle/contents/splash/Splash.qml:71:17: Unable to assign [undefined] to double
Jul 20 15:00:49 ksplashqml[731]: file:///home/mirdarthos/.local/share/plasma/look-and-feel/manjaro.circle/contents/splash/Splash.qml:71:17: Unable to assign [undefined] to double
Probably this user modification. It starts normally, but right after that it shuts down.
Went back to re-read few things, and this doesn’t make any sense. Create a new user and login with it.
There’s also a bunch of sddm theme errors:
sddm-greeter[692]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
These themes definitely aren’t part of sddm package.
I might have missed it above, but this was in the Stable Update - 92023-07-10 Known Issue
Black screen after login with SDDM 0.20
Check ~/.profile for any commands that don’t execute properly (but return non-zero exit code instead). May include ~/.bash_profile and .zprofile too. Downgrading to SDDM 0.19 also restores desktop after login.
The issue has been reported 6 upstream.
It seems you definitely missed it:
No, haven’t come across it before. Maybe I’ll downgrade anyway. However, I don’t find any of the files mentioned locally: $ locate .zpro $ cat /home/mirdarthos/.profile cat: /home/mirdarthos/.profile: No such file or directory And I don’t have anything custom in ~/.bash_profile. (Or at least I don’t think so.) $ cat /home/mirdarthos/.bash_profile # # ~/.bash_profile # [[ -f ~/.bashrc ]] && . ~/.bashrc export HISTCONTROL=ignoreboth:erasedups So I continue to wait ready for action. Edit…
I renamed that directory, and tried login in again. Sure enough, the splash screen gets reset to the default one, but that’s all difference it makes.
Here is the updated boot log from that instance: https://0x0.st/Heqa.txt
And anyway, those messages looked like warnings only, not errors. And AFAIK warnings are not usually show-stoppers.
You are right. It didn’t make sense and no, I don’t know where my confusion happened. So I did it again, just now.
I also can’t log in with the new user, it returns to the login screen when I enter the correct password, and when I enter the wrong one, the expected behaviour, of a short timepoout, occurs.
To be fair, in the logs they appear as warnings, at least to me, being yellow and all that, not errors, which are red. And AFAIK warnings aren’t show-stoppers like errors.
kdebugsettings? Don’t know if that’s also possible with sddm.
Just installed it in the live environment, opened it, and was lost. I search for “sddm” and for “splash”, but nothing. So I don’t know further.
Since
startxworks
I doesn’t. See here:
I ran
startxand while it looked like it worked, the splash screen with the spinner appeared again, it did the same as previously…
FWIW, just tested with Wayland again, and it resets login. Here’s the log for that: https://0x0.st/HeqO.txt
This is the important part:
Jul 21 08:45:44 sddm-helper[724]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Jul 21 08:45:44 sddm[660]: Session started true
Jul 21 08:45:44 systemd[726]: Created slice User Core Session Slice.
Jul 21 08:45:44 systemd[726]: Starting D-Bus User Message Bus...
Jul 21 08:45:44 systemd[726]: Started D-Bus User Message Bus.
Jul 21 08:45:44 dbus-daemon[747]: [session uid=1000 pid=747] Successfully activated service 'org.freedesktop.systemd1'
Jul 21 08:45:44 dbus-daemon[747]: [session uid=1000 pid=747] Connection :1.2 (uid=1000 pid=752 comm="dbus-monitor --session type='signal',interface='or") became a monitor.
Jul 21 08:45:48 nmbd[719]: [2023/07/21 08:45:48.586964, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Jul 21 08:45:48 nmbd[719]: *****
Jul 21 08:45:48 nmbd[719]: Samba name server MIRDARTHOS-PC is now a local master browser for workgroup DISCWORLD on subnet 10.0.0.20
Jul 21 08:45:49 systemd-timesyncd[533]: Contacted time server 102.64.113.152:123 (2.manjaro.pool.ntp.org).
Jul 21 08:45:49 systemd-timesyncd[533]: Initial clock synchronization to Fri 2023-07-21 08:45:49.392376 SAST.
It actually starts the x11 session and then after 3 sec it shuts down…
SDDM is not the problem as I see, but plasma itself. So you would need to enable debug messages for plasma. I guess the “Core Libs” ? No idea. Really… I just use it in a VM and start it if some KDE Plasma Users have problems, other than that it is just “there” and is not used.
Wayland is not used here:
Jul 21 09:24:32 sddm-helper[733]: Starting X11 session: "" "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
OK, so I just rebooted and made absolutely,
sure that Wayland was selected for the session, tried to login, failed and was returned to the login screen. Rebooted into the Live environment, chrooted, and run it again.
Here’s the log from that: https://0x0.st/Heqh.txt
No idea. Really…
Well, my dear sir, if you don’t know, how the heck should I? And how do I use it on my real installation, not the live environment anyway.
Hmmm…wonder if there is a way to find out why it shuts down. Here’s a few logs for you:
/var/log/Xorg.1.log:$ cat /var/log/Xorg.1.log
[ 645.045]
X.Org X Server 1.21.1.8
[ 645.047] Current Operating System: Linux Mirdarthos-PC 6.1.38-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Jul 5 23:49:30 UTC 2023 x86_64
[ 645.047] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet udev.log_priority=3
[ 645.048]
[ 645.048] Current version of pixman: 0.42.2
[ 645.049] Before reporting problems, check http://wiki.x.org
[ 645.049] Markers: (--) probed, (**) from config file, (==) default setting,
[ 645.051] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Jul 20 12:40:06 2023
[ 645.051] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 645.052] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 645.052] (==) ServerLayout "layout"
[ 645.052] (**) |-->Screen "Screen0" (0)
[ 645.052] (**) | |-->Monitor "Monitor0"
[ 645.052] (**) | |-->Device "Device0"
[ 645.052] (==) Automatically adding devices
[ 645.052] (==) Automatically enabling devices
[ 645.052] (==) Automatically adding GPU devices
[ 645.052] (==) Automatically binding GPU devices
[ 645.052] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 645.052] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 645.052] Entry deleted from font path.
[ 645.052] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 645.052] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 645.052] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 645.052] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 645.052] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 645.052] (II) The server relies on udev to provide the list of input devices.
[ 645.052] (II) Module ABI versions:
[ 645.052] X.Org ANSI C Emulation: 0.4
[ 645.052] X.Org Video Driver: 25.2
[ 645.052] X.Org XInput driver : 24.4
[ 645.052] X.Org Server Extension : 10.0
[ 645.053] (++) using VT number 6
[ 645.054] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[ 645.054] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 645.054] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 645.055] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 645.056] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 645.056] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 645.056] (--) PCI:*(1@0:0:0) 10de:1401:1458:36bd rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 645.056] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 645.056] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 645.056] (II) LoadModule: "dbe"
[ 645.057] (II) Module "dbe" already built-in
[ 645.057] (II) LoadModule: "extmod"
[ 645.057] (II) Module "extmod" already built-in
[ 645.057] (II) LoadModule: "glx"
[ 645.057] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 645.057] (II) Module glx: vendor="X.Org Foundation"
[ 645.057] compiled for 1.21.1.8, module version = 1.0.0
[ 645.057] ABI class: X.Org Server Extension, version 10.0
[ 645.057] (II) LoadModule: "nvidia"
[ 645.058] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 645.058] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 645.058] compiled for 1.6.99.901, module version = 1.0.0
[ 645.058] Module class: X.Org Video Driver
[ 645.058] (II) NVIDIA dlloader X Driver 535.54.03 Tue Jun 6 22:23:02 UTC 2023
[ 645.058] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 645.058] (II) systemd-logind: releasing fd for 226:0
[ 645.058] (II) Loading sub module "fb"
[ 645.058] (II) LoadModule: "fb"
[ 645.058] (II) Module "fb" already built-in
[ 645.058] (II) Loading sub module "wfb"
[ 645.058] (II) LoadModule: "wfb"
[ 645.058] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 645.059] (II) Module wfb: vendor="X.Org Foundation"
[ 645.059] compiled for 1.21.1.8, module version = 1.0.0
[ 645.059] ABI class: X.Org ANSI C Emulation, version 0.4
[ 645.059] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 645.059] (==) NVIDIA(0): RGB weight 888
[ 645.059] (==) NVIDIA(0): Default visual is TrueColor
[ 645.059] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 645.059] (**) Option "AllowNVIDIAGpuScreens"
[ 645.059] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 645.059] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 645.059] (**) NVIDIA(0): Enabling 2D acceleration
[ 645.059] (II) Loading sub module "glxserver_nvidia"
[ 645.059] (II) LoadModule: "glxserver_nvidia"
[ 645.059] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 645.064] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 645.064] compiled for 1.6.99.901, module version = 1.0.0
[ 645.064] Module class: X.Org Server Extension
[ 645.064] (II) NVIDIA GLX Module 535.54.03 Tue Jun 6 22:23:41 UTC 2023
[ 645.065] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 645.065] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 645.065] (--) NVIDIA(0): CRT-0
[ 645.065] (--) NVIDIA(0): DFP-0
[ 645.065] (--) NVIDIA(0): DFP-1 (boot)
[ 645.065] (--) NVIDIA(0): DFP-2
[ 645.065] (--) NVIDIA(0): DFP-3
[ 645.065] (--) NVIDIA(0): DFP-4
[ 645.066] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 960 (GM206-A) at PCI:1:0:0
[ 645.066] (II) NVIDIA(0): (GPU-0)
[ 645.066] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 645.066] (--) NVIDIA(0): VideoBIOS: 84.06.14.40.22
[ 645.066] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 645.295] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 645.295] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 645.637] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[ 645.637] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
[ 645.637] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
[ 645.736] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): connected
[ 645.736] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): Internal TMDS
[ 645.736] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): 600.0 MHz maximum pixel clock
[ 645.736] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 645.736] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 645.736] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 645.736] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 645.736] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 645.736] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 645.736] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 645.736] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 645.736] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 645.742] (==) NVIDIA(0):
[ 645.742] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 645.742] (==) NVIDIA(0): will be used as the requested mode.
[ 645.742] (II) NVIDIA(0): Validated MetaModes:
[ 645.742] (II) NVIDIA(0): "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 645.742] (II) NVIDIA(0): Virtual screen size determined to be 5120 x 1080
[ 645.746] (--) NVIDIA(0): DPI set to (97, 97); computed from "UseEdidDpi" X config
[ 645.746] (--) NVIDIA(0): option
[ 645.746] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 645.746] (II) NVIDIA: access.
[ 645.748] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 645.748] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 645.748] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 645.748] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 645.748] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 645.748] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 645.748] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 645.748] (II) NVIDIA(0): Config Options in the README.
[ 645.764] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 645.899] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 645.899] (==) NVIDIA(0): Backing store enabled
[ 645.899] (==) NVIDIA(0): Silken mouse enabled
[ 645.899] (**) NVIDIA(0): DPMS enabled
[ 645.899] (II) Loading sub module "dri2"
[ 645.899] (II) LoadModule: "dri2"
[ 645.899] (II) Module "dri2" already built-in
[ 645.899] (II) NVIDIA(0): [DRI2] Setup complete
[ 645.899] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 645.900] (II) Initializing extension Generic Event Extension
[ 645.900] (II) Initializing extension SHAPE
[ 645.900] (II) Initializing extension MIT-SHM
[ 645.900] (II) Initializing extension XInputExtension
[ 645.900] (II) Initializing extension XTEST
[ 645.900] (II) Initializing extension BIG-REQUESTS
[ 645.900] (II) Initializing extension SYNC
[ 645.900] (II) Initializing extension XKEYBOARD
[ 645.900] (II) Initializing extension XC-MISC
[ 645.900] (II) Initializing extension SECURITY
[ 645.900] (II) Initializing extension XFIXES
[ 645.900] (II) Initializing extension RENDER
[ 645.900] (II) Initializing extension RANDR
[ 645.900] (II) Initializing extension COMPOSITE
[ 645.900] (II) Initializing extension DAMAGE
[ 645.900] (II) Initializing extension MIT-SCREEN-SAVER
[ 645.901] (II) Initializing extension DOUBLE-BUFFER
[ 645.901] (II) Initializing extension RECORD
[ 645.901] (II) Initializing extension DPMS
[ 645.901] (II) Initializing extension Present
[ 645.901] (II) Initializing extension DRI3
[ 645.901] (II) Initializing extension X-Resource
[ 645.901] (II) Initializing extension XVideo
[ 645.901] (II) Initializing extension XVideo-MotionCompensation
[ 645.901] (II) Initializing extension GLX
[ 645.901] (II) Indirect GLX disabled.
[ 645.901] (II) GLX: Another vendor is already registered for screen 0
[ 645.901] (II) Initializing extension XFree86-VidModeExtension
[ 645.901] (II) Initializing extension XFree86-DGA
[ 645.901] (II) Initializing extension XFree86-DRI
[ 645.901] (II) Initializing extension DRI2
[ 645.901] (II) Initializing extension NV-GLX
[ 645.901] (II) Initializing extension NV-CONTROL
[ 645.901] (II) Initializing extension XINERAMA
[ 645.939] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 645.939] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 645.939] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 645.939] (**) Power Button: Applying InputClass "system-keyboard"
[ 645.939] (II) LoadModule: "libinput"
[ 645.939] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 645.940] (II) Module libinput: vendor="X.Org Foundation"
[ 645.940] compiled for 1.21.1.8, module version = 1.3.0
[ 645.940] Module class: X.Org XInput Driver
[ 645.940] ABI class: X.Org XInput driver, version 24.4
[ 645.940] (II) Using input driver 'libinput' for 'Power Button'
[ 645.940] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 41 paused 0
[ 645.940] (**) Power Button: always reports core events
[ 645.940] (**) Option "Device" "/dev/input/event2"
[ 645.942] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 645.942] (II) event2 - Power Button: device is a keyboard
[ 645.942] (II) event2 - Power Button: device removed
[ 645.942] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 645.942] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 645.942] (**) Option "xkb_model" "pc105"
[ 645.942] (**) Option "xkb_layout" "za"
[ 645.951] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 645.951] (II) event2 - Power Button: device is a keyboard
[ 645.951] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 645.951] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 645.951] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 645.951] (**) Power Button: Applying InputClass "system-keyboard"
[ 645.951] (II) Using input driver 'libinput' for 'Power Button'
[ 645.952] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 44 paused 0
[ 645.952] (**) Power Button: always reports core events
[ 645.952] (**) Option "Device" "/dev/input/event1"
[ 645.953] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 645.953] (II) event1 - Power Button: device is a keyboard
[ 645.953] (II) event1 - Power Button: device removed
[ 645.953] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 645.953] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 645.953] (**) Option "xkb_model" "pc105"
[ 645.953] (**) Option "xkb_layout" "za"
[ 645.954] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 645.954] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 645.954] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 645.954] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 645.954] (II) Using input driver 'libinput' for 'Sleep Button'
[ 645.954] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[ 645.954] (**) Sleep Button: always reports core events
[ 645.954] (**) Option "Device" "/dev/input/event0"
[ 645.955] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 645.955] (II) event0 - Sleep Button: device is a keyboard
[ 645.955] (II) event0 - Sleep Button: device removed
[ 645.955] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 645.955] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 645.955] (**) Option "xkb_model" "pc105"
[ 645.955] (**) Option "xkb_layout" "za"
[ 645.956] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 645.956] (II) event0 - Sleep Button: device is a keyboard
[ 645.956] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 645.956] (II) No input driver specified, ignoring this device.
[ 645.956] (II) This device may have been added with another device file.
[ 645.957] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 645.957] (II) No input driver specified, ignoring this device.
[ 645.957] (II) This device may have been added with another device file.
[ 645.957] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 645.957] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 645.958] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/event4)
[ 645.958] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "evdev pointer catchall"
[ 645.958] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "libinput pointer catchall"
[ 645.958] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Mouse'
[ 645.958] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[ 645.958] (**) ROCCAT ROCCAT Kone EMP Mouse: always reports core events
[ 645.958] (**) Option "Device" "/dev/input/event4"
[ 645.959] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 645.959] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 645.959] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 645.959] (II) libinput: ROCCAT ROCCAT Kone EMP Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 645.959] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input4/event4"
[ 645.959] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Mouse" (type: MOUSE, id 9)
[ 645.959] (**) Option "AccelerationScheme" "none"
[ 645.959] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) selected scheme none/0
[ 645.959] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration factor: 2.000
[ 645.959] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration threshold: 4
[ 645.960] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 645.960] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 645.961] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/mouse0)
[ 645.961] (II) No input driver specified, ignoring this device.
[ 645.961] (II) This device may have been added with another device file.
[ 645.961] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Consumer Control (/dev/input/event5)
[ 645.961] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 645.961] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 645.961] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 645.961] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 645.962] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 47 paused 0
[ 645.962] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 645.962] (**) Option "Device" "/dev/input/event5"
[ 645.963] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 645.963] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 645.963] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 645.963] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: needs a virtual subdevice
[ 645.963] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 645.963] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: MOUSE, id 10)
[ 645.963] (**) Option "AccelerationScheme" "none"
[ 645.963] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) selected scheme none/0
[ 645.963] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration factor: 2.000
[ 645.963] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration threshold: 4
[ 645.964] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 645.964] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 645.965] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP System Control (/dev/input/event6)
[ 645.965] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "evdev keyboard catchall"
[ 645.965] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "libinput keyboard catchall"
[ 645.965] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "system-keyboard"
[ 645.965] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP System Control'
[ 645.965] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 48 paused 0
[ 645.965] (**) ROCCAT ROCCAT Kone EMP System Control: always reports core events
[ 645.965] (**) Option "Device" "/dev/input/event6"
[ 645.967] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 645.967] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 645.967] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 645.967] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input6/event6"
[ 645.967] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP System Control" (type: KEYBOARD, id 11)
[ 645.967] (**) Option "xkb_model" "pc105"
[ 645.967] (**) Option "xkb_layout" "za"
[ 645.968] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 645.968] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 645.969] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event7)
[ 645.969] (II) No input driver specified, ignoring this device.
[ 645.969] (II) This device may have been added with another device file.
[ 645.969] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event8)
[ 645.969] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "evdev keyboard catchall"
[ 645.969] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "libinput keyboard catchall"
[ 645.969] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "system-keyboard"
[ 645.969] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP'
[ 645.970] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 49 paused 0
[ 645.970] (**) ROCCAT ROCCAT Kone EMP: always reports core events
[ 645.970] (**) Option "Device" "/dev/input/event8"
[ 645.971] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 645.971] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 645.971] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 645.971] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:1E7D:2E24.0002/input/input8/event8"
[ 645.971] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP" (type: KEYBOARD, id 12)
[ 645.971] (**) Option "xkb_model" "pc105"
[ 645.971] (**) Option "xkb_layout" "za"
[ 645.972] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 645.972] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 645.973] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event17)
[ 645.973] (II) No input driver specified, ignoring this device.
[ 645.973] (II) This device may have been added with another device file.
[ 645.973] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event18)
[ 645.973] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event19)
[ 645.973] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event20)
[ 645.974] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event21)
[ 645.974] (II) No input driver specified, ignoring this device.
[ 645.974] (II) This device may have been added with another device file.
[ 645.974] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event22)
[ 645.974] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event23)
[ 645.974] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event24)
[ 645.975] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 645.975] (II) No input driver specified, ignoring this device.
[ 645.975] (II) This device may have been added with another device file.
[ 645.976] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB (/dev/input/event9)
[ 645.976] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[ 645.976] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[ 645.976] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[ 645.976] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB'
[ 645.977] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 50 paused 0
[ 645.977] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: always reports core events
[ 645.977] (**) Option "Device" "/dev/input/event9"
[ 645.977] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 645.978] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 645.978] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 645.978] (**) Option "config_info" "udev:/sys/devices/virtual/input/input25/event9"
[ 645.978] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 13)
[ 645.978] (**) Option "xkb_model" "pc105"
[ 645.978] (**) Option "xkb_layout" "za"
[ 645.978] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 645.979] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/event10)
[ 645.979] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[ 645.979] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[ 645.979] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM'
[ 645.979] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 51 paused 0
[ 645.979] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: always reports core events
[ 645.979] (**) Option "Device" "/dev/input/event10"
[ 645.980] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 645.980] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 645.980] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 645.980] (II) libinput: ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 645.980] (**) Option "config_info" "udev:/sys/devices/virtual/input/input26/event10"
[ 645.980] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM" (type: MOUSE, id 14)
[ 645.980] (**) Option "AccelerationScheme" "none"
[ 645.980] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[ 645.980] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[ 645.980] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[ 645.981] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/mouse1)
[ 645.981] (II) No input driver specified, ignoring this device.
[ 645.981] (II) This device may have been added with another device file.
[ 645.984] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 645.984] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 645.984] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 645.984] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 645.984] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[ 645.984] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 645.984] (**) Option "Device" "/dev/input/event5"
[ 645.984] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: is a virtual subdevice
[ 645.984] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 645.984] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: KEYBOARD, id 15)
[ 645.984] (**) Option "xkb_model" "pc105"
[ 645.984] (**) Option "xkb_layout" "za"
[ 668.547] (**) Option "fd" "41"
[ 668.547] (II) event2 - Power Button: device removed
[ 668.547] (**) Option "fd" "44"
[ 668.547] (II) event1 - Power Button: device removed
[ 668.547] (**) Option "fd" "45"
[ 668.547] (II) event0 - Sleep Button: device removed
[ 668.547] (**) Option "fd" "46"
[ 668.547] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 668.547] (**) Option "fd" "47"
[ 668.547] (**) Option "fd" "48"
[ 668.547] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 668.547] (**) Option "fd" "49"
[ 668.547] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 668.547] (**) Option "fd" "50"
[ 668.547] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 668.547] (**) Option "fd" "51"
[ 668.547] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 668.547] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 669.005] (II) systemd-logind: got pause for 13:69
[ 669.005] (II) systemd-logind: got pause for 13:66
[ 669.005] (II) systemd-logind: got pause for 13:70
[ 669.005] (II) systemd-logind: got pause for 13:73
[ 669.005] (II) systemd-logind: got pause for 13:68
[ 669.005] (II) systemd-logind: got pause for 13:65
[ 669.005] (II) systemd-logind: got pause for 13:64
[ 669.005] (II) systemd-logind: got pause for 13:72
[ 669.005] (II) systemd-logind: got pause for 13:74
[ 673.426] (II) systemd-logind: got resume for 13:69
[ 673.633] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 673.633] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 673.926] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[ 673.926] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
[ 673.926] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
[ 673.974] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): connected
[ 673.974] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): Internal TMDS
[ 673.974] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): 600.0 MHz maximum pixel clock
[ 673.974] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 673.974] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 673.974] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 673.974] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 673.974] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 673.974] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 673.975] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 673.975] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 673.975] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 673.992] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 674.137] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 674.137] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 674.137] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 674.137] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 674.137] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 674.137] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 674.137] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 674.137] (II) NVIDIA(0): Config Options in the README.
[ 674.206] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 674.206] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 674.237] (II) systemd-logind: got resume for 13:66
[ 674.237] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 674.238] (II) event2 - Power Button: device is a keyboard
[ 674.238] (II) systemd-logind: got resume for 13:70
[ 674.238] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 674.239] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 674.239] (II) systemd-logind: got resume for 13:73
[ 674.239] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 674.239] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 674.239] (II) systemd-logind: got resume for 13:68
[ 674.240] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 674.240] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 674.240] (II) systemd-logind: got resume for 13:65
[ 674.241] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 674.241] (II) event1 - Power Button: device is a keyboard
[ 674.241] (II) systemd-logind: got resume for 13:64
[ 674.242] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 674.242] (II) event0 - Sleep Button: device is a keyboard
[ 674.242] (II) systemd-logind: got resume for 13:72
[ 674.243] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 674.243] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 674.243] (II) systemd-logind: got resume for 13:74
[ 674.243] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 674.243] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 680.030] (**) Option "fd" "53"
[ 680.030] (II) event2 - Power Button: device removed
[ 680.030] (**) Option "fd" "47"
[ 680.030] (II) event1 - Power Button: device removed
[ 680.030] (**) Option "fd" "48"
[ 680.030] (II) event0 - Sleep Button: device removed
[ 680.030] (**) Option "fd" "46"
[ 680.030] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 680.030] (**) Option "fd" "28"
[ 680.030] (**) Option "fd" "27"
[ 680.030] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 680.030] (**) Option "fd" "49"
[ 680.030] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 680.030] (**) Option "fd" "45"
[ 680.030] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 680.030] (**) Option "fd" "50"
[ 680.030] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 680.030] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 680.471] (II) systemd-logind: got pause for 13:69
[ 680.471] (II) systemd-logind: got pause for 13:66
[ 680.471] (II) systemd-logind: got pause for 13:70
[ 680.471] (II) systemd-logind: got pause for 13:73
[ 680.471] (II) systemd-logind: got pause for 13:68
[ 680.471] (II) systemd-logind: got pause for 13:65
[ 680.471] (II) systemd-logind: got pause for 13:64
[ 680.471] (II) systemd-logind: got pause for 13:72
[ 680.471] (II) systemd-logind: got pause for 13:74
[ 691.550] (II) systemd-logind: got resume for 13:69
[ 691.657] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 691.657] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 691.811] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[ 691.811] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
[ 691.811] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
[ 691.857] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): connected
[ 691.857] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): Internal TMDS
[ 691.857] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): 600.0 MHz maximum pixel clock
[ 691.857] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 691.857] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 691.857] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 691.857] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 691.857] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 691.857] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 691.857] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 691.857] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 691.857] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 691.868] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 692.004] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 692.004] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 692.004] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 692.004] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 692.004] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 692.004] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 692.004] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 692.004] (II) NVIDIA(0): Config Options in the README.
[ 692.072] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 692.072] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 692.072] (II) systemd-logind: got resume for 13:66
[ 692.072] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 692.072] (II) event2 - Power Button: device is a keyboard
[ 692.073] (II) systemd-logind: got resume for 13:70
[ 692.073] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 692.073] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 692.074] (II) systemd-logind: got resume for 13:73
[ 692.074] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 692.074] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 692.074] (II) systemd-logind: got resume for 13:68
[ 692.075] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 692.075] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 692.075] (II) systemd-logind: got resume for 13:65
[ 692.076] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 692.076] (II) event1 - Power Button: device is a keyboard
[ 692.076] (II) systemd-logind: got resume for 13:64
[ 692.076] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 692.076] (II) event0 - Sleep Button: device is a keyboard
[ 692.077] (II) systemd-logind: got resume for 13:72
[ 692.077] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 692.077] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 692.078] (II) systemd-logind: got resume for 13:74
[ 692.078] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 692.078] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 699.790] (**) Option "fd" "52"
[ 699.790] (II) event2 - Power Button: device removed
[ 699.790] (**) Option "fd" "47"
[ 699.790] (II) event1 - Power Button: device removed
[ 699.790] (**) Option "fd" "48"
[ 699.790] (II) event0 - Sleep Button: device removed
[ 699.790] (**) Option "fd" "46"
[ 699.790] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 699.790] (**) Option "fd" "28"
[ 699.790] (**) Option "fd" "27"
[ 699.790] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 699.790] (**) Option "fd" "49"
[ 699.790] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 699.790] (**) Option "fd" "45"
[ 699.790] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 699.790] (**) Option "fd" "50"
[ 699.790] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 699.790] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 700.239] (II) systemd-logind: got pause for 13:69
[ 700.239] (II) systemd-logind: got pause for 13:66
[ 700.239] (II) systemd-logind: got pause for 13:70
[ 700.239] (II) systemd-logind: got pause for 13:73
[ 700.239] (II) systemd-logind: got pause for 13:68
[ 700.239] (II) systemd-logind: got pause for 13:65
[ 700.239] (II) systemd-logind: got pause for 13:64
[ 700.239] (II) systemd-logind: got pause for 13:72
[ 700.239] (II) systemd-logind: got pause for 13:74
[ 723.467] (II) UnloadModule: "libinput"
[ 723.467] (II) systemd-logind: not releasing fd for 13:69, still in use
[ 723.467] (II) systemd-logind: releasing fd for 13:74
[ 724.320] (EE) systemd-logind: failed to release device: Device not taken
[ 724.320] (II) UnloadModule: "libinput"
[ 724.320] (II) systemd-logind: releasing fd for 13:73
[ 724.421] (EE) systemd-logind: failed to release device: Device not taken
[ 724.421] (II) UnloadModule: "libinput"
[ 724.421] (II) systemd-logind: releasing fd for 13:72
[ 724.466] (II) UnloadModule: "libinput"
[ 724.466] (II) systemd-logind: releasing fd for 13:70
[ 724.483] (II) UnloadModule: "libinput"
[ 724.483] (II) systemd-logind: releasing fd for 13:69
[ 724.500] (II) UnloadModule: "libinput"
[ 724.500] (II) systemd-logind: releasing fd for 13:68
[ 724.543] (II) UnloadModule: "libinput"
[ 724.543] (II) systemd-logind: releasing fd for 13:64
[ 724.563] (II) UnloadModule: "libinput"
[ 724.563] (II) systemd-logind: releasing fd for 13:65
[ 724.580] (II) UnloadModule: "libinput"
[ 724.580] (II) systemd-logind: releasing fd for 13:66
[ 724.854] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 724.854] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 724.854] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 724.854] (WW) xf86OpenConsole: VT_GETSTATE failed: Input/output error
[ 724.855] (II) Server terminated successfully (0). Closing log file.
cat /var/log/Xorg.0.log:$ cat /var/log/Xorg.0.log
[ 20.808] (--) Log file renamed from "/var/log/Xorg.pid-702.log" to "/var/log/Xorg.0.log"
[ 20.809]
[ 20.809] Current Operating System: Linux Mirdarthos-PC 6.1.38-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Jul 5 23:49:30 UTC 2023 x86_64
[ 20.809] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet udev.log_priority=3 nvidia_drm.modeset=1
[ 20.809]
[ 20.809] Current version of pixman: 0.42.2
[ 20.809] Before reporting problems, check http://wiki.x.org
[ 20.809] Markers: (--) probed, (**) from config file, (==) default setting,
[ 20.809] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 21 11:15:08 2023
[ 20.809] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 20.809] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 20.809] (==) No Layout section. Using the first Screen section.
[ 20.809] (==) No screen section available. Using defaults.
[ 20.809] (**) |-->Screen "Default Screen Section" (0)
[ 20.809] (**) | |-->Monitor "<default monitor>"
[ 20.809] (==) No monitor specified for screen "Default Screen Section".
[ 20.809] (==) Automatically adding devices
[ 20.809] (==) Automatically enabling devices
[ 20.809] (==) Automatically adding GPU devices
[ 20.809] (==) Automatically binding GPU devices
[ 20.809] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 20.809] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 20.809] Entry deleted from font path.
[ 20.809] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 20.809] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 20.809] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 20.809] (==) FontPath set to:
[ 20.809] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 20.809] (II) The server relies on udev to provide the list of input devices.
[ 20.809] (II) Module ABI versions:
[ 20.809] X.Org ANSI C Emulation: 0.4
[ 20.809] X.Org Video Driver: 25.2
[ 20.809] X.Org XInput driver : 24.4
[ 20.809] X.Org Server Extension : 10.0
[ 20.809] (++) using VT number 2
[ 20.809] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 20.810] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 20.810] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 20.812] (--) PCI:*(1@0:0:0) 10de:1401:1458:36bd rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 20.812] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 20.812] (II) LoadModule: "glx"
[ 20.812] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 20.813] (II) Module glx: vendor="X.Org Foundation"
[ 20.813] compiled for 1.21.1.8, module version = 1.0.0
[ 20.813] ABI class: X.Org Server Extension, version 10.0
[ 20.814] (==) Matched modesetting as autoconfigured driver 0
[ 20.814] (==) Matched fbdev as autoconfigured driver 1
[ 20.814] (==) Matched vesa as autoconfigured driver 2
[ 20.814] (==) Assigned the driver to the xf86ConfigLayout
[ 20.814] (II) LoadModule: "modesetting"
[ 20.814] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 20.814] (II) Module modesetting: vendor="X.Org Foundation"
[ 20.814] compiled for 1.21.1.8, module version = 1.21.1
[ 20.814] Module class: X.Org Video Driver
[ 20.814] ABI class: X.Org Video Driver, version 25.2
[ 20.814] (II) LoadModule: "fbdev"
[ 20.814] (WW) Warning, couldn't open module fbdev
[ 20.814] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 20.814] (II) LoadModule: "vesa"
[ 20.814] (WW) Warning, couldn't open module vesa
[ 20.814] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 20.814] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 20.815] (II) modeset(0): using drv /dev/dri/card0
[ 20.815] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 20.815] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 20.815] (==) modeset(0): RGB weight 888
[ 20.815] (==) modeset(0): Default visual is TrueColor
[ 20.815] (II) Loading sub module "glamoregl"
[ 20.815] (II) LoadModule: "glamoregl"
[ 20.815] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 20.817] (II) Module glamoregl: vendor="X.Org Foundation"
[ 20.817] compiled for 1.21.1.8, module version = 1.0.1
[ 20.817] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.838] (II) modeset(0): glamor X acceleration enabled on NV126
[ 20.838] (II) modeset(0): glamor initialized
[ 20.838] (==) modeset(0): VariableRefresh: disabled
[ 20.838] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 20.904] (II) modeset(0): Output DVI-I-1 has no monitor section
[ 20.956] (II) modeset(0): Output DP-1 has no monitor section
[ 21.022] (II) modeset(0): Output HDMI-1 has no monitor section
[ 21.023] (II) modeset(0): Output DVI-D-1 has no monitor section
[ 21.090] (II) modeset(0): EDID for output DVI-I-1
[ 21.090] (II) modeset(0): Manufacturer: GSM Model: 59f1 Serial#: 9951
[ 21.090] (II) modeset(0): Year: 2016 Week: 7
[ 21.090] (II) modeset(0): EDID Version: 1.3
[ 21.090] (II) modeset(0): Digital Display Input
[ 21.090] (II) modeset(0): Max Image Size [cm]: horiz.: 67 vert.: 28
[ 21.090] (II) modeset(0): Gamma: 2.20
[ 21.090] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 21.090] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 21.090] (II) modeset(0): First detailed timing is preferred mode
[ 21.090] (II) modeset(0): redX: 0.651 redY: 0.332 greenX: 0.307 greenY: 0.631
[ 21.090] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 21.090] (II) modeset(0): Supported established timings:
[ 21.090] (II) modeset(0): 720x400@70Hz
[ 21.090] (II) modeset(0): 640x480@60Hz
[ 21.090] (II) modeset(0): 640x480@75Hz
[ 21.090] (II) modeset(0): 800x600@60Hz
[ 21.090] (II) modeset(0): 800x600@75Hz
[ 21.090] (II) modeset(0): 1024x768@60Hz
[ 21.090] (II) modeset(0): 1024x768@75Hz
[ 21.090] (II) modeset(0): 1280x1024@75Hz
[ 21.090] (II) modeset(0): 1152x864@75Hz
[ 21.090] (II) modeset(0): Manufacturer's mask: 0
[ 21.090] (II) modeset(0): Supported standard timings:
[ 21.090] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 21.090] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 21.090] (II) modeset(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 21.090] (II) modeset(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 21.090] (II) modeset(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 21.090] (II) modeset(0): Supported detailed timing:
[ 21.090] (II) modeset(0): clock: 185.6 MHz Image Size: 673 x 284 mm
[ 21.090] (II) modeset(0): h_active: 2560 h_sync: 2624 h_sync_end 2688 h_blank_end 2784 h_border: 0
[ 21.090] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1111 v_border: 0
[ 21.090] (II) modeset(0): clock: 148.5 MHz Image Size: 673 x 284 mm
[ 21.090] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 21.090] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 21.090] (II) modeset(0): Monitor name: LG ULTRAWIDE
[ 21.090] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 90 kHz, PixClock max 245 MHz
[ 21.090] (II) modeset(0): clock: 148.5 MHz Image Size: 598 x 337 mm
[ 21.090] (II) modeset(0): clock: 74.2 MHz Image Size: 598 x 337 mm
[ 21.090] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 21.090] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 21.090] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 21.090] (II) modeset(0): clock: 27.0 MHz Image Size: 598 x 337 mm
[ 21.090] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 21.090] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 21.090] (II) modeset(0): Serial No: 607SANH09951
[ 21.090] (II) modeset(0): Number of EDID sections to follow: 1
[ 21.090] (II) modeset(0): EDID (in hex):
[ 21.090] (II) modeset(0): 00ffffffffffff001e6df159df260000
[ 21.090] (II) modeset(0): 071a010380431c78eaca95a6554ea126
[ 21.090] (II) modeset(0): 0f5054a54b80714f818081c0a9c0b300
[ 21.090] (II) modeset(0): 0101010101017e4800e0a0381f404040
[ 21.090] (II) modeset(0): 3a00a11c21000018023a801871382d40
[ 21.090] (II) modeset(0): 582c4500a11c2100001e000000fc004c
[ 21.090] (II) modeset(0): 4720554c545241574944450a000000fd
[ 21.090] (II) modeset(0): 00384b1e5a18000a202020202020018f
[ 21.090] (II) modeset(0): 02031df14a900403001412051f011323
[ 21.090] (II) modeset(0): 0907078301000065030c001000023a80
[ 21.090] (II) modeset(0): 1871382d40582c450056512100001e01
[ 21.090] (II) modeset(0): 1d8018711c1620582c25005651210000
[ 21.090] (II) modeset(0): 9e011d007251d01e206e285500565121
[ 21.090] (II) modeset(0): 00001e8c0ad08a20e02d10103e960056
[ 21.090] (II) modeset(0): 5121000018000000ff0036303753414e
[ 21.090] (II) modeset(0): 4830393935310a0000000000000000c2
[ 21.090] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 21.090] (II) modeset(0): Printing probed modes for output DVI-I-1
[ 21.090] (II) modeset(0): Modeline "2560x1080"x60.0 185.58 2560 2624 2688 2784 1080 1083 1093 1111 -hsync -vsync (66.7 kHz eP)
[ 21.090] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 21.090] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 21.090] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 21.090] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 21.090] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 21.090] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 21.090] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 21.090] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 21.090] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 21.090] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 21.090] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 21.090] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 21.090] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 21.090] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21.090] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 21.090] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 21.090] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 21.090] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 21.090] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 21.090] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 21.090] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 21.090] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 21.090] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 21.090] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 21.090] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 21.143] (II) modeset(0): EDID for output DP-1
[ 21.209] (II) modeset(0): EDID for output HDMI-1
[ 21.209] (II) modeset(0): Manufacturer: GSM Model: 59f1 Serial#: 9973
[ 21.209] (II) modeset(0): Year: 2016 Week: 7
[ 21.209] (II) modeset(0): EDID Version: 1.3
[ 21.209] (II) modeset(0): Digital Display Input
[ 21.209] (II) modeset(0): Max Image Size [cm]: horiz.: 67 vert.: 28
[ 21.209] (II) modeset(0): Gamma: 2.20
[ 21.209] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 21.209] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 21.209] (II) modeset(0): First detailed timing is preferred mode
[ 21.209] (II) modeset(0): redX: 0.651 redY: 0.332 greenX: 0.307 greenY: 0.631
[ 21.209] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 21.209] (II) modeset(0): Supported established timings:
[ 21.209] (II) modeset(0): 720x400@70Hz
[ 21.209] (II) modeset(0): 640x480@60Hz
[ 21.209] (II) modeset(0): 640x480@75Hz
[ 21.209] (II) modeset(0): 800x600@60Hz
[ 21.209] (II) modeset(0): 800x600@75Hz
[ 21.209] (II) modeset(0): 1024x768@60Hz
[ 21.209] (II) modeset(0): 1024x768@75Hz
[ 21.209] (II) modeset(0): 1280x1024@75Hz
[ 21.209] (II) modeset(0): 1152x864@75Hz
[ 21.209] (II) modeset(0): Manufacturer's mask: 0
[ 21.209] (II) modeset(0): Supported standard timings:
[ 21.209] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 21.209] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 21.209] (II) modeset(0): #2: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 21.209] (II) modeset(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 21.209] (II) modeset(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 21.209] (II) modeset(0): Supported detailed timing:
[ 21.209] (II) modeset(0): clock: 185.6 MHz Image Size: 673 x 284 mm
[ 21.209] (II) modeset(0): h_active: 2560 h_sync: 2624 h_sync_end 2688 h_blank_end 2784 h_border: 0
[ 21.209] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1093 v_blanking: 1111 v_border: 0
[ 21.209] (II) modeset(0): clock: 148.5 MHz Image Size: 673 x 284 mm
[ 21.209] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 21.209] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 21.209] (II) modeset(0): Monitor name: LG ULTRAWIDE
[ 21.209] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 90 kHz, PixClock max 245 MHz
[ 21.209] (II) modeset(0): clock: 148.5 MHz Image Size: 598 x 337 mm
[ 21.209] (II) modeset(0): clock: 74.2 MHz Image Size: 598 x 337 mm
[ 21.209] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 21.209] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 21.209] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 21.209] (II) modeset(0): clock: 27.0 MHz Image Size: 598 x 337 mm
[ 21.209] (II) modeset(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 21.209] (II) modeset(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 21.209] (II) modeset(0): Unknown vendor-specific block 0
[ 21.209] (II) modeset(0): Number of EDID sections to follow: 1
[ 21.209] (II) modeset(0): EDID (in hex):
[ 21.209] (II) modeset(0): 00ffffffffffff001e6df159f5260000
[ 21.209] (II) modeset(0): 071a010380431c78eaca95a6554ea126
[ 21.209] (II) modeset(0): 0f5054a54b80714f818081c0a9c0b300
[ 21.210] (II) modeset(0): 0101010101017e4800e0a0381f404040
[ 21.210] (II) modeset(0): 3a00a11c21000018023a801871382d40
[ 21.210] (II) modeset(0): 582c4500a11c2100001e000000fc004c
[ 21.210] (II) modeset(0): 4720554c545241574944450a000000fd
[ 21.210] (II) modeset(0): 00384b1e5a18000a2020202020200179
[ 21.210] (II) modeset(0): 02031cf1499004031412051f01132309
[ 21.210] (II) modeset(0): 07078301000065030c002000023a8018
[ 21.210] (II) modeset(0): 71382d40582c450056512100001e011d
[ 21.210] (II) modeset(0): 8018711c1620582c250056512100009e
[ 21.210] (II) modeset(0): 011d007251d01e206e28550056512100
[ 21.210] (II) modeset(0): 001e8c0ad08a20e02d10103e96005651
[ 21.210] (II) modeset(0): 2100001800000000ff0036303753414b
[ 21.210] (II) modeset(0): 4630393937330a0000000000000000b5
[ 21.210] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 21.210] (II) modeset(0): Printing probed modes for output HDMI-1
[ 21.210] (II) modeset(0): Modeline "2560x1080"x60.0 185.58 2560 2624 2688 2784 1080 1083 1093 1111 -hsync -vsync (66.7 kHz eP)
[ 21.210] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 21.210] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 21.210] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 21.210] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 21.210] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 21.210] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 21.210] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 21.210] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 21.210] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 21.210] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 21.210] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 21.210] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 21.210] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 21.210] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21.210] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 21.210] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 21.210] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 21.210] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 21.210] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 21.210] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 21.210] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 21.210] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 21.210] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 21.210] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 21.210] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 21.211] (II) modeset(0): EDID for output DVI-D-1
[ 21.211] (II) modeset(0): Output DVI-I-1 connected
[ 21.211] (II) modeset(0): Output DP-1 disconnected
[ 21.211] (II) modeset(0): Output HDMI-1 connected
[ 21.211] (II) modeset(0): Output DVI-D-1 disconnected
[ 21.211] (II) modeset(0): Using spanning desktop for initial modes
[ 21.211] (II) modeset(0): Output DVI-I-1 using initial mode 2560x1080 +0+0
[ 21.211] (II) modeset(0): Output HDMI-1 using initial mode 2560x1080 +2560+0
[ 21.211] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21.211] (==) modeset(0): DPI set to (96, 96)
[ 21.211] (II) Loading sub module "fb"
[ 21.211] (II) LoadModule: "fb"
[ 21.211] (II) Module "fb" already built-in
[ 21.217] (==) modeset(0): Backing store enabled
[ 21.217] (==) modeset(0): Silken mouse enabled
[ 21.249] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 21.249] (==) modeset(0): DPMS enabled
[ 21.249] (II) modeset(0): [DRI2] Setup complete
[ 21.249] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 21.249] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 21.249] (II) Initializing extension Generic Event Extension
[ 21.249] (II) Initializing extension SHAPE
[ 21.249] (II) Initializing extension MIT-SHM
[ 21.249] (II) Initializing extension XInputExtension
[ 21.249] (II) Initializing extension XTEST
[ 21.249] (II) Initializing extension BIG-REQUESTS
[ 21.250] (II) Initializing extension SYNC
[ 21.250] (II) Initializing extension XKEYBOARD
[ 21.250] (II) Initializing extension XC-MISC
[ 21.250] (II) Initializing extension SECURITY
[ 21.250] (II) Initializing extension XFIXES
[ 21.250] (II) Initializing extension RENDER
[ 21.250] (II) Initializing extension RANDR
[ 21.250] (II) Initializing extension COMPOSITE
[ 21.250] (II) Initializing extension DAMAGE
[ 21.250] (II) Initializing extension MIT-SCREEN-SAVER
[ 21.250] (II) Initializing extension DOUBLE-BUFFER
[ 21.250] (II) Initializing extension RECORD
[ 21.250] (II) Initializing extension DPMS
[ 21.250] (II) Initializing extension Present
[ 21.250] (II) Initializing extension DRI3
[ 21.250] (II) Initializing extension X-Resource
[ 21.251] (II) Initializing extension XVideo
[ 21.251] (II) Initializing extension XVideo-MotionCompensation
[ 21.251] (II) Initializing extension GLX
[ 21.253] (II) AIGLX: Loaded and initialized nouveau
[ 21.253] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 21.253] (II) Initializing extension XFree86-VidModeExtension
[ 21.253] (II) Initializing extension XFree86-DGA
[ 21.253] (II) Initializing extension XFree86-DRI
[ 21.253] (II) Initializing extension DRI2
[ 21.254] (II) modeset(0): Damage tracking initialized
[ 21.254] (II) modeset(0): Setting screen physical size to 1354 x 285
[ 21.288] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 21.288] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21.288] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 21.288] (**) Power Button: Applying InputClass "system-keyboard"
[ 21.288] (II) LoadModule: "libinput"
[ 21.288] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 21.289] (II) Module libinput: vendor="X.Org Foundation"
[ 21.289] compiled for 1.21.1.8, module version = 1.3.0
[ 21.289] Module class: X.Org XInput Driver
[ 21.289] ABI class: X.Org XInput driver, version 24.4
[ 21.289] (II) Using input driver 'libinput' for 'Power Button'
[ 21.289] (**) Power Button: always reports core events
[ 21.289] (**) Option "Device" "/dev/input/event2"
[ 21.291] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 21.291] (II) event2 - Power Button: device is a keyboard
[ 21.291] (II) event2 - Power Button: device removed
[ 21.306] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 21.306] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 21.306] (**) Option "xkb_model" "pc105"
[ 21.307] (**) Option "xkb_layout" "za"
[ 21.317] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 21.317] (II) event2 - Power Button: device is a keyboard
[ 21.318] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 21.318] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21.318] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 21.318] (**) Power Button: Applying InputClass "system-keyboard"
[ 21.318] (II) Using input driver 'libinput' for 'Power Button'
[ 21.318] (**) Power Button: always reports core events
[ 21.318] (**) Option "Device" "/dev/input/event1"
[ 21.318] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 21.318] (II) event1 - Power Button: device is a keyboard
[ 21.318] (II) event1 - Power Button: device removed
[ 21.336] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 21.336] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 21.336] (**) Option "xkb_model" "pc105"
[ 21.336] (**) Option "xkb_layout" "za"
[ 21.337] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 21.337] (II) event1 - Power Button: device is a keyboard
[ 21.337] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 21.337] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 21.337] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 21.337] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 21.337] (II) Using input driver 'libinput' for 'Sleep Button'
[ 21.337] (**) Sleep Button: always reports core events
[ 21.337] (**) Option "Device" "/dev/input/event0"
[ 21.338] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 21.338] (II) event0 - Sleep Button: device is a keyboard
[ 21.338] (II) event0 - Sleep Button: device removed
[ 21.356] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 21.356] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 21.356] (**) Option "xkb_model" "pc105"
[ 21.356] (**) Option "xkb_layout" "za"
[ 21.357] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 21.357] (II) event0 - Sleep Button: device is a keyboard
[ 21.358] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 21.358] (II) No input driver specified, ignoring this device.
[ 21.358] (II) This device may have been added with another device file.
[ 21.358] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[ 21.358] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[ 21.358] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[ 21.359] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/event4)
[ 21.359] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "evdev pointer catchall"
[ 21.359] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "libinput pointer catchall"
[ 21.359] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Mouse'
[ 21.359] (**) ROCCAT ROCCAT Kone EMP Mouse: always reports core events
[ 21.359] (**) Option "Device" "/dev/input/event4"
[ 21.360] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 21.360] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 21.360] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 21.393] (II) libinput: ROCCAT ROCCAT Kone EMP Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 21.393] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input4/event4"
[ 21.393] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Mouse" (type: MOUSE, id 9)
[ 21.393] (**) Option "AccelerationScheme" "none"
[ 21.393] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) selected scheme none/0
[ 21.393] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration factor: 2.000
[ 21.393] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration threshold: 4
[ 21.394] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 21.394] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 21.395] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/mouse0)
[ 21.395] (II) No input driver specified, ignoring this device.
[ 21.395] (II) This device may have been added with another device file.
[ 21.395] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Consumer Control (/dev/input/event5)
[ 21.395] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21.395] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21.395] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 21.395] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 21.395] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 21.395] (**) Option "Device" "/dev/input/event5"
[ 21.396] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 21.396] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 21.396] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 21.430] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: needs a virtual subdevice
[ 21.430] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 21.430] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: MOUSE, id 10)
[ 21.430] (**) Option "AccelerationScheme" "none"
[ 21.430] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) selected scheme none/0
[ 21.430] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration factor: 2.000
[ 21.430] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration threshold: 4
[ 21.431] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 21.431] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 21.431] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP System Control (/dev/input/event6)
[ 21.431] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "evdev keyboard catchall"
[ 21.431] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "libinput keyboard catchall"
[ 21.431] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "system-keyboard"
[ 21.431] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP System Control'
[ 21.431] (**) ROCCAT ROCCAT Kone EMP System Control: always reports core events
[ 21.431] (**) Option "Device" "/dev/input/event6"
[ 21.432] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 21.432] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 21.432] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 21.456] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input6/event6"
[ 21.456] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP System Control" (type: KEYBOARD, id 11)
[ 21.456] (**) Option "xkb_model" "pc105"
[ 21.456] (**) Option "xkb_layout" "za"
[ 21.457] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 21.457] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 21.458] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event7)
[ 21.458] (II) No input driver specified, ignoring this device.
[ 21.458] (II) This device may have been added with another device file.
[ 21.459] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event8)
[ 21.459] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "evdev keyboard catchall"
[ 21.459] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "libinput keyboard catchall"
[ 21.459] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "system-keyboard"
[ 21.459] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP'
[ 21.459] (**) ROCCAT ROCCAT Kone EMP: always reports core events
[ 21.459] (**) Option "Device" "/dev/input/event8"
[ 21.459] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 21.459] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 21.460] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 21.510] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:1E7D:2E24.0002/input/input8/event8"
[ 21.510] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP" (type: KEYBOARD, id 12)
[ 21.510] (**) Option "xkb_model" "pc105"
[ 21.510] (**) Option "xkb_layout" "za"
[ 21.511] (II) event8 - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 21.511] (II) event8 - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 21.511] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event17)
[ 21.511] (II) No input driver specified, ignoring this device.
[ 21.511] (II) This device may have been added with another device file.
[ 21.511] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event18)
[ 21.512] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event19)
[ 21.512] (II) No input driver specified, ignoring this device.
[ 21.512] (II) This device may have been added with another device file.
[ 21.512] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event20)
[ 21.512] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event21)
[ 21.512] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event22)
[ 21.513] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event23)
[ 21.513] (II) No input driver specified, ignoring this device.
[ 21.513] (II) This device may have been added with another device file.
[ 21.513] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event24)
[ 21.513] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 21.515] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB (/dev/input/event9)
[ 21.515] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[ 21.515] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[ 21.515] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[ 21.515] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB'
[ 21.515] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: always reports core events
[ 21.515] (**) Option "Device" "/dev/input/event9"
[ 21.515] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 21.515] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 21.515] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 21.536] (**) Option "config_info" "udev:/sys/devices/virtual/input/input25/event9"
[ 21.536] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 13)
[ 21.536] (**) Option "xkb_model" "pc105"
[ 21.536] (**) Option "xkb_layout" "za"
[ 21.537] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 21.537] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 21.537] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/event10)
[ 21.537] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[ 21.537] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[ 21.537] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM'
[ 21.537] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: always reports core events
[ 21.537] (**) Option "Device" "/dev/input/event10"
[ 21.538] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 21.538] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 21.538] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 21.570] (II) libinput: ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 21.570] (**) Option "config_info" "udev:/sys/devices/virtual/input/input26/event10"
[ 21.570] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM" (type: MOUSE, id 14)
[ 21.570] (**) Option "AccelerationScheme" "none"
[ 21.570] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[ 21.570] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[ 21.570] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[ 21.570] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 21.570] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 21.571] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/mouse1)
[ 21.571] (II) No input driver specified, ignoring this device.
[ 21.571] (II) This device may have been added with another device file.
[ 21.574] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21.574] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21.574] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 21.574] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 21.574] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 21.574] (**) Option "Device" "/dev/input/event5"
[ 21.574] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: is a virtual subdevice
[ 21.574] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 21.574] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: KEYBOARD, id 15)
[ 21.574] (**) Option "xkb_model" "pc105"
[ 21.574] (**) Option "xkb_layout" "za"
[ 21.932] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 28.341] (II) event2 - Power Button: device removed
[ 28.360] (II) event1 - Power Button: device removed
[ 28.396] (II) event0 - Sleep Button: device removed
[ 28.423] (II) event4 - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 28.483] (II) event6 - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 28.503] (II) event8 - ROCCAT ROCCAT Kone EMP: device removed
[ 28.576] (II) event9 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 28.596] (II) event10 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 28.666] (II) event5 - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 28.707] (II) UnloadModule: "libinput"
[ 28.735] (II) Server terminated successfully (0). Closing log file.
Any other logs I can give you/
Here’s the log from that: https://0x0.st/Heqh.txt
Sorry, I have no idea. I could believe that someone adds an autostart entry which contains systemctl poweroff
, but other than that, no idea. Are you the only one who uses that computer?
The Xorg logs show nothing unusual.
Yeah. It’s my baby that my wife doesn’t want to touch if there’s any way to avoid it.
systemctl poweroff
At this point, that wouldn’t even surprise me, except for the fact that the shutdowns are because of me pressing the power button, I think. It would have to be something like this, I’d imagine:
session=${loginctl session-status | head -n 1 | awk '{print $1}') && loginctl terminate-session $session
You made my day. Thanks. ![]()
hm the variable “session” starts with { and end with ). Do you think that works? ![]()
What happens if loginctl terminate-session has no ID?
Definitely not…rookie typo ![]()
What happens if
loginctl terminate-sessionhas no ID?
It moans…:
$ loginctl terminate-session
Too few arguments.
I also can’t log in with the new user, it returns to the login screen when I enter the correct password, and when I enter the wrong one, the expected behaviour, of a short timepoout, occurs.
Switch to tty5 and login with new user and run
systemctl --user start plasma-plasmashell.service
To be fair, in the logs they appear as warnings, at least to me, being yellow and all that, not errors, which are red. And AFAIK warnings aren’t show-stoppers like errors.
Sure, but I’m just pointing out all the differences from default setup - you have to start reverting things somewhere.
Can you also cat /etc/sddm.conf.d/* and /etc/sddm.conf if it exists.
Also, did you reinstall sudo, sddm, mkinitcpio, kernels? If not, please do and check for new .pacnew files just in case:
find /etc -name '*.pacnew' -o -name '*.pacsave'
EDIT:
To be honest, just reinstall anything plasma* too
pacman -Qsq plasma\* | sudo pacman -S -
EDIT2:
And show
pacman -Qm
I understand and I try. I really do. that’s why I went ahead and checked anyway.
I did. See:
Also did:
anon51566685:
Be sure you are updated and reinstall any affected package that comes to mind, eg.:
pacman -Syu sddm linuxXXX{-headers} sudo mkinitcpioNo difference…
Only my uninstalled kernels:
$ find /etc -name '*.pacnew' -o -name '*.pacsave'
/etc/mkinitcpio.d/linux60.preset.pacsave
/etc/mkinitcpio.d/linux54.preset.pacsave
/etc/mkinitcpio.d/linux517.preset.pacsave
/etc/mkinitcpio.d/linux58.preset.pacsave
/etc/mkinitcpio.d/linux519.preset.pacsave
/etc/mkinitcpio.d/linux516.preset.pacsave
/etc/mkinitcpio.d/linux518.preset.pacsave
/etc/mkinitcpio.d/linux510.preset.pacsave
/etc/mkinitcpio.d/linux419.preset.pacsave
Have actually been looking for this:
…or something like it, thanks!
And show
pacman -Qm
Huh…Seems I need to clean up a bit:
$ pacman -Qm
android-platform 34_r01-1
android-sdk 26.1.1-2
android-sdk-platform-tools 34.0.3-1
anydesk-bin 6.2.1-2
appimagetool-bin 13-0
brave-bin 1:1.52.130-1
chaotic-keyring 20210617-1
chaotic-mirrorlist 20210716-1
chkservice 0.3-3
ckb-next 0.6.0-1
code-marketplace 1.78.0-1
cow-translator-git r33.000173c-1
cpuid 20230505-1
crabfetch 0.1.0-1
cuda_memtest 1.2.3-3
debtap 3.5.1-1
dissenter-browser-bin 1.5.114-2
edid-decode r541.9ca8433-1
etcher-bin 1.18.4-1
extundelete 0.2.4-1
fast 0.0.4-1
find-the-command 2.0.1-1
firefox-h264ify 1.1.0-2
freetube-bin 0.18.0-1
fswatch 1.17.1-1
geekbench4 4.4.4-1
github-desktop-bin 3.2.5_linux1-1
gitklient 0.3-1
gittyup 1.3.0-1
gnome-icon-theme 3.12.0-7
gnome-icon-theme-symbolic 3.12.0-6
google-chrome 114.0.5735.198-1
hunspell-af 2020.02.14-1
hw-probe 1.6.5-1
icecat-bin 60.7.0-2
libgaminggear 0.15.1-8
librewolf-bin 115.0.1-1
lutris-battlenet-meta 1.1.0-2
lutris-wine-meta 2.1.0-5
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
manjaro-tools-iso 0.15.13-1
manjaro-tools-pkg 0.15.13-1
manly-git 0.4.0.r13.722cfe0-1
mcelog 191-1
mhwd-tui 0.4-1
mozilla-common 1.4-6
my-universal-manjaro-update-helper v2.0.RC12-1
ntfsprogs-ntfs3 2022.10.3-3
ocs-url 3.1.0-7
openprinting-ppds-pxlmono-samsung 20161207-1
pacgraph 20110629-7
paclast r5-2
pacman-backup-hook 1.0.1-2
php7 7.4.33-4
pineapple-pictures 0.7.1-1
pingu 0.0.5-1
plasma5-applets-eventcalendar 76-1
plasma5-applets-plasma-pstate 2.0.0-1
pqmusic 1.3.0-1
ps_mem 3.14-2
python-injector 0.20.1-2
python2 2.7.18-8
python2-setuptools 2:44.1.1-2
qt5-webkit 5.212.0alpha4-20
qview 5.0-1
raven-reader-bin 1.0.80-1
roccat-tools-common 5.9.0-2
roccat-tools-ryosmk 5.9.0-2
roccat-tools-ryosmkfx 5.9.0-2
rofmoji 0.2.2-1
rustdesk-bin 1.2.0-2
samsung-ssd-dc-toolkit 2.1-1
samsung-unified-driver 1.00.39-6
samsung-unified-driver-common 1.00.39-6
samsung-unified-driver-printer 1.00.39-6
samsung-unified-driver-scanner 1.00.39-6
sayonara-player 1.7.0_stable3-1
signal-desktop-beta-bin 6.26.0beta.1-1
skypeforlinux-stable-bin 8.99.0.403-1
smtube 21.10.0-4
soulanchor 1.08-1
sublime-text-4 4.4143-4
symlinks 1.4.3-3
systemd-fsck-silent 239-1
sysvbanner 1.0.15-3
teamviewer14 14.7.39531-1
tor-browser 12.5.1-1
trebleshot 0.1.0_alpha2-2
tremc 0.9.3-2
ttf-ms-fonts 2.0-12
unetbootin 702-1
unigine-valley 1.0-1
unrar-libre 0.0.1-1
wat-git r29.0861966-1
waterfox-g5-bin G5.0-0
woeusb-ng 0.2.12-3
wttr 1.55.r0.g36893b1-1
zenith-bin 0.14.0-1
Although, most of them were just for curiosity sake, I never use many of those.
I think I shall trey reinstalling the plasma packages next.
-> No AUR package found for chaotic-keyring
-> No AUR package found for chaotic-mirrorlist
-> No AUR package found for lutris-battlenet-meta
-> No AUR package found for manjaro-documentation-en
-> No AUR package found for manjaro-firmware
-> No AUR package found for manjaro-tools-iso
-> No AUR package found for manjaro-tools-pkg
-> No AUR package found for mhwd-tui
-> No AUR package found for my-universal-manjaro-update-helper
-> No AUR package found for openprinting-ppds-pxlmono-samsung
-> No AUR package found for php7
-> No AUR package found for systemd-fsck-silent
-> No AUR package found for waterfox-g5-bin
Can you also
cat/etc/sddm.conf.d/*and/etc/sddm.confif it exists.
$ cat /etc/sddm.conf
[General]
InputMethod=
[Theme]
DisableAvatarsThreshold=7
EnableAvatars=true
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
HideShells=
HideUsers=
RememberLastSession=true
RememberLastUser=true
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
DisplayCommand=/usr/share/sddm/scripts/Xsetup
DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
$ ls -l /etc/sddm.conf.d/
total 12
-rw-r--r-- 1 root root 23 May 29 19:34 00_manjaro_settings.conf
-rw-r--r-- 1 root root 282 Jul 16 08:50 kde_settings.conf
-rw-r--r-- 1 root root 31 May 29 19:34 virtualkeyboard.conf
$ cat /etc/sddm.conf.d/*
[Theme]
Current=breath
[Autologin]
Relogin=false
Session=
User=
[General]
HaltCommand=/usr/bin/systemctl poweroff
Numlock=on
RebootCommand=/usr/bin/systemctl reboot
[Theme]
Current=Sweet-Ambar-Blue
CursorTheme=Nordic-cursors
Font=Noto Sans,11,-1,5,50,0,0,0,0,0
[Users]
MaximumUid=60000
MinimumUid=1000
InputMethod=qtvirtualkeyboard
-> No AUR package found for chaotic-keyring -> No AUR package found for chaotic-mirrorlist -> No AUR package found for lutris-battlenet-meta -> No AUR package found for manjaro-documentation-en -> No AUR package found for manjaro-firmware -> No AUR package found for manjaro-tools-iso -> No AUR package found for manjaro-tools-pkg -> No AUR package found for mhwd-tui -> No AUR package found for my-universal-manjaro-update-helper -> No AUR package found for openprinting-ppds-pxlmono-samsung -> No AUR package found for php7 -> No AUR package found for systemd-fsck-silent -> No AUR package found for waterfox-g5-bin
O_o
$ pamac list --foreign
android-platform 34_r01-1 AUR 99.1 MB
android-sdk 26.1.1-2 AUR 175.4 MB
android-sdk-platform-tools 34.0.3-1 AUR 14.0 MB
anydesk-bin 6.2.1-2 AUR 16.3 MB
appimagetool-bin 13-0 AUR 733.7 kB
brave-bin 1:1.52.130-1 AUR 340.1 MB
chaotic-keyring 20210617-1 16.2 kB
chaotic-mirrorlist 20210716-1 1.4 kB
chkservice 0.3-3 AUR 73.9 kB
ckb-next 0.6.0-1 AUR 3.5 MB
code-marketplace 1.78.0-1 AUR 2.4 kB
cow-translator-git r33.000173c-1 AUR 3.5 MB
cpuid 20230505-1 AUR 459.1 kB
crabfetch 0.1.0-1 AUR 776.5 kB
cuda_memtest 1.2.3-3 AUR 76.6 kB
debtap 3.5.1-1 AUR 322.1 kB
dissenter-browser-bin 1.5.114-2 AUR 226.6 MB
edid-decode r541.9ca8433-1 315.2 kB
etcher-bin 1.18.4-1 AUR 240.3 MB
extundelete 0.2.4-1 AUR 1.6 MB
fast 0.0.4-1 AUR 4.5 MB
find-the-command 2.0.1-1 AUR 23.3 kB
firefox-h264ify 1.1.0-2 AUR 37.7 kB
freetube-bin 0.18.0-1 AUR 234.8 MB
fswatch 1.17.1-1 AUR 764.0 kB
geekbench4 4.4.4-1 AUR 77.6 MB
github-desktop-bin 3.2.5_linux1-1 AUR 304.7 MB
gitklient 0.3-1 AUR 1.4 MB
gittyup 1.3.0-1 AUR 23.1 MB
gnome-icon-theme 3.12.0-7 AUR 10.3 MB
gnome-icon-theme-symbolic 3.12.0-6 AUR 2.0 MB
google-chrome 114.0.5735.198-1 AUR 321.6 MB
hunspell-af 2020.02.14-1 AUR 1.3 MB
hw-probe 1.6.5-1 AUR 542.5 kB
icecat-bin 60.7.0-2 168.1 MB
libgaminggear 0.15.1-8 AUR 447.6 kB
librewolf-bin 115.0.1-1 AUR 326.1 MB
lutris-wine-meta 2.1.0-5 AUR
manjaro-documentation-en 20181009-1 10.0 MB
manjaro-firmware 20160419-1 2.6 MB
manjaro-tools-iso 0.15.13-1 101.2 kB
manjaro-tools-pkg 0.15.13-1 43.8 kB
manly-git 0.4.0.r13.722cfe0-1 AUR 6.9 kB
mcelog 191-1 AUR 449.3 kB
mhwd-tui 0.4-1 19.5 kB
mozilla-common 1.4-6 AUR 100 bytes
ntfsprogs-ntfs3 2022.10.3-3 AUR 1.7 MB
ocs-url 3.1.0-7 AUR 166.1 kB
openprinting-ppds-pxlmono-samsung 20161207-1 88.4 kB
pacgraph 20110629-7 AUR 47.1 kB
paclast r5-2 AUR 2.2 kB
pacman-backup-hook 1.0.1-2 AUR 1.4 kB
php7 7.4.33-4 24.2 MB
pineapple-pictures 0.7.1-1 AUR 638.5 kB
pingu 0.0.5-1 AUR 2.7 MB
plasma5-applets-eventcalendar 76-1 AUR 838.6 kB
plasma5-applets-plasma-pstate 2.0.0-1 AUR 213.1 kB
pqmusic 1.3.0-1 AUR 2.0 MB
ps_mem 3.14-2 AUR 25.8 kB
python-injector 0.20.1-2 AUR 212.8 kB
python2 2.7.18-8 AUR 80.5 MB
python2-setuptools 2:44.1.1-2 AUR 4.0 MB
qt5-webkit 5.212.0alpha4-20 AUR 49.6 MB
qview 5.0-1 AUR 1.2 MB
raven-reader-bin 1.0.80-1 AUR 221.6 MB
roccat-tools-common 5.9.0-2 AUR 3.7 MB
roccat-tools-ryosmk 5.9.0-2 AUR 876.4 kB
roccat-tools-ryosmkfx 5.9.0-2 AUR 283.4 kB
rofmoji 0.2.2-1 AUR 216.2 kB
rustdesk-bin 1.2.0-2 AUR 62.8 MB
samsung-ssd-dc-toolkit 2.1-1 AUR 7.4 MB
samsung-unified-driver 1.00.39-6 AUR
samsung-unified-driver-common 1.00.39-6 AUR 21.3 kB
samsung-unified-driver-printer 1.00.39-6 AUR 29.4 MB
samsung-unified-driver-scanner 1.00.39-6 AUR 2.3 MB
sayonara-player 1.7.0_stable3-1 AUR 8.8 MB
signal-desktop-beta-bin 6.26.0beta.1-1 AUR 428.5 MB
skypeforlinux-stable-bin 8.99.0.403-1 AUR 320.7 MB
smtube 21.10.0-4 AUR 797.7 kB
soulanchor 1.08-1 AUR 199.5 MB
sublime-text-4 4.4143-4 AUR 51.7 MB
symlinks 1.4.3-3 AUR 18.0 kB
systemd-fsck-silent 239-1 34.8 kB
sysvbanner 1.0.15-3 AUR 19.8 kB
teamviewer14 14.7.39531-1 AUR 69.0 MB
tor-browser 12.5.1-1 AUR 113.2 MB
trebleshot 0.1.0_alpha2-2 AUR 722.4 kB
tremc 0.9.3-2 AUR 237.1 kB
ttf-ms-fonts 2.0-12 AUR 5.7 MB
unetbootin 702-1 AUR 2.4 MB
unigine-valley 1.0-1 AUR 492.1 MB
unrar-libre 0.0.1-1 AUR 3.3 MB
wat-git r29.0861966-1 AUR 1.5 kB
waterfox-g5-bin G5.0-0 261.3 MB
woeusb-ng 0.2.12-3 AUR 647.6 kB
wttr 1.55.r0.g36893b1-1 AUR 9.0 kB
zenith-bin 0.14.0-1 AUR 2.3 MB
You sure your database/metadata/whateveryouwannacallit has been updated?
